ASOPD4580S-R
ASOPD4580S-R
    ASCEND(安森德)
    SOP-8
ASOPD4580S-R 数据手册
ASOPD4580 Dual Operational Amplifier ■ GENERAL DESCRIPTION ASOPD4580 is the dual operational amplifier, specially designed for improving the tone control, which is most suitable for the audio application. Featuring noiseless, higher gain bandwidth, high output current and low distortion ratio, and it is most suitable not only for acoustic electronic parts of audio pre-amp and active filter, but also for the industrial measurement tools. It is also suitable for the head phone amp at higher output current, and further more, it can be applied for the handy type set operational amplifier of general purpose in application of low voltage single supply type which is properly biased of the low voltage source. ■ Pin Configuration Top View ■ FEATURES ● Operating Voltage ● Low Input Noise Voltage ● Wide GBW ● Low Distortion ● Slew Rate ● Bipolar Technology ● Package Outline 1 ±2V~±18V 0.8µVrms typ. (RIAA) 15MHz typ. 0.0005% typ. 5V/µs typ. 2 3 8 7 A B 4 6 5 SOP8 ,DIP8 ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) V+ -INPUT +INPUT OUTPUT - V NOV 2018 Version1.0 1/9 Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier ■ABSOLUTE MAXIMUM RATINGS (Ta=25°C, unless otherwise noted.) PARAMETER AMETER RATING UNIT V+/V- ±18 V Input Voltage VIN ±15 (note1) V Differential Input Voltage Range VID V Power Dissipation PD Operating Temperature Range a opr ±30 550 ( note2) 820 ( note3) -40~+85 Supply Voltage Storage Temperature Range Tstg -40~+125 mW °C °C (note1) For supply voltage less than ±15V, the absolute maximum input voltage is equal to supply voltage. ( note2) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 2layers, FR-4) mounting ( note3) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 4layers, FR-4) mounting ■ RECOMMENDED OPERATING CONDITIONS (Ta=25°C) PARAMETER AMETER Supply Voltage CONDITION + - V /V MIN. TYP. ±2 ±2 MAX. UNIT ±18 V MAX. UNIT ■ ELECTRICAL CHARACTERISTICS (V+/V-=±15V, Ta=25°C, unless otherwise noted.) PARAMETER AMETER TEST CONDITION MIN. TYP. RS≤10kΩ Input Offset Voltage VIO - 0.3 3 mV Input Offset Current IIO - 5 200 nA Input Bias Current IB - 100 500 nA Voltage Gain AV RL≥2kΩ,VO=±10V 90 110 - dB Maximum Output Voltage VOM RL≥2kΩ ±12 ±13.5 - V Common Mode Input Voltage Range VICM ±12 ±13.5 - V Common Mode Rejection Ratio CMR RS≤10kΩ 90 110 - dB Supply Voltage Rejection Ratio SVR RS≤10kΩ 90 110 - dB - 6 9 mA RL≥2kΩ - 5 - V/µs - Supply Current ICC Slew Rate SR Gain Bandwidth Product GB f=10kHz Total Harmonic Distortion THD AV=20dB,VO=5V,RL=2kΩ,f=1kHz kHz VNI RIAA,RS=2.2kΩ,30kHz LPF Equivalent Input Noise Voltage NOV 2018 Version1.0 2/9 - 15 - MHz 0.0005 - % 0.8 - µVrms Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier ■ TYPICAL CHARACTERISTICS 40dB Gain/Phase vs. Frequency (Temperature) V+/V-=±15V, Gv=40dB, RL=2kΩ, CL=10pF Voltage Gain [dB] 120 Ta=-40ºC Ta=25ºC 20 60 Ta=85ºC Phase 0 0 Ta=-40ºC -20 -60 Ta=25ºC Ta=85ºC -40 -60 1000 10k -120 100k 1M 10M Frequency [Hz] 25 20 15 10 5 0 1000 -180 100M Maximum Output Voltage vs. Output Current Ta=25ºC 5 Ta=85ºC 0 Ta=85ºC -5 Ta=25ºC -10 -VOM Ta=-40ºC -15 1 (Temperature) V+/V-=±15V, Gv=open 10 Ta=85ºC Ta=-40ºC 5 Ta=25ºC 0 Ta=25ºC -5 Ta=-40ºC Ta=85ºC -10 -15 100 10 Output Current [mA] -VOM Equivalent Input Noise Voltage [nV/√Hz] THD+N [%] 0.001 f=1kHz f=20Hz NOV 2018 Version1.0 1 Output Voltage [Vrms] V+/V-=±15V, GV=40dB, RF=2kΩ 30 f=20kHz 0.1 100k Voltage Noise vs. Frequency V+/V-=±15V, GV=20dB, RF=2kΩ, Ta=25ºC 0.01 0.0001 1k 10k Load Resistance[Ω] 100 THD+N vs. Output Voltage (Frequency) 0.1 10M +VOM Maximum Output Voltage [V] Maximum Output Voltage [V] 10 100k 1M Frequency[Hz] 15 Ta=-40ºC +VOM 10k Maximum Output Voltage vs. Load Resistance (Temperature) V+/V-=±15V 15 V+/V-=±15V, Ta=25ºC 30 Maximum Output Voltage[Vpp] Gain 40 180 Phase [deg] 60 Maximum Output Voltage vs. Frequency 25 20 15 10 5 0 10 3/9 1 10 100 1k Frequency [Hz] 10k 100k Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier ■ TYPICAL CHARACTERISTICS Supply Current vs. Supply Voltage (Temperature) Supply Current vs. Temperature (Supply Voltage) RL=open 10 9 9 8 Ta=-40ºC 7 Supply Current [mA] Supply Current [mA] 8 Ta=25ºC 6 5 4 3 Ta=85ºC 2 1 0 RL=open 10 7 V+/V-=±18V 5 4 V+/V-=±2V 3 2 1 0 2 4 6 0 8 10 12 14 16 18 20 Supply Voltage [V+/V-] -50 (Supply Voltage) 3 Input Bias Current [nA] Input Offset Voltage[mV] V+/V-=±15V V+/V-=±18V -1 -2 400 350 300 -50 -25 150 100 0 0 25 50 75 100 125 150 Ambient Temperature[ºC] V+/V-=±18V Maximum Output Voltage [V] 10 5 Ta=-40ºC Ta=25ºC Ta=85ºC -5 -10 -VOM -15 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] (Supply Voltage) Gv=open, RL=2kΩ, RL to GND 18 +VOM 0 -50 Maximum Output Voltage vs. Temperature (Temperature) RL=2kΩ to GND 15 V+/V-=±2V 200 50 20 Maximum Output Voltage [V] V+/V-=±15V 250 Maximum Output Voltage vs. Supply Voltage -20 (Supply Voltage) VICM=0V 450 1 0 0 25 50 75 100 125 150 Ambient Temperature [ºC] 500 V+/V-=±2V 2 -25 Input Bias Current vs. Temperature Input Offset Voltage vs. Temperature -3 V+/V-=±15V 6 15 12 V+/V-=±18V 9 6 +VOM V+/V-=±15V V+/V-=±2V 3 0 -3 V+/V-=±2V -6 -9 V+/V-=±18V -12 V+/V-=±15V -VOM -15 0 2 4 NOV 2018 Version1.0 -18 6 8 10 12 14 16 18 20 Supply Voltage [V+/V-] 4/9 -50 -25 0 25 50 75 100 125 150 Ambient Temperature [ºC] Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier ■ Noise Voltage (RIAA) measurement circuit +15V 3.3µ -15V 100µ Rs 2.2k 100µ 40dB Amp 30kHz LPF 0.47µ 2.2µ Vout 56k 30k 330k 0.0024µ 0.0082µ 220k 47µ 610 NOV 2018 Version1.0 5/9 Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier Ordering and Marking Information Device Marking Package Packaging Quantity ASOPD4580S-R D4580 SOP8L Tape&Reel 2500/Reel ASOPD4580N-T D4580 DIP8L Tube 50/Tube MARKING PACKAGE SOP-8L D4580 DIP-8L NOV 2018 Version1.0 6/8 Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier ■ Package Dimension SOP8 Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A --- 1.75 --- 0.069 A1 0.00 0.26 0.000 0.010 A2 1.30 1.70 0.051 0.067 b 0.30 0.55 0.012 0.022 C 0.15 0.35 0.006 0.014 D 4.80 5.00 0.189 0.197 E 3.80 4.00 0.150 1.27 TYP e 0.157 0.050 TYP H 5.70 6.30 0.224 0.248 L 0.45 0.85 0.018 0.033 θ 0∘ 8∘ 0∘ 8∘ NOV 2018 Version1.0 7/9 Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier DIP8 Symbol Dimensions In Millmeters Dimensions In Inches A1 M i 3.60 n 0.38 M a 4.80 x --- M i 0.142 n 0.015 M a 0.210 x --- A2 3.05 3.65 0.120 0.210 b 0.36 0.51 0.014 0.020 b1 1.14 1.78 0.045 0.070 C 0.20 0.36 0.008 0.014 D 9.02 10.16 0.355 0.400 E 6.10 7.11 0.240 0.280 E1 7.45 8.26 0.300 A 2.54 BSC e 0.325 0.100 BSC eB 7.62 10.92 0.300 0.430 L 2.92 3.81 0.115 0.150 NOV 2018 Version1.0 8/9 Ascend Semicondutor Co.,Ltd ASOPD4580 Dual Operational Amplifier IMPORTANT NOTICE Xi‘an Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION). Xi‘an Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to this document and any product described herein. Xi‘an Ascend Semiconductor Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither does Xi‘an Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this document or products described herein in such applications shall assume . all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on Xi‘an Ascend Semiconductor Incorporated website, harmless against all damages. Xi‘an Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through unauthorized sales channel. Should Customers purchase or use Xi‘an Ascend Semiconductor Incorporated products for any unintended or unauthorized application, Customers shall indemnify and hold Xi‘an Ascend Semiconductor Incorporated and its representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized application. www.ascendsemi.com NOV 2018 Version1.0 9/9 Ascend Semicondutor Co.,Ltd
ASOPD4580S-R 价格&库存
很抱歉,暂时无法提供与“ASOPD4580S-R”相匹配的价格&库存,您可以联系我们找货
ASOPD4580S-R
    • 1+0.78460
    库存:10
