EC4BE21
EC4BE21
    CINCON
    DIP4 模块
    隔离模块 直流转换器 1 输出 5V 2A 36V - 72V 输入
EC4BE21 数据手册
V15 EC4BE SERIES ︳ 10 WATT 2:1 INPUT RANGE DC-DC CONVERTERS FEATURES * 10W Isolated Output * 2”x1” Six-Sided Shield Metal Case * Efficiency to 82% * 2:1 Input Range * Pi Input Filter * Continuous Short Circuit Protection * Meets EN55032 Class A Conducted * UL60950-1 Approval * Safety Meets IEC/EN/UL 62368-1 MODEL NUMBER INPUT VOLTAGE EC4BE01 9-18 VDC EC4BE02 OUTPUT VOLTAGE OUTPUT CURRENT INPUT CURRENT % EFF. CAPACITOR LOAD MAX. MIN. MAX. NO LOAD FULL LOAD 5 VDC 100 mA 2000 mA 30 mA 1100 mA 76 2000uF 9-18 VDC 12 VDC 45 mA 830 mA 30 mA 1065 mA 78 830uF EC4BE03 9-18 VDC 15 VDC 35 mA 666 mA 30 mA 1065 mA 78 666uF EC4BE04 9-18 VDC ±12 VDC ±25 mA ±415 mA 40 mA 1065 mA 78 415uF EC4BE05 9-18 VDC ±15 VDC ±20 mA ±333 mA 40 mA 1065 mA 78 333uF EC4BE06 9-18 VDC ±5 VDC ±50 mA ±1000 mA 40 mA 1065 mA 78 1000uF EC4BE11 18-36 VDC 5 VDC 100 mA 2000 mA 20 mA 535 mA 78 2000uF EC4BE12 18-36 VDC 12 VDC 45 mA 830 mA 20 mA 520 mA 80 830uF EC4BE13 18-36 VDC 15 VDC 35 mA 666 mA 20 mA 520 mA 80 666uF EC4BE14 18-36 VDC ±12 VDC ±25 mA ±415 mA 20 mA 520 mA 80 415uF EC4BE15 18-36 VDC ±15 VDC ±20 mA ±333 mA 20 mA 520 mA 80 333uF EC4BE16 18-36 VDC ±5 VDC ±50 mA ±1000 mA 20 mA 520 mA 80 1000uF EC4BE21 36-72 VDC 5 VDC 100 mA 2000 mA 10 mA 260 mA 80 2000uF EC4BE22 36-72 VDC 12 VDC 45 mA 830 mA 10 mA 254 mA 82 830uF EC4BE23 36-72 VDC 15 VDC 35 mA 666 mA 10 mA 254 mA 82 666uF EC4BE24 36-72 VDC ±12 VDC ±25 mA ±415 mA 10 mA 254 mA 82 415uF EC4BE25 36-72 VDC ±15 VDC ±20 mA ±333 mA 10 mA 254 mA 82 333uF EC4BE26 36-72 VDC ±5 VDC ±50 mA ±1000 mA 10 mA 254 mA 82 1000uF NOTE: 1. Nominal Input Voltage 12, 24 or 48VDC 1 V15 SPECIFICATIONS All Specifications Typical at Nominal Line, Full Load, and 25℃ Unless Otherwise Noted INPUT SPECIFICATIONS: GENERAL SPECIFICATIONS: Input Voltage Range ....…………….... 12V ……………………….…..….. 9-18V 24V …………………………… 18-36V 48V …………………….…..…. 36-72V Input Surge Voltage (100ms max.) ………….….… 12V …............. 25Vdc max. 24V ................ 50Vdc max. 48V .............. 100Vdc max. Input Filter ………………..……………………………….……………..... Pi Type Efficiency ................................................................................. See Table Isolation Voltage ............................................................... 500 VDC min Isolation Resistance .................................…….….......…… 109 Ohm min. Isolation Capacitance ……………………………..…………. 2500pF typ. Switching Frequency ........................................................... 200KHz min. Operating Ambient Temperature Range …..................... –25℃ to +71℃ De-rating, Above 71℃ ………………… Linearly to Zero Power at 100℃ OUTPUT SPECIFICATIONS: Case Temperature (note4) ……............................................ 100℃ max. Voltage Accuracy ………………....…………….….......….………… ±1.0% max. Voltage Balance (Dual) …………………………………..………… ±1.0% max. Transient Response Single 25% Step Load Change ………………….….……….……………
EC4BE21 价格&库存
很抱歉,暂时无法提供与“EC4BE21”相匹配的价格&库存,您可以联系我们找货
