PKV5222PI
PKV5222PI
    FLEX(伟创力)
    DIP10 模块
    隔离模块 直流转换器 2 输出 5V -5V 250mA,250mA 18V - 72V 输入
PKV5222PI 数据手册
PKV 3000 I – PKV 5000 I DC/DC converter Input 9-36 and 18-72 Vdc Output up to 0.5 A / 3 W Key Features • Industry standard DIL24 • Wide input voltage range, 9–36 V, 18–72 V • High efficiency 74–83% typical • Low idling power • Full output power up to +75 °C ambient temperature • Input/Output isolation 1,500 Vdc • MTBF > 650,000 hours at +25 °C ambient • Functional insulation according to UL 62368-1 Safety Approvals Design for Environment Meets requirements in high-temperature lead-free soldering processes. The PKV series of DC/DC power modules is intended for general use in 12/24 V and 48/60V DC systems. Designed with MOSFET transistors and 200 kHz switching frequency, they are characterized by high efficiency over a wide load range, very low quiescent power and an excel- lent line and load regulation. The DC/DC power modules are encapsulated in an epoxy filled plastic box. The flammability ratings of the encapsulating materials are in conformance with UL 94V-0 and have an adequate thermal conductivity. The materials withstand all normal PBA cleaning methods. Flex is an ISO 9001/14001 certified supplier. Datasheet General Safety Absolute Maximum Ratings Characteristics min max Units TC Case temperature1) –40 +95 °C TS Storage temperature –40 +125 °C VI Input voltage, 0.1 s max 40 80 Vdc VISO Isolation voltage2) (input to output test voltage) PKV 3000 PKV 5000 Vdc 1,500 Stress in excess of Absolute Maximum Ratings may cause permanent damage. Absolute Maximum Ratings, sometimes referred to as no destruction limits, are normally tested with one parameter at a time exceeding the limits of Output data or Electrical Characteristics. If exposed to stress above these limits, function and performance may degrade in an unspecified manner. Note: 1) Corresponding typical ambient temperature range (TA) at full output power is – 40 to +75°C. 2) Typical Isolation voltage of PKV5211 module is 2,000 Vdc Input TA = +25°C, unless otherwise specified Characteristics Conditions VI Input voltage range TA= – 40 to +75°C VIoff Turn-off input voltage Inrush current VIac Peak I2t min PKV 3000 PKV 5000 typ max 9 18 PKV 3000 PKV 5000 Low loss, low inductive capacitive source PKV 3000 PKV 5000 Units 36 72 V 8 16 V 35 0.005 0.005 A A2s A2s • Isolate the faulty DC/DC converter from the input power source not to affect the operation of other parts of the system. Idling power IO = 0 0.3 W Ripple voltage IO = IOmax, BW=20 MHz 100 mVp-p Miscellaneous Characteristics Conditions min typ max Unit Input/Output coupling capacitor RH = 48%, TC = +25°C f = 100 Hz 1000 pF Switching frequency VI = VInom, IO = IOmax 200 kHz The PKV 3000 I and PKV 5000 I series DC/DC converters are designed in accordance with safety standards UL 62368-1, Safety of Information Technology Equipment. The PKV 3000 I and PKV 5000 I series DC/ DC converters are UL 62368-1 recognized. The DC/DC converter should be installed in the end-use equipment, in accordance with the requirements of the ultimate application. The input source must be isolated by minimum Basic insulation from the primary circuit in accordance with UL 62368-1. If the input voltage to the DC/DC converter is 72 V dc or less, then the output remains SELV (Safety Extra Low Voltage) under normal and abnormal operating conditions. It is recommended that a slow blow fuse with a rating of 2 x IImax be used at the input of each DC/DC converter. If a fault occurs in the converter that imposes a short circuit on the input source, this fuse will provide the following functions: • Protect the distribution wiring from excessive current and power loss thus preventing hazardous overheating. The galvanic isolation is verified in an electric strength test. The test voltage (VISO) between input and output is 1500 Vdc for 60 seconds. Leakage current is less than 1µA at nominal input voltage. The flammability rating for all construction parts of the DC/DC converter meets UL 94V-0. Environmental Characteristics Test method Reference Vibration (Sinusoidial) IEC 68-2-6 FC Shock (Half-sinus) Temperature change 2 Test procedure & conditons Frequency Amplitude Accelaration Number of cycles Test duration 10...500Hz 0.75 mm 10 g 10 in each axis 1 h per axis IEC 68-2-27 Ea Peak acceleration Shock duration 200g 3 ms IEC 68-2-14 Na Temperature Number of cycles – 40°C to +125°C 100 28701- BMR 702 Rev. D © Flex, October 2023 Mechanical Data 3.0 - 3.5 (0.120 - 0.140) PIN SECTION Width Thickness Connections Pin Designation 2 3 9 10 11 14 15 16 22 23 – In –In NC/Rtn NC NC/–Out +Out NC Rtn +In +In Weight: Maximum 15 g (0.53 oz). Function Single output Dual output Negative input Negative input Not connected Not connected Not connected Positive output Not connected Output return Positive input Positive input Negative input Negative input Output return Not connected Negative output Positive output Not connected Output return Positive input Positive input Pins: Material: Copper Plating: 3 µm Tin over 1.5 µm Ni Case: Non-conductive plastic, UL 94V-0. 28701- BMR 702 Rev. D © Flex, October 2023 3 PKV 3211 PI Output TA =+25°C, VI = 9...36 V unless otherwise specified. Characteristics VO IO =0.1 …1.0 × IO max and long term drift Line regulation IO =IOmax Load regulation IO =0.1 …1.0 × IO max, VI = 26 V Load transient recovery time Vtr Load transient voltage Tcoeff Temperature coefficient tr Ramp-up time ts Start-up time IO Output current max min Output voltage tolerance band ttr PO Output 1 Conditions 4.90 IO= 0.1 …1.0 × IO max, VI = 26 V load step = 0.5 × IO max IO= 0.1…1.0 × IO max, VI = 26 V 10 25 mV 10 50 mV 300 µs +100 mV –100 mV ±0.02 0.5 From VI connection to VO = 0.9 × VOi 800 TC < TC max Isc Short circuit current VI =26 V VO ac Output ripple & noise IO =IO max,TA = 25 °C 1300 ms 0.5 A SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) W 0.5 DC 20 MHz %/°C ms 2.5 Current limiting threshold1) Unit V 0.1 …0.9 × VO Max output power max 5.10 Measured after stabilization Ilim 1) At typ 1.62 A 0.25 A 60 mVp-p 60 dB Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) 4 Power derating Characteristics Conditions min typ η Efficiency IO = IOmax, VI = 26 V 76 82 Pd Power dissipation IO =IO max, VI = 26 V 0.55 max Unit % 0.79 28701- BMR 702 Rev. D © Flex, October 2023 W PKV 3313 PI Output TA = +25°C, VI = 9...36 V unless otherwise specified. Characteristics VO min Output voltage tolerance band IO =0.1 …1.0 × IO max and long term drift Line regulation IO =IOmax Load regulation IO =0.1 …1.0 × IO max, VI = 26 V Vtr Load transient voltage Tcoeff Temperature coefficient tr Ramp-up time ts Start-up time IO Output current max IO= 0.1 …1.0 × IO max, VI = 26 V load step = 0.5 × IO max IO= 0.1…1.0 × IO max, VI = 26 V max V 24 60 mV 24 120 mV 300 µs +150 mV –150 mV ± 0.02 0.1 …0.9 × VO 1.2 From VI connection to VO = 0.9 × VOi 800 Max output power TC < TC max Isc Short circuit current VI =26 V VO ac Output ripple & noise IO =IO max,TA = 25 °C 1300 ms 0.25 A SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) W 0.25 DC … 20 MHz %/°C ms 3 Current limiting threshold1) Unit 12.24 Measured after stabilization Ilim 1) At typ 11.76 Load transient recovery time ttr PO Output 1 Conditions 0.81 A 0.35 A 60 mVp-p 60 dB Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Power derating Efficiency (typ) Characteristics Conditions min typ η Efficiency IO = IOmax, VI = 26 V 76 82 Pd Power dissipation IO =IO max, VI = 26 V 28701- BMR 702 Rev. D © Flex, October 2023 0.66 max Unit % 0.95 W 5 PKV 3315 PI Output TA = +25°C, VI = 9...36 V unless otherwise specified. Characteristics VO Output 1 Conditions min Output voltage tolerance band IO =0.1 …1.0 × IO max and long term drift Line regulation IO =IOmax Load regulation IO =0.1 …1.0 × IO max, VI = 26 V 14.7 Load transient recovery time ttr IO= 0.1 …1.0 × IO max, VI = 26 V load step = 0.5 × IO max Vtr Load transient voltage Tcoeff Temperature coefficient Measured after stabilization tr Ramp-up time ts Start-up time IO= 0.1…1.0 × IO max, VI = 26 V IO Output current PO max max V 30 75 mV 30 150 mV 300 µs +200 mV –200 mV 0.1 …0.9 × VO 1.2 From VI connection to VO = 0.9 × VOi 800 Max output power TC < TC max Isc Short circuit current VI =26 V VO ac Output ripple & noise IO =IO max,TA = 25 °C 1300 ms 0.2 A SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) W 0.2 DC … 20 MHz %/°C ms 3 Current limiting threshold1) Unit 15.3 ±0.02 Ilim 1) At typ 0.65 A 0.35 A 60 mVp-p 60 dB Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) 6 Power derating Characteristics Conditions min typ η Efficiency IO = IOmax, VI = 26 V 76 82 Pd Power dissipation IO =IO max, VI = 26 V 0.66 max Unit % 0.95 28701- BMR 702 Rev. D © Flex, October 2023 W PKV 3222 PI Output TA =+25°C, VI = 9...36V unless otherwise specified. Characteristics VO Output 1 Conditions min +5.1 –4.9 Line regulation IO =IOmax 10 25 Load regulation IO =0.1 …1.0 × IO max, VI = 26 V 10 50 +4.9 IO= 0.1 …1.0 × IO max, VI = 26 V load step = 0.5 × IO max Load transient voltage Tcoeff Temperature coefficient Measured after stabilization tr Ramp-up time ts Start-up time IO= 0.1…1.0 × IO max, VI = 26 V IO Output current typ max –5.1 V 10 25 mV 10 50 mV 300 µs +100 +100 mV –100 –100 mV ±0.02 1.2 From VI connection to VO = 0.9 × VOi 800 ±0.02 1.2 1300 800 1.25 Current limiting threshold1) TC < TC max Isc Short circuit current VI =26 V VO ac Output ripple & noise IO =IO max, TA = 25 °C SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) 1300 ms 0.25 A 1.25 0.25 0.81 %/°C ms 0.25 Max output power Unit 300 0.1 …0.9 × VO Ilim 1) At min IO =0.1 …1.0 × IO max and long term drift Vtr max max Output voltage tolerance band Load transient recovery time ttr PO typ Output 2 W 0.25 0.81 A 0.25 0.25 A 60 60 mVp-p 45 45 dB DC …20 MHz Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) Power derating Characteristics Conditions η Efficiency IO = IOmax, VI = 26 V Pd Power dissipation IO = IO max, VI = 26 V 28701- BMR 702 Rev. D © Flex, October 2023 min typ 75 82 0.55 max Unit % 0.83 W 7 PKV 3321 PI Output TA = +25°C, VI = 9...36V unless otherwise specified. Characteristics VO min +12.24 –11.76 Line regulation IO =IOmax 24 60 Load regulation IO =0.1 …1.0 × IO max, VI = 26 V 24 120 +11.76 IO= 0.1 …1.0 × IO max, VI = 26 V load step = 0.5 × IO max Tcoeff Temperature coefficient Measured after stabilization tr Ramp-up time ts Start-up time IO= 0.1…1.0 × IO max, VI = 26 V IO Output current typ max –12.24 V 24 60 mV 24 120 mV 300 µs +150 +150 mV –150 –150 mV ±0.02 1.2 From VI connection to VO = 0.9 × VOi 800 ±0.02 1.2 1300 800 1.5 Current limiting threshold1) TC < TC max Isc Short circuit current VI =26 V VO ac Output ripple & noise IO =IO max, TA = 25 °C SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) 1300 ms 0.125 A 1.5 0.125 0.400 %/°C ms 0.125 Max output power Unit 300 0.1 …0.9 × VO Ilim 1) At max IO =0.1 …1.0 × IO max and long term drift Load transient voltage max Output 2 Output voltage tolerance band Vtr PO typ min Load transient recovery time ttr W 0.125 0.400 A 0.35 0.35 A 60 60 mVp-p 45 45 dB DC …20 MHz Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Power derating Efficiency (typ) 8 Output 1 Conditions Characteristics Conditions min typ η Efficiency IO = IOmax, VI = 26 V 73 82 Pd Power dissipation IO = IO max, VI = 26 V 0.66 max Unit % 1.11 28701- BMR 702 Rev. D © Flex, October 2023 W PKV 3325 PI Output TA = +25°C, VI = 9...36V unless otherwise specified. Characteristics VO Output 1 Conditions +15.3 –14.7 Line regulation IO =IOmax 30 75 Load regulation IO =0.1 …1.0 × IO max, VI = 26 V 30 150 +14.7 IO= 0.1 …1.0 × IO max, VI = 26 V load step = 0.5 × IO max Load transient voltage Tcoeff Temperature coefficient Measured after stabilization tr Ramp-up time ts Start-up time IO= 0.1…1.0 × IO max, VI = 26 V IO Output current typ max –15.3 V 30 75 mV 30 150 mV 300 µs +200 +200 mV –200 –200 mV ±0.02 1.2 From VI connection to VO = 0.9 × VOi 800 ±0.02 1.2 1300 800 1.5 Current limiting threshold1) TC < TC max Isc Short circuit current VI =26 V VO ac Output ripple & noise IO =IO max, TA = 25 °C SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) 1300 ms 0.1 A 1.5 0.10 0.32 %/°C ms 0.1 Max output power Unit 300 0.1 …0.9 × VO Ilim 1) At min IO =0.1 …1.0 × IO max and long term drift Vtr max max Output voltage tolerance band Load transient recovery time ttr PO typ min Output 2 W 0.10 0.32 A 0.35 0.35 A 50 50 mVp-p 45 45 dB DC …20 MHz Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) Power derating Characteristics Conditions η Efficiency IO = IOmax, VI = 26 V Pd Power dissipation IO = IO max, VI = 26 V 28701- BMR 702 Rev. D © Flex, October 2023 min typ 76 80 0.75 max Unit % 0.95 W 9 PKV 5211 PI Output TA = +25°C, VI = 18...72V unless otherwise specified. Maximum Recommended Capacitive Load = 660μF. Characteristics VO IO =0.1 …1.0 × IO max and long term drift Line regulation IO =IOmax Load regulation IO =0.1 …1.0 × IO max, VI = 53 V Load transient recovery time Vtr Load transient voltage Tcoeff Temperature coefficient tr Ramp-up time ts Start-up time IO Output current max min Output voltage tolerance band ttr PO Output 1 Conditions 4.90 IO= 0.1 …1.0 × IO max, VI = 53 V load step = 0.5 × IO max IO= 0.1…1.0 × IO max, VI = 53 V 10 25 mV 10 50 mV 300 µs +100 mV –100 mV ±0.02 0.5 From VI connection to VO = 0.9 × VOi 900 TC < TC max Isc Short circuit current VI =53 V VO ac Output ripple & noise IO =IO max,TA = 25 °C 1300 ms 0.5 A SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) W 0.5 DC … 20 MHz %/°C ms 2.5 Current limiting threshold1) Unit V 0.1 …0.9 × VO Max output power max 5.10 Measured after stabilization Ilim 1) At typ 1.62 A 0.12 A 60 mVp-p 60 dB Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) Power derating Characteristics Conditions η Efficiency IO = IOmax, VI = 53 V Pd Power dissipation IO = IO max, VI = 53 V 10 min typ 75 82 0.55 max Unit % 0.84 W 28701- BMR 702 Rev. D © Flex, October 2023 PKV 5315 PI Output TA = +25°C, VI = 18...72V unless otherwise specified. Characteristics VO min Output voltage tolerance band IO =0.1 …1.0 × IO max and long term drift Line regulation IO =IOmax Load regulation IO =0.1 …1.0 × IO max, VI = 53 V Vtr Load transient voltage Tcoeff Temperature coefficient tr Ramp-up time ts Start-up time IO Output current max IO= 0.1 …1.0 × IO max, VI = 53 V load step = 0.5 × IO max IO= 0.1…1.0 × IO max, VI = 53 V 30 75 mV 30 150 mV 300 µs +200 mV –200 mV ±0.02 1.2 From VI connection to VO = 0.9 × VOi 900 TC < TC max Isc Short circuit current VI =53 V VO ac Output ripple & noise IO =IO max,TA = 25 °C 1300 ms 0.2 A SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) W 0.20 DC … 20 MHz %/°C ms 3 Current limiting threshold1) Unit V 0.1 …0.9 × VO Max output power max 15.3 Measured after stabilization Ilim 1) At typ 14.7 Load transient recovery time ttr PO Output 1 Conditions 0.65 A 0.17 A 60 mVp-p 60 dB Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) Power derating Characteristics Conditions η Efficiency IO = IOmax, VI = 53 V Pd Power dissipation IO = IO max, VI = 53 V 28701- BMR 702 Rev. D © Flex, October 2023 min typ 76 82 0.66 max Unit % 0.95 W 11 PKV 5222 PI Output TA = +25°C, VI = 18...72V unless otherwise specified. Characteristics VO Output 1 Conditions min +5.1 –4.9 Line regulation IO =IOmax 10 25 Load regulation IO =0.1 …1.0 × IO max, VI = 53 V 10 50 +4.9 Vtr Load transient voltage Tcoeff Temperature coefficient Measured after stabilization tr Ramp-up time ts Start-up time IO= 0.1…1.0 × IO max, VI = 53 V IO Output current IO= 0.1 …1.0 × IO max, VI = 53 V load step = 0.5 × IO max typ max –5.1 V 10 25 mV 10 50 mV 300 µs +100 +100 mV –100 –100 mV ±0.02 1.2 From VI connection to VO = 0.9 × VOi 900 ±0.02 1.2 1300 900 1.25 Current limiting threshold1) TC < TC max Isc Short circuit current VI =53 V VO ac Output ripple & noise IO =IO max, TA = 25 °C SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) 1300 ms 0.25 A 1.25 0.25 0.81 %/°C ms 0.25 Max output power Unit 300 0.1 …0.9 × VO Ilim 1) At min IO =0.1 …1.0 × IO max and long term drift Load transient recovery time max max Output voltage tolerance band ttr PO typ Output 2 W 0.25 0.81 A 0.12 0.12 A 60 60 mVp-p 45 45 dB DC …20 MHz Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) 12 Power derating Characteristics Conditions min typ η Efficiency IO = IOmax, VI = 53 V 75 82 Pd Power dissipation IO = IO max, VI = 53 V 0.55 max Unit % 0.83 28701- BMR 702 Rev. D © Flex, October 2023 W PKV 5321 PI Output TA = +25°C, VI = 18...72V unless otherwise specified. Characteristics VO max min +12.24 –11.76 IO =0.1 …1.0 × IO max and long term drift Line regulation IO =IOmax 24 60 Load regulation IO =0.1 …1.0 × IO max, VI = 53 V 24 120 Load transient voltage Tcoeff Temperature coefficient tr Ramp-up time ts Start-up time IO Output current max Output 2 Output voltage tolerance band Vtr +11.76 IO= 0.1 …1.0 × IO max, VI = 53 V load step = 0.5 × IO max IO= 0.1…1.0 × IO max, VI = 53 V typ max –12.24 V 24 60 mV 24 120 mV 300 µs +150 +150 mV –150 –150 mV ±0.02 0.1 …0.9 × VO 1.2 From VI connection to VO = 0.9 × VOi 900 ±0.02 1.2 1300 900 1.5 Current limiting threshold1) TC < TC max Isc Short circuit current VI =53 V VO ac Output ripple & noise IO =IO max, TA = 25 °C SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) 1300 ms 0.125 A 1.5 0.125 0.400 DC …20 MHz %/°C ms 0.125 Max output power Unit 300 Measured after stabilization Ilim 1) At typ min Load transient recovery time ttr PO Output 1 Conditions W 0.125 0.400 A 0.17 0.17 A 60 60 mVp-p 45 45 dB Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) Power derating Characteristics Conditions η Efficiency IO = IOmax, VI = 53 V Pd Power dissipation IO = IO max, VI = 53 V 28701- BMR 702 Rev. D © Flex, October 2023 min typ 73 82 0.66 max Unit % 1.11 W 13 PKV 5325 PI Output TA = +25°C, VI = 18...72V unless otherwise specified. Characteristics VO Output 1 Conditions +15.3 –14.7 Line regulation IO =IOmax 30 75 Load regulation IO =0.1 …1.0 × IO max, VI = 53 V 30 150 +14.7 Vtr Load transient voltage Tcoeff Temperature coefficient Measured after stabilization tr Ramp-up time ts Start-up time IO= 0.1…1.0 × IO max, VI = 53 V IO Output current IO= 0.1 …1.0 × IO max, VI = 53 V load step = 0.5 × IO max typ max –15.3 V 30 75 mV 30 150 mV 300 µs +200 +200 mV –200 –200 mV ±0.02 1.2 From VI connection to VO = 0.9 × VOi 900 ±0.02 1.2 1300 900 1.5 Current limiting threshold1) TC < TC max Isc Short circuit current VI =53 V VO ac Output ripple & noise IO =IO max, TA = 25 °C SVR Supply voltage rejection (ac) f = 100/120 Hz sine wave, 1 Vp-p, (SVR = 20 log (1 Vp-p/VOp-p)) 1300 ms 0.1 A 1.5 0.10 0.32 %/°C ms 0.1 Max output power Unit 300 0.1 …0.9 × VO Ilim 1) At min IO =0.1 …1.0 × IO max and long term drift Load transient recovery time max max Output voltage tolerance band ttr PO typ min Output 2 W 0.10 0.32 A 0.17 0.17 A 60 60 mVp-p 45 45 dB DC …20 MHz Vout ≤ 80% of nominal the power module goes into hick up mode. Miscellaneous Efficiency (typ) 14 Power derating Characteristics Conditions η Efficiency IO = IOmax, VI = 53 V Pd Power dissipation IO = IO max, VI = 53 V min typ 76 82 0.66 max Unit % 0.95 28701- BMR 702 Rev. D © Flex, October 2023 W EMC Specifications The PKV DC/DC power module is mounted on a double sided printed circuit board (PB) with groundplane during EMC measurements. The fundamental switching frequency is approx. 200 kHz. The PKV series has a good input filter and will only need a simple filter to meet conducted noise according to EN 55022 level B. Fig. 1 shows an example of filter and the results for this filter is shown below. Fig. 1 Conducted noise PKV 3211 without filter PKV 3211 with filter PKV 5211 without filter PKV 5211 with filter 28701- BMR 702 Rev. D © Flex, October 2023 15 Delivery Package Information ∙ The PKV series DC/DC converters are delivered in tubes with a lenght of 384 mm (15.1 in) Tube Specification Material: Max surface resistance: Color: Capacity: Weight: End stops Test set up Miscellaneous Soldering Information The PKV Series DC/DC Converters are intended for through hole mounting in a PCB. When wave soldering is used, the temperature on the pins is specified to maximum 260 °C for maximum 10 seconds. Maximum preheat rate of 4 °C/s and temperature of max 150 °C is suggested. When hand soldering, care should be taken to avoid direct contact between the hot soldering iron tip and the pins for more than a few seconds in order to prevent overheating. A no-clean (NC) flux is recommended to avoid entrapment of cleaning fluids in cavities inside of the DC/DC power module. The residues may affect long time reliability and isolation voltage. External Decoupling Capacitors When powering loads with significant dynamic current requirements, the voltage regulation at the point of load can be improved by addition of decoupling capacitors at the load. The most effective technique is to locate low ESR ceramic and electrolytic capacitors as close to the load as possible, using several parallel capacitors to lower the effective ESR. The ceramic capacitors will handle highfrequency dynamic load changes while the electrolytic capacitors are used to handle low frequency dynamic load changes. Ceramic capacitors will also reduce any high frequency noise at the load. It is equally important to use low resistance and low inductance PCB layouts and cabling. PVC 10 to1000 MOhm/sq Transparent 10 pcs/tube typ 160 g Pins Reliability According to MIL-HDBK-217F the calculated MTBF value at 100% load (from PKV 5211 PI) at the following ambient temperatures will be approx.: Tamb 0 °C 10 °C 25 °C 40 °C 60 °C 75 °C Hours 2.7 million 1.5 million 650 000 276 000 88 000 37 000 At 80–100% load the case temperature will be approx. 15–20 °C higher than the ambient temperature. Compatibility with RoHS requirements The products are compatible with the relevant clauses and requirements of the RoHS directive 2011/65/EU and have a maximum concentration value of 0.1% by weight in homogeneous materials for lead, mercury, hexavalent chromium, PBB and PBDE and of 0.01% by weight in homogeneous materials for cadmium. Exemptions in the RoHS directive utilized in Flex products are found in the Statement of Compliance document. Flex fulfills and will continuously fulfill all its obligations under regulation (EC) No 1907/2006 concerning the registration, evaluation, authorization and restriction of chemicals (REACH) as they enter into force and is through product materials declarations preparing for the obligations to communicate information on substances in the products. External decoupling capacitors will become part of the control loop of the DC/DC converter and may affect the stability margins. As a “rule of thumb”, 100 µF/A of output current can be added without any additional analysis. The ESR of the capacitors is a very important parameter. Power Modules guarantee stable operation with a verified ESR value of > 10 mOhm across the output connections. For further information please contact your local Flex representative. 16 28701- BMR 702 Rev. D © Flex, October 2023 Quality Statement The PKV series DC/DC converters are designed and manufactured in an industrial environment where quality systems and methods like ISO 9000 and SPC are intensively in use to boost the continuous improvements strategy. Infant mortality or early failures in the products are screened out by a burn-in procedure. Warranty Warranty period and conditions are defined in Flex General Terms and Conditions of Sale. Limitation of liability Flex does not make any other warranties, expressed or implied including any warranty of merchantability or fitness for a particular purpose (including, but not limited to, use in life support applications, where malfunctions of product can cause injury to a person’s health or life). © Flex 2023 The information and specifications in this technical specification is believed to be correct at the time of publication. However, no liability is accepted for inaccuracies, printing errors or for any consequences thereof. Flex reserves the right to change the contents of this technical specification at any time without prior notice. 28701- BMR 702 Rev. D © Flex, October 2023 17 Product Program VI VO/IO max PO max Ordering No. 12/24 V 5 V/500 mA 12 V/250 mA 15 V/200 mA ± 5 V/250 mA ±12 V/125 mA ±15 V/100 mA 2.5 W 3.0 W 3.0 W 2.5 W 3.0 W 3.0 W PKV3211PI PKV3313PI PKV3315PI PKV3222PI PKV3321PI PKV3325PI 48/60 V 5 V/500 mA 15 V/200 mA ± 5 V/250 mA ±12 V/125 mA ±15 V/100 mA 2.50 W 3.00 W 2.50 W 3.00 W 3.00 W PKV 5211 PI PKV 5315 PI PKV 5222 PI PKV 5321 PI PKV 5325 PI Information given in this data sheet is believed to be accurate and reliable. No responsibility is assumed for the consequences of its use nor for any infringement of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Flex. These products are sold only according to Flex general conditions of sale, unless otherwise confirmed in writing. Specifications subject to change without notice. The latest and most complete information can be found on our website. Datasheet 18 28701- BMR 702 Rev.D © Flex, October 2023 28701- BMR 702 Rev. D © Flex, October 2023
PKV5222PI 价格&库存
很抱歉,暂时无法提供与“PKV5222PI”相匹配的价格&库存,您可以联系我们找货
PKV5222PI
    • 1+439.06320
    • 150+175.18680
    • 450+169.33320
    • 1050+166.44960
