88 01 180
88 01 180
    KNIPEX(凯尼派克)
    可调(水泵) 钳子 平头 有齿 7.25"(184.2mm)
88 01 180 数据手册
88 01 180 KNIPEX Alligator® Water Pump Pliers ● ● ● ● ● ● ● ● Article No. 88 01 180 EAN 4003773035480 Pliers black atramentized Head polished Handles with non-slip plastic coating Adjustment positions 9 Nominal size 180 mm Capacity for pipes, inches (diameter) Ø Inch 1 1/2 More output and comfort compared to conventional water pump pliers of the same length: 9-notch adjustment positioning for 30 % more gripping capacity Good access to the workpiece due to slim size of head and joint area Self-locking on pipes and nuts: no slipping on the workpiece and low handforce required Gripping surfaces with special hardened teeth, teeth hardness approx. 61 HRC: high wear resistance and stable gripping Box-joint design for high stability due to double guide Robust construction, insensitive to dirt; particularly suitable for outdoor work Guard prevents operators’ fingers being pinched Chrome vanadium electric steel, forged, multi stage oil-hardened Self-locking on pipes and nuts: no slipping on the workpiece; the complete actuating force can be used to turn the workpieces; not having to squeeze the pliers handles reduces the required effort Capacities for nuts mm 36 Capacities for pipes (diameter) Ø mm 42 Length mm 180 Net weight g 180 technical change and errors excepted Spare Parts Article No. EAN 88 09 180 4003773053507 Bolt (Kerpin) for 88 180 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
88 01 180 价格&库存
很抱歉,暂时无法提供与“88 01 180”相匹配的价格&库存,您可以联系我们找货
