CD4001BE
CD4001BE
    XBLW(芯伯乐)
    DIP14_19.2X6.6MM
    通用逻辑门芯片 四路二输入或与非门电路,工作电压(Vcc)(v)3-15V,静态电流Iq(Typ)0.01uA
CD4001BE 数据手册
XBLW CD4001 Quad 2-Input NOR Gate General Description The CD4001 is a quad 2-input NOR gate. The outputs are fully buffered for the highest noise immunity and pattern insensitivity to output impedance. It operates over a recommended VDD power supply range of 3V to 15V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. Features  Wide supply voltage range from 3V to 15V  Fully static operation  5V, 10V, and 15V parametric ratings  Standardized symmetrical output characteristics  Inputs and outputs are protected against electrostatic effects  Specified from -40℃ to +85℃  Packaging information: DIP14/SOP14/TSSOP14 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY CD4001BE CD4001BDTR CD4001BTDTR DIP-14 SOP-14 TSSOP-14 CD4001BE CD4001B CD4001B Tube Tape Tape 1000/Box 2500/Reel 3000/Reel XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 1 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate Block Diagram And Pin Description Block Diagram Figure 1. Functional diagram Figure 2. Logic diagram(one gate) Pin Configurations XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 2 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate Pin Description Pin No. Pin Name Description 1 1A 2 1B 3 1Y 4 2Y 5 2A 6 2B 7 VSS 8 3A 9 3B 10 3Y 11 4Y 12 4A 13 4B 14 VDD Note: CPD, CPU is LOW-to-HIGH, edge triggered. data input data input data output data output data input data input ground(0V) data input data input data output data output data input data input supply voltage Function Table nA Input L L H H Note: H=HIGH voltage level; L=LOW voltage level; XBLW version 1.0 nB Output nY L H L H H L L L 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 3 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage DC input current input voltage storage temperature total power dissipation device dissipation VDD IIK VI Tstg any one input all inputs - -0.5 -0.5 -65 +18 ±10 VDD +0.5 +150 V mA V ℃ Ptot - - 500 mW P per output transistor - 100 mW ℃ ℃ Soldering temperature TL DIP SOP 10s 245 250 Note: [1] For DIP14 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP14 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP14 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. Recommended Operating Conditions Parameter Symbol Conditions Min. Typ. Max. Unit supply voltage ambient temperature VDD - 3 - 15 V Tamb - -40 - +85 ℃ XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 4 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter supply current LOW-level output current HIGH-level output current LOW-level output voltage HIGH-level output voltage LOW-level input voltage Symbol VDD IOL IOH VOL VOH VIL HIGH-level input voltage VIH input leakage current II XBLW version 1.0 VO Conditions(V) VIN VDD Min. Tamb=25℃ Typ. Max. Unit - 0, 5 5 - 0.01 0.25 μA - 0, 10 10 - 0.01 0.5 μA - 0, 15 15 - 0.01 1 μA 0.4 0, 5 5 0.51 1 - mA 0.5 0, 10 10 1.3 2.6 - mA 1.5 0, 15 15 3.4 6.8 - mA 4.6 0, 5 5 -0.51 -1 - mA 2.5 0, 5 5 -1.6 -3.2 - mA 9.5 0, 10 10 -1.3 -2.6 - mA 13.5 0, 15 15 -3.4 -6.8 - mA - 0, 5 5 - 0 0.05 V - 0, 10 10 - 0 0.05 V - 0, 15 15 - 0 0.05 V - 0, 5 5 4.95 5 - V - 0, 10 10 9.95 10 - V - 0, 15 15 14.95 15 - V 0.5, 4.5 - 5 - - 1.5 V 1, 9 - 10 - - 3 V 1.5, 13.5 - 15 - - 4 V 0.5 - 5 3.5 - - V 1 - 10 7 - - V 1.5 - 15 11 - - V - 0, 15 15 - ±10-5 ±0.1 μA 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 5 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter Symbol supply current VDD LOW-level output current IOL HIGH-level output current IOH LOW-level output voltage VOL HIGH-level output voltage VOH LOW-level input voltage VIL HIGH-level input voltage VIH input leakage current II XBLW version 1.0 Conditions(V) VO VIN VDD Tamb=-40℃ Min. Max. Tamb=+85℃ Min. Max. Unit - 0, 5 5 - 0.25 - 7.5 μA - 0, 10 10 - 0.5 - 15 μA - 0, 15 15 - 1 - 30 μA 0.4 0.5 1.5 4.6 2.5 9.5 13.5 0.5, 4.5 1, 9 1.5, 13.5 0.5 1 1.5 0, 5 0, 10 0, 15 0, 5 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 - 5 10 15 5 5 10 15 5 10 15 5 10 15 5 10 15 5 10 15 0.61 1.5 4 -0.61 -1.8 -1.5 -4 4.95 9.95 14.95 3.5 7 11 0.05 0.05 0.05 1.5 3 4 - 0.42 1.1 2.8 -0.42 -1.3 -1.1 -2.8 4.95 9.95 14.95 3.5 7 11 0.05 0.05 0.05 1.5 3 4 - mA mA mA mA mA mA mA V V V V V V V V V V V V - 0, 15 15 - ±0.1 - ±1 μA 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 6 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate AC Characteristics (Tamb=25℃, VSS=0V, tr, tf=20ns, CL=50pF, RL=200KΩ, unless otherwise specified.) Parameter Symbol Conditions propagation delay time tPHL, tPLH see Figure 4 transition time tTHL, tTLH see Figure 4 input capacitance CI VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V any input Min. Typ. Max. Unit - 125 60 45 100 50 40 250 120 90 200 100 80 ns ns ns ns ns ns - 5 7.5 pF Testing Circuit AC Testing Circuit Figure 3. Test circuit for measuring switching times Definitions for test circuit: DUT=Device Under Test CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 7 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate AC Testing Waveforms Figure 4. Propagation delay, output transition time Measurement Points Supply voltage VDD 5V to 15V Input VM 0.5×VDD Output VM 0.5×VDD Test Data Supply voltage VDD VI tr, tf Load CL 5V to 15V VSS or VDD ≤20ns 50pF XBLW version 1.0 Input 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 8 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate Package Information DIP14 Symbol A A1 A2 B B1 C D E E1 e L E2 XBLW version 1.0 Dimensions In Millimeters Min Max 3.710 4.310 0.510 3.200 3.600 0.380 0.570 1.524(BSC) 0.204 0.360 18.800 19.200 6.200 6.600 7.320 7.920 2.540(BSC) 3.000 3.600 8.400 9.000 Dimensions In Inches Min Max 0.146 0.170 0.020 0.126 0.142 0.015 0.022 0.060(BSC) 0.008 0.014 0.740 0.756 0.244 0.260 0.288 0.312 0.100(BSC) 0.118 0.142 0.331 0.354 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 9 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate SOP14 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 10 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate TSSOP14 SYMBOL A A1 A2 A3 b b1 c c1 D E1 E e L L1 θ XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 MILLIMETER MIN MAX 1.20 0.05 0.15 0.90 1.05 0.39 0.49 0.20 0.30 0.19 0.25 0.13 0.19 0.12 0.14 4.86 5.06 4.30 4.50 6.20 6.60 0.65BSC 0.45 0.75 1.00BSC 0° 8° 第 11 页 共 12 页 XBLW CD4001 Quad 2-Input NOR Gate Statements And Notes Part name Lead and lead compounds Lead frame ○ Plastic resin ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ The lead Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ explanation Cadmium and cadmium compounds ○ Hazardous substances or Elements Polybro Hexavalent Polybro minated Dibutyl chromium minated biphenyl phthalate compounds biphenyls ethers ○ ○ ○ ○ Mercury and mercury compounds ○ Butyl benzyl phthalate Di-2ethylhexyl phthalate Diisobutyl phthalate ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 12 页 共 12 页
CD4001BE 价格&库存
很抱歉,暂时无法提供与“CD4001BE”相匹配的价格&库存,您可以联系我们找货
