S243N101J502CT
S243N101J502CT
    WALSIN(华新科)
    等级:X1,Y2 100PF ±5% 250V
S243N101J502CT 数据手册
Multilayer Ceramic Capacitors Approval Sheet MULTILAYER CERAMIC CAPACITORS Safety Certified X1/Y2, S2 Series 1808 to 2220 Sizes NP0 & X7R Dielectrics Halogen Free & RoHS Compliance *Contents in this sheet are subject to change without prior notice. Page 1 of 11 ASC Safety Certified X1/Y2_(S2)_010AA Nov. 2020 Multilayer Ceramic Capacitors Approval Sheet 1. DESCRIPTION WTC’s SAFETY CERTIFIED CAPACITORS are designed for surge or lightning immunity in modem facsimile and other equipments. The capacitors of series S2 are class X1/Y2 compliant respectively. The green type capacitors in S2 and S3 series are manufactured by using environmentally friendly materials without lead or cadmium. The terminations are composed of plated nickel and pure tin to feature the superior leaching resistance during soldering. 2. FEATURES 3. APPLICATIONS a. b. c. d. a. b. c. d. e. f. High reliability and stability. Small size and high capacitance RoHS compliant Safety standard approval by EN 60384-14 : 2013 IEC 60384-14 : 2013 UL 60384-14 (Ed 2.0) Certificate number: TUV: R50195920, TUV: R50381780 UL: E182369 HALOGEN compliant. Modem. Facsimile. Telephone. Other electronic equipment for lighting or surge protection and isolation 4. HOW TO ORDER S2 42 N 100 J 502 C T Series Size Dielectric Capacitance Tolerance Impulse voltage Termination Packaging S2=X1/Y2 Safety Certified 42=1808 (4520) N=NP0 43=1812 (4532) B=X7R 52=2211 (5728) 55=2220 (5750) Two significant digits followed by no. of zeros. And R is in place of decimal point. eg.: 0R5=0.5pF 1R0=1.0pF 100=10x100 =10pF Page 2 of 11 D= ±0.5pF F= ±1.0% G= ±2.0% J= ±5.0% K= ±10% M= ±20% Two significant C=Cu/Ni/Sn T=7” reeled digits followed by E=Cu+Conductive G=13” reeled no. of zeros. And R resin /Ni /Sn is in place of decimal point. 502: 5000V Impulse Voltage 602: 6000V Impulse Voltage ASC Safety Certified X1/Y2_(S2)_010AA Nov. 2020 Multilayer Ceramic Capacitors Approval Sheet 5. EXTERNAL DIMENSIONS & STRUCTURE 5-1 Safety certified Caps. Size Inch (mm) L (mm) W (mm) T (mm) MB (mm) 1808 (4520) 4.50 +0.5/-0.3 2.00±0.25 0.50±0.25 1812 (4532) 4.50 +0.5/-0.3 3.20±0.40 2211 (5728) 5.70±0.40 2.80±0.30 2220 (5750) 5.70±0.40 5.00±0.40 1.25±0.10 (D) 1.40±0.15 (F) 1.60±0.20 (G) 2.00±0.20 (K) 2.50±0.30 (M) 2.80±0.30 (U) L T 0.50±0.25 W 0.60±0.30 MB 0.60±0.30 MB Fig. 1 The outline of MLCC 5-2 Safety certified Caps. with soft termination Size Inch (mm) L (mm) W (mm) T (mm) MB (mm) 1808 (4520) 4.50 +0.6/-0.3 2.00±0.30 0.50±0.25 1812 (4532) 4.50 +0.6/-0.3 3.20±0.40 2211 (5728) 5.70±0.50 2.80±0.40 2220 (5750) 5.70±0.50 5.00±0.50 1.25±0.10 (D) 1.40±0.15 (F) 1.60±0.20 (G) 2.00±0.20 (K) 2.50±0.30 (M) 2.80±0.30 (U) 0.50±0.25 0.60±0.30 0.60±0.30 # Reflow soldering only is recommended 6. GENERAL ELECTRICAL DATA Dielectric Size Capacitance NP0 1808, 1812, 2211 3pF to 680pF X7R 1808, 1812, 2211, 2220 100pF to 4700pF Cap.1000pF, 1.0±0.2Vrms, 1KHz±10%. * Capacitance is within specified tolerance. * CR means rated capacitance for conform to the E6 series of preferred values given in IEC 60063. Dielectric * Class II : (X7R) 1.0±0.2Vrms, 1KHz±10%. Q≥1000 Cap.≥30pF Q≥400+20C Cap.500 500Vdc ≤50mA 60 sec. 7. Solderability IEC 60384-21/22 4.10 8. Resistance IEC 60384-14 to Soldering 4.4 Heat IEC 60384-21/22 4.9 Q/D.F. * Solder temperature: 235±5°C(0201~1210). * Solder temperature: 245±5°C(1808~2225). * Dipping time : 2±0.5 sec. * Solder temperature : 260±5°C. * Dipping time : 10±1 sec. * Preheating : 120 to 150°C for 1 minute before immerse the capacitor in a eutectic solder. * Measurement to be made after keeping at room temperature for 24±2 hrs. ≥100GΩ or RxC≥1000Ω-F, whichever is smaller ≥10GΩ or RxC≥500Ω-F, whichever is smaller * 75% min. coverage of all metalized area. Dielectric I.R. Class I (C0G) Class II (X7R) Cap. Change Q/D.F. Within ±2.5% or ≤100% of ≥1GΩ ±0.25pF, whichever initial is larger requireme nt ≥1GΩ Within ±7.5% * Conduct the five cycles according to the temperatures and time. Step Temp.(°C) Time(min.) 1 Min. operating temp. +0/-3 30±3 2 Room temp. 2~3 3 Max.operating temp. +3/-0 30±3 4 Room temp. 2~3 Dielectric * Measurement to be made after keeping at room temperature for 24±2 hrs. Class I (C0G) Class II (X7R) I.R. Cap. Change Q/D.F. Within ±2.5% ≤1.0(Q) × or ±0.25pF, initial To meet whichever is requirement initial larger require ≤1.5(D.F.) × ment Within ±7.5% initial requirement * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 6 of 11 ASC Safety Certified X1/Y2_(S2)_010AA Nov. 2020 Multilayer Ceramic Capacitors Approval Sheet Standard Test Condition Method 10. Humidity IEC 60384-14 * Test temp. : 40±2°C. (Damp Heat) 4.12 * Humidity : 90~95% RH. Steady State * Test time : 500 +24/-0hrs. * Applied voltage : 250Vac. * Measurement to be made after keeping at room temp. for 24±2 hrs (Class I) and 48±4 hrs (Class II). No. Item 11. Passive IEC 60384-14 * Volume sample: 21.56 mm3 Flammability 4.17 * Flame exposure time: 5 sec Max. IEC 60384-1 * Category of flammability : C. 4.38 12. Active IEC Flammability 60384-21/22 4.18 Requirements * No remarkable damage. Dielectr I.R. Cap. Change ic Within ±3.0% or Class I ≥1GΩ or ±2pF, whichever (C0G) RxC≥ is larger 25Ω-F, whichever Class II is Within ±15% (X7R) smaller Q/D.F. ≤0.25% ≤2.0(D.F.) × initial requireme nt * Capacitor didn’t burn at all. * The capacitors applied UR (250Vac). Then each * The cheese cloth shall not burn with a flame. sample shall be subjected to 20 discharges from a tank capacitor, charge to a voltage that, when discharged, plase Ui 2500V for X1Y2 across the capacitor under test. The interval between successive discharges shall be 5 sec. 13. High IEC 60384-14 * Impulse Voltage : Temperature 4.14 Each individual capacitor shall be subjected to a Vp Load = 5.0KV (X1Y2 Class Impulse 5KV) & Vp = 6.0KV (Endurance) (X1Y2 Class Impulse 6KV) impulse for three times before applied to endurance test. * Test temp. : 125±3°C. * Test time: 1000 +48/-0 hrs. * Applied voltage : X capacitor: 1.25UR (312.5Vac). Y capacitor: 1.70UR (425Vac). Once every hour the voltage shall be increased to 1000Vrms for 0.1 sec. * Measurement to be made after keeping at room temp. for 24±2 hrs (Class I) and 48±4 hrs (Class II). * Appearance : No mechanical damage. * Cap. change : C0G within ±5% or ±0.5pF, whichever is larger. X7R within ±20%. * D.F. value : C0G≤0.25%. X7R≤5.0%. * I.R.≥1GΩ. * Dielectric strength satisfies the specified initial value. 14. Resistance IEC to Flexure of 60384-21/22 Substrate 4.8 * No remarkable damage. * Capacitors mounted on a substrate. The board shall be bent 1mm with a rate of 1mm/sec. 20 R = 230 50 1mm 45±1 Dielectric Cap. Change Class I (C0G) Class II (X7R) Within ±3.0% or ±2pF, whichever is larger Within ±12.5% (This capacitance change means the change of capacitance under specified flexure of substrate from the capacitance measured before the test) 45±1 * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 7 of 11 ASC Safety Certified X1/Y2_(S2)_010AA Nov. 2020 Multilayer Ceramic Capacitors No. Item Standard Method Approval Sheet Test Condition Requirements 15. Adhesive IEC * No remarkable damage or removal of the Strength of 60384-21/22 * Capacitors mounted on a substrate. A force of 10N terminations. Termination 4.15 applied perpendicular to the place of substrate IEC 60384-1 and parallel the line joining the center of terminations for 10±1 sec. 4.13 16. Vibration IEC 60384-1 * Reflow solder the capacitors on P. C. Board before * No remarkable damage. 4.17 test. * Cap. change and Q/D.F. : To meet initial spec. * Vibration frequency : 10~55 Hz/min. * Total amplitude : 1.5mm. * Repeat the conditions for 2 hours each in 3 perpendicular directions. 17. Impulse Voltage IEC 60384-14 4.13 * X1 : 4.0KV * Y2 : 5.0KV. * Number of impulse : 24 max. * There shall be no permanent breakdown or flashover. * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 8 of 11 ASC Safety Certified X1/Y2_(S2)_010AA Nov. 2020 Multilayer Ceramic Capacitors Approval Sheet EMBOSSED TAPE DIMENSIONS Fig. 2 The dimension of plastic tape Size 1808 1.25± ±0.10 Chip 1.40± ±0.15 Thickness 1.60± ±0.20
S243N101J502CT 价格&库存
很抱歉,暂时无法提供与“S243N101J502CT”相匹配的价格&库存,您可以联系我们找货
S243N101J502CT
  • 1000+2.259381000+0.29229
