NDS7002A-ES
Rev-1.1
www.elecsuper.com
SuperMOS – SOT23-3L 60V BVDSS 1.5Ω RDS(on) 0.38A ID, N-channel MOSFET
1. Description
The NDS7002A-ES is N-Channel enhancement MOS Field Effect Transistor. Uses advanced trench
technology and design to provide excellent RDS(ON) with low gate charge. Device is suitable for use in
DC-DC conversion, power switch and charging circuit. Standard Product NDS7002A-ES is Pb-free.
2. Features
60V, RDS(ON)=1.5Ω(Typ), VGS=10V
RDS(ON)=2.06Ω(Typ), VGS=4.5V
Material: Halogen free
Reliable and rugged
Use trench MOSFET technology
Avalanche Rated
High density cell design for low RDS(on)
Low leakage current
3. Applications
PWM applications
Power management in portable/desktop PCs
Load switch
DC/DC conversion
4. Ordering Information
Part Number
Package
Marking
Material
Packing
Quantity
per reel
Flammability
Rating
NDS7002AES
SOT233L
72KA
Halogen
free
Tape &
Reel
3,000 PCS
UL 94V-0
Table-1
Reel
Size
7
inches
Ordering information
5. Pin Configuration and Functions
Pin
Function
1
Gate
2
Source
3
Drain
Outline
D
3
72KA
1
G
2
Table-2
Copyright© ElecSuper Incorporated
Circuit Diagram
S
Pin configuration
Contact Us
1 / 7
NDS7002A-ES
Rev-1.1
www.elecsuper.com
6. Specification
Absolute Maximum Rating & Thermal Characteristics
Ratings at 25 ℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
BVDSS
60
V
Gate-Source Voltage
VGS
±20
V
TA=25℃
Continuous Drain Current
TA=100℃
0.38
ID
A
0.25
Maximum Power Dissipation
PD
350
mW
Pulsed Drain Current a
IDM
1.5
A
Operating Junction Temperature
TJ
150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Single Operation
Parameter
Junction-to-Ambient Thermal Resistance
Symbol
Typical
Unit
RθJA
300
°C/W
Note:
a: Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1%
Contact Us
2 / 7
NDS7002A-ES
Rev-1.1
www.elecsuper.com
Electrical Characteristics
At TA = 25℃ unless otherwise specified
Parameter
Symbol
Test Conditions
Min.
Typ.
Max. Unit
OFF CHARACTERISTICS
Drain-to-Source Breakdown Voltage
BVDSS
VGS=0V, ID=10mA
60
V
Zero Gate Voltage Drain Current
IDSS
VDS=60V, VGS=0V
1.0
uA
Gate-to-source Leakage Current
IGSS
VDS=0V, VGS=±20V
±10
uA
Forward Trans conductance
gfs
VDS=10V, ID=0.1A
0.24
S
ON CHARACTERISTICS
Gate Threshold Voltage
VGS(TH)
Drain-to-source On-resistance
RDS(on)
VGS=VDS, ID=250uA
0.8
1.5
2.5
VGS=10V, ID=0.3A
1.5
3
VGS=4.5V, ID=0.2A
2.06
4
30.5
45
5.5
10
V
Ω
CHARGES, CAPACITANCES AND GATE RESISTANCE
Input Capacitance
CISS
VGS=0V, f=1MHz, VDS
=10V
Output Capacitance
COSS
Reverse Transfer Capacitance
CRSS
4.1
8
QG(TOT)
1.12
2
0.1
0.2
0.23
0.5
3
6
5
10
14
27
9
17
Total Gate Charge
Gate-to-Source Charge
QGS
Gate-to-Drain Charge
QGD
VGS=10V, VDS=30V,
ID=0.2A
pF
nC
SWITCHING CHARACTERISTICS
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
td(ON)
tr
td(OFF)
VGS=10V, VDS=30V,
ID=0.2A, RG=6Ω
tf
ns
BODY DIODE CHARACTERISTICS
Forward Voltage
VSD
VGS=0V, IS=1A
Contact Us
1
V
3 / 7
NDS7002A-ES
Rev-1.1
www.elecsuper.com
7. Typical Characteristic
Contact Us
4 / 7
NDS7002A-ES
Rev-1.1
Contact Us
www.elecsuper.com
5 / 7
NDS7002A-ES
Rev-1.1
www.elecsuper.com
8. Dimension and Patterns (SOT23-3L)
D
b
θ
3
L
E1
E
1
2
e
C
e1
A1
A2
A
COMMON DIMENSIONS: UNITS OF MEASURE=MILLIMETER
Dimensions
Symbol
Symbol
Min.
Max.
A
1.05
1.25
E
A1
E1
A2
1.05
1.15
e
b
0.30
0.50
e1
c
0.10
0.20
L
D
2.82
3.02
θ
Contact Us
Min.
1.50
2.65
1.80
0.30
0°
Dimensions
0.95TYP
Max.
1.70
2.95
2.00
0.60
8°
6 / 7
NDS7002A-ES
Rev-1.1
www.elecsuper.com
DISCLAIMER
ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES
(INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND
OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED,
INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR
PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application;
(2) designing, validating and testing your application;
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements.
These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for
development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of
these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party
intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives
against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products
are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or
provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise
alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products.
Contact Us
7 / 7
很抱歉,暂时无法提供与“NDS7002A-ES”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.09504
- 200+0.08144
- 600+0.07388
- 3000+0.06934
- 9000+0.06534
- 21000+0.06318
