SS8550
SS8550
    FUXINSEMI(富芯森美)
    SOT-23
    PNP 电流:1.5A 电压:25V
SS8550 数据手册
FEATURES  High Collector Current  Complementary to SS8050 SOT-23 MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage -40 V VCEO Collector-Emitter Voltage -25 V VEBO Emitter-Base Voltage -5 V IC Collector Current -1.5 A PC Collector Power Dissipation 300 mW Thermal Resistance From Junction To Ambient 417 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test conditions Min Typ Max Unit Collector-base breakdown voltage V(BR)CBO IC=-100µA, IE=0 -40 V Collector-emitter breakdown voltage V(BR)CEO IC=-0.1mA, IB=0 -25 V Emitter-base breakdown voltage V(BR)EBO IE=-100µA, IC=0 -5 V Collector cut-off current ICBO VCB=-40V, IE=0 -100 nA Collector cut-off current ICEO VCE=-20V, IB=0 -100 nA Emitter cut-off current IEBO VEB=-5V, IC=0 -100 nA hFE(1) VCE=-1V, IC=-100mA 120 hFE(2) VCE=-1V, IC=-800mA 40 DC current gain 400 Collector-emitter saturation voltage VCE(sat) IC=-800mA, IB=-80mA -0.5 V Base-emitter saturation voltage VBE(sat) IC=-800mA, IB=-80mA -1.2 V -1 V Base-emitter voltage VBE Transition frequency fT Collector output capacitance Cob VCE=-1V, IC=-10mA VCE=-10V,IC=-50mA , f=30MHz VCB=-10V, IE=0, f=1MHz 100 MHz 20 pF CLASSIFICATION OF hFE(1) RANK L H J RANGE 120–200 200–350 300–400 MARKING www.fuxinsemi.com Y2 Page 1 Ver2.1 hFE Static Characteristic 500 -180 —— IC 1mA Ta=100℃ 0.9mA 0.8mA -120 0.7mA -100 0.6mA hFE -140 DC CURRENT GAIN COLLECTOR CURRENT IC (mA) -160 0.5mA -80 0.4mA -60 0.3mA -40 0.2mA -20 IB=0.1mA -0 -0.0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -3.5 COLLECTOR-EMITTER VOLTAGE VBEsat —— -4.0 VCE -4.5 VCE=-1V 10 -0.1 -5.0 -1 (V) -10 IC VCEsat -1000 COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (mV) -900 -800 Ta=25℃ -700 -600 Ta=100℃ -500 -100 COLLECTOR CURRENT -1000 BASE-EMITTER SATURATION VOLTAGE VBEsat (mV) Ta=25℃ 100 -400 -300 IC -1000 (mA) IC —— -100 Ta=100℃ Ta=25℃ -10 β=10 -200 -0.1 -1 -10 -100 COLLECTOR CURRENT VBE —— IC β=10 -1 0.2 -1000 -1 -10 -100 COLLECTOR CURRENT (mA) IC Cob/ Cib -1000 IC —— VCB/ VEB 100 f=1MHz IE=0/ IC=0 (pF) -100 o Ta=25 C Cob C o Ta=100 C Ta=25℃ CAPACITANCE IC (mA) Cib COLLCETOR CURRENT -1000 (mA) -10 -1 VCE=-1V -0.1 -200 -300 -400 -500 -600 -700 BASE-EMMITER VOLTAGE fT -900 —— IC Pc COLLECTOR POWER DISSIPATION Pc (mW) VCE-10V o Ta=25 C 10 -10 COLLECTOR CURRENT www.fuxinsemi.com -10 —— V 20 (V) Ta 350 100 -1 -1 REVERSE VOLTAGE fT TRANSITION FREQUENCY 1 -0.2 -1000 (mV) (MHz) 500 VBE -800 -100 IC 300 250 200 150 100 50 0 0 (mA) 25 50 75 AMBIENT TEMPERATURE Page 2 100 Ta 125 150 (℃) Ver2.1 SOT-23 Package Information Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 0.900 1.150 0.035 0.045 A1 0.000 0.100 0.000 0.004 A2 0.900 1.050 0.035 0.041 b 0.300 0.500 0.012 0.020 c 0.080 0.150 0.003 0.006 D 2.800 3.000 0.110 0.118 E 1.200 1.400 0.047 0.055 E1 2.250 2.550 0.089 0.100 2.000 0.071 e e1 0.950 TYP. 1.800 L L1 www.fuxinsemi.com 0.037 TYP. 0.550 REF. 0.300 0.079 0.022 REF. 0.500 Page 3 0.012 0.020 Ver2.1 Pinning information Pin Simplified outline Symbol C B E Marking Type number Marking code Y2 SS8550 Suggested solder pad layout SOT-23 0.037(0.95) 0.037(0.95) 0.079(2.0) 0.035(0.90) 0.031(0.80) Dimensions in inches and (millimeters) Reel packing PACKAGE SOT-23 REEL SIZE 7" www.fuxinsemi.com REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) 3,000 4.0 30,000 183*123*183 178 Page 4 CARTON SIZE (m/m) 382*257*387 CARTON (pcs) 240,000 APPROX. GROSS WEIGHT (kg) 11.6 Ver2.1 Suggested thermal profiles for soldering processes 1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25% 2.Reflow soldering of surface-mount devices Critical Zone TL to TP Tp TP Ramp-up TL TL Tsmax Temperature Tsmin tS Preheat Ramp-down 25 o t25 C to Peak Time 3.Reflow soldering Profile Feature Soldering Condition Average ramp-up rate(T L to T P ) o
SS8550 价格&库存
很抱歉,暂时无法提供与“SS8550”相匹配的价格&库存,您可以联系我们找货
SS8550
  • 1+0.22110
  • 200+0.07392
  • 1500+0.04620
  • 3000+0.03663
库存:5998
SS8550
  • 50+0.07235
  • 500+0.05890
  • 3000+0.05141
  • 6000+0.04695
  • 24000+0.04302
  • 51000+0.04090
库存:2933
