Bellnix High Efficiency, Minimum Size, Non-Isolated Type POL DC-DC Converter
Minimum Size, High power 40W!
8A/12A BSI-POWER Series
RoHS
Compliance
Ultra High Efficiency (95%), Minimum Size Step-Down DC-DC Converter
Input: +5V, +12V
Input: +12V
Output: +3.3V (+1.0V to +3.3V)
Output: +5.0V (+5.0V to +6.0V)
5.08
5.08 7.62
12.7
7.62
%(typ.)
%(typ.) mVpp(typ.) %(typ.)
0.3
0.25
40
93
0.2
0.2
60
95
pin
1
2
3
4
5
6
7
8
9
10
11
12
25.9 max.
20.32
C/L
3.0
5.54
(Application note available)
- Operating Temp Range
-10°C to +70°C
(Temp Derating Required)
- RoHS Compliance
Line Reg Load Reg Ripple/Noise Efficiency
(Stand off )
0.8
3.3S12F
Lot.No.
- Efficiency 93%-95%
Models
Input V
Output V
Output I
- Input Voltage Range 4.5V-13.6V
BSI Series
Vdc
Vdc
A
- Output Voltage Range 1.0V-3.3V
3.3
4.5-13.6
0-12
BSI-3.3S12R0F
5V-6V
(1.0-3.3)
- Latest Technology, Synchronous
5.0
8-13.6
0-8
BSI-5.0S8R0F
Rectification Circuit
(5.0-6.0)
Note 1: The output voltage inside the ( ) indicates the adjustable range.
- Heat Sink Not Required
Note 2: External capacitors are required.
- Adjustable Output Voltage
Note 3:Airflow maybe required depending on the ambient temperature.
- Non-Isolated Type Converter
- Short Circuit, Over-Current
Protection
BSI-3.3S12R0F/ BSI-5.0S8R0F
10.7 max.
51.0 max.
- No Electrolytic Capacitor used
C/L
t1.0
3.0
No Tantalum Capacitor used
- Ultra Small Size
11 10 9
8
7
6
12
- Remote ON/OFF Control
- MTBF 900,000Hrs
5
2
3
4
1
- High Reliability, High Performance
- 40W+40W=80W
Parallel Operation Possible
2.0
Function
ON/OFF
S.GND
+Vin
-Vin
NC
-Vs
-Vout
+Vout
+Vs
NC
V.ADJ 1
V.ADJ 2
Units: mm
Φ 1.0
5.08
Weight: 13g typ.
Tolerances unless otherwise specified: ±0.5
1.27
Non-coated externally
+Vin
3
C1
+Vs
9
FET1
PWM.OCP.CONT
ON/OFF CONT
-Vin
8
+Vout
-Vout
7
FET2
C3
Load
C2
4
5.0S 3.3S
S.GND 2
V.ADJ2
ON/OFF 1
- External Capacitor
12
ON = Open
OFF= Short
(0 to 0.5V)
11
V.ADJ1
6
-Vs
V.ADJ
Open = +3.3V(BSI-3.3S12R0F)
Open = +5.0V(BSI-5.0S8R0F)
C1: 68µF(ESR=34mΩ or less)×2pcs or more *2 (Recommended: OS-CON)
*2 BSI-5.0S8R0F: 1pce or more
C2(Vout=3.3V): 220µF(ESR=28mΩ or less)×2pcs or more (Recommended: OS-CON)
C2(Vout=5.0V): 150µF(ESR=30mΩ or less)×1pcs or more (Recommended: OS-CON)
C2(Vout
很抱歉,暂时无法提供与“BSI-5.0S8R0F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+457.956881+57.27095
