Product information
92 89 01
● For particularly demanding precision work: tough and highly resistant
to corrosion
● Maximum surface protection when handling sensitive electronic
components, micro-mechanical parts, as well as glass and ceramic
components
● For the electronics and precision engineering industries, watchmakers
and jewellers
● Handcrafted body: polished edges and an excellent matt, scratch-free
and non-reflective surface
● High-quality premium stainless steel body: high temperature
resistance and excellent corrosion resistance to most chemicals, salts
and acids
● The interchangeable tips are made from 30% carbon fibre reinforced
plastic: very good electrical and thermal conductivity, scratch-proof
and with high abrasion resistance
● The interchangeable, carbon fibre reinforced plastic tips have a
surface resistance between 10^2 and 10^3 ohms to compensate in a
controlled manner the differences in potential between the operator
and electronic components
● The interchangeable tips are permanently temperature stable up to
130° C, and up to 190° C for short periods
● The carbon fibre reinforced plastic tips are extremely flexible, fatigueresistant, vibration-dampening and water-repellent
● The tips have good chemical resistance to most oils, lubricants, fuels
and nonpolar solvents
● The same accuracy and stability as regular tweezers: the plastic tips
have a 3-point connection with zero backlash (2 fixed points on the
arms, one screw), which guarantee the user perfect attachment to the
body with zero backlash
● Potential savings: the tip assortment includes a selection of the most
diverse shapes. Depending on the application, only the tips need to be
purchased later
Exchangeable ESD tips
For 92 81 01
General
Article No.
92 89 01
EAN
4003773087106
Gripping surfaces
smooth gripping surfaces
Weight
1g
Dimensions
40 x 8 x 3.5 mm
Reach
no
RohS
no
Technical details
Tips width (A)
0.4 mm
Tips width (B)
2 mm
Corrosion-resistant
yes
yes
VDE tested
no
sectors
Industry electronics
KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal
05.07.2021 | page 1 2
Classification
eCl@ss 5.1.4
21040500
ETIM 5.0
EC000182
ETIM 6.0
EC000182
proficl@ss 6.0
EAB696c019
technical change and errors excepted
05.07.2021 | page 2 2
很抱歉,暂时无法提供与“92 89 01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+90.24230
- 2+87.23580
- 3+84.20530
- 4+82.46850
