PMG4318TP
PMG4318TP
    FLEX(伟创力)
    DIP10 模块
    非隔离 PoL 模块 直流转换器 1 输出 0.8 ~ 2.5V 15A 2.95V - 3.65V 输入
PMG4318TP 数据手册
EricssonInternal Limited Internal TABLE OF CONTENTS PRODUCT SPECIFICATION E Prepared (also subject responsible if other) MPM/BY/P Henrik Sundh Henrik (MPM/BY/P) Sundh Approved 1 (1) (3) No. PoL Regulators PMG 4000[Krister series seriesLundberg] MPM/BY/M Checked 1/1301 00152-EN/LZT146319 BMR 644Technical 4 Uen Specification Specifi cation Date 2006-02-22 2006-02-20 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB Key Features • • • • • • • • 15A output current 2.95-3.65V input voltage range Output voltages from 0.8V up to 2.5V Industry standard POLA™ compatible 34.8 x 15.75 x 9.00 mm (1.37 x 0.62 x 0.354 in.) High efficiency, up to. 95% Auto Track™ sequencing pin More than 4.0 million hours MTBF General Characteristics • • • • • • • • • Operating temperature: -40ºC to 85ºC Input under voltage protection Start up into a pre-biased output safe Output short-circuit protection On/Off inhibit control Margin up/down control Wide output voltage adjust function Highly automated manufacturing ensures quality ISO 9001/14001 certified supplier Safety Approvals Design for Environment Meets requirements in hightemperature lead-free soldering processes. Contents General Information Safety Specification Absolute Maximum Ratings ............................................................. 2 ............................................................. 3 ............................................................. 4 Product Program 0.8-2.5 V/15 A 1.0 V/15 A Electrical Specification 1.2 V/15 A Electrical Specification 1.5 V/15 A Electrical Specification 1.8 V/15 A Electrical Specification 2.5 V/15 A Electrical Specification Ordering No. PMG 4318T ........................................... ............................................................. 5 ............................................................. 8 ........................................................... 11 ........................................................... 14 ........................................................... 17 EMC Specification Operating Information Thermal Consideration Connections Mechanical Information Soldering Information Delivery Information Product Qualification Specification ........................................................... 20 ........................................................... 20 ........................................................... 22 ........................................................... 23 ........................................................... 24 ........................................................... 26 ........................................................... 28 ........................................................... 29 Ericsson Internal PRODUCT SPECIFICATION E Prepared (also subject responsible if other) 2 (3) No. Henrik Sundh (MPM/BY/P) Approved PoL Regulators PMG 4000[Krister series seriesLundberg] MPM/BY/M Checked 1/1301 BMR 644Technical 4 Uen Specification Specifi cation Date 2006-02-20 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 2 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB Compatibility with RoHS requirements General Information Ordering Information See Contents for individual product ordering numbers. Option Through hole pin Suffix P PMG4318TP SMD pin, leadfree reflow temperature capable SR PMG4318TSR The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. The Mean Time Between Failure (MTBF) is calculated at full output power and an operating ambient temperature (TA) of +40°C. Different methods could be used to calculate the predicted MTBF and failure rate which may give different results. Flex currently uses Telcordia SR332. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. Predicted MTBF for the series is: Quality Statement Reliability - 4.02 million hours according to Telcordia SR332, issue 1, Black box technique. Telcordia SR332 is a commonly used standard method intended for reliability calculations in IT&T equipment. The parts count procedure used in this method was originally modelled on the methods from MIL-HDBK-217F, Reliability Predictions of Electronic Equipment. It assumes that no reliability data is available on the actual units and devices for which the predictions are to be made, i.e. all predictions are based on generic reliability parameters. The products are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000, 6σ (sigma), and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out and they are subjected to an ATE-based final test. Conservative design rules, design reviews and product qualifications, plus the high competence of an engaged work force, contribute to the high quality of our products. Warranty Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. Limitation of Liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2017 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. Ericsson Internal PRODUCT SPECIFICATION E Prepared (also subject responsible if other) Henrik Sundh (MPM/BY/P) Approved PoL Regulators PMG 4000[Krister series seriesLundberg] MPM/BY/M 3 (3) No. Checked 1/1301 BMR 644Technical 4 Uen Specification Specifi cation Date Rev 2006-02-20 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Reference 3 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB Safety Specification General information Flex DC/DC converters and DC/DC regulators are designed in accordance with safety standards IEC/EN/ UL60950, Safety of Information Technology Equipment. IEC/EN/UL60950 contains requirements to prevent injury or damage due to the following hazards: • • • • • • Electrical shock Energy hazards Fire Mechanical and heat hazards Radiation hazards Chemical hazards On-board DC-DC converters are defined as component power supplies. As components they cannot fully comply with the provisions of any Safety requirements without “Conditions of Acceptability”. It is the responsibility of the installer to ensure that the final product housing these components complies with the requirements of all applicable Safety standards and Directives for the final product. Component power supplies for general use should comply with the requirements in IEC60950, EN60950 and UL60950 “Safety of information technology equipment”. There are other more product related standards, e.g. IEEE802.3af “Ethernet LAN/MAN Data terminal equipment power”, and ETS300132-2 “Power supply interface at the input to telecommunications equipment; part 2: DC”, but all of these standards are based on IEC/EN/UL60950 with regards to safety. Flex DC/DC converters and DC/DC regulators are UL60950 recognized and certified in accordance with EN60950. The flammability rating for all construction parts of the products meets requirements for V-0 class material according to IEC 60695-11-10. The products should be installed in the end-use equipment, in accordance with the requirements of the ultimate application. Normally the output of the DC/DC converter is considered as SELV (Safety Extra Low Voltage) and the input source must be isolated by minimum Double or Reinforced Insulation from the primary circuit (AC mains) in accordance with IEC/EN/UL60950. Isolated DC/DC converters It is recommended that a slow blow fuse with a rating twice the maximum input current per selected product be used at the input of each DC/DC converter. If an input filter is used in the circuit the fuse should be placed in front of the input filter. In the rare event of a component problem in the input filter or in the DC/DC converter that imposes a short circuit on the input source, this fuse will provide the following functions: • • Isolate the faulty DC/DC converter from the input power source so as not to affect the operation of other parts of the system. Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating. The galvanic isolation is verified in an electric strength test. The test voltage (Viso) between input and output is 1500 Vdc or 2250 Vdc for 60 seconds (refer to product specification). Leakage current is less than 1 μA at nominal input voltage. 24 V DC systems The input voltage to the DC/DC converter is SELV (Safety Extra Low Voltage) and the output remains SELV under normal and abnormal operating conditions. 48 and 60 V DC systems If the input voltage to Flex DC/DC converter is 75 Vdc or less, then the output remains SELV (Safety Extra Low Voltage) under normal and abnormal operating conditions. Single fault testing in the input power supply circuit should be performed with the DC/DC converter connected to demonstrate that the input voltage does not exceed 75 Vdc. If the input power source circuit is a DC power system, the source may be treated as a TNV2 circuit and testing has demonstrated compliance with SELV limits and isolation requirements equivalent to Basic Insulation in accordance with IEC/EN/UL60950. Non-isolated DC/DC regulators The input voltage to the DC/DC regulator is SELV (Safety Extra Low Voltage) and the output remains SELV under normal and abnormal operating conditions. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 1 (19) No. 2/1301-BMR 644Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved Checked PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Date Rev 2006-1-27 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W 4 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB Absolute Maximum Ratings Characteristics min Tref Operating Temperature (see Thermal Consideration section) –40 85 °C TS Storage temperature –40 125 °C 2.95 VI Input voltage Vinh Inhibit On/Off pin voltage (see Operating Information section) Vadj Adjust pin voltage (see Operating Information section) Positive logic option Negative logic option typ max 3.30 Vin-0.5 Unit 3.65 V Open V N/A N/A V N/A N/A V Stress in excess of Absolute Maximum Ratings may cause permanent damage. Absolute Maximum Ratings, sometimes referred to as no destruction limits, are normally tested with one parameter at a time exceeding the limits of Output data or Electrical Characteristics. If exposed to stress above these limits, function and performance may degrade in an unspecified manner. Fundamental Circuit Diagram 3 VIN 2 1 2 VOUT 1 VSEN 3 1 2 GND Auto Track TRK ADJ PWM Controller Error Amplifier Ref INH RC Block GND GND GND MARDN MARUP Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 2 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.0 V/15 A Electrical Specification PMG 4318T Tref = -40 to +85ºC, VI = 2.95 to 3.65 V, Radj = 36.5 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI= 3.3 V, max IO , unless otherwise specified under Conditions. Additional Cin=470uF and Cout=330uF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage VIon Turn-on input voltage Increasing input voltage CI Internal input capacitance PO Output power η Efficiency 5 Reference 2.95 2.2 V 2.8 V 2.50 2.45 V μF 50 0 15 50 % of max IO 87.8 max IO 81.4 Unit 3.65 W % Pd Power Dissipation max IO 3.4 Pli Input idling power IO= 0, VI = 3.3 V 200 mW PRC Input standby power VI = 3.3 V (turned off with INHIBIT) 33 mW IS Static Input current VI = 3.3 V, max IO 5.6 fs Switching frequency 0-100% of max IO VOi Output voltage initial setting and Tref = +25°C, VI = 3.3 V, max IO accuracy 3.9 W A 275 300 325 kHz 0.980 1.000 1.020 V 1.030 V Output voltage tolerance band 10-100% of max IO Idling voltage IO = 0 1.002 V Line regulation max IO ±10 mV Load regulation VI = 3.3 V, 0-100% of max IO ±12 mV Vtr Load transient voltage deviation ±180 mV ttr Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/μs, see Note 1 20 μs 3.7 ms 6.5 ms μs VO tr ts tf tInh Ramp-up time (from 10−90 % of VOi) Start-up time max IO (from VI connection to 90% of VOi) Vin shutdown fall time. (From VI off to 10% of VO) Max Io 60 Io = 1A 560 μs INHIBIT start-up time Max Io 6.0 ms INHIBIT shutdown fall time (From INHIBIT off to 10% of VO) Max Io 540 μs Io = 0.1 A 3.2 ms IO Output current Ilim Current limit threshold Tref < max Tref, Output ripple & noise See ripple & noise section, max IO, VOi VOac 0.970 0 Note 1: Output filter according to Ripple & Noise section 15 A 27.5 A 20 mVp-p Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 3 (19) No. 2/1301-BMR 644Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked Date Rev 6 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.0 V/15 A Typical Characteristics PMG 4318T Efficiency Power Dissipation [%] [W] 100 4 95 3 90 2.95 V 85 3.3 V 80 3.65 V 2.95 V 2 3.3 V 3.65 V 1 75 0 70 0 3 6 9 12 15 0 18 [A] 3 6 9 12 15 18 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 18 [V] 1.10 15 2.0 m/s 1.05 12 2.95 V 1.0 m/s 9 1.00 3.3 V 3.65 V 0.5 m/s 6 0.95 3 Nat. Conv. 0 0.90 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.5 V. See Thermal Consideration section. 0 3 6 9 12 15 Output voltage vs. load current at Tref = +25°C 18 [A] Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 4 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date 2006-1-27 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB 1.0 V/15 A Typical Characteristics Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. PMG 4318T Shut-down Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 10 ms/div.. Output Ripple & Noise Output voltage ripple (20mV/div.) at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Time scale: 2 μs/div. 7 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 5.0 ms/div.. Output Load Transient Response See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current step- Top trace: output voltage (100mV/div.). change (7-15-7 A) at: Bottom trace: load current (10 A/div.). Tref =+25°C, VI = 3.3 V. Time scale: 0.1 ms/div.. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 5 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.2 V/15 A Electrical Specification PMG 4318T Tref = -40 to +85ºC, VI = 2.95 to 3.65 V, Radj = 17.4 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI= 3.3 V, max IO , unless otherwise specified under Conditions. Additional Cin=470uF and Cout=330uF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage VIon Turn-on input voltage Increasing input voltage CI Internal input capacitance PO Output power η Efficiency 8 Reference 2.95 2.2 3.65 V 2.8 V 2.50 2.45 V μF 50 0 18 50 % of max IO 89.4 max IO 83.7 Unit W % Pd Power Dissipation max IO 3.5 Pli Input idling power IO= 0, VI = 3.3 V 210 mW PRC Input standby power VI = 3.3 V (turned off with INHIBIT) 33 mW IS Static Input current VI = 3.3 V, max IO fs Switching frequency 0-100% of max IO VOi Output voltage initial setting and Tref = +25°C, VI = 3.3 V, max IO accuracy 4.0 6.5 W A 275 300 325 kHz 1.176 1.200 1.224 V 1.236 V Output voltage tolerance band 10-100% of max IO Idling voltage IO = 0 1.198 V Line regulation max IO ±10 mV Load regulation VI = 3.3 V, 0-100% of max IO ±12 mV Vtr Load transient voltage deviation ±180 mV ttr Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/μs, see Note 1 20 μs 3.7 ms 6.5 ms μs VO tr ts tf tInh 1.164 Ramp-up time (from 10−90 % of VOi) Start-up time max IO (from VI connection to 90% of VOi) Vin shutdown fall time. (From VI off to 10% of VO) Max Io 70 Io = 1A 420 μs INHIBIT start-up time Max Io 6.1 ms INHIBIT shutdown fall time (From INHIBIT off to 10% of VO) Max Io 480 μs Io = 0.1 A 3.8 ms IO Output current Ilim Current limit threshold Tref < max Tref, VOac Output ripple & noise See ripple & noise section, max IO, VOi 0 Note 1: Output filter according to Ripple & Noise section 15 A 27.5 A 20 mVp-p Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 6 (19) No. 2/1301-BMR 644Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked Date Rev 9 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.2 V/15 A Typical Characteristics PMG 4318T Efficiency Power Dissipation [%] [W] 100 4 95 3 90 2.95 V 85 3.3 V 80 3.65 V 2.95 V 2 3.3 V 3.65 V 1 75 0 70 0 3 6 9 12 15 0 18 [A] 3 6 9 12 15 18 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 18 [V] 1.30 15 2.0 m/s 1.25 12 2.95 V 1.0 m/s 9 1.20 3.3 V 3.65 V 0.5 m/s 6 1.15 3 Nat. Conv. 0 1.10 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.5 V. See Thermal Consideration section. 0 3 6 9 12 15 18 [A] Output voltage vs. load current at Tref = +25°C Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 7 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date 2006-1-27 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB 1.2 V/15 A Typical Characteristics Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. PMG 4318T Shut-down Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 10 ms/div. Output Ripple & Noise Output voltage ripple (20mV/div.) at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Time scale: 2 μs/div. 10 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 5.0 ms/div.. Output Load Transient Response See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current step- Top trace: output voltage (100mV/div.). change (7-15-7 A) at: Bottom trace: load current (10 A/div.). Tref =+25°C, VI = 3.3 V. Time scale: 0.1 ms/div.. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 8 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.5 V/15 A Electrical Specification PMG 4318T Tref = -40 to +85ºC, VI = 2.95 to 3.65 V, Radj = 8.87 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI= 3.3 V, max IO , unless otherwise specified under Conditions. Additional Cin=470uF and Cout=330uF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage VIon Turn-on input voltage Increasing input voltage CI Internal input capacitance PO Output power η Efficiency 11 2.95 2.2 V 2.8 V 2.50 2.45 V μF 50 0 22.5 50 % of max IO 91.2 max IO 86.3 Unit 3.65 W % Pd Power Dissipation max IO 3.6 Pli Input idling power IO= 0, VI = 3.3 V 210 mW PRC Input standby power VI = 3.3 V (turned off with INHIBIT) 33 mW IS Static Input current VI = 3.3 V, max IO 7.9 fs Switching frequency 0-100% of max IO VOi Output voltage initial setting and Tref = +25°C, VI = 3.3 V, max IO accuracy 4.1 W A 275 300 325 kHz 1.470 1.500 1.530 V 1.545 V Output voltage tolerance band 10-100% of max IO Idling voltage IO = 0 1.499 V Line regulation max IO ±10 mV Load regulation VI = 3.3 V, 0-100% of max IO ±12 mV Vtr Load transient voltage deviation ±180 mV ttr Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/μs, see Note 1 20 μs 3.6 ms 6.5 ms μs VO tr ts tf tInh Ramp-up time (from 10−90 % of VOi) Start-up time max IO (from VI connection to 90% of VOi) Vin shutdown fall time. (From VI off to 10% of VO) Max Io 70 Io = 1A 540 μs INHIBIT start-up time Max Io 6.1 ms INHIBIT shutdown fall time (From INHIBIT off to 10% of VO) Max Io 440 μs Io = 0.1 A 4.8 ms IO Output current Ilim Current limit threshold Tref < max Tref, Output ripple & noise See ripple & noise section, max IO, VOi VOac 1.455 0 Note 1: Output filter according to Ripple & Noise section 15 A 27.5 A 20 mVp-p Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 9 (19) No. 2/1301-BMR 644Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked Date Rev 12 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.5 V/15 A Typical Characteristics PMG 4318T Efficiency Power Dissipation [%] [W] 100 4 95 3 90 2.95 V 85 3.3 V 80 3.65 V 2.95 V 2 3.3 V 3.65 V 1 75 0 70 0 3 6 9 12 15 0 18 [A] 3 6 9 12 15 18 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 18 [V] 1.60 15 2.0 m/s 1.55 12 2.95 V 1.0 m/s 9 1.50 3.3 V 3.65 V 0.5 m/s 6 1.45 3 Nat. Conv. 0 1.40 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.5 V. See Thermal Consideration section. 0 3 6 9 12 15 18 [A] Output voltage vs. load current at Tref = +25°C Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 10 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date 2006-1-27 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB 1.5 V/15 A Typical Characteristics Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. PMG 4318T Shut-down Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 10 ms/div.. Output Ripple & Noise Output voltage ripple (20mV/div.) at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Time scale: 2 μs/div. 13 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 5.0 ms/div.. Output Load Transient Response See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current step- Top trace: output voltage (100mV/div.). change (7-15-7 A) at: Bottom trace: load current (10 A/div.). Tref =+25°C, VI = 3.3 V. Time scale: 0.1 ms/div.. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 11 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.8 V/15 A Electrical Specification PMG 4318T Tref = -40 to +85ºC, VI = 2.95 to 3.65 V, Radj = 5.49 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI= 3.3 V, max IO , unless otherwise specified under Conditions. Additional Cin=470uF and Cout=330uF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage VIon Turn-on input voltage Increasing input voltage CI Internal input capacitance PO Output power η Efficiency 14 2.95 2.2 V 2.8 V 2.50 2.45 V μF 50 0 27 50 % of max IO 92.4 max IO 88.2 Unit 3.65 W % Pd Power Dissipation max IO 3.6 Pli Input idling power IO= 0, VI = 3.3 V 210 mW PRC Input standby power VI = 3.3 V (turned off with INHIBIT) 33 mW IS Static Input current VI = 3.3 V, max IO 9.3 fs Switching frequency 0-100% of max IO VOi Output voltage initial setting and Tref = +25°C, VI = 3.3 V, max IO accuracy 4.1 W A 275 300 325 kHz 1.764 1.800 1.836 V 1.854 V Output voltage tolerance band 10-100% of max IO Idling voltage IO = 0 1.796 V Line regulation max IO ±10 mV Load regulation VI = 3.3 V, 0-100% of max IO ±12 mV Vtr Load transient voltage deviation ±190 mV ttr Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/μs, see Note 1 30 μs 3.6 ms 6.4 ms μs VO tr ts tf tInh Ramp-up time (from 10−90 % of VOi) Start-up time max IO (from VI connection to 90% of VOi) Vin shutdown fall time. (From VI off to 10% of VO) Max Io 90 Io = 1A 660 μs INHIBIT start-up time Max Io 6.1 ms INHIBIT shutdown fall time (From INHIBIT off to 10% of VO) Max Io 450 μs Io = 0.1 A 5.8 ms IO Output current Ilim Current limit threshold Tref < max Tref, Output ripple & noise See ripple & noise section, max IO, VOi VOac 1.746 0 Note 1: Output filter according to Ripple & Noise section 15 A 27.5 A 20 mVp-p Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 12 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev 15 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 1.8 V/15 A Typical Characteristics PMG 4318T Efficiency Power Dissipation [%] [W] 100 4 95 3 90 2.95 V 85 3.3 V 80 3.65 V 2.95 V 2 3.3 V 3.65 V 1 75 70 0 0 3 6 9 12 15 18 [A] 0 3 6 9 12 15 18 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 18 [V] 1.90 15 2.0 m/s 1.85 12 2.95 V 1.0 m/s 9 1.80 3.3 V 3.65 V 0.5 m/s 6 1.75 3 Nat. Conv. 0 1.70 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.5 V. See Thermal Consideration section. 0 3 6 9 12 15 18 [A] Output voltage vs. load current at Tref = +25°C Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 13 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date 2006-1-27 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB 1.8 V/15 A Typical Characteristics Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. PMG 4318T Shut-down Top trace: output voltage (0.5 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 10 ms/div.. Output Ripple & Noise Output voltage ripple (20mV/div.) at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Time scale: 2 μs/div. 16 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 5.0 ms/div.. Output Load Transient Response See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current step- Top trace: output voltage (100mV/div.). change (7-15-7 A) at: Bottom trace: load current (10 A/div.). Tref =+25°C, VI = 3.3 V. Time scale: 0.1 ms/div.. Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 17 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 2.5 V/15 A Electrical Specification PMG 4318T Tref = -40 to +85ºC, VI = 2.95 to 3.65 V, Radj = 2.21 kΩ, unless otherwise specified under Conditions. Typical values given at: Tref = +25°C, VI= 3.3 V, max IO , unless otherwise specified under Conditions. Additional Cin=470uF and Cout=330uF. See Operating Information section for selection of capacitor types. Connect the sense pin, where available, to the output pin. Characteristics Conditions min typ max VI Input voltage range VIoff Turn-off input voltage Decreasing input voltage VIon Turn-on input voltage Increasing input voltage CI Internal input capacitance PO Output power η Efficiency 17 2.95 2.2 V 2.8 V 2.50 2.45 V μF 50 0 37.5 50 % of max IO 94.5 max IO 91.4 Unit 3.65 W % Pd Power Dissipation max IO 3.5 Pli Input idling power IO= 0, VI = 3.3 V 200 mW PRC Input standby power VI = 3.3 V (turned off with INHIBIT) 33 mW IS Static Input current VI = 3.3 V, max IO fs Switching frequency 0-100% of max IO VOi Output voltage initial setting and Tref = +25°C, VI = 3.3 V, max IO accuracy 4.0 12.4 W A 275 300 325 kHz 2.450 2.500 2.550 V 2.575 V Output voltage tolerance band 10-100% of max IO Idling voltage IO = 0 2.492 V Line regulation max IO ±10 mV Load regulation VI = 3.3 V, 0-100% of max IO ±12 mV Vtr Load transient voltage deviation ±200 mV ttr Load transient recovery time VI = 3.3 V, Load step 50-100-50 % of max IO, di/dt = 1 A/μs, see Note 1 60 μs 3.6 ms 6.4 ms μs VO tr ts tf tInh Ramp-up time (from 10−90 % of VOi) Start-up time max IO (from VI connection to 90% of VOi) Vin shutdown fall time. (From VI off to 10% of VO) Max Io 130 Io = 1A 1030 μs INHIBIT start-up time Max Io 6.2 ms INHIBIT shutdown fall time (From INHIBIT off to 10% of VO) Max Io 410 μs Io = 0.1 A 8.2 ms IO Output current Ilim Current limit threshold Tref < max Tref, Output ripple & noise See ripple & noise section, max IO, VOi VOac 2.425 0 Note 1: Output filter according to Ripple & Noise section 15 A 27.5 A 20 mVp-p Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 18 (19) No. 2/1301-BMR 644Technical 4 Uen Specification Specifi cation SEC/D KEVIN YAN Approved Checked PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Date Rev 18 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-1-27 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W © Flex Ericsson Power Modules AB 2.5 V/15 A Typical Characteristics PMG 4318T Efficiencys Power Dissipation [%] [W] 100 4 95 3 90 2.95 V 85 3.3 V 80 3.65 V 2.95 V 2 3.3 V 3.65 V 1 75 0 70 0 3 6 9 12 15 0 18 [A] 3 6 9 12 15 18 [A] Dissipated power vs. load current and input voltage at Tref = +25°C Efficiency vs. load current and input voltage at Tref = +25°C Output Current Derating Output Characteristics [A] 18 [V] 2.60 2.0 m/s 15 2.55 12 2.95 V 1.0 m/s 9 2.50 3.3 V 0.5 m/s 6 3.65 V 2.45 3 Nat. Conv. 0 2.40 0 20 40 60 80 [°C] Available load current vs. ambient air temperature and airflow at VI = 3.3 V, VOUT = 2.5 V. See Thermal Consideration section. 0 3 6 9 12 15 18 [A] Output voltage vs. load current at Tref = +25°C Limited Internal PRODUCT SPEC. E Prepared (also subject responsible if other) 19 (19) No. SEC/D KEVIN YAN Approved PMG 4000 series series SEC/D Wei Zhang A PoL Regulators Checked 2/1301-BMR 644Technical 4 Uen Specification Specifi cation Date 2006-1-27 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB 2.5 V/15 A Typical Characteristics Start-up Start-up enabled by connecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. PMG 4318T Shut-down Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 10 ms/div.. Output Ripple & Noise Output voltage ripple (20mV/div.) at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Time scale: 2 μs/div. 19 Shut-down enabled by disconnecting VI at: Tref = +25°C, IO = 15 A resistive load, VI = 3.3 V. Top trace: output voltage (1.0 V/div.). Bottom trace: input voltage (2 V/div.). Time scale: 5.0 ms/div.. Output Load Transient Response See the filter in the Output ripple and noise section (EMC Specification). Output voltage response to load current step- Top trace: output voltage (100mV/div.). change (7-15-7 A) at: Bottom trace: load current (5 A/div.). Tref =+25°C, VI = 3.3 V. Time scale: 0.1 ms/div. Ericsson Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved PMG 4000 series seriesA) PoL Regulators SEC/D (Wei Zhang 1 (5) No. Checked 3/1301-BMR 644Technical 4 Uen Specification Specifi cation Date 2006-02-08 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W EMC Specification Rev Reference 20 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB Output ripple and noise Conducted EMI measured according to test set-up. The fundamental switching frequency is 300 kHz for PMG 4318T @ VI = 3.3 V, max IO. Output ripple and noise measured according to figure below. See Design Note 022 for detailed information. Conducted EMI Input terminal value (typ) TBD Output ripple and noise test setup EMI without filter Operating information Extended information for POLA products is found in Application Note POLA. Input Voltage The input voltage range 2.95 to 3.65 Vdc makes the product easy to use in intermediate bus applications when powered by a regulated bus converter. TBD Turn-off Input Voltage The DC/DC regulators monitor the input voltage and will turn on and turn off at predetermined levels. The minimum hysteresis between turn on and turn off input voltage is 50mV. Test set-up Layout recommendation The radiated EMI performance of the DC/DC regulator will depend on the PCB layout and ground layer design. It is also important to consider the stand-off of the DC/DC regulator. If a ground layer is used, it should be connected to the output of the DC/DC regulator and the equipment ground or chassis. A ground layer will increase the stray capacitance in the PCB and improve the high frequency EMC performance. Remote Control (RC) Inhibit The products are fitted with a remote control function referenced to the primary negative input connection (- In), positive logic. The INHIBIT function allows the regulator to be turned on/off by an external device like a semiconductor or mechanical switch. The INHIBIT pin has an internal pull up resistor to + In. The regulator will turn on when the input voltage is applied with the INHIBIT pin open. Turn off is achieved by connecting the INHIBIT pin to the - In. To ensure safe turn off, the voltage difference between INHIBIT pin and the - In pin shall be less than 0.6V. The regulator will restart automatically when this connection is opened. Ericsson Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved PMG 4000 series seriesA) PoL Regulators SEC/D (Wei Zhang 2 (5) No. Checked 3/1301-BMR 644Technical 4 Uen Specification Specifi cation Date 2006-02-08 Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Rev Reference 21 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 A © Flex Ericsson Power Modules AB External Capacitors Output Voltage Adjust (Vadj) Input capacitors: The recommended input capacitors are determined by the 470 μF minimum capacitance and 700 mArms minimum ripple current rating. The DC/DC regulators have an Output Voltage Adjust pin (Vadj). This pin can be used to adjust the output voltage above or below Output voltage initial setting. Output capacitors (optional): The recommended output capacitance of 330 μF will allow the module to meet its transient response specification as defined in the electrical specification. To increase or decrease the voltage the resistor should be connected between the Vadj pin and GND pin. The resistor value of the Output voltage adjust function is according to information given under the Output section for the respective product. When using one or more non-ceramic capacitors, the calculated equivalent ESR should be no lower than 4 mΩ (7mΩ using the manufacturer’s maximum ESR for a single capacitor). Input And Output Impedance The impedance of both the input source and the load will interact with the impedance of the DC/DC regulator. It is important that the input source has low characteristic impedance. The regulators are designed for stable operation without external capacitors connected to the input or output. The performance in some applications can be enhanced by addition of external capacitance as described under External Decoupling Capacitors. If the input voltage source contains significant inductance, the addition of a 100 μF capacitor across the input of the regulator will ensure stable operation. The capacitor is not required when powering the DC/DC regulator from an input source with an inductance below 10 μH. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle high-frequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. Ceramic capacitors will also reduce any high frequency noise at the load. It is equally important to use low resistance and low inductance PCB layouts and cabling. External decoupling capacitors will become part of the control loop of the DC/DC regulator and may affect the stability margins. As a “rule of thumb”, 100 μF/A of output current can be added without any additional analysis. The ESR of the capacitors is a very important parameter. Power Modules guarantee stable operation with a verified ESR value of >10 mΩ across the output connections. For further information please contact your local Flex representative. Parallel Operation Two regulators may be paralleled for redundancy if the total power is equal or less than PO max. It is not recommended to parallel the regulators without using external current sharing circuits. Remote Sense The DC/DC regulators have remote sense that can be used to compensate for voltage drops between the output and the point of load. The sense traces should be located close to the PCB ground layer to reduce noise susceptibility. The remote sense circuitry will compensate for up to 0.3v voltage drop between output pins and the point of load. If the remote sense is not needed +Sense should be left open. Over Current Protection (OCP) The regulators include current limiting circuitry for protection at continuous overload. The output voltage will decrease towards zero for output currents in excess of the over-current threshold. The regulator will resume normal operation after removal of the overload. The load distribution should be designed for the maximum output short circuit current specified. The current limit operation is a “hick up” mode current limit. Ericsson Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved PMG 4000 series seriesA) PoL Regulators SEC/D (Wei Zhang 3 (5) No. Checked 3/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev From the moment a valid input voltage is applied, the softstart control introduces a short time-delay (typically 5-10 ms) before allowing the output voltage to rise. The initial rise in input current when the input voltage first starts to rise is the charge current drawn by the input capacitors. Power-up is complete within 15 ms. Auto-Track™ Function Auto-Track was designed to simplify the amount of circuitry required to make the output vltage from each module power up and power down in sequence. The sequencing of two or more supply voltages during power up is a common requirement for complex mixed-signal applications, that use dual-voltage VLSI ICs such as DSPs, micro-processors and ASICs. 22 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-02-08 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Soft-start Power Up Reference © Flex Ericsson Power Modules AB Thermal Consideration General The regulators are designed to operate in different thermal environments and sufficient cooling must be provided to ensure reliable operation. Cooling is achieved mainly by conduction, from the pins to the host board, and convection, which is dependant on the airflow across the regulator. Increased airflow enhances the cooling of the regulator. The Output Current Derating graph found in the Output section for each model provides the available output current vs. ambient air temperature and air velocity at Vin = 3.3 V. Margin Up/Down controls The DC/DC regulator is tested on a 254 x 254 mm, 35 μm (1 oz), 8-layer test board mounted vertically in a wind tunnel with a cross-section of 305 x 305 mm. These controls allow the input voltage to be momentarily adjusted, either up or down, by a nominal 5 %. This provides a convenient method for dynamically testing the operation of the load circuit over its supply margin or range. It can also be used to verify the function of supply voltage supervisors. Proper cooling of the DC/DC regulator can be verified by measuring the temperature at positions P1, P2 and P3. The temperature at these positions should not exceed the max values provided in the table below. Pre-Bias Startup Capability This often occurs in complex digital systems when current from another power source is backfed through a dual-supply logic component, such as FPGA or ASIC. The PMG(3.3/5.0V Vin) incorporate synchronous rectifiers, but will not sink current during startup, or whenever the Inhibit pin is held low. However, to ensure satisfactory operation of this function, certain conditions must be maintained. Note that the max value is the absolute maximum rating (non destruction) and that the electrical Output data is guaranteed up to Tref +85°C. See Design Note 019 for further information. Position Device P1 Pcb P2 Mosfet P3 Inductor Designation max value Tref 135º C 120º C 130º C Ericsson Internal PRODUCT SPEC. E Prepared (also subject responsible if other) SEC/D KEVIN YAN Approved PMG 4000 series seriesA) PoL Regulators SEC/D (Wei Zhang 4 (5) No. Checked 3/1301-BMR 644Technical 4 Uen Specification Specifi cation Date Rev 23 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 2006-02-08 A Input 2.95 - 3.65Input V, Output up toV,15 A / 37.5 POL regulator, 2.95-3.65 Output 15 W A/37.5 W Thermal Consideration continued Reference © Flex Ericsson Power Modules AB Connections Definition of reference temperature (Tref) The reference temperature is used to monitor the temperature limits of the product. Temperatures above maximum Tref are not allowed and may cause degradation or permanent damage to the product. Tref is also used to define the temperature range for normal operating conditions. Tref is defined by the design and used to guarantee safety margins, proper operation and high reliability of the module. Ambient Temperature Calculation TBD TOP VIEW Pin 1 Designation GND Function Common ground connection for the Vin and Vout power connections. 2 Vin The positive input voltage power node to the module. 3 Inhibit Applying a low-level ground signal to this input disables the module’s output. 4 Vo Adjust 5 Vo Sense 6 Vout The regulated positive power output with respect to the GND node. 7 GND Common ground connection for the Vin and Vout power connections. 8 Track 9 Margin Down 10 Margin Up This is an analog control input that enables the output voltage to follow an external voltage. When this input is asserted to GND, the output voltage is decreased by 5% from the nominal. When this input is asserted to GND, the output voltage is increased by 5%. A 0.1 W 1% resistor must be directly connected between this pin and pin 7(GND) to set the output voltage. The sense input allows the regulation circuit to compensate for voltage drop between the module and the load. E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) SEC/D EPANHON Approved 1 (7) No. Checked PMG 4000 series SEC/D (Linadseries Zhong) PoL Regulators See end 4/1301-BMR 644Technical Specification Specification Date 2006-2-14 Inputregulator, 2.95 - 3.65 V, Output up toV,15 A / 37.5 POL Input 2.95-3.65 Output 15 W A/37.5 W Mechanical Information (Surface mount version) Rev Reference 24 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 B © Flex Ericsson Power Modules AB E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) SEC/D EPANHON Approved 2 (7) No. Checked PMG 4000 series SEC/D (Linadseries Zhong) PoL Regulators See end 4/1301-BMR 644Technical Specification Specification Date 2006-2-14 Inputregulator, 2.95 - 3.65 V, Output up toV,15 A / 37.5 POL Input 2.95-3.65 Output 15 W A/37.5 W Mechanical Information (Through hole mount version) Rev Reference 25 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 B © Flex Ericsson Power Modules AB E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 3 (7) No. SEC/D EPANHON Approved Checked PMG 4000 series SEC/D (Linadseries Zhong) PoL Regulators See end 4/1301-BMR 644Technical Specification Specification Date 2006-2-14 Inputregulator, 2.95 - 3.65 V, Output up toV,15 A / 37.5 POL Input 2.95-3.65 Output 15 W A/37.5 W Rev 26 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 B © Flex Ericsson Power Modules AB Soldering Information - Surface mounting Maximum regulator temperature requirements The surface mount version of the product is intended for convection or vapor phase reflow Pb-free processes. To achieve a good and reliable soldering result, make sure to follow the recommendations from the solder paste supplier, to use state-of-the-art reflow equipment and reflow profiling techniques as well as the following guidelines. To avoid damage or performance degradation of the product, the reflow profile should be optimized to avoid excessive heating. The maximum product temperature shall be monitored by attaching a thermocoupler to the top of the main transformer. A no-clean flux is recommended to avoid entrapment of cleaning fluids in cavities inside of the DC/DC regulator. The cleaning residues may affect long time reliability and isolation voltage. A sufficiently extended preheat time is recommended to ensure an even temperature across the host PCB, for both small and large devices. To reduce the risk of excessive heating is also recommended to reduce the time in the reflow zone as much as possible. Minimum pin temperature recommendations SnPb solder processes Pin number 9 is chosen as reference location for the minimum pin temperature recommendations since this will be the coolest solder joint during the reflow process. For conventional SnPb solder processes, the product is qualified for MSL 1 according to IPC/JEDEC standard J-STD-020C. During reflow, TP must not exceed +225 °C at any time. PIN 9 for measurement of minimum solder joint temperature, TPIN Lead-free (Pb-free) solder processes For Pb-free solder processes, the product is qualified for MSL 3 according to IPC/JEDEC standard J-STD-020C. Main transformer for measurement of Max product temperature, TP During reflow, TP must not exceed +260 °C at any time. Temperature Ramp-up TP SnPb solder processes Ramp-down (cooling) TL For Pb solder processes, a pin temperature (TPIN) in excess of the solder melting temperature, (TL, +183 °C for Sn63/Pb37) for more than 30 seconds, and a peak temperature of +210 °C is recommended to ensure a reliable solder joint. Reflow Preheat Lead-free (Pb-free) solder processes For Pb-free solder processes, a pin temperature (TPIN) in excess of the solder melting temperature (TL, +217 to +221 °C for Sn/Ag/Cu solder alloys) for more than 30 seconds, and a peak temperature of +235 °C on all solder joints is recommended to ensure a reliable solder joint. 25 °C Time 25 °C to peak Time Profile features Sn/Pb eutectic assembly Average ramp-up rate Pb-free assembly 3 °C/s max 3 °C/s max TL +183 °C +221 °C Peak product temperature TP +225 °C +260 °C Average ramp-down rate 6 °C/s max 6 °C/s max Time 25 °C to peak temperature 6 minutes max 8 minutes max Solder melting temperature (typical) E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) SEC/D EPANHON Approved 4 (7) No. Checked PMG 4000 series SEC/D (Linadseries Zhong) PoL Regulators See end 4/1301-BMR 644Technical Specification Specification Date 2006-2-14 Inputregulator, 2.95 - 3.65 V, Output up toV,15 A / 37.5 POL Input 2.95-3.65 Output 15 W A/37.5 W Soldering Information — Through Hole Mounting The through hole mount version of the product is intended for through hole mounting in a PCB. When wave soldering is used, the temperature on the pins is specified to maximum 260 °C for maximum 10 seconds. Maximum preheat rate of 4 °C/s and temperature of max 150 °C is suggested. When hand soldering, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean (NC) flux is recommended to avoid entrapment of cleaning fluids in cavities inside of the DC/DC power module. The residues may affect long time reliability and isolation voltage. Rev Reference 27 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 B © Flex Ericsson Power Modules AB E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) SEC/D EPANHON Approved 5 (7) No. Checked PMG 4000 series SEC/D (Linadseries Zhong) PoL Regulators See end 4/1301-BMR 644Technical Specification Specification Date Rev 2006-2-14 Inputregulator, 2.95 - 3.65 V, Output up toV,15 A / 37.5 POL Input 2.95-3.65 Output 15 W A/37.5 W 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 B © Flex Ericsson Power Modules AB Delivery package information for SMD Carrier tape specifications The products are delivered in antistatic trays (JEDEC standard) or in antistatic carrier tape (EIA standard). Material Polystyrene Surface resistance < 10E5 ohms/square Bake ability The tape can not be baked. Tape width 56 mm [2.205 inch] Tray specifications 28 Reference Material PET Pocket pitch 24 mm [0.945 inch] Surface resistance 10E3 to 10E5 ohms/square Pocket depth 9.57 mm [0.377 inch] Bake ability The trays can not be baked. Reel diameter 380 mm [15 inch] Tray capacity 25 products /tray Reel capacity 250 products /reel Box capacity 125 products/box) Box capacity 250 products (1 reels/box) Weight 210 g/full tray Weight 1.5 kg/full reel Tape feed directions Round holes Elongated holes Dry pack information The products are delivered in trays or tape & reel. These inner shipment containers are dry packed in standard moisture barrier bags according to IPC/JEDEC standard J-STD-033A (Handling, packing, shipping and use of moisture/reflow sensitivity surface mount devices). Using products in high temperature Pb-free soldering processes requires dry pack storage and handling. In case the products have been stored in an uncontrolled environment and no longer can be considered dry, the modules must be baked according to the referred IPC/JEDEC standard. E Ericsson Internal PRODUCT SPECIFICATION Prepared (also subject responsible if other) 6 (7) No. SEC/D EPANHON Approved Checked PMG 4000 series SEC/D (Linadseries Zhong) PoL Regulators See end 4/1301-BMR 644Technical Specification Specification Date 2006-2-14 Inputregulator, 2.95 - 3.65 V, Output up toV,15 A / 37.5 POL Input 2.95-3.65 Output 15 W A/37.5 W Rev 29 Reference 1/ 28701BMR November 2017 EN/LZT 146 319644 R1BRev.A April 2006 B © Flex Ericsson Power Modules AB Product Qualification Specification Characteristics Visual inspection JESD22-B101 Temperature cycling JESD22-A104-B Dwell time Transfer time Temperature range Number of cycles 30 min 0-1 min -40 °C to +125 °C 300 cycles High temperature storage life JESD22-A103-B Temperature Duration 125 °C 1000 h Cold (in operation) IEC 68-2-1, test Ad Temperature TA Duration -45 °C 72 h Lead integrity JESD22-B105-C Test condition A Weight Duration 1000 g 30 s Solder ability(only apply to through hole version) IEC 68-2-54 Solder immersion depth Duration of immersion (FC time) TA (time for onset of wetting) Time to FB Wetting Strength FB Stability FC /FB 1 mm 15 s 100 mN/m >0.8 Steady State Temperature Humidity Bias Life Test JESD22-A101-B Temperature Humidity Duration Input Voltage +85 °C 85 % RH 1000 hours Maximum Mechanical shock JESD22-B104-B Peak acceleration Duration Number of shocks 200 g 1.5 ms 5 in each of two directions of three axes Vibration, variable freq JESD22-B103-B Frequency range Acceleration amplitude 10-1000 Hz 10 g or displacement amplitude 1.0 mm Random vibration JESD22-B103-B Frequency Acceleration density 2-500 Hz 0.008-0.2 g2/Hz Temperature Load ON OFF Test duration 85 °C Maximum 9 min 3 min 1000 h SnPb eutectic MSL 1 225 °C Pb free MSL 3 260 °C Water Glycol ether Isopropyl alcohol +55 ±5 °C +35 ±5 °C +35 ±5 °C Operational life test Moisture reflow sensitivity classification test J-STD-020C Resistance to cleaning agents IEC 68-2-45 Xa Method 2
PMG4318TP 价格&库存
很抱歉,暂时无法提供与“PMG4318TP”相匹配的价格&库存,您可以联系我们找货
