AW21018QNR
AW21018QNR
    AWINIC(艾为)
AW21018QNR 数据手册
AW21018 Feb. 2022 V1.1 18 MULTI-FUNCTION LED DRIVER WITH I2C INTERFACE General Description ⚫ AW21018 is an 18-channel multi-function LED driver. Each channel has individual 8-bit DC current setting for color-mixing and maximum 12-bit PWM resolution for brightness control. The global current of each channel is recommended to be 40mA configured via register and external resistor REXT. ⚫ ⚫ ⚫ ⚫ Applications tia en AW21018 can be turned off with minimum current consumption by pulling the EN pin low. AW21018 is available in QFN 4mmX4mmX 0.85mm-32L package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +85°C. aw ini Cell Phone Keyboard Programmable phase-shifting and spread spectrum technology are utilized to reduce EMI and audible noise caused by MLCC when LEDs turn on or off simultaneously. fid ⚫ ⚫ ⚫ Group control mode, autonomous breathing pattern and rapid RGB control mode are provided for flexible, high efficiency lighting effect programming and fast display updating. on ⚫ cC ⚫ 18-channel RGB LED Driver ➢ Global 256-levels DC current configuration ➢ Individual 4096-levels PWM for dimming ➢ Individual 256-levels current for colormixing ➢ Dither function High-precision current sinks ➢ Device-to-device error: ±5% ➢ Channel-to-channel error: ±5% EMI and audible noise reduction ➢ Phase delay and phase inverting scheme ➢ Slew rate control function Flexible LED lighting pattern control LED open/short detection per channel Auto power save mode when all LEDs off > 32ms Under voltage lock out and over temperature protection 1MHz I2C interface, 4 selectable addresses: 20h, 21h, 24h, 25h Power supply: 2.7V~5.5V QFN 4mmX4mmX0.85mm-32L package l Features PDA/MP3/MP4/CD/Mini display Smart home appliance www.awinic.com 1 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Typical Application Circuit VLED C3 1μF VDD VIO 27 V DD LED18 26 LED17 25 AD1 AD0 LED16 R1 4.7kΩ R2 4.7kΩ 30 EN 17 RG 16 RR en AW21018 29 SCL 28 SDA LED3 3 RB 31 ISET LED2 2 RG 1 RR 33 GND LED1 on REXT 4kΩ RB fid MCU 18 l C2 0.1μF tia C1 1μF Note: The resistor RR /RG /RB are only thermal reduction. And they are determined by VLED , VF of LED, VHR of LEDx and I LED . RX=(VLED -VFX-VHR)/ILED . cC Figure 1 AW21018 Application Circuit Pin Configuration And Top Mark AW21018QNR Marking (Top View) 25 32 aw ini AW21018QNR (Top View) 1 24 33 GND 17 8 16 9 RNAL – AW21018QNR XXXX – Production Tracing Code Figure 2 Pin Configuration and Top Marking www.awinic.com 2 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Pin Definition NAME DESCRIPTION 1~18 LED1~LED18 Constant current sink, connect to LED’s cathode. 19~24 NC Not connected 25 AD0 I2C interface device address, connects to GND, VDD for different device addresses of I2C. 26 AD1 I2C interface device address, connects to GND, VDD for different device addresses of I2C. 27 VDD Power supply: 2.7V~5.5V. 28 SDA Serial data I/O for I2C interface. 29 SCL Serial clock input for I2C interface. 30 EN Shutdown the chip when pulled low. 31 ISET When REXT=4.0kΩ, global current of LED is 40mA. 32 NC Not connected 33 GND Ground aw ini cC on fid en tia l No. www.awinic.com 3 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Functional Block Diagram POR VDD BG OTP OSC Open/Short Detect l UVLO tia GND Phase Control AD0 PWM Modulation en EN BRx I2C AD1 Digital Control LED DRIVER SLx SCL SDA fid GCC LED1 LED2 LED18 Global Current Setting on ISET aw ini cC Figure 3 Functional Block Diagram www.awinic.com 4 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Typical Application Circuits VLED C3 1μF VIO 27 V DD LED18 26 LED17 25 AD1 AD0 LED16 R1 4.7kΩ R2 4.7kΩ 30 EN MCU RLED 17 RLED 16 RLED AW21018 29 SCL 28 SDA LED3 3 RLED 31 ISET LED2 2 RLED 1 RLED 33 GND LED1 fid REXT 4kΩ 18 tia C2 0.1μF en C1 1μF l VDD on Note: The resistor RLED is only thermal reduction, and it is determined by VLED , VF of LED, VHR of LEDx and ILED . RLED =(VLED -VF-VHR)/ILED . cC Figure 4 AW21018 Application Circuit VDD C1 1μF C2 0.1μF 18 RB 17 RG 16 RR 29 SCL 28 SDA LED3 3 RB 31 ISET LED2 2 RG 1 RR LED18 26 LED17 AD1 AD0 aw ini R1 4.7kΩ LED16 R2 4.7kΩ 30 EN MCU REXT 4kΩ C3 1μF 27 V DD 25 VIO VLED 33 AW21018 GND LED1 Note: The resistor RR /RG /RB are only thermal reduction. And they are determined by VLED , VF of LED, VHR of LEDx and I LED . RX=(VLED -VFX-VHR)/ILED . Figure 5 AW21018 Application Circuit(RGB) www.awinic.com 5 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Ordering Information Temperature Package Marking Moisture Sensitivity Level Environmental Information Delivery Form AW21018QNR -40℃~85℃ QFN 4mmX4mmX0.85m m-32L RNAL MSL3 ROHS+HF 6000 units/ Tape and Reel l Part Number Parameter VDD Input voltage CIN Input capacitance TA Operating free-air temperature range Min. Typ. Max. Unit 2.7 3.6 5.5 V 0.1 1 100 μF -40° 25 85 °C en Symbol tia Recommended Operating Conditions fid Absolute Maximum Ratings(NOTE1) PARAMETERS on Supply voltage range VDD RANGE -0.3V to 6V Input voltage range SCL, SDA, EN, AD0, AD1 -0.3V to VDD Output voltage range LED1~LED18 -0.3V to VDD 42°C/W Junction-to-case (top) thermal resistance θJC 45°C/W cC Junction-to-ambient thermal resistance θJA -40°C to 85°C Operating free-air temperature range 150°C Storage temperature TSTG -65°C to 150°C aw ini Maximum operating junction temperature TJMAX 260°C Lead temperature (soldering 10 seconds) ESD (NOTE 2) HBM ±2000V CDM ±1500V Test condition: Latch-Up +IT:200mA JESD78E -IT:-200mA NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883J Method 3015.9 EIA/JESD22-C101F(CDM) www.awinic.com 6 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Electrical Characteristics TA=36°C, VDD=3.6V (unless otherwise noted), REXT=4kΩ, PWMRES=8bit. PARAMETER TEST CONDITION MIN TYP MAX UNIT 5.5 V 5 μA 3 10 μA 3 10 μA 2 4 mA 8 10 mA 0.1 1 μA 40 42 mA 5 % 100 150 mV ILEDX=40mA 120 200 mV ILEDX=60mA 180 300 mV 16 17.12 MHz Power supply voltage and current VCC Power supply voltage ISD_VCC Shutdown current of VCC VEN=GND Standby current of VCC VEN=3.6V,CHIPEN=0 Power-save mode current consumption VEN=3.6V, GCR.APSE=1, All LEDs off >32ms IACT_VCC Quiescent current in active mode tia VEN=VCC, GCR.CHIPEN=1 l 0.1 en ISTB_VCC 2.7 VEN=VCC, Iout=20mA per LEDx Output leakage current VEN=0V, VLEDX=5.5V IMAX Maximum global current of LEDX GCCR.GCC=0xFF, BRX=COLX=0xFF IMATCH Output current match accuracy GCCR.GCC=0xFF, SLX= BRx =0XFF VDROPOUT Dropout voltage when the LED current has dropped 5% on fid ILEAKAGE 38 -5 TSD OSC clock frequency Thermal shutdown threshold Thermal shutdown hysteresis 14.88 aw ini FOSC cC ILEDX=20mA 165 °C 25 °C AD0,AD1, EN VIL VIH VIL VIH Input low level EN Input high level EN Input low level AD0,AD1 0.4 1.4 AD0,AD1 VOL Output low level SDA,IOL = 10 mA VIH Input high level SCL, SDA VIL Input low level SCL, SDA www.awinic.com 0.7*VCC EN 7 V 0.3*VCC Input high level Internal pull down RENPD resistance 2 I C Interface V V V Ω 1M 0.1 1.2 V V 0.4 V Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 I2C INTERFACE TIMING FAST MODE MIN MAX - 400 - 1000 kHz 0.26 - μs 0.5 - μs 0.26 - μs (Repeat-start) START condition hold time 0.6 - TLOW Low level width of SCL 1.3 - THIGH High level width of SCL 0.6 - TSU:STA (Repeat-start) START condition setup time 0.6 THD:DAT Data hold time 0 TSU:DAT Data setup time 0.1 TR Rising time of SDA and SCL TF Falling time of SDA and SCL TSU:STO STOP condition setup time TBUF Time between condition tLOW 0.26 - μs - 0 - μs - 0.05 - μs - 0.3 - 0.12 μs - 0.3 - 0.12 μs 0.6 - 0.26 - μs 1.3 - 0.5 - μs fid - on tHIGH tR aw ini tBUF stop cC SDA en THD:STA l MAX Interface clock frequency and VIH VIL tF VIH SCL Stop UNIT MIN FSCL start FAST MODE PLUS tia PARAMETER VIL tHD:STA Start tHD:DAT tSU:DAT tSU:STA Start tSU:STO Stop Figure 6 I2C Interface Timing www.awinic.com 8 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Detailed Functional Description OVERVIEW AW21018 is an18 channel multi-function LED driver with I2C interface. Each channel has individual 8-bit DC current setting for color-mixing and maximum 12-bit PWM resolution for brightness control. The global current of each channel is recommended to be 40mA configured via register and external resistor REXT. en tia l Phase-control, spread spectrum technology and slew rate control are utilized to reduce EMI and audible noise caused by MLCC. Output current of each LED can be controlled by one pattern or be configured independently. The integrated pattern controller provides breathing or group dimming control. The breathing mode includes auto breathing and manual control mode. All breathing parameters are configurable including rising/falling slope, on/off time, repeat times and brightness. OPERATION MODE AND RESET RESET fid Power On Reset Upon initial power-up, the AW21018 is reset by internal power-on-reset, and all registers are reset to default value, and the chip is shut down. on Once the supply voltage VDD drops below the threshold voltage VPOR(2.0V), the power-on-reset will reset the chip again. By reading the bit PUST of the register UVCR (address 60h), whether the chip has been reset can be detected. cC When the VDD ramps up above the threshold voltage VPOR (2.0V) and EN is high, POR is pulled high, meanwhile the chip enters into initialization mode. The chip needs about 2ms to load the efuse information in initalization mode. After initialization, it works in lower-power mode. About 200μs delay is required after CHIPEN is pulled up, otherwise, internal OSCCLK may work incorrectly. Only in low-power and active mode, registers could be configurated. The recommended operation timing is shown as bellow. aw ini VDD EN POR 2ms INITIAL initial CHIPEN (bit CHIPEN of GCR register) Note: The chip needs about 2ms for initalization after power on Note: Recommend CHIPEN=1 after Initial 200μs .. OSC Configuring Time MODE Note: OSC operates stable,which needs 200μs after CHIPEN=1 Internal registers are configurable Shutdown Initialization Standby Active Figure 7 Power On Timing Software Reset By writing 00h to register RESET (address 70h) in active mode, the software reset is triggered. Then all registers will be reset to the default value and the chip enters into initialization mode. After the software reset command is input by I2C, it needs to wait at least 2ms before any other I2C commands www.awinic.com 9 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 are accepted. Software Reset Note: The device need about 2ms for initalization after power on 2ms INITIAL initial CHIPEN (bit CHIPEN of GCR register) Note: Recommend CHIPEN=1 after Initial 200us .. Configuring Time tia l OSC MODE Note: OSC operate stable need 200μs after CHIPEN=1 Internal registers are configurable Active Initialization Standby en Figure 8 Software Reset Timing Active OPERATING MODE fid Shutdown mode The AW21018 enters into shutdown mode automatically when EN is pulled to low. In this situation, I2C interface is not accessible, all registers will be reset and can not be configured. on Initialization mode If EN is high, AW21018 enters into initialization mode. During this period, all registers will be reset and chip starts loading efuse information automatically. Standby mode Active mode cC After initialization, the AW21018 enters into standby mode when the bit CHIPEN of the register GCR (address 20h) is ‘0’, or UVLO is triggered in active mode. In this mode, only POR and I2C circuits work. I2C interface is accessible, and all registers can be configured now. aw ini The AW21018 enters into active mode when EN is high and the bit CHIPEN of the register GCR (address 20h) is ‘1’. Power save mode In active mode, when the bit APSE of the register GCR (address 20h) is set to “1”, the auto power-save function is enabled. When all LEDs are switched off and the value of all registers BR00L~BR17H are 00h and write 00h to register UPDATE(address 45h) for more than 32 ms, AW21018 automatically enters into power saving mode. In power save mode, most analog blocks are disabled to minimize power consumption, but the registers retain the data and keep it available via I2C. Once writing a non-zero value into any register among BR00L~BR17H, the chip exits power-save mode immediately. Thermal shutdown The AW21018 enters the thermal shutdown mode when the junction temperature exceeds 165°C(typical) automatically. In this mode, all the LEDx outputs are shut down. If the junction temperature decreases below 140°C(typical), the AW21018 returns to active mode. www.awinic.com 10 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 VDD power on EN = L Shutdown From all modes EN = H Software reset Active mode l Initialization CHIPEN=1 tia Standby CHIPEN=0 APSE=1 && All LEDs off > 32ms en OTST=1 Power Save Active Thermal Shutdown APSE=0 or Write a non-zero value to register BRx OTST=0 fid Figure 9 AW21018 operating mode transition FEATURE DESCRIPTION on CURRENT SETTING The average output current of LEDx (x=1~18) can be expressed by the following formula, 𝑮𝑪𝑪 𝑺𝑳𝒙 𝑩𝑹𝒙 × × 𝟐𝟓𝟓 𝟐𝟓𝟓 𝟐𝑷𝑾𝑴𝑹𝑬𝑺 𝒙 = 𝟏~𝟏𝟖 cC 𝑰𝑶𝑼𝑻(𝒙) = 𝑰𝑴𝑨𝑿 × aw ini Where IMAX=40mA when REXT=4KΩ, GCC is the 8bit global current configured by the register GCCR (address 58h), SLx is 8bit individual constant current parameter configured by the register SLx (address 46h~57h) , PWMRES is 8bit/9bit/12bit PWM resolution configured by the register GCR (address 20h), and BRx is 8bit/9bit/12bit individual PWM modulated current parameter configured by the register BRxL/BRxH (address 21h~44h). PWM MODLULATION Dither Function When PWMRES[1:0] of GCR(address 20h) equal to ‘11’, dither function is enabled. Then the final output PWM has the frequency equal to 9 bits and resolution equal to 12 bits. This is achieved by 9 bits PWM modulation and 3bits digital dither control. For 3-bit dither, every PWM in the 8 PWM group can be added one LSB or not according to the 8-bit digital dither timing. PWM Frequency The output PWM frequency is decided by bits CLKFRQ [2:0] and PWMRES[1:0] in register GCR (address 20h). Following table shows the relationship of PWM frequency, the CLKFRQ [2:0] and PWMRES[1:0]. To avoid the MLCC audible noise, it’s recommended to use the PWM frequency lower than 500Hz or higher than 20kHz. CLKFRQ[2:0] BR Resolution www.awinic.com 000 001 11 010 011 100 101 110 111 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 8bit 62k 32k 4k 2k 1k 500 244 122 9bit 32k 16k 2k 1k 488 244 122 - 12bit 4k 2k 244 122 - - - - 9bit+3bit dither 32k 16k 2k 1k 488 244 122 - . PWM Phase Control Phase2 LED4~LED6 Phase3 LED7~LED9 0 π /3 2π /3 Phase4 3π /3 LED10~LED12 Phase5 on 4π /3 fid Phase1 LED1~LED3 en tia l To reduce the peak load current and ceramic-capacitor audible ringing, AW21018 supports 6 PWM phase shifting (Phase1~Phase6) and phase-inverting scheme. When setting PDE in register PHCR (address 59h) to ‘1’, the phase shifting scheme is enabled, and each adjacent phase differs by 60 degrees,which meaning only 3 of 18 LEDs could switch on in the same time. LED13~LED15 Phase6 5π /3 LED16~LED18 cC Figure 10 Phase shift scheme aw ini When setting PINVTEn in register PHCR (address 59h, n=0~5) to ‘1’, the PWM phase of the even-numbered channels is inverted. As shown below, if setting PINVTEn to ‘1’, the even-numbered channels are rotated 180 degrees counterclockwise when the odd-numbered channels are not, which is good for reducing the inputcurrent ripple. For an example, when setting PINVTE0 to ‘1’, LED2 is rotated 180 degrees counterclockwise while the LED1 and LED3 are not. n=0,2,4 PINVTE=“0” LED[3n +1 ] LED[3n +2 ] LED[3n +3 ] PINVTE=“1” LED[3n +1 ] LED[3n +2 ] LED[3n +3 ] www.awinic.com 12 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 n=1,3,5 PINVTE=“0” LED[3n +1 ] LED[3n +2 ] LED[3n +3 ] tia l PINVTE=“1” LED[3n +1 ] LED[3n +2 ] en LED[3n +3 ] Figure 11 Phase invert scheme fid PWM Disable If the bits DCPWM [2:0] in register SSCR (address 5Fh) is set to “111”, the PWM output is disabled, and the duty of each PWM is forced to 100%. In this mode, the BRx parameter is not valid, but the SLx parameter is still effective. on It should be noted that when performing open-short detection, the bits DCPWM [2:0] need to be set to “111”. GROUP CONTROL MODE cC AW21018 supports group control mode, in this mode, all selected LEDs are controlled by the group control registers (GSLR, GSLG, GSLB). The register GCFG select which LEDs are controlled by group control register. There are total 6 control bits (GEx), each bit set adjacent 3 LEDs are included in or not. User can configure group control register to setting common brightness and color for all selected LED, so as to simplify lighting effect programming and speed up display refreshing via I2C interface. aw ini If bit GSLDIS in register GCFG (address 8bh) is ‘1’, the color parameters of the grouped LED are no longer configured by register GSLR/G/B but by individual register (SL0~SL15). The detailed configurations are as follows. LED GE Brightness Color GE=0 GE=1 GE=0 or GSLDIS=1 GE=1 and GSLDIS=0 BR00 GBR SL00 GSLR BR01 GBR SL01 GSLG 3 BR02 GBR SL02 GSLB 4 BR03 GBR SL03 GSLR BR04 GBR SL04 GSLG BR05 GBR SL05 GSLB … … … … BR12 GBR SL12 GSLR BR13 GBR SL13 GSLG BR14 GBR SL14 GSLB 1 2 5 GCFG[0] GCFG[1] 6 … … 13 14 15 www.awinic.com GCFG[4] 13 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 16 17 GCFG[5] 18 BR15 GBR SL15 GSLR BR16 GBR SL16 GSLG BR17 GBR SL17 GSLB Note: GBR={GBRH,GBRL}. SPREAD SPECTRUM en tia l PWM is a troublesome for some application which is concerned about EMI. AW21018 has spread spectrum function to optimize the EMI performance. If bit SSE in register SSCR (address 5Fh) is set to ‘1’, spread spectrum function is enabled. By setting the bit SSR in register SSCR, four spread spectrum range ±5%/±15%/±25%/±35% can be selected. The total electromagnetic emitting energy can spread into a wider range of frequency band that significantly degrades the peak energy of EMI. RGB CONFIGURE MODE fid In RGB applications, every 3 LEDs in RGB share a same BR parameter. To achieve fast register configuration for RGB applications, AW21018 provides an RGB configuration mode by setting the bit RGBMD in register GCR2 (address 61h). on If RGBMD=1, register BR00~BR05 configure brightness parameters for corresponding 6 RGB groups. In other words, in RGB mode, only registers BR00~BR05 need to be configured, and the registers BR06~BR17 are not valid any more. If RGBMD=0, register BR00~BR17 configure brightness parameters for corresponding 18 LEDs independently, more details as follows, BR parameter source cC LED RGBMD=0 BR00 2 BR01 3 BR02 4 BR03 5 BR04 6 BR05 … … 13 BR12 14 BR13 15 BR14 16 BR15 17 BR16 18 BR17 aw ini 1 RGBMD=1 BR00 BR01 … BR04 BR05 Note: BRxx = {BRxxH,BRxxL} SINGLE BYTE CONFIGURATION MODE By default, every LED has a 12bits BR parameter with BRxxL and BRxxH. The effective bit of BRxxH is 4bit. However, AW21018 provides a single byte configuration mode by setting the bit SBMD in register GCR2 (address 61h). In single byte applications, every LED has a 8bit BR parameter configured by BR00L~BR08H. www.awinic.com 14 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 It is worth noting that the effective bit of BRxH(xx is 00~05) is 8 bit in single byte mode compared with default mode.More details are as follows. SBMD=1 1 {BR00H,BR00L} BR00L 2 {BR01H,BR01L} BR00H 3 {BR02H,BR02L} BR01L 4 {BR03H,BR03L} BR01H 5 {BR04H,BR04L} BR02L 6 {BR05H,BR05L} BR02H … … … 13 {BR12H,BR12L} 14 {BR13H,BR13L} 15 {BR14H,BR14L} 16 {BR15H,BR15L} BR07H 17 {BR16H,BR16L} BR08L 18 {BR17H,BR17L} BR08H en tia SBMD=0 l BR parameter source LED BR06L BR06L on fid BR07L PATTERN CONTROLLERS cC There is a breathing pattern controller in the chip. When bit PATE in register PATCFG (address 80h) is set to ‘1’, breathing pattern controller is enabled. Pattern controller can be configured as autonomous breathing mode or manual-controlled mode. When corresponding GE is configured as ‘1’, if in pattern controlled mode, each led group (consisting of three adjacent LEDs) can enter into breathing mode. When GE is ‘0’, the three adjacent LEDs exit breathing mode directly. For example, when setting GCFG = 0x01 and in pattern controlled mode, LED1~LED3 will work in breathing mode and other LEDs will work in default mode. aw ini Autonomous Breathing Mode When bit PATE and PATMD in register PATCFG are set to ‘1’, the pattern controller works in autonomous breathing mode. In this mode, the pattern controller will generate a breathing lighting effect, which is configured by the user-defined timing parameter. The waveform of the breathing lighting effect is shown in the following figure. The parameter T0~T3 define 4 key periods in a complete breathing cycle. T0~T3 composite a breathing loop, denoting the rise-time, on-time, fall-time and off-time respectively. Register GBRH (address 86h) and GBRL (address 87h) control the max and min brightness of the breathing respectively. GBRH GBRL T0 T1 T2 T3 Figure 12 LED breath timing in pattern mode The start point and end point of autonomous breathing loop are configurable. The loop starting point could be selected among T0~T3, which is set by bits LB [1:0] in register PATT2 (address 84h). The end point of the loop can only be selected between the end of T3 and the end of T1, which is determined by bits LE [1:0] in register www.awinic.com 15 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 PATT2. If bits LE [1:0] is not “00”, the end point of breathing loop is the end of T1, and the loop counter increment by 1 at the end of T1. If bit LE [1:0] is “00”, the loop end point is the end of T3, and the loop counter increment by 1 at the end of T3. The repeat times is decided by bit RPT [11:8] of register PATT2 (address 84h) and RPT [7:0] of register PATT3 (address 85h). When setting RPT [11:0] to ‘0’, the breathing pattern will run unlimited times. tia l After the breathing pattern is over, the status bit PATIS in register PATGO (address 81h) will be set to ‘1’, and PATIS will be cleared to ‘0’ after reading out through I 2C bus. Once breathing loop start again or pattern controller switches to manual mode by setting PATE bit to ‘0’, the PATIS will also be cleared. When bit RUN in register PATGO is set to ‘1’, breathing pattern is started. The full process of the autonomous breathing is as follows: Set GSLR/G/B, GBRH/L parameter. 2. Set GCFG to select the LED in breathing pattern mode or not. 3. Configure PATT0, PATT1, PATT2, and PATT3 for parameters T0~T3, start/stop point, and repeat times. 4. Set PATE=1 to enable breathing pattern mode. 5. Set PATMD=1 to select auto breathing mode. 6. Set RUN=1 to start the breath pattern. fid Manual Control Mode en 1. on If bit PATMD is set to ‘0’, manual control mode is selected. In manual control mode, user could program the bit SWITCH of register PATCFG to control the output of pattern controller. When bit SWITCH is ‘1’, the output of pattern controller is decided by register GBRH. When bit SWITCH is set as “0”, the output is the decided by register GBRL. cC If bit RAMPE in register PATCFG is set to ‘1’, the smooth ramp up/down will be enabled. At the same time, if SWITCH changes from “0” to ‘1’, the output will be ramp up to GBRH smoothly. Similarly, if SWITCH changes from “1” to ‘0’, the output of the pattern controller will ramp down to GBRL smoothly. However, if the RAMPE is set to ‘0’, the output of the pattern controller will change to GBRH or GBR directly with no ramp as the SWITCH changes. aw ini GBRH PATCFG.RAMPE =0 GBRL GBRH PATCFG.RAMPE =1 fade-out fade-in GBRL Set PATCFG.SWITCH =1 Set PATCFG.SWITCH =0 Figure 13 Manual Control Mode PROTECTION FEATURES Under Voltage Lock Out (UVLO) When bit UVDIS of the register UVCR (address 60h) is set to ‘0’, the chip monitors the voltage of VDD. If the supply voltage drops below threshold (2.5V typically), the bit UVST of the register UVCR (address 60h) will be set to ‘1’. After read-out, the register UVCR will be clear. If both bit UVDIS and bit UVPD of the register UVCR (address 60h) is set to ‘0’, UVLO protection function is enabled. Once the event of under voltage occurs, the bit CHIPEN of the register GCR (address 20h) will be www.awinic.com 16 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 cleared to ‘0’, and then the chip will enter into standby mode. If the voltage of VDD rises above 2.6V then write “1” to bit CHIPEN, the chip will enter into active mode again. By default, control bits UVDIS, UVPD are all “0”. Both UVLO monitor and protection are enabled. Over Temperature Protection (OTP) tia l When bit OTDIS of the register OTCR (address 5Eh) is set to ‘0’, the over-temperature detection is enabled. Once the temperature of this chip reaches 165°C, the over-temperature condition is detected, and the bit OTST of the register OTCR (address 5Eh) will be set to ‘1’. The OTST will be cleared to ‘0’ after reading the register OTCR. en If both bit OTDIS and bit OTPD of the register OTCR (address 5Eh) are set to ‘0’, the Over-Temperature Protection (OTP) function is enabled. Once the temperature is over 165°C, the bit CHIPEN of the register GCR (address 20h) will be cleared to ‘0’, and then the chip will enter into thermal shutdown mode. When the temperature returns below 140°C, the chip will enter into active mode again after writing “1” to bit CHIPEN. By default, control bits OTDIS and OTPD are all “0”, both OT monitor and OT protection are enable. LED Open/Short Detection The valid detect result is determined by: ⚫ Short Detection: VLED > VDD- VTHSHORT ⚫ Open Detection: VLED < VTHOPEN on fid AW21018 supports LED open/short detection. When bit OSDE[1:0] of the register OSDCR(address 5Ah) is set to “10” , short detection is enabled, and the detection results can be read out via the registers OSST0~2(5Bh~5Dh). Similarly, when set bit OSDE [1:0] of the register OSDCR (address 5Ah) to “11”, open detection is enabled, and the results also can be read out via the registers OSST0~2. Where VTHOPEN: Threshold of open detection (When OTH=0, VTHOPEN = 0.1V,else VTHOPEN = 0.2V;). cC VTHSHORT: Threshold of short detection (When STH=0, VTHSHORT = 0.5V,else VTHSHORT = 1V). VLED:The voltage of chip LED pin. aw ini We recommend the bit DCPWM[2:0] of the register SSCR (address 5Fh) being set to “111” and maintain about 1mA current of each LED when the open/short function is enabled. www.awinic.com 17 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 I2C INTERFACE l The AW21018 supports the I2C protocol. The maximum frequency supported by the I2C is 1 MHz. The pull-up resistor for the SDA and SCL can be selected from 1k to 10kΩ. Usually, 4.7kΩ is recommended for 400 kHz I2C, 1kΩ is recommended for 1 MHz I2C. The voltage from 1.8V to 3.3V is allowed for the I2C interface. Additionally, the I2C chip supports continuous read and write operations. Particularly, if register address is 00h or 01h, the slave chip will poll register address between 00h and 01h. tia CHIP ADDRESS GND/GND GND/VDD 010 VDD/GND VDD/VDD A4:A3 A2:A1 00 00 00 01 01 00 01 01 A0 Chip Address Broadcast Address 20h fid A7:A5 0/1 21h 24h 1Ch 25h on AD PIN en The I2C chip address is 7-bit (A7~A1), followed by the bit R/W (A0). Set A0 to “0” for writing and “1” for reading. The values of bit A1 and A2 are depended on the pin AD0. A3 and A4 are depended on the pin AD1. There are 2 options: VDD and GND. The A7 to A5 is “010” constantly. The chip also supports using a broadcast slave address of 1Ch. All slave addresses as followed. I2C START/STOP cC All transactions begin with a START and are terminated by a STOP sent by master to slave. A high-to-low transition on the SDA input/output while the SCL input is high defines a START condition. A low-to-high transition on the SDA input/output while the SCL input is high defines a STOP condition. In particular, the bus stays busy when a repeated START (Sr) is generated instead of a STOP signal corresponding to the lastest START (S). Sr and S are usually regarded as equivalent. aw ini SDA SCL S/Sr P S: START condition Sr: START Repeated condition P: STOP condition Figure 14 I2C START/STOP Condition Timing DATA VALIDATION When SCL is high level, SDA level must be constant. SDA can be changed only when SCL is low level.Each SCL pulse corresponds to one bit data transaction. www.awinic.com 18 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 SDA SCL Change of Data Allowed Figure 15 Data Validation Diagram en ACK (ACKNOWLEDGEMENT) tia l Data Line Stable Data Valid ACK means the successful transaction of I 2C bus data. During writing cycle, after master sends 8-bit data, SDA must be released by master and SDA is pulled down to GND by slave chip when slave sends ACK. fid During reading cycle, after slave chip sends 8-bit data, slave releases the SDA and waits for ACK from master. If master sends ACK with STOP condition, slave chip sends the next data. If master sends NACK, slave chip stops sending data and waits for I2C stop. on Data Output by Transmitter Not Acknowledge(NACK) Data Output by Receiver Acknowledge(ACK) 1 cC SCL From Master 2 8 9 Clock Pulse for Acknowledgement START condition Figure 16 I2C ACK Timing aw ini WRITE CYCLE One data bit is transferred during each clock pulse. Data is sampled during the high state of the serial clock (SCL). Consequently, throughout the clock’s high period, the data should remain stable. Any changes on the SDA line aborts the current transaction during the high state of the SCL. New data should be sent to SDA bus during the low SCL state. This protocol allows a single data line to transfer both command/control information and data using the synchronous serial clock. Each data transaction is composed of a start condition, a number of byte transfers and a stop condition to terminate the transaction. Every byte written to the SDA bus must be 8 bits and is transferred with the most significant bit first. After each byte, an Ack signal must follow. 1. In a write process, the following steps should be followed: 2. Master chip generates START condition. The “START” signal is generated by pulling down the SDA signal while the SCL signal is high. 3. ̅ = 0. Master chip sends slave address (7-bit) and the data direction bit R/𝑊 4. Slave chip sends acknowledge signal if the slave address is correct. 5. Master sends control register address (8-bit). 6. Slave sends acknowledge signal. 7. Master sends data byte to write to the addressed register. www.awinic.com 19 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 8. Slave sends acknowledge signal. 9. If master send more data bytes, the control register address will be incremented by one after acknowledge signal (repeat step f and g). 10. Master generates STOP condition to indicate write cycle ends. SCL 0 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 A6 A5 A4 A3 A2 A1 A0 R/WAck A7 A6 A5 A4 A3 A2 A1 A0 Ack D7 D6 D5 D4 D3 D2 D1 D0 Ack Start Device Address tia l SDA Register Address Write Data Figure 17 I2C Write Byte Cycle en READ CYCLE Stop In a read cycle, the following steps should be followed: Master chip generates START condition 2. Master chip sends slave address (7-bit) and the data direction bit (R/W = 0). 3. Slave chip sends acknowledge signal if the slave address is correct. 4. Master sends control register address (8-bit) 5. Slave sends acknowledge signal 6. Master generates STOP condition followed with START condition or REPEAT START condition 7. Master chip sends slave address (7-bit) and the data direction bit (R/W = 1). 8. Slave chip sends acknowledge signal if the slave address is correct. 9. Slave sends data byte from addressed register. cC on fid 1. 10. If the master chip sends acknowledge signal, the slave chip will increase the control register address by one, then send the next data from the new addressed register. In particular, if register address is 00h or 01h, the slave chip will poll register address between 00h and 01h. 11. If the master chip generates STOP condition, the read cycle ends. 0 1 2 3 4 5 A6 A5 A4 A3 A2 A1 aw ini SCL SDA start 6 7 8 0 1 2 3 4 5 6 A0 R/W Ack A7 A6 A5 A4 A3 A2 A1 Device Address …… Using Repeat start…… 1 2 3 4 5 A6 A5 A4 A3 A2 A1 …… P 6 7 8 0 A0 R/W Ack D7 S 1 ... 6 D6 …… D1 7 8 D0 Ack stop Read Data Device Address Separated Read/write transaction …… A0 Ack Register Address 0 RS 8 7 0 1 2 3 4 5 A6 A5 A4 A3 A2 A1 6 7 8 0 A0 R/W Ack D7 Device Address 1 ... 6 7 D6 …… D1 D0 Read Data 8 Ack stop Figure 18 I2C Read Byte Cycle www.awinic.com 20 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Register Configuration ADDR R/W NAME D7 20h RW GCR APSE 21h RW BR00L 22h RW BR00H … … … 43h RW BR17L 44h RW BR17H 45h W UPDATE UPDATE 46h RW SL00 SL00 … … … 57h RW SL17 58h RW GCCR 59h RW PHCR 5Ah RW OSDCR 5Bh R OSST0 5Ch R OSST1 5Dh R OSST2 5Eh RW OTCR 5Fh RW SSCR 60h RW UVCR REXT_ST 61h RW GCR2 62h RW GCR3 70h RW RESET 80h RW PATCFG 81h RW PATGO 82h RW PATT0 cC Register List D6 D5 D4 D3 83h RW PATT1 84h RW PATT2 85h RW PATT3 RPT[7:0] 00h 86h RW GBRH GBRH 00h 87h RW GBRL GBRL 00h 88h RW GSLR GSLR 00h CLKFRQ D2 - D1 PWMRES D0 DEF CHIPEN 00h BR00L 00h BR00H … tia … BR17L 00h BR17H 00h 00h 00h en - - … … SL17 00h GCC 00h fid PDE 00h l - OTH TROF STH OSDE 00h 00h OP/ST [15:8] 00h 00h TRTH 00h CLT 00h OTST SSE SSR UVST PUST OCPTH UVPD UVDIS 00h BSDIS UDMD SBMD RGBMD 00h - - OTPD OP/ST [17:16] TRST DCPWM OTDIS APS2E SRR SWITCH - RAMPE PATIS PATMD PATE 00h PATST RUN 00h T1 00h T3 00h RPT[11:8] 00h T2 LB 00h 02h T0 LE SRF[1:0] RESET/ID - aw ini 00h OP/ST [7:0] on - PINVTE 89h RW GSLG GSLG 00h 8Ah RW GSLB GSLB 00h 8Bh RW GCFG www.awinic.com - GSLDIS 21 GE5 GE4 GE3 GE2 GE1 GE0 00h Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Register Detailed Description GCR: Global Control Register (Address 20h) Symbol R/W 7 APSE RW Description Auto power save enable 0: disable 1: enable 0 RW 3 reserved - 000: 16MHz 001: 8MHz 010: 1MHz 011: 512kHz 100: 256kHz 101: 125kHz 110: 62.5kHz 111: 31.25kHz en CLKFRQ tia OSC frequency selection 6:4 Default l Bit - 0 00 PWMRES RW 0 CHIPEN RW Chip enable 0: disable 1: enable on fid 2:1 Brightness resolution selection 00: 8bit 01: 9bit 10: 12bit 11: 12bit with dither enabled cC 000 0 BRxxL/BRxxH: Brightness Control Register (Addredd 21h~44h) Symbol R/W 7:0 BRxxL RW 3:0 BRxxH RW Description Default Brightness control LSB8 for LED 00h Brightness control MSB4 for LED 0000 aw ini Bit UPDATE: Update Register (Address 45h) Bit Symbol R/W 7:0 UPDATE W Description Write 00h to update BR and SL registers Default 00h SLxx: Scaling Register (Address 46h~57h) Bit Symbol R/W 7:0 SLxx RW Description Scaling parameter for LED Default 00h GCCR: Global Current Control Register (Address 58h) Bit Symbol R/W 7:0 GCC RW www.awinic.com Description Global current control register 22 Default 00h Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 PHCR: Phase Control Register (Address 59h) R/W 7 PDE RW 6:4 reserved - 3:0 PINVTE RW Description Default PWM phase delay enable 0: disable 1: enable 0 - 000 Phase invert enable for every 3 LEDs 0: phase not invert 1: phase invert 180 degree for even LEDs en OSDCR: Open/Short Detect Control Register (Address 5Ah) l Symbol tia Bit 0000 Bit Symbol R/W Description Default 7:4 reserved - - 0000 3 OTH RW 2 STH RW RW fid 1: 0.2V Short threshold 0: 0.5 V 1: 1 V on OSDE 0: 0.1V Open/short detect enable, must set PWMDIS=111 before detecting 0x: detect disable 10: short detect enable 11: open detect enable cC 1:0 Open threshold 0 0 00 OSST: Open/Short Status Register (Address 5Bh/5Ch/5Dh) Symbol R/W Description aw ini Bit Default 7:0 OSST0 R Open/Short Status of LED1~8 0: no open/short detected 1: open/short detected 7:0 OSST1 R Open/Short status of LED9~16 0: no open/short detected 1: open/short detected 00h R Open/Short status of LED17~18 0: no open/short detected 1: open/short detected 00 1:0 OSST2 00h OTCR: Over Temperature Control Register (Address 5Eh) Bit Symbol R/W Description Default Thermal roll off percentage of LED output current 7:6 TROF www.awinic.com RW 00: 100% 01: 75% 10: 50% 11: 25% 23 00 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 TRST R 4 OTST R Over temperature status 0: normal 1: over temperature occurred 0 0 l 5 Thermal roll off status 0: normal 1: thermal roll off occurred 2 OTDIS RW RW Over temperature detect disable 0: OT detect enable 1: OT detect disable tia OTPD en 3 Over temperature protect disable 0: OT protect enable, when OT event occurs, chip will clear GCR.CHIPEN to 0 1: OT protect disable 0 0 1:0 TRTH RW fid Temperature roll off threshold 00: 140°C 01: 120°C 11: 90°C on 10: 100°C 00 SSCR: Spread Spectrum Control Register (Address 5Fh) R/W 7 DCPWM2 RW 6 DCPWM1 RW 5 DCPWM0 4 Description cC Symbol SSE Default 0: LED 13~18 PWM duty set by 39h~44h 1: LED 13~18 PWM duty set as 100% 0 0: LED 7~12 PWM duty set by 2Dh~38h 1: LED 7~12 PWM duty set as 100% 0 aw ini Bit RW 0: LED 1~6 PWM duty set by 21h~2Ch 1: LED 1~6 PWM duty set as 100% 0 RW Spread spectrum enable 0: disable 1: enable 0 Spread spectrum range 3:2 SSR RW 00: ±5% 01: ±15% 10: ±24% 11: ±34% 00 Spread spectrum period 1:0 CLT www.awinic.com RW 00: 1980μs 01: 1200μs 10: 820μs 11: 660μs 24 00 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 UVCR: UVLO Control Register (Address 60h) Symbol R/W Description REXT_ST R 5 UVST R UVLO status 0: normal 1: UVLO detected Power up status 0: normal 1: power up occurred 00 en tia 7:6 Rext status 00: normal 01: Rext is short or OCP 10: Rext is open 11: no exist Default l Bit 0 PUST R 3 OCPTH RW OCP threshold 0: 85mA 1: 55mA RW OCP disable 0: enable OCP 1: disable OCP RW UVLO protect disable 0: UVLO protect enable, when UVLO occurs, chip will clear GCR.CHIPEN to 0 1: UVLO protect disable 0 UVLO detect disable 0: UVLO detect enable 1: UVLO detect disable 0 0 UVPD UVDIS RW on 0 0 0 cC 1 OCPD aw ini 2 fid 4 GCR2: Global Control Register2 (Address 61h) Bit Symbol R/W Description Default 7:5 reserved - - 000 4 3:2 BSDIS UDMD www.awinic.com RW I2C broadcast slave address disable 0: I2C broadcast slave address enable 1: I2C broadcast slave address disable 0 RW BR and SL update mode 00: BR is updated at PWM carrier boundary, and SL does not need to be updated. 01: Both BR and SL are updated at PWM carrier boundary. 10: BR is updated at fast mode, and SL does not need to be updated. 11: Both BR and SL are updated at fast mode. 00 25 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 RGBMD RW Single byte mode for BR 0: disable 1: enable 0 RW RGB mode enable 0: disable 1: enable, every 3 LEDs uses a common BR. 0 l 0 SBMD GCR3: Global Control Register3 (Address 62h) Bit Symbol R/W Description 7:4 reserved - - 3 APS2E RW 2 SRR RW en Enable PWMIS0 function 0: disable 1: enable tia 1 Slew rate control for LED output rising 1: 6ns fid 0: 1ns Default 0000 0 0 Slew rate control for LED output falling 1:0 SRF RW 00: 1 ns 01: 3 ns on 10: 6 ns Bit Symbol R/W 7:0 RESET RW cC RESET: Reset Register (Address 70h) 00 11:10 ns Description Software reset/ID Write 00h will reset all registers to their default value. When read, chip ID is read out. Default 02h aw ini PATCFG: PAT Configuration Register (Address 80h) Bit Symbol R/W Description Default 7:4 reserved - - 0000 3 SWITCH RW Switch on or off at manual mode. 0: switch LED off 1: switch LED on 2 RAMP RW Ramp for manual mode 0: direct set 1: ramp enable when transition 0 0 0 1 PATMD RW PAT operation mode 0: manual mode 1: auto breath mode 0 PATE RW PAT Enable 0: disable 1: enable www.awinic.com 26 0 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 PAT Run Control Register (Address 81h) Bit Symbol R/W Description Default 7:3 reserved - - 00000 2 PATIS RW PAT loop over flag 0: pattern is non-over 1: pattern is over 0 PATST RW 0 RUN RW PAT run enable. Transition from 0 to 1 start PAT loop. en tia l 1 ABM loop state 0: pattern is in stop state 1: pattern in running PATT0:PAT Pattern Time 0 (Address 82h) Bit Symbol R/W Description T0 RW 0000: 0.00s 0001: 0.13s 0010: 0.26s 0011: 0.38s 0100: 0.51s 0101: 0.77s 0110: 1.04s 0111: 1.60s 1000: 2.10s 1001: 2.60s 1010: 3.10s 1011: 4.20s 1101: 6.20s 1110: 7.30s 1111: 8.30s 0001: 0.13s 0010: 0.26s 0011: 0.38s 1100: 5.20s 0 Default on 7:4 fid Pattern rise time 0 0000 Pattern on time 3:0 T1 RW cC 0000: 0.00s 0100: 0.51s 0101: 0.77s 0110: 1.04s 0111: 1.60s 1000: 2.10s 1001: 2.60s 1010: 3.10s 1011: 4.20s 1100: 5.20s 1101: 6.20s 1110: 7.30s 1111: 8.30s 0000 Bit aw ini PATT1:PAT Pattern Time 1 (Address 83h) Symbol R/W Description Default Pattern fall time 7:4 T2 RW 0000: 0.00s 0001: 0.13s 0010: 0.26s 0011: 0.38s 0100: 0.51s 0101: 0.77s 0110: 1.04s 0111: 1.60s 1000: 2.10s 1001: 2.60s 1010: 3.10s 1011: 4.20s 1100: 5.20s 1101: 6.20s 1110: 7.30s 1111: 8.30s 0000: 0.00s 0001: 0.13s 0010: 0.26s 0011: 0.38s 0100: 0.51s 0101: 0.77s 0110: 1.04s 0111: 1.60s 1000: 2.10s 1001: 2.60s 1010: 3.10s 1011: 4.20s 1100: 5.20s 1101: 6.20s 1110: 7.30s 1111: 8.30s 0000 Pattern off time 3:0 T3 www.awinic.com RW 27 0000 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 PATT2 :Pattern Time 2 (Address 84h) 7:6 Symbol LE R/W Description RW Loop stop point 00: stop at the start of T3 Others: stop at the start of T1 LB RW 3:0 RPT[11:8] RW Loop repeat times 4 MSB Symbol R/W 7:0 RPT[7:0] RW - tia Description Loop repeat times 8 LSB. If RPT[11:0] is all zero, PAT loop will repeat forever . on Bit fid PATT3: Pattern Time 3 (Address 85h) 00 l 5:4 Loop start point 00: T0 01: T1 10: T2 11: T3 Default en Bit 00 0000 Default 00h GBRH/GBRL: Group Brightness Register (Address 86h/87h) R/W 7:0 GBRH RW 7:0 GBRL RW Description Default When PATCFG.PATE=1, it is the max fade level of ABM; When PATCFG.PATE=0, it is the high 4bit of group brightness. 00h When PATCFG.PATE=1, it is the min fade level of ABM; When PATCFG.PATE=0, it is the low 8 bit of group brightness. 00h cC Symbol aw ini Bit GSLR/GSLG/GSLB: Group SL Register (Address 88h/89h/8Ah) Bit Symbol R/W Description Default 7:0 GSLR RW When LEDx (x=1, 4, 7, …) works in group mode, its SL scaling is decided by GSLR. 00h 7:0 GSLG RW When LEDx (x=2, 5, 8, …) works in group mode, its SL scaling is decided by GSLG. 00h 7:0 GSLB RW When LEDx (x=3, 6, 9, …) works in group mode, its SL scaling is decided by GSLB. 00h www.awinic.com 28 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 GCFG: Group Configure Register (Address 8Bh) Bit Symbol R/W Description Default 7 reserved RW - 0 RW Group SL disable: 0: Group SL enable, all LEDs in group/pattern mode share the common SL parameters decided by GSLR/G/B. 1: Group SL disable, all LEDs’ color parameter in group/pattern mode is configured by their respective register SL 0 GSLDIS tia l 6 5:0 GEx RW fid en Group mode enable If bit PATEN inregister PATCFG is set to “0”, GE[0]=1: LED1~3 work in group mode GE[1]=1: LED4~6 work in group mode GE[2]=1: LED7~9 work in group mode GE[3]=1: LED10~12 work in group mode GE[4]=1: LED13~15 work in group mode GE[5]=1: LED16~18 work in group mode 000000 aw ini cC on If bit PATEN inregister PATCFG is set to “1”, GE[0]=1: LED1~3 work in auto breath pattern mode GE[1]=1: LED4~6 work in auto breath pattern mode GE[2]=1: LED7~9 work in auto breath pattern mode GE[3]=1: LED10~12 work in auto breath pattern mode GE[4]=1: LED13~15 work in auto breath pattern mode GE[5]=1: LED16~18 work in auto breath pattern mode www.awinic.com 29 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Application Information REXT The selection of REXT determined the maximum LED1~LED18 current Imax as described in below formula. K Where K = 160V, the recommended minimum value of REXT is 2KΩ. aw ini cC on fid en When REXT = 4KΩ, Imax = 40mA l R EXT tia I max = www.awinic.com 30 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 PCB Layout Consideration AW21018 is an 18-channel multi-function LED driver programmed via I2C compatible interface. When all LEDs are operating, the device power dissipation is large. To obtain the good thermal performance and avoid thermal shutdown, PCB layout should be considered carefully. Here are some guidelines: 1. The C1、C2 should be placed as close to the chip as possible. l 2. The REXT should be placed as close to the chip as possible. en tia 3. The Thermal PAD must be well connecting to the GND of the PCB, and add as many thermal vias as possible beneath the thermal PAD on the PCB for the heat conductivity of the device and PCB. C1 C2 on AD0 AD1 VDD SDA SCL EN ISET NC NC LED1 LED2 NC LED3 NC GND NC cC LED4 LED5 LED6 LED7 NC NC LED18 LED17 Top Layer LED16 LED15 LED14 LED13 LED12 LED11 LED10 LED9 aw ini LED8 www.awinic.com fid REXT GND Layer Via to GND 31 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Tape And Reel Information TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 l K0 tia W D1 A0 en Cavity B0 fid A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D1:Reel Diameter D0:Reel Width D0 on QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Pin 1 Q2 Q1 Q1 Q2 Q2 Q1 cC Q1 Q3 Q4 Q3 Q4 Q3 Q4 Q3 Sprocket Holes Q2 Q4 User Direction of Feed Pocket Quadrants Note:The above picture is for reference only. Please refer to the value in the table below for the actual size DIMENSIONS AND PIN1 ORIENTATION D0 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) 330 12.4 4.3 4.3 1.1 2 8 4 aw ini D1 (mm) W Pin1 Quadrant (mm) 12 Q1 All dimensions are nominal www.awinic.com 32 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Package Description PIN1 CORNER tia l 4.00±0.10 fid TOP VIEW en 4.00±0.10 0.20 REF on 0.85±0.05 0.00~0.05 cC SIDE VIEW 2.80 T YP 9 16 0.40 T YP 8 SYMM ℄ aw ini 2.90±0.10 17 32x(0.20±0.05) 0.30 REF www.awinic.com 32x(0.30±0.05) 1 24 32 25 0.30 REF SYMM ℄ 2.90±0.10 BOTTOM VIEW Unit:mm 33 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Land Pattern Data 3.00 REF 32 X 0.25 REF 1 en tia 24 l 25 32 fid 2.90 REF on 8 9 SYMM ℄ 3.00 REF 17 16 SYMM cC ℄ 32X 0.20 TYP 32X 0.40 TYP 0.40 TYP aw ini 2.90 REF 0.05 MAX All AROUND 0.05 MIN All AROUND SOLDER MASK OPENING METAL METAL UNDER SOLDER MASK SOLDER MASK DEFINED NON SOLDER MASK DEFINED www.awinic.com SOLDER MASK OPENING Unit:mm 34 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Revision History Date Change Record V1.0 Oct 2020 Officially released V1.1 Feb 2022 Modified EC table aw ini cC on fid en tia l Version www.awinic.com 35 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com AW21018 Feb. 2022 V1.1 Disclaimer All trademarks are the property of their respective owners. Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. tia l AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. en AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. fid Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. on All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. cC Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. aw ini Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com 36 Copyright © 2020 SHANGHAI AWINIC TECHNOLOGY CO., LTD Downloaded From Oneyac.com 单击下面可查看定价,库存,交付和生命周期等信息 >>AWINIC(艾为) Downloaded From Oneyac.com
AW21018QNR 价格&库存
很抱歉,暂时无法提供与“AW21018QNR”相匹配的价格&库存,您可以联系我们找货
