SFX897FYT02
SFX897FYT02
    WISOL(威盛)
SFX897FYT02 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. WISOL PART No. SFX897FYT02 DOC. No. SMS-51-L-SFT FX-212 DATE December 6, 2018 REVISION 000 WISOL Yu, Sang-Tai Ha, Sang-Ki Hong, Sang-Dea ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 531-7, Gajang-ro, Osan-si, Gyeonggi-do, KOREA, 18103 http://www.wisol.co.kr Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 ▶ A TABLE OF CONTENTS 1. REVISION HISTORY ..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 5. MARKING ...................................................................................................................................................... 6 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 7. RELIABILITY ............................................................................................................................................... 13 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 13 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 15 11-1. DIMENSIONS.................................................................................................................................. 17 11-2. REELING QUANTITY ..................................................................................................................... 18 11-3. TAPING STRUCTURE .................................................................................................................... 18 11-4. INNER BOX(Reel Packing) STRUCTURE ...................................................................................... 19 11-5. OUTER BOX STRUCTURE ............................................................................................................ 20 12. TAPE SPECIFICATIONS .......................................................................................................................... 21 13. RoHS DATA ............................................................................................................................................... 22 SMS-51-L-SFT FX-212 Page 2/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 1. REVISION HISTORY 000 December 6, 2018 SMS-51-L-SFT FX-212 All Page Make specification Page 3/28 December 6, 2018 Surface Acoustic Wave Filter SFX897FYT02 TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz 1.8×1.4×0.52mm3 8pin lay-out Version : 000 2. DEFINITION 2-1. PART No. SFX897FYT02 ① ② ③ ④ No. ⑤ ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency : Tx 897.5MHz (880 ~ 915MHz) ④ Input:50ohm,Output:50ohm ⑤ Package size: 1.8×1.4mm² ⑥ Design Revision (02 : Molding Type) 2-2. APPLICATION : LTE B8 Duplexer 2-3. SPEC ESD Level HBM=300V 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT FX-212 Page 4/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 4. OUTLINE DRAWING & DIMENSIONS D XX O X SMS-51-L-SFT FX-212 Page 5/28 No. Function 1 Rx Output 3 Tx Input 6 Antenna 2, 4, 5, 7, 8 GND December 6, 2018 Surface Acoustic Wave Filter SFX897FYT02 TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz Version : 000 1.8×1.4×0.52mm3 8pin lay-out 5. MARKING D XX O X 5-1. D XX X - The 1st - The 2nd Year character 'D' indicates the model name of SAW Filter SFX897FYT02. character 'X' indicates the year and the month of manufacture.. Month 1 2 3 4 5 6 7 8 9 10 11 12 2017 1 2 3 4 5 6 7 8 9 A B C 2018 D E F G H I J K L M N O 2019 P Q R S T U V W X Y Z a 2020 1 2 3 4 5 6 7 8 9 A B C ※ This rotates by the 3 years. - The 3rd, 4th character 'X' indicates Lot No. 5-2. ○ - This symbol indicates input pin 1. - This indicates the producing center ○ : China 5-3. Marking : Laser Marking SMS-51-L-SFT FX-212 Page 6/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 30 dBm CW, 55℃, 5000hr Operating Temperature Range -20 ~ +85 ℃ ℃ Storage Temperature Range -40 ~ +85 ℃ ℃ SMS-51-L-SFT FX-212 Page 7/28 NOTES December 6, 2018 Surface Acoustic Wave Filter SFX897FYT02 TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz Version : 000 1.8×1.4×0.52mm3 8pin lay-out 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -20 ~ +85℃ *1. PCB loss is de-embedded. CONDITION Item RATING UNIT Note [MHz] Min. Typ.(25℃) Max. TX  ANTENNA Insertion Loss(*1) Inband Ripple 880 ~ 915 dB 2.0 2.7 Over Temp 880 ~ 915 dB 2.0 2.5 +23 to +27℃ 882.5 ~ 912.5 dBINT 1.7 2.5 Any 4.5MHz 880 ~ 915 dB 1.0 2.5 880 ~ 915 - 1.8 2.2 880 ~ 915 - 1.8 2.2 10 ~ 716 dB 25 30 925 ~ 960 dB 33 50 Over. Temp. Rx 925 ~ 960 dB 40 50 +23 to +27℃, Rx 1559 ~ 1563 dB 35 43 1565 ~ 1573 dB 35 43 1573 ~ 1577 dB 35 43 1760 ~ 1840 dB 40 49 2110 ~ 2170 dB 40 45 2400 ~ 2500 dB 40 44 2620 ~ 2745 dB 39 44 VSWR Absolute Attenuation 50Ω(+ 10[nH]) / 50Ω(// 9.1[nH]) Termination Impedance : Tx / ANT ANTENNA  RX Insertion Loss(*1) Inband Ripple 925 ~ 960 dB 2.4 3.6 Over Temp 925 ~ 960 dB 2.4 2.7 +23 to +27℃ 927.5 ~ 957.5 dBINT 1.9 2.7 Any 4.5MHz 925 ~ 960 dB 1.1 2.5 925 ~ 960 - 1.8 2.5 925 ~ 960 - 1.8 2.5 10 ~ 880 dB 50 56 880 ~ 915 dB 45 56 Over Temp. Tx 880 ~ 915 dB 50 56 +23 to +27℃, Tx 1805 ~ 1920 dB 50 63 1920 ~ 1980 dB 40 45 2400 ~ 2500 dB 40 50 2500 ~ 2570 dB 40 45 VSWR Absolute Attenuation Termination Impedance : ANT / Rx SMS-51-L-SFT FX-212 50Ω(// 9.1[nH]) / 50Ω(// 70[nH]) Page 8/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 TX → RX Isolation between Rx and Tx 882.5 ~ 912.5 dBINT 55 58 Any 4.5MHz, Tx 927.5 ~ 957.5 dBINT 50 58 Any 4.5MHz, Rx 6-2-2. TEST FIXTURE SMS-51-L-SFT FX-212 Page 9/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 6-2-3. GRAPH SMS-51-L-SFT FX-212 Page 10/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 11/28 Version : 000 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 12/28 Version : 000 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (MSL 2a) (JESD22-A113) (n=177) ESD(HBM) (n=9) Board Level Drop (n=11) (n=23) ESD(MM) (n=9) Solder Heat (n=11) THS (n=23) ESD(CDM) (n=6) Solderability (n=11) HTS (n=23) LTS (n=23) uHAST Temp. Drift (n=5) TC (n=23) Final Electrical Data (n=115) SMS-51-L-SFT FX-212 Final Electrical Data (n=24) Page 13/28 Final Electrical Data (n=38) December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 Version : 000 1.8×1.4×0.52mm3 8pin lay-out 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning TEST CONDITION Bake + Soak(MSL or above) + 3X Reflow duration ( Soak 60℃ 60% 120HR) TEST ITEM REMARK HTS (High Temperature Storage) JESD22-A103 LTS (Low Temperature Storage) JESD22-A119 uHAST (Unbiased HAST) JESD22-A118 THS (Temperature Humidity Storage) REMARK TEST CONDITION condition A condition A Duration +125(-10/+0)℃ 1000hr -40(-10/+0)℃ 1000hr condition A 130±2℃, 96hr 85±5%, 33.3psi JESD22-A101 85±2℃, 85±5% RH 1000hr condition B (-55℃⇔ +125℃) TC (Temperature Cycle) JESD22-A104 ESD(HBM) JESD22-A114 200V, 250V, 300V ESD(MM) JESD22-A115 100V 150V 200V ESD(CDM) JESD22-C101 1.0KV, 1.2KV Board Level Drop Test JESD22-A113 - Soak mode 4 (30min) 500cycle All pin 1sec 1time All pin 1sec 1time All pin 1sec 1time 120 ㎝, 12times 152 ㎝ 19times Solder Heat Resistance JESD22-B106C 260℃ Solder Pore Dipping 10sec Solderability JESD22-B102E 235℃Solder Pore Dipping 3sec -40℃ => 25℃ => 125℃ 조건당 2HR Temp Drift SMS-51-L-SFT FX-212 Page 14/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [unit : mm] [SAW, X-ray Top view] SMS-51-L-SFT FX-212 [PCB, X-ray Top view] Page 15/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT FX-212 Page 16/28 December 6, 2018 Surface Acoustic Wave Filter SFX897FYT02 TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz Version : 000 1.8×1.4×0.52mm3 8pin lay-out 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.60 2.00 Ø1.55 Ø1.00 1.75 3.50 4.00 4.00 2.00 0.25 0.80 8.00 0.05 0.05 0.05 MIN 0.10 0.05 0.10 0.10 0.05 0.05 0.05 0.10 -0.05 -0.05 -0.05 - -0.10 -0.05 -0.10 -0.10 -0.05 -0.05 -0.05 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø258.0 +1.0 -0.5 Ø81.0 +1.0 -1.0 Ø13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT FX-212 Page 17/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 11-2. REELING QUANTITY 10 inch reel : 8,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. D O D O XX X XX X 11-3-2. BARCODE LABEL ① MODEL NAME BARCODE ② Model Name ③ Reel number ④ Quantity / Marking SMS-51-L-SFT FX-212 Page 18/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material : Polyethylene + Aluminium Size : 310×370mm2 Material Size: : Paper (D)260×(W)37×(H)265mm3 SMS-51-L-SFT FX-212 Page 19/28 December 6, 2018 EA . . Surface Acoustic Wave Filter SFX897FYT02 TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz Version : 000 1.8×1.4×0.52mm3 8pin lay-out 11-5. OUTER BOX STRUCTURE Material : Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② MODEL Q'TY EA USER DATE . . - SIDE is the same as front side. SMS-51-L-SFT FX-212 Page 20/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT FX-212 Page 21/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Version : 000 13. RoHS DATA SMS-51-L-SFT FX-212 Page 22/28 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 23/28 Version : 000 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 24/28 Version : 000 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 25/28 Version : 000 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 26/28 Version : 000 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 27/28 Version : 000 December 6, 2018 Surface Acoustic Wave Filter TC-SAW LTE B8 DPX-Tx 897.5MHz TC-SAW LTE B8 DPX-Rx 942.5MHz SMS-51-L-SFT FX-212 SFX897FYT02 1.8×1.4×0.52mm3 8pin lay-out Page 28/28 Version : 000 December 6, 2018
SFX897FYT02 价格&库存
很抱歉,暂时无法提供与“SFX897FYT02”相匹配的价格&库存,您可以联系我们找货
