BV-SMBT-20CA
Order Code: BV-SMBT-20CA
Version: A3 2021-03-12
Transient Voltage Suppressor
Features
Exterior
IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact)
Small size: SMB-T
Surge rating 1KA@8/20us
Bi-directional
Moisture sensitivity level: Level 1
Application Information
rmation
Agency Approvals
DC12V
Icon
Description
Compliance with 2011/65/EU
Compliance withIEC61249-2-21:2003
1309
Part Number and Electrical Parameter
VBR①@IR
IDRM@VDRM
μA
Part Number
V
MAX
1
BV-SMBT-20CA
V
Vc@Ipp②
mA
MIN
V
CO○4
A
PF
MIN
MAX
1000
2500
A
MAX
1
Ipp③
24.5
1
Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted).
① VBR is measured at IR=1Ma (PIN1or3 to 2)
② Surge Waveform: 10/1000μS (PIN1and3 to 2)
③ Surge Waveform: 8/20μS (PIN1and3 to 2)
4 Off-state capacitance is measured in VDC=0V, VRMS=1V, f=1MHz (PIN1and3 to 2)
Part Numbering System
Mark
BV
SMBT
C
A
(1)
(2)
(3)
(4)
(5)
2
(1) Bencent TVS
(2) Package: SMB-T
B20CT
1
1503
3
(3) VDRM=20V
(4) Bidirectional polar
B20CT: Part Number
(5) Suffix ‘A’ denotes 5% tolerance devices
1503: March, 2015
1/4
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
BV-SMBT-20CA
V-I Curve
Parameters
Definition
VC
Clamping voltage
Ipp
Surge waveform 10/1000μs
VDRM
Stand-off Voltage
VBR
Breakdown Voltage
IDRM
Reverse Leakage Current
IR
Test current
Ppp
Peak Pulse Power Dissipation
IPP
VC VBR VDRM
IR
IDRM
IDRM
IR
VDRM VBR VC
V
IPP
Thermal Considerations
symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature Range
-55 to +150
TS
Storage Temperature Range
-55 to +150
Environmental Characteristics
Testing Items
Technical Standards
High Temperature Reverse Bias Test
Temperature: 150±3℃, Bias=80%VDRM
Time: 168H
High Temperature Life Test
Temperature: 150℃
Time: 168H
High-low Temperature Cycle Test
Temperature: From -40℃ to125℃
Dwell time: 30min, 10-100 cycles
High Temperature &High Humidity Test
Temperature: 85℃ Humidity: 85%
Test time: 168H
Pressure Cooker Test
Temperature: 121℃, 2atm. Humidity: 100%
Test time: 24H to 168H
Resistance of Soldering Heat
Temperature: 260±5℃
Time of dip soldering: 10s, 3times
Note: The above testing items can be specified by customers by contacting Bencent service
2/4
www.bencent.com.cn
BV-SMBT-20CA
Product Dimensions
Bottom view
Side view
REF
mm
inch
A
5.4±0.15
0.213±0.006
B
3.3±0.3
0.130±0.012
C
0.7±0.03
0.028±0.001
D
2.0±0.2
0.079±0.008
E
0.9±0.2
0.035±0.008
F
0.9±0.3
0.035±0.012
G
0.9±0.3
0.035±0.012
H
2±0.3
0.079±0.012
I
0.25±0.05
0.010±0.002
J
4.4±0.2
0.173±0.008
Recommended Soldering Pad
3/4
www.bencent.com.cn
REF
mm
inch
A
3.35
0.132
B
2.3
0.091
C
1.2
0.047
D
1.15
0.045
E
1
0.039
F
0.6
0.024
BV-SMBT-20CA
Reflow Profile
Reflow Condition
Temperature Min.
+150°C
Temperature Max.
+200°C
Time (Min to Max)
60 – 180 secs.
Average ramp up rate (Liquidus Temp
(TL) to peak)
TS(max) to TL - Ramp-up Rate
- Temperature (TL)
Reflow
(Liquidus)
- Temperature (TL)
Peak Temp (TP)
TP
TP
3°C/sec. Max.
3°C/sec. Max.
+217°C
60 – 150 secs.
TL
TS(max)
Ramp-down
Preheat
TS(min)
TS
+(260+0/-5 )°C
Time within 5°C of actual Peak Temp
(TP)
Critical Zone
TL to TP
Ramp-up
TL
Temperature
Pre Heat
Pb-Free Assembly
TL
20 – 40 secs.
Ramp-down Rate
6°C/sec. Max.
Time 25°C to peak Temp (TP)
8 min. Max.
Do not exceed
+260°C
25
Time
time to peak temperature
Package Reel Information
REF
mm
inch
A
3.65+/-0.3
0.144+/-0.012
B
5.69+/-0.1
0.244+/-0.004
d
1.5+/-0.1
0.059+/-0.004
D
type330.0
type13.0
D1
100+/-3
3.937+/-0.118
D2
13+/-0.3
0.512+/-0.012
E
1.5+/-0.2
0.059+/-0.008
F
5.65+/-0.2
0.222+/-0.008
P
8.0+/-0.2
0.315+/-0.008
P0
4.0+/-0.2
0.157+/-0.008
P1
2.0+/-0.2
0.079+/-0.008
W
12.0+/-0.2
0.472+/-0.008
W1
16.8+/-2.0
0.661+/-0.079
OUTLINE
REEL
(PCS)
PER CARTON
(PCS)
REEL
DIAMETERS
(mm)
L
W
H
TAPING
3,000
48,000
330
360
360
385
4/4
www.bencent.com.cn
CARTON SIZE(mm)
很抱歉,暂时无法提供与“BV-SMBT-20CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.51800
- 100+1.16600
- 750+0.97350
- 1500+0.88330
- 3000+0.82060
