V15
EC4BE SERIES
10 WATT 2:1 INPUT RANGE
DC-DC CONVERTERS
FEATURES
* 10W Isolated Output
* 2”x1” Six-Sided Shield Metal Case
* Efficiency to 82%
* 2:1 Input Range
* Pi Input Filter
* Continuous Short Circuit Protection
* Meets EN55032 Class A Conducted
* UL60950-1 Approval
* Safety Meets IEC/EN/UL 62368-1
MODEL
NUMBER
INPUT
VOLTAGE
EC4BE01
9-18 VDC
EC4BE02
OUTPUT
VOLTAGE
OUTPUT CURRENT
INPUT CURRENT
% EFF.
CAPACITOR
LOAD MAX.
MIN.
MAX.
NO LOAD
FULL LOAD
5 VDC
100 mA
2000 mA
30 mA
1100 mA
76
2000uF
9-18 VDC
12 VDC
45 mA
830 mA
30 mA
1065 mA
78
830uF
EC4BE03
9-18 VDC
15 VDC
35 mA
666 mA
30 mA
1065 mA
78
666uF
EC4BE04
9-18 VDC
±12 VDC
±25 mA
±415 mA
40 mA
1065 mA
78
415uF
EC4BE05
9-18 VDC
±15 VDC
±20 mA
±333 mA
40 mA
1065 mA
78
333uF
EC4BE06
9-18 VDC
±5 VDC
±50 mA
±1000 mA
40 mA
1065 mA
78
1000uF
EC4BE11
18-36 VDC
5 VDC
100 mA
2000 mA
20 mA
535 mA
78
2000uF
EC4BE12
18-36 VDC
12 VDC
45 mA
830 mA
20 mA
520 mA
80
830uF
EC4BE13
18-36 VDC
15 VDC
35 mA
666 mA
20 mA
520 mA
80
666uF
EC4BE14
18-36 VDC
±12 VDC
±25 mA
±415 mA
20 mA
520 mA
80
415uF
EC4BE15
18-36 VDC
±15 VDC
±20 mA
±333 mA
20 mA
520 mA
80
333uF
EC4BE16
18-36 VDC
±5 VDC
±50 mA
±1000 mA
20 mA
520 mA
80
1000uF
EC4BE21
36-72 VDC
5 VDC
100 mA
2000 mA
10 mA
260 mA
80
2000uF
EC4BE22
36-72 VDC
12 VDC
45 mA
830 mA
10 mA
254 mA
82
830uF
EC4BE23
36-72 VDC
15 VDC
35 mA
666 mA
10 mA
254 mA
82
666uF
EC4BE24
36-72 VDC
±12 VDC
±25 mA
±415 mA
10 mA
254 mA
82
415uF
EC4BE25
36-72 VDC
±15 VDC
±20 mA
±333 mA
10 mA
254 mA
82
333uF
EC4BE26
36-72 VDC
±5 VDC
±50 mA
±1000 mA
10 mA
254 mA
82
1000uF
NOTE: 1. Nominal Input Voltage 12, 24 or 48VDC
1
V15
SPECIFICATIONS
All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ....…………….... 12V ……………………….…..….. 9-18V
24V …………………………… 18-36V
48V …………………….…..…. 36-72V
Input Surge Voltage (100ms max.) ………….….… 12V …............. 25Vdc max.
24V ................ 50Vdc max.
48V .............. 100Vdc max.
Input Filter ………………..……………………………….……………..... Pi Type
Efficiency ................................................................................. See Table
Isolation Voltage ............................................................... 500 VDC min
Isolation Resistance .................................…….….......…… 109 Ohm min.
Isolation Capacitance ……………………………..…………. 2500pF typ.
Switching Frequency ........................................................... 200KHz min.
Operating Ambient Temperature Range …..................... –25℃ to +71℃
De-rating, Above 71℃ ………………… Linearly to Zero Power at 100℃
OUTPUT SPECIFICATIONS:
Case Temperature (note4) ……............................................ 100℃ max.
Voltage Accuracy ………………....…………….….......….………… ±1.0% max.
Voltage Balance (Dual) …………………………………..………… ±1.0% max.
Transient Response
Single 25% Step Load Change ………………….….……….……………
很抱歉,暂时无法提供与“EC4BE12”相匹配的价格&库存,您可以联系我们找货
