SMBJ5.0CA-IR400/TR13 数据手册
SMBJ5.0CA-IR400
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 10V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
Mechanical Data
Case: JEDEC DO-214AA. Molded plastic over glass passivated junction
Terminal: Solder plated, solderable per MIL-STD-750, Method 2026
Standard Packaging: 12mm tape (EIA STD RS-481)
Weight: 0.10g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 600
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
5.0
Watts
TJ,TSTG
-65 to +150
Typical thermal resistance junction to lead
RθJL
℃/W
Typical thermal resistance junction to ambient
RθJA
100
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal.
Revision:01-Nov-17
www.brightking.com
SMBJ5.0CA-IR400
Dimensions (SMB/DO-214AA)
Millimeters
Symbol
Inches
Min.
Max.
Min.
Max.
L
4.06
4.57
0.160
0.180
D
3.30
3.94
0.130
0.155
D1
1.95
2.20
0.077
0.086
T
5.21
5.59
0.205
0.220
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.15
2.65
0.085
0.104
H1
2.13
2.47
0.084
0.097
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Electrical Characteristics (TA=25℃)
Part
Number
SMBJ5.0CA
Type
①
IR400
Device
Marking
Code
AE
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
5.0
6.40~7.00
10
10.2
58.8
400
Notes: ① Specific code by request.
Part Number Code and Marking
Revision:01-Nov-17
www.brightking.com
SMBJ5.0CA-IR400
Ratings and Characteristic Curves (TA=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
100
80
60
40
50
75
100
125
150
175
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
150
tr=10µs
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
50
10/1000µs Waveform
as defined by R.E.A
td
2.0
3.0
4.0
t-Time (ms)
PM(AV), Steady State Power Dissipation (W)
Figure 5. Steady State Power Dissipation Derating
Curve
Revision:01-Nov-17
www.brightking.com
SMBJ5.0CA-IR400
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:01-Nov-17
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
SMBJ5.0CA-IR400
Packaging
Tape
7” Reel
Symbol
Dimension (mm)
W
12.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
5.50±0.10
A0
3.86±0.15
B0
5.65±0.10
K0
2.75±0.15
T
0.25±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
16.0±2.0
D4
D3
D2
W1
Quantity: 500PCS
13” Reel
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 3000PCS
Revision:01-Nov-17
www.brightking.com
SMBJ5.0CA-IR400/TR13 价格&库存
很抱歉,暂时无法提供与“SMBJ5.0CA-IR400/TR13”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34977
- 100+0.28274
- 600+0.27991
- 1200+0.27431
- 3000+0.26608
- 国内价格
- 10+0.38157
- 100+0.30845
- 300+0.27184
