CD4060BDTR
CD4060BDTR
    XBLW(芯伯乐)
    SOP-16
    二进制分频器/振荡器,工作电压(Vcc)(v)3-15V,静态电流Iq(Typ)0.04uA
CD4060BDTR 数据手册
CD4052 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or General Description CD4060 is a 14-stage ripple-carry binary counter/divider and oscillator with three oscillator terminals (RS, REXT and CEXT), ten buffered outputs (Q3 to Q9 and Q11 to Q13) and an overriding asynchronous master reset input (MR). The oscillator configuration allows design of either RC or crystal oscillator circuits. The oscillator may be replaced by an external clock signal at input RS. The counter advances on the negative -going transition of RS. A HIGH level on MR resets the counter (Q3 to Q9 and Q11 to Q13= LOW), independent of other input conditions. It operates over a recommended VDD power supply range of 3V to 15V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. Features         Wide supply voltage range from 3V to 15V Tolerant of slow clock rise and fall times Fully static operation 5V, 10V, and 15V parametric ratings Standardized symmetrical output characteristics Inputs and outputs are protected against electrostatic effects Specified from -40℃ to +85℃ Packaging information: DIP16/SOP16/TSSOP16 Ordering Information Product Model Package Type Marking Packing Packing Qty CD4060BE DIP-16 CD4060BE CD4060BDTR SOP-16 CD4060B Tube Tape 2500/Reel CD4060BTDTR TSSOP-16 CD4060B Tape 3000/Reel XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 1000/Box 第1页共9页 CD4052 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or 2、Block Diagram And Pin Description 2.1 Block Diagram Figure 1. Functional diagram Figure 2. Logic diagram 2.2 Pin Configurations XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第2页共9页 CD4052 2.3 XBLW CD4060 Pin Description Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 2.4 14-stage Ripple-carry Binary Counter/Divider and Oscillat or Description counter output counter output counter output counter output counter output counter output counter output ground (0V) external capacitor connection oscillator pin clock input/oscillator pin Pin Name Q11 Q12 Q13 Q5 Q4 Q6 Q3 VSS CEXT REXT RS MR Q8 Q7 Q9 VDD master reset counter output counter output counter output supply voltage Function Table Input RS Output MR L L H t ↓ X Q3 to Q9 and Q11 to Q13 no change count L Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; t=LOW-to-HIGH clock transition. 3 Electrical Parameter 3.1 Absolute Maximum Ratings (Voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter supply voltage DC input current input voltage storage temperature total power dissipation device dissipation Symbol VDD IIK Soldering temperature TL - -0.5 -65 Max. +18 ±10 VDD+0.5 +150 Unit V mA V ℃ Ptot - - 500 mW P per output transistor DIP 10s SOP - 100 mW ℃ ℃ VI Tstg Conditions Min. -0.5 any one input all inputs 245 250 Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第3页共9页 CD4052 3.2 Recommended Operating Conditions Parameter supply voltage ambient temperature input pulse width input pulse rise and fall time input pulse frequency reset pulse width 3.1 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or Symbol VDD Conditions Tamb tw Typ. - Min. 3 - Max. 15 Unit V in free air -40 - +85 ℃ 100 40 30 - - ns ns ns 3.5 8 12 MHz MHz MHz ns ns ns VDD=5V VDD=10V VDD=15V f=100kHz VDD=5V VDD=10V VDD=15V trIN, tfIN VDD=5V VDD=10V VDD=15V external pulse source f RS unlimited VDD=5V VDD=10V VDD=15V twR 120 60 40 - - Absolute Maximum Ratings (Voltages are referenced to VSS (ground=0V), unless otherwise specified.) Parameter supply voltage DC input current input voltage storage temperature total power dissipation device dissipation Symbol VDD IIK Soldering temperature TL Conditions Min. -0.5 - -0.5 -65 Max. +18 ±10 VDD+0.5 +150 Unit V mA V ℃ Ptot - - 500 mW P per output transistor DIP 10s SOP - 100 mW ℃ ℃ any one input all inputs VI Tstg 245 250 Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. 3.2 Recommended Operating Conditions Parameter supply voltage ambient temperature input pulse width input pulse rise and fall time input pulse frequency reset pulse width XBLWversion1.0 Symbol VDD Conditions Tamb tw trIN, tfIN f RS twR Typ. - Min. 3 in free air VDD=5V VDD=10V VDD=15V f=100kHz - Max. 15 Unit V -40 - +85 ℃ 100 40 30 - - ns ns ns 3.5 8 12 MHz MHz MHz ns ns ns VDD=5V VDD=10V VDD=15V external pulse source unlimited VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V 120 60 40 - 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 - 第4页共9页 CD4052 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or LOW-level output voltage VOL HIGH-level output voltage VOH LOW-level input voltage VIL HIGH-level input voltage VIH 0, 5 0, 10 0, 15 0, 5 0, 10 0, 15 0.5, 4.5 1, 9 1.5, 13.5 0.5, 4.5 1, 9 1.5, 13.5 - 5 10 15 5 10 15 5 10 15 5 10 15 0.05 0.05 0.05 4.95 9.95 14.95 4.95 9.95 14.95 1.5 3 4 3.5 7 11 - 3.5 7 11 input leakage 15 II 0, 15 ±0.1 current 3.3.3 AC Characteristics 1 (Tamb=25℃, VSS=0V, tr, tf=20ns, CL=50pF, RL=200kΩ, unless otherwise specified.) Parameter Symbol Conditions RS to Q3 out; see Figure 4 propagation delay time tPHL, tPLH Qn to Qn+1 ; see Figure 4 MR to Qn; see Figure 4 transition time pulse width input pulse rise and fall time tt tW see Figure 4 minimum width; f=100kHz; RS HIGH; minimum width; MR HIGH; see Figure 4 trIN, tfIN - maximum clock frequency fmax input RS; see Figure 4 input capacitance CI any input Min. VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V VDD=5V VDD=10V VDD=15V - - Typ. 370 150 100 100 50 40 180 80 50 100 50 40 50 20 15 60 30 20 0.05 0.05 0.05 - V V V V V V V V V V V V ±1 uA Max. 740 300 200 200 100 80 360 160 100 200 100 80 100 40 30 120 60 40 Unit ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 1.5 3 4 3.5 8 12 7 16 24 - MHz MHz MHz - 5 7.5 pF unlimited Note: tt is the same as tTLH and tTHL. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第5页共9页 CD4052 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or 4、Testing Circuit 4.1 AC Testing Circuit Figure 3. Test circuit for switching times Definitions for test circuit: DUT=Device Under Test. CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. 4.2 AC Testing Waveforms Figure 4. Waveforms showing propagation delays 4.3 Measurement Points Supply voltage VDD 5V to 15V 4.4 Input Output VM VM 0.5×VDD 0.5×VDD Test Data Supply voltage Input Load VDD VI tr , tf 5V to 15V VSS or VDD ≤ 20ns XBLWversion1.0 CL 50pF 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第6页共9页 CD4052 5、Package Information 5.1 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or DIP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第7页共9页 CD4052 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or 5.2 SOP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第8页共9页 CD4052 5.3 XBLW CD4060 14-stage Ripple-carry Binary Counter/Divider and Oscillat or TSSOP16 SYMBOL A A1 A2 b c D E1 E e L θ MILLIMETER MIN 0.05 0.80 0.19 0.09 4.90 4.30 6.20 MAX 1.20 0.15 1.05 0.30 0.20 5.10 4.50 6.60 0.65 0.45 0° 0.75 8° Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第9页共9页
CD4060BDTR 价格&库存
很抱歉,暂时无法提供与“CD4060BDTR”相匹配的价格&库存,您可以联系我们找货
