CD40106BE
CD40106BE
    XBLW(芯伯乐)
    DIP14_19.2X6.6MM
    六路反相施密特触发器,工作电压(Vcc)(v)3-15V,静态电流Iq(Typ)0.02uA
CD40106BE 数据手册
XBLW CD40106 Six Inverting Buffers General Description The CD40106 provides six inverting buffers. Each input has a Schmitt trigger circuit. The inverting buffer switches at different points for positive-going and negative-going signals. The difference between the positive voltage (VT+) and the negative voltage (VT-) is defined as hysteresis voltage (VH). The CD40106 may be used for enhanced noise immunity or to “square up” slowly changing waveforms. It operates over a recommended VDD power supply range of 3V to 15V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. Features  Wide supply voltage range from 3V to 15V  Schmitt trigger input discrimination  Fully static operation  5V, 10V, and 15V parametric ratings  Standardized symmetrical output characteristics  Specified from -40℃ to +105℃  Packaging information: DIP14/SOP14/TSSOP14 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY CD40106BE CD40106BDTR CD40106BTDTR DIP-14 SOP-14 TSSOP-14 CD40106BE CD40106B CD40106B Tube Tape Tape 1000/Box 2500/Reel 3000/Reel XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 1 页 共 13 页 XBLW CD40106 Six Inverting Buffers Block Diagram And Pin Description Block Diagram Figure 1. Functional diagram Figure 2. Logic diagram(one gate) Pin Configurations XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 2 页 共 13 页 XBLW CD40106 Six Inverting Buffers Pin Description Pin No. Pin Name Description 1 2 3 4 5 6 7 8 9 10 11 12 13 14 1A 1Y 2A 2Y 3A 3Y VSS 4Y 4A 5Y 5A 6Y 6A VDD data input data output data input data output data input data output ground (0V) data output data input data output data input data output data input supply voltage Function Table Input Output nA L H Note: H=HIGH voltage level; L=LOW voltage level nY H L Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage DC input current input voltage storage temperature total power dissipation device dissipation VDD IIK VI Tstg any one input all inputs - -0.5 -0.5 -65 +18 ±10 VDD +0.5 +150 V mA V ℃ Ptot - - 500 mW - 100 mW ℃ ℃ Soldering temperature P TL per output transistor DIP 10s SOP 245 250 Note: [1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 3 页 共 13 页 XBLW CD40106 Six Inverting Buffers [3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. Recommended Operating Conditions Parameter Symbol Conditions Min. Typ. Max. Unit supply voltage ambient temperature VDD - 3 - 15 V Tamb in free air -40 - +105 ℃ Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter supply current Symbol IDD LOW-level output current IOL HIGH-level output current IOH LOW-level output voltage VOL HIGH-level output voltage VOH input leakage current II XBLW version 1.0 VO Conditions(V) VIN VDD Min. Tamb=25℃ Typ. Max. Unit - 0, 5 5 - 0.02 1 μA - 0, 10 10 - 0.02 2 μA - 0, 15 15 - 0.02 4 μA 0.4 0.5 1.5 4.6 2.5 9.5 13.5 - 0, 5 0, 10 0, 15 0, 5 0, 5 0, 10 0, 15 5 10 15 0 0 0 5 10 15 5 5 10 15 5 10 15 5 10 15 0.51 1.3 3.4 -0.51 -1.6 -1.3 -3.4 4.95 9.95 14.95 1 2.6 6.8 -1 -3.2 -2.6 -6.8 0 0 0 5 10 15 0.05 0.05 0.05 - mA mA mA mA mA mA mA V V V V V V - 0, 15 15 - ±10-5 ±0.1 μA 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 4 页 共 13 页 XBLW CD40106 Six Inverting Buffers DC Characteristics 2 (Tamb=-40℃ to +105℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter Symbol supply current IDD LOW-level output current IOL HIGH-level output current IOH LOW-level output voltage VOL HIGH-level output voltage VOH input leakage current II Conditions(V) VO VIN VDD Tamb=-40℃ Min. Max. Tamb=+85℃ Tamb=+105℃ Min. Max. Min. Max. Unit - 0, 5 5 - 1 - 30 - 30 μA - 0, 10 10 - 2 - 60 - 60 μA - 0, 15 15 - 4 - 120 - 120 μA 0.4 0.5 1.5 4.6 2.5 9.5 13.5 - 0, 5 0, 10 0, 15 0, 5 0, 5 0, 10 0, 15 5 10 15 0 0 0 5 10 15 5 5 10 15 5 10 15 5 10 15 0.61 1.5 4 -0.61 -1.8 -1.5 -4 4.95 9.95 14.95 0.05 0.05 0.05 - 0.42 1.1 2.8 -0.42 -1.3 -1.1 -2.8 4.95 9.95 14.95 0.05 0.05 0.05 - 0.36 0.9 2.4 -0.36 -1.15 -0.9 -2.4 4.95 9.95 14.95 0.05 0.05 0.05 - mA mA mA mA mA mA mA V V V V V V - 0, 15 15 - ±0.1 - ±1.0 - ±1.0 μA AC Characteristics (Tamb=25℃, VSS=0V, tr, tf=20ns, CL=50pF, RL=200KΩ, unless otherwise specified.) Parameter Symbol Conditions propagation delay time tPHL, tPLH see Figure 4 transition time tTHL, tTLH see Figure 4 input capacitance CI XBLW version 1.0 VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V any input Min. Typ. Max. Unit - 140 70 60 100 50 40 280 140 120 200 100 80 ns ns ns ns ns ns - 5 7.5 pF 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 5 页 共 13 页 XBLW CD40106 Six Inverting Buffers Transfer Characteristics1(Tamb=25℃, voltages are referenced to VSS(ground=0V) , unless otherwise specified.) Parameter Conditions (V) VO VIN VDD Symbol positive-going threshold voltage VT+ negative-going threshold voltage VT- hysteresis voltage VH - - 5 10 15 5 10 15 5 10 15 Tamb=25℃ Min. Typ. Max. 2.2 4.6 6.8 0.9 2.5 4 0.3 1.2 1.6 2.9 5.9 8.8 1.9 3.9 5.8 0.9 2.3 3.5 Unit 3.6 7.1 10.8 2.8 5.2 7.4 1.6 3.4 5 V V V V V V V V V Note: See Figure 5 and Figure 6. Transfer Characteristics2 (Tamb=-40℃~105℃, voltages are referenced to GND(ground=0V) , unless otherwise specified.) Parameter Symbol Conditions (V) VO VIN VDD VT+ negative-going threshold VTvoltage hysteresis VH voltage Note: See Figure 5 and Figure 6. positive-going threshold voltage XBLW version 1.0 - 5 10 15 5 10 15 5 10 15 Tamb=-40℃ Min. Max. 2.2 4.6 6.8 0.9 2.5 4 0.3 1.2 1.6 3.6 7.1 10.8 2.8 5.2 7.4 1.6 3.4 5 Tamb=+85℃ Min. Max. 2.2 4.6 6.8 0.9 2.5 4 0.3 1.2 1.6 Tamb=+105℃ Min. Max. 3.6 7.1 10.8 2.8 5.2 7.4 1.6 3.4 5 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 2.2 4.6 6.8 0.9 2.5 4 0.3 1.2 1.6 3.6 7.1 10.8 2.8 5.2 7.4 1.6 3.4 5 Unit V V V V V V V V V 第 6 页 共 13 页 XBLW CD40106 Six Inverting Buffers Testing Circuit AC Testing Circuit Figure 3. Test circuit for switching times Definitions for test circuit: DUT=Device Under Test CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. AC Testing Waveforms Figure 4. Propagation delay and output transition time XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 7 页 共 13 页 XBLW CD40106 Six Inverting Buffers Transfer Characteristics Waveforms Figure 5. Transfer characteristic Figure 6. Waveforms showing definition of VT+ and VT- (between limits at 30% and 70%) and VH XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 8 页 共 13 页 XBLW CD40106 Six Inverting Buffers Figure 7. Typical drain current as a function of input Measurement Points Supply voltage VDD 5V to 15V Input VM 0.5×VDD Output VM 0.5×VDD Test Data Supply voltage VDD VI tr, tf Load CL 5V to 15V VSS or VDD ≤20ns 50pF XBLW version 1.0 Input 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 9 页 共 13 页 XBLW CD40106 Six Inverting Buffers Package Information DIP14 Symbol A A1 A2 B B1 C D E E1 e L E2 XBLW version 1.0 Dimensions In Millimeters Min Max 3.710 4.310 0.510 3.200 3.600 0.380 0.570 1.524(BSC) 0.204 0.360 18.800 19.200 6.200 6.600 7.320 7.920 2.540(BSC) 3.000 3.600 8.400 9.000 Dimensions In Inches Min Max 0.146 0.170 0.020 0.126 0.142 0.015 0.022 0.060(BSC) 0.008 0.014 0.740 0.756 0.244 0.260 0.288 0.312 0.100(BSC) 0.118 0.142 0.331 0.354 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 10 页 共 13 页 XBLW CD40106 Six Inverting Buffers SOP14 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 11 页 共 13 页 XBLW CD40106 Six Inverting Buffers TSSOP14 SYMBOL A A1 A2 A3 b b1 c c1 D E1 E e L L1 θ XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 MILLIMETER MIN MAX 1.20 0.05 0.15 0.90 1.05 0.39 0.49 0.20 0.30 0.19 0.25 0.13 0.19 0.12 0.14 4.86 5.06 4.30 4.50 6.20 6.60 0.65BSC 0.45 0.75 1.00BSC 0° 8° 第 12 页 共 13 页 XBLW CD40106 Six Inverting Buffers Statements And Notes Part name Lead and lead compounds Lead frame ○ Plastic resin ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ The lead Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ explanation Cadmium and cadmium compounds ○ Hazardous substances or Elements Polybro Hexavalent Polybro minated Dibutyl chromium minated biphenyl phthalate compounds biphenyls ethers ○ ○ ○ ○ Mercury and mercury compounds ○ Butyl benzyl phthalate Di-2ethylhexyl phthalate Diisobutyl phthalate ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 13 页 共 13 页
CD40106BE 价格&库存
很抱歉,暂时无法提供与“CD40106BE”相匹配的价格&库存,您可以联系我们找货
