KM400M221SI235*30TA-1A3ET
    BERYL(绿宝石)
    AEC-D35X30MM_TM
    220UF ±20% 400V
KM400M221SI235*30TA-1A3ET 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS KM Series Features Applications ● Snap-in,general purpose ● Professional power supply ● Frequency converters ● Endurance with ripple current:105℃ 2000 hours ● Inverter ● Medical power supply ● High ripple current capability ● UPS ● And others ● Safety vent designed on aluminum case ● Air conditioner,generalpurpose inverter ● RoHS2.0 Compliant ● Professional arena power amplifier ◆ 规格表 Specifications 参数特性 Characteristics 项目Items 使用温度范围 Category Temperture Range 额定工作电压范围 Rated Voltage Range 电容量允许偏差 Capacitance Tolerance 漏电流 Leakage Current 损耗角正切值tanδ Dissipation Factor -40 ~ +105℃(6.3 ~ 100V.DC) -25 ~ +105℃(160 ~ 500V.DC) 6.3 ~ 500V.DC ±20%(M) (at 20℃,120Hz) I≤0.02CV (0.03CV for L=20mm) or 3mA , 二者取最小值(施加额定工作电压5分钟后) Whichever is smaller (After 5 minutes application of rated voltage ) Note: I=Max.leakage current (μA), C=Nominal capacitance(μF), V=Rated voltage(V) (at 20℃) 6.3 10 16 25 35 50 63 80 100 160 ~ 250 315 ~ 400 450 500 Rated voltage(V) 0.60 0.50 0.40 0.30 0.25 0.20 0.15 0.15 0.15 0.15 0.20 0.20 0.24 tanδ (Max.) 标称容量超过1000μF,则每增加1000μF,损耗角正切值增加0.02 When nominal capacitance exceeds 1000μF,add 0.02 to the value above for each 1000μF increase. 低温特性 LOW Temperature Characteristics (Max.Impedance Ratio) (at 20℃,120Hz) 阻抗比值不得超过下表中列出的值 The impedance ratio shall not exceed the values listed in the below table. Rated volage(V) (at 120Hz) 315 ~ 400 4 450 500 2 160 ~ 250 4 8 10 5 ─ ─ ─ ─ 6.3 10 16 25 35 50 63 80 100 Z(-25℃)/Z(+20℃) 4 4 4 3 3 2 2 2 Z(-40℃)/Z(+20℃) 15 15 15 10 8 6 6 5 在105℃环境中,不超过额定电压的范围内叠加最大允许纹波电流,连续2000小时,经恢复到20℃后,电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored to 20℃ after applied within maximum allowable ripple current and not over rated voltage range for 2000 hours at 105℃. 耐久性 Endurance Capacitance change≦±20% of the initial value ≦200% of the initial specified value D.F.(tanδ) ≦The initial specified value Leakage current 在105℃环境中,不施加电压条件下储存1000小时,经恢复到20℃后,电容器满足以下各项要求。 The following specifications shall be satisfied when the capacitors are restored at 20℃ after exposing them for 1000 hours at 105℃ without voltage applied. 高温储存特性 Shelf Life Capacitance change≦±20% of the initial value ≦150% of the initial specified value D.F.(tanδ) ≦200% of the initial specified value Leakage current ΦD+1max Negative mark Vent ● Sleeve PC board pin-out 2-Φ2 L±2.5 Terminal Type:P (Φ35) Negative mark Vent 6.0±0.5 5±0.5 L±2.5 4.5±1 Terminal Type:L (Φ22×30 ~ 50L) Sleeve ΦD+1max. Negative mark Vent 1.5±0.2 PC board pin-out 2 - Φ2 0.8±0.1 L±2.5 1.5±0.1 3±1 10±1 10±1 -78- PC board pin-out 2-1.2X6 ΦD+1max Sleeve ● 4.2±0.5 ◆ 尺寸图(单位:mm)DIMENSIONS (Unit:mm) ●Standard Terminal Type:S (Φ22 ~ Φ35) 14.2±1 LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS KM Series ◆ 纹波电流补正系数 Rated Ripple Current Coefficient ● 频率系数 Frequency Coefficient Frequency(Hz) 6.3 ~ 50V 63 ~ 100V 160 ~ 250 V 315 ~ 450 V 50 0.95 0.92 0.81 0.77 120 1 1 1 1 300 1.03 1.07 1.17 1.16 1k 1.05 1.13 1.32 1.3 10k 1.08 1.19 1.45 1.41 50k 1.08 1.2 1.5 1.43 ◆ 标准品一览表Standard Ratings WV(V) Cap.(μF) 6.3(0J) 10(1A) 16(1C) 22×25 1.57 22×30 1.97 22×35 2.22 22×40 2.55 22×45 2.87 6,800 10,000 12,000 15,000 18,000 22,000 27,000 33,000 22×25 1.54 22×25 1.72 22×30 1.95 22×35 2.23 22×40 2.54 22×45 2.88 39,000 47,000 25×25 1.96 25×30 2.25 25×35 2.57 25×40 2.93 25×40 3.18 25×50 3.69 56,000 68,000 30×25 2.28 30×25 2.52 30×30 2.89 30×35 3.26 30×40 3.69 30×45 4.16 30×50 4.71 82,000 WV(V) Cap.(μF) 35×25 2.93 35×30 3.40 35×30 3.73 35×35 4.12 35×40 4.69 35×45 5.32 22×25 1.55 22×30 1.77 22×30 1.97 22×35 2.21 22×40 2.51 22×50 2.93 25(1E) 25×25 1.96 25×30 2.23 25×35 2.54 25×40 2.90 25×45 3.30 25×50 3.68 30×25 2.40 30×30 2.87 30×35 3.28 30×40 3.69 30×45 4.17 30×50 4.68 35×25 2.73 35×30 3.16 35×30 3.43 35×35 3.76 35×40 4.67 35×50 5.46 35(1V) 2,700 3,900 4,700 5,600 6,800 8,200 10,000 22×25 1.50 22×25 1.63 22×30 1.86 22×35 2.11 22×40 2.39 22×45 2.69 25×25 1.87 25×30 2.12 25×35 2.42 25×40 2.74 25×45 3.15 25×50 3.54 30×25 2.15 30×25 2.37 30×30 2.70 30×35 3.13 30×40 3.54 30×45 4.04 22×25 1.40 22×30 1.57 22×30 1.72 22×35 1.95 22×40 2.20 22×50 2.55 25×25 1.80 25×30 1.96 25×35 2.23 25×40 2.53 25×45 2.87 25×50 3.24 30×25 1.99 30×25 2.19 30×30 2.75 30×35 2.90 30×40 3.23 30×45 3.72 30×25 2.45 30×25 2.52 30×30 2.88 30×35 3.29 30×40 3.77 30×45 4.30 30×50 4.81 35×25 2.92 35×25 3.23 35×30 3.45 35×35 4.26 35×40 4.79 35×45 5.43 50(1H) 22×25 1.33 22×30 1.69 22×35 1.93 22×40 2.16 22×45 2.43 22×50 2.75 1,800 3,300 25×25 1.97 25×30 2.24 25×35 2.58 25×40 2.92 25×45 3.32 25×50 3.78 35×25 2.75 35×30 2.91 35×30 2.99 35×35 3.67 35×40 4.37 35×50 4.92 25×25 1.70 25×30 1.85 25×35 2.18 25×35 2.39 25×40 2.70 25×50 3.30 30×25 1.95 30×30 2.25 30×35 2.76 30×40 3.30 30×45 3.60 30×50 4.04 35×25 2.48 35×25 2.70 35×30 3.25 35×35 3.55 35×40 4.03 35×45 4.55 35×25 2.74 35×30 15,000 3.27 35×30 18,000 3.58 35×35 22,000 3.64 35×45 Case size:ΦD×L(mm) 27,000 4.73 外壳尺寸:直径X长度(毫米) 35×50 Maximum allowable ripple current at 105℃/120Hz(A.r.m.s) 33,000 在105℃/120Hz下的最大允许纹波电流(有效值,单位:安) 5.39 ※铝电解电容器由于在纹波电流叠加时自我发热、温度上升而老化,中心温度每升温5℃寿命减少一半。要想保持长寿命请在使用过程中降低纹波电流。 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.When long life performance is required in actual use,the rms ripple current has to be reduced. 12,000 -79- LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS KM Series ◆ 标准品一览表Standard Ratings WV(V) Cap.(μF) 63(1J) 80(1K) 100(2A) 22×25 1.05 22×30 1.32 22×35 1.50 22×40 1.69 22×45 1.94 560 22×25 1.11 22×25 1.22 22×30 1.38 22×35 1.59 22×40 1.80 22×45 2.04 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 22×25 1.19 22×25 1.33 22×30 1.51 22×35 1.73 22×40 1.97 22×50 2.29 3,900 4,700 25×25 1.52 25×30 1.74 25×35 1.99 25×40 2.27 25×45 2.54 25×50 2.86 5,600 6,800 22X25 1.50 30×25 1.76 30×30 2.24 30×35 2.55 30×40 2.86 30×45 3.22 30×50 3.65 8,200 10,000 WV(V) Cap.(μF) 35×25 2.06 35×25 2.24 35×30 2.79 35×35 3.19 35×40 3.64 35×45 3.90 35×50 4.40 160(2C) 25×25 1.39 25×30 1.61 25×30 1.76 25×35 2.01 25×45 2.36 25×50 2.68 30×25 1.65 30×30 2.05 30×35 2.35 30×40 2.68 30×45 3.00 30×50 3.39 35×25 2.07 35×25 2.29 35×30 2.45 35×35 2.98 35×40 3.38 35×45 3.80 35×50 3.90 180( 2Z) 35×20 1.54 35×20 1.70 35×25 1.91 35×25 2.11 35×30 2.44 35×35 2.50 35×45 3.31 35×50 22×20 0.73 22×20 0.80 22×25 0.96 22×25 1.06 22×30 1.30 22×35 1.35 22×40 1.51 22×45 1.71 22×50 1.97 25×50 2.23 30×45 2.52 30×50 2.89 35×40 3.17 35×50 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 22×20 0.8 22×25 1.09 22×25 1.20 22×30 1.30 22×35 1.40 22×40 1.50 22×45 1.71 22×50 1.93 25×20 1.02 25×25 1.28 25×25 1.41 25×30 1.51 25×35 1.70 25×40 2.01 25×45 2.20 25×50 2.45 30×20 1.17 30×20 1.28 30×25 1.56 30×25 1.72 30×30 2.00 30×35 2.22 30×40 2.44 30×45 2.82 30×50 3.31 3.77 3.60 25×20 0.92 25×25 1.20 25×25 1.30 25×30 1.40 25×35 1.53 25×40 1.74 25×45 1.97 30×40 2.24 35×35 2.50 35×40 2.89 30×25 1.68 30×30 1.95 30×35 2.50 30×40 2.70 30×45 2.88 30×50 3.28 35×25 1.98 35×25 2.17 35×30 2.50 35×35 2.86 35×40 3.27 35×45 3.67 35×50 3.80 200(2D) 150 180 25×25 1.33 25×30 1.51 25×35 1.71 25×40 1.98 25×45 2.23 25×50 2.53 30×20 1.17 30×25 1.38 30×25 1.51 30×30 1.72 30×35 2.00 35×30 2.26 35×20 1.41 35×20 1.53 35×25 1.74 35×25 1.91 22×20 0.66 22×20 0.72 22×25 0.79 22×25 0.87 22×30 1.20 22×35 1.31 22×40 1.40 22×45 1.56 22×50 1.74 25×20 0.83 25×25 1.09 25×25 1.21 25×25 1.31 25×30 1.41 25×35 1.53 25×40 1.74 25×50 2.04 30×20 1.08 30×25 1.37 30×25 1.50 30×25 1.63 30×30 1.74 30×35 2.00 30×45 2.30 30×50 2.60 35×20 1.41 35×25 1.56 35×25 1.72 35×30 2.04 35×35 2.30 35×40 2.65 35×45 3.08 35×50 3.47 Case size: ΦD×L(mm) Maximum allowable ripple current at 105℃/120Hz(A.r.m.s) ※铝电解电容器由于在纹波电流叠加时自我发热 、温度上升而老化,中心温度每升温5℃寿命减少一半。要想保持长寿命请在使用过程中降低纹波电流 。 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.When long life performance is required in actual use,the rms ripple current has to be reduced. -80- LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS KM Series ◆ 标准品一览表Standard Ratings WV(V) 250(2E) Cap.(μF) 315(2F) 350(2V) 56 68 82 100 120 150 180 220 270 330 390 470 560 22×20 0.59 22×25 0.71 22×25 0.78 22×30 0.95 22×35 1.14 22×40 1.26 22×45 1.49 22×50 1.57 25×45 1.79 680 25×20 0.75 25×25 0.95 25×25 1.05 25×30 1.20 25×35 1.49 25×40 1.57 30×35 1.79 25×50 1.84 820 30×20 0.88 30×20 0.97 30×25 1.26 30×25 1.37 30×30 1.57 35×25 1.62 30×40 2.00 30×45 2.16 1,000 1,200 2.43 WV(V) 56 68 82 100 120 25×20 0.56 25×25 0.76 25×30 0.80 25×30 0.88 25×35 1.02 25×40 1.15 25×50 1.33 22×20 0.37 22×20 0.4 22×25 0.51 22×30 0.58 22×30 0.64 22×35 0.72 22×40 0.82 22×50 0.95 25×20 0.46 25×25 0.64 25×25 0.67 25×30 0.72 25×35 0.84 25×40 0.94 25×45 1.07 25×50 1.21 25×45 1.08 30×20 0.59 30×25 0.76 30×25 0.84 30×30 0.92 30×35 1.06 30×40 1.21 30×45 1.39 30×50 1.55 30×20 0.65 30×25 0.82 30×25 0.90 30×30 1.02 30×35 1.17 30×35 1.30 30×40 1.46 30×50 1.70 35×20 0.83 35×25 1.03 35×25 1.15 35×30 1.32 35×35 1.47 35×40 1.69 35×45 1.90 35×50 2.15 25×20 0.51 25×25 0.69 25×25 0.75 25×30 0.83 25×35 0.92 25×40 1.04 25×45 1.18 30×20 0.59 30×20 0.64 30×25 0.83 30×25 0.91 30×30 1.02 30×35 1.17 30×40 1.34 30×45 1.51 35×20 0.76 35×25 0.94 35×25 1.04 35×30 1.20 35×30 1.33 35×35 1.47 35×40 1.69 35×45 1.90 Case size:ΦD×L(mm) 外壳尺寸:直径X长度(毫米) Maximum allowable ripple current at 105℃/120Hz(A.r.m.s) 在105℃/120Hz下的最大纹波电流(有效值,单位:安) 400(2G) Cap.(μF) 47 35×20 1.18 35×25 1.43 35×25 1.57 35×30 1.79 35×30 1.97 35×35 1.98 35×40 2.30 35×45 22×20 0.44 22×25 0.64 22×30 0.68 22×30 0.75 22×35 0.82 22×40 0.91 22×45 1.02 22×50 1.16 22×20 0.4 22×25 0.51 22×25 0.56 22×30 0.69 22×35 0.75 22×40 0.82 22×45 0.92 22×50 1.05 450(2W) 22×25 0.4 22×30 0.5 22×35 0.56 22×40 0.64 22×45 0.72 22×50 0.79 25×25 0.5 25×25 0.55 25×30 0.57 25×35 0.71 25×40 0.75 25×45 0.84 25×50 0.98 30×25 0.64 30×25 0.70 30×30 0.74 30×35 0.87 30×40 0.98 30×45 1.15 30×50 1.38 500(2H) 30×25 0.50 35×20 35×25 22×50 30×30 0.76 0.75 0.66 0.64 35×25 35×30 180 0.94 0.90 35×30 35×30 220 1.08 1.00 35×30 35×35 270 1.20 1.17 35×35 35×40 330 1.35 1.38 35×40 35×45 390 1.54 1.55 35×45 35×50 470 1.74 1.72 35X35 560 1.42 35X50 35X60 680 1.78 1.85 35X70 1,000 2.3 ※铝电解电容器由于在纹波电流叠加时自我发热、温度上升而老化,中心温度每升温5℃寿命减少一半。要想保持长寿命请在使用过程中降低纹波电流。 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.When long life performance is required in actual use,the rms ripple current has to be reduced. 150 -81-
KM400M221SI235*30TA-1A3ET 价格&库存
很抱歉,暂时无法提供与“KM400M221SI235*30TA-1A3ET”相匹配的价格&库存,您可以联系我们找货
