7116-1472
7116-1472
    YAZAKI(矢崎)
7116-1472 数据手册
08/05/2019 YAZAKI Connectors Catalog SWP Connectors Terminal Female (Unit:mm) https://connectors-catalog.sys.yzk.co.jp/yazaki-web/servlet/SubServlet_e?forward=7116-1472&plist=list&select=XX 1/2 Specifications 08/05/2019 YAZAKI Connectors Catalog Classified Parts Terminal * 2 Family SWP Connectors Type - Yazaki Part Number 7116-1472 Connection Type Wire to Wire Wire to Board Wire to Device Unsealed/Seald Sealed Male/Female Female Number of Poles - Tab Width mm(inches) 1.8(070) Material Copper Alloy Plating Tin Plating Color - Rating - Mating Part Numbers 7114-1472 Product Specification No. YPES-11-04-012 Instruction Manual No. YPES-15-029 Product Specification Allowable Current(Ref.) Refer to the table of Housing Low Level Contact Resistance Refer to the table of Housing Insulation Resistance Refer to the table of Housing Withstanding Voltage Refer to the table of Housing Temperature Range Refer to the table of Housing Application List of Installable Components Wire Type Wire Size(mm2) Wire Seals AVS 1.25 7157-7899-90 AVSS 2f 7157-7899-90 CAVS 1.25 7157-7811-80 https://connectors-catalog.sys.yzk.co.jp/yazaki-web/servlet/SubServlet_e?forward=7116-1472&plist=list&select=XX 2/2
7116-1472 价格&库存
很抱歉,暂时无法提供与“7116-1472”相匹配的价格&库存,您可以联系我们找货
    • 1+0.81280
    • 10+0.66510
    • 100+0.56260
    • 500+0.52250
    • 1000+0.48760
    库存:3975
