CD4049BE
CD4049BE
    XBLW(芯伯乐)
    DIP16
    六路反相缓冲器和变换器,工作电压(Vcc)(v)3-15V,静态电流Iq(Typ)4uA
CD4049BE 数据手册
XBLW CD4049 Six Inverting Buffer and Converter General Description The CD4049 provides six inverting buffers with high current output capability suitable for driving TTL or high capacitive loads. Since input voltages in excess of the buffers’ supply voltage are permitted, the buffers may also be used to convert logic levels of up to 15V to standard TTL levels. It operates over a recommended VDD power supply range of 3V to 15V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. Features  Wide supply voltage range from 3v to 15v  Accepts input voltages in excess of the supply voltage  5V, 10V, and 15V parametric ratings  Specified from -40℃ to +105℃  Packaging information: DIP16/SOP16/TSSOP16 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY CD4049BE CD4049BDTR CD4049BTDTR DIP-16 SOP-16 TSSOP-16 CD4049BE CD4049B CD4049B Tube Tape Tape 1000/Box 2500/Reel 3000/Reel Block Diagram And Pin Description XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 1 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter Block Diagram Figure 1. Functional symbol Figure 2. Logic diagram for one gate Figure 3. Input protection circuit Pin Configurations Figure 4. pin configuration Pin Description XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 2 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter Pin No. Pin Name Description 1 2 3 4 VDD 1Y 1A 2Y supply voltage data output 5 6 7 8 2A 3Y data input data output 3A VSS 4A 4Y 5A 5Y n.c. 6A 6Y n.c. data input ground supply voltage 9 10 11 12 13 14 15 16 data input data output data input data output data input data output not connected data input data output not connected Electrical Parameter Absolute Maximum Ratings (Tamb=25℃, unless otherwise specified.) Characteristic Symbol Conditions Min. Max. Unit supply voltage DC input current input voltage output clamping current input/output current supply current storage temperature VDD IIK VI IOK II/O IDD Tstg -0.5 -10 -0.5 -65 +18 +18 ±10 ±10 50 +150 soldering temperature TL VI < -0.5V VO < -0.5V or VO > VDD +0.5V DIP 10s SOP/TSSOP V mA V mA mA mh ℃ ℃ ℃ 245 260 Recommended Operating Conditions Parameter Symbol Conditions Min. Typ. Max. Unit supply voltage input voltage ambient temperature VDD VI Tamb in free air 3 0 -40 - 15 15 +105 V V ℃ Electrical Characteristics XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 3 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter DC Characteristics 1 (Tamb=25℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter Symbol supply current LOW-level output current HIGH-level output current LOW-level output voltage HIGH-level output voltage LOW-level input voltage IDD IOL IOH VOL VOH VIL HIGH-level input voltage VIH input leakage current II VO Conditions(V) VIN VDD Min. Tamb=25℃ Typ. Max. Unit - 0, 5 5 - - 4 μA - 0, 10 10 - - 8 μA - 0, 15 15 - - 16 μA 0.4 0, 5 5 2.9 - - mA 0.5 0, 10 10 10 - - mA 1.5 0, 15 15 20 - - mA 4.6 0, 5 5 - - -0.44 mA 2.5 0, 5 5 - - -1.4 mA 9.5 0, 10 10 - - -1.1 mA 13.5 0, 15 15 - - -3 mA - 0, 5 5 - - 0.05 V - 0, 10 10 - - 0.05 V - 0, 15 15 - - 0.05 V - 0, 5 5 4.95 - - V - 0, 10 10 9.95 - - V - 0, 15 15 14.95 - - V - 0, 5 5 - - 1.5 V - 0, 10 10 - - 3 V - 0, 15 15 - - 4 V - 0, 5 5 3.5 - - V - 0, 10 10 7 - - V - 0, 15 15 11 - - V - 0, 15 15 - - ±0.3 μA DC Characteristics 2 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 4 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter (Tamb=-40℃ to +105℃, voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter supply current Symbol IDD LOW-level output current IOL HIGH-level output current IOH LOW-level output voltage VOL HIGH-level output voltage VOH LOW-level input voltage VIL HIGH-level input voltage VIH input leakage current II Conditions(V) VO VIN VDD Tamb=-40℃ Min. Max. Tamb=+105℃ Min. Max. Unit - 0, 5 5 - 4 - 30 μA - 0, 10 10 - 8 - 60 μA - 0, 15 15 - 16 - 120 μA 0.4 0.5 1.5 4.6 2.5 9.5 13.5 - 0, 5 0, 10 0, 15 0, 5 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 5 10 15 5 5 10 15 5 10 15 5 10 15 5 10 15 5 10 15 3.5 12 24 4.95 9.95 14.95 3.5 7 11 -0.52 -1.7 -1.3 -3.6 0.05 0.05 0.05 1.5 3 4 - 2.3 8 16 4.95 9.95 14.95 3.5 7 11 -0.36 -1.1 -0.9 -2.4 0.05 0.05 0.05 1.5 3 4 - mA mA mA mA mA mA mA V V V V V V V V V V V V - 0, 15 15 - ±0.3 - ±1.0 μA AC Characteristics (Tamb=25℃, VSS=0V; CL=50pF; tr=tf≤20ns, unless otherwise specified.) XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 5 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter Parameter Symbol Conditions HIGH to LOW propagation delay tPHL nA to nY; see Figure 6 LOW to HIGH propagation delay tPLH nA to nY; see Figure 6 HIGH to LOW output transition time tTHL see Figure 6 LOW to HIGH output transition time tTLH see Figure 6 DD 5 10 15 5 10 15 5 10 15 5 10 15 Min. - Typ. 35 15 12 50 25 20 20 10 7 60 30 20 Max. 70 30 25 100 50 40 40 20 14 120 60 40 Unit ns ns ns ns ns ns ns ns ns ns ns ns Testing Circuit AC Testing Circuit Figure 5. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. AC Testing Waveforms XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 6 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter Figure 6. Input (nA) to output (nY) propagation delays and transition times Measurement Points Input VM 0.5×VDD VI 0V to VDD VM 0.5×VDD Output VX 0.1×VDD VY 0.9×VDD Test Data Supply voltage VDD VI 5V to 15V VDD Input VM 0.5×VI tr, tf Load CL ≤20ns 50pF Package Information XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 7 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter DIP16 Symbol A2 A1 A L b B1 D E1 e c eB Min. Dimensions(mm) 3.20 0.51 3.60 3.00 0.36 Max. 3.60 5.33 3.60 0.56 1.52 18.80 6.20 19.94 6.60 2.54 0.20 7.62 0.36 9.30 SOP16 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 8 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter Symbol A1 A2 b c D E E1 e L θ Min. Dimensions (mm) 0.10 1.25 0.33 0.19 9.50 5.80 3.70 Max. 0.25 1.55 0.51 0.25 10.10 6.30 4.10 1.27 0.35 0° 0.89 8° TSSOP16 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 9 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter SYMBOL A A1 A2 b c D E1 E e L θ MILLIMETER MIN 0.05 0.80 0.19 0.09 4.90 4.30 6.20 MAX 1.20 0.15 1.05 0.30 0.20 5.10 4.50 6.60 0.65 0.45 0° 0.75 8° Statements And Notes XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 10 页 共 11 页 XBLW CD4049 Six Inverting Buffer and Converter Part name Lead and lead compounds Lead frame ○ Plastic resin ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ The lead Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ explanation Cadmium and cadmium compounds ○ Hazardous substances or Elements Polybro Hexavalent Polybro minated Dibutyl chromium minated biphenyl phthalate compounds biphenyls ethers ○ ○ ○ ○ Mercury and mercury compounds ○ Butyl benzyl phthalate Di-2ethylhexyl phthalate Diisobutyl phthalate ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 11 页 共 11 页
CD4049BE 价格&库存
很抱歉,暂时无法提供与“CD4049BE”相匹配的价格&库存,您可以联系我们找货
