HSF 2012F2SF-900T03-H 数据手册
TAI-TECH
P2
Wire Wound Type Common Mode Filter
HSF1210F2SF-SERIES
1. Features
1. High common mode impedance at high frequency cause excellent
Halogen
noise suppression performance.
2. HSF1210F2SF series realizes small size and low profile. 1.2x1.0x0.9 mm.
Halogen-free
3. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
4. Excellent for USB3.0
5. Operating temperature -40~+125℃ (Including self - temperature rise)
2. Dimension
E
C
A
D
D
B
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
1210F2SF
1.2±0.2
1.0±0.2
0.9 max.
0.35±0.1
0.35±0.1 0.03 min.
3. Part Numbering
HSF 1210
A
B
F
2
S
F
C
D
E
F
900
T
02
G
H
I
A: Series
B: Dimension
C: Material
Ferrite
D: Number of Lines
2=2 lines
E: Type
S=Shielded, N=Unshielded
F: Lead free
G: Impedance
H: Packaging
I: Rated Current
900=90Ω
T=Taping and Reel, B=Bulk
02=200mA
4. Specification
TAI-TECH
Part Number
DC
Common mode
Impedance Test Frequency Resistance
(MHz)
(Ω)
(Ω) max.
Rated Current
(mA) max.
Withstand
IR
Rated Volt.
(Vdc) max. Volt. (Vdc) (Ω) min.
max.
HSF1210F2SF-350T02
35±25%
100
0.30
200
50
125
10M
HSF1210F2SF-500T02
50±25%
100
0.30
250
50
125
10M
HSF1210F2SF-600T02
60±25%
100
0.30
250
50
125
10M
HSF1210F2SF-900T02
90±25%
100
0.40
200
50
125
10M
www.tai-tech.com.tw
TAI-TECH
HSF1210F2SF-350T02
1000
100
Common Mode
10
Normal Mode
1
HSF1210F2SF-500T02
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
P3
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
HSF1210F2SF-600T02
Common Mode
100
10
Normal Mode
1
1000
10000
HSF1210F2SF-900T02
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
0.1
Common Mode
100
10
Normal Mode
1
0.1
1
10
100
1000
10000
1
FREQUENCY(MHz)
10
100
FREQUENCY(MHz)
Sdd21&Scc21
www.tai-tech.com.tw
1000
10000
TAI-TECH
P4
www.tai-tech.com.tw
TAI-TECH
P5
www.tai-tech.com.tw
TAI-TECH
P6
HSF1210F2SF-SERIES-U4
1. Features
Halogen
Halogen-free
4. For USB3.1G1/2、HDMI2.0/2.1、USB4.0、Thunderbolt.
2. Dimension
E
C
A
D
D
B
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
1210F2SF
1.2±0.2
1.0±0.2
0.9 max.
0.35±0.1
0.35±0.1 0.03 min.
3. Part Numbering
HSF 1210
A
B
F
2
S
F
C
D
E
F
900
T
03
G
H
I
U4
J
A: Series
B: Dimension
Ferrite
C: Material
D: Number of Lines
2=2 lines
E: Type
F: Lead free
G: Impedance
900=90Ω
H: Packaging
I: Rated Current
03=300mA
J: Control S/N
4. Specification
TAI-TECH
Part Number
HSF1210F2SF-1R9T04-U4
Common mode
Impedance (Ω)
Typ.
Test
Frequency
(MHz)
1.9
100
DC
Cut-off
(Ω) max.
(GHz)Typ.
18
Rated Current
(mA)max.
0.20
400
Withstand
Rated Volt.
IR
(Vdc)max.
max.
50
125
10M
HSF1210F2SF-5R3T03-U4
5.3
100
18
0.30
300
50
125
10M
HSF1210F2SF-300T04-U4
30.0
100
18
0.20
400
50
125
10M
HSF1210F2SF-900T03-U4
90.0
100
18
0.30
300
50
125
10M
www.tai-tech.com.tw
TAI-TECH
P7
10
Common Mode
Normal Mode
1
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
100
0.1
100
Common Mode
10
Normal Mode
1
0.1
0.01
1
10
100
1000
1
10000
10
IMPEDANCE(Ohm)
10
Normal Mode
1
1000
10000
1000
Common Mode
100
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
10000
1
10
100
1000
FREQUENCY(MHz)
FREQUENCY(MHz)
Sdd21&Scc21
-10
-15
dB
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
-20
-25
-30
-35
-40
Sdd21
-45
Scc21
-50
1
10
100
1000
Frequency (MHz)
www.tai-tech.com.tw
10000
100000
10000
TAI-TECH
P8
-10
dB
-15
-20
-25
-30
-35
-40
Sdd21
Scc21
Sdd21
-45
-50
1
10
100
1000
10000
100000
Frequency (MHz)
-10
dB
-15
-20
-25
-30
-35
-40
Sdd21
-45
Scc21
-50
1
10
100
1000
Frequency (MHz)
www.tai-tech.com.tw
10000
100000
TAI-TECH
P9
-10
dB
-15
-20
-25
-30
-35
-40
Sdd21
-45
Scc21
-50
1
10
100
1000
Frequency (MHz)
www.tai-tech.com.tw
10000
100000
TAI-TECH
P10
HSF2012F2SF-SERIES-H
1. Features
1. High common mode impedance at high frequency cause excellent noise
Halogen
2. HSF2012F2SF series realizes small size and low profile. 2.0x1.2x1.2 mm.
Halogen-free
4. For USB3.1G2 & HDMI2.0
2. Dimension
E
C
A
D
B
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
2012F2SF
2.0±0.2
1.2±0.2
1.2±0.2
0.50±0.1
0.51±0.1
0.15±0.1
600
T
03
G
H
I
D
Series
3. Part Numbering
HSF 2012
A
B
F
2
S
F
C
D
E
F
H
J
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
S=Shieded , N=Unshielded
F: Lead free
G: Impedance
600=60Ω
H: Packaging
T=Taping and Reel
I: Rated Current
03=300mA
J: Control S/N
4. Specification
TAI-TECH
Part Number
Common mode
Impedance (Ω)
Test
Frequency
(MHz)
DC
Resistance
(Ω) max.
Rated Current
(mA) max.
Rated Volt.
(Vdc) max.
HSF2012F2SF-300T04-H
30±25%
100
0.20
400
50
125
10M
HSF2012F2SF-600T03-H
60±25%
100
0.30
300
50
125
10M
HSF2012F2SF-900T03-H
90±25%
100
0.30
300
50
125
10M
HSF2012F2SF-121T03-H
120±25%
100
0.35
330
50
125
10M
www.tai-tech.com.tw
Withstand Volt.
IR
(Ω) min.
(Vdc) max.
TAI-TECH
1000
100
Common Mode
10
Normal Mode
1
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
P11
0.1
100
Common Mode
10
Normal Mode
1
0.1
1
10
100
1000
10000
1
10
FREQUENCY(MHz)
100
1000
10000
FREQUENCY(MHz)
-H
Common Mode
100
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
10
Normal Mode
1
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
10000
1
10
100
FREQUENCY(MHz)
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
TAI-TECH
P12
www.tai-tech.com.tw
TAI-TECH
P13
www.tai-tech.com.tw
TAI-TECH
P14
www.tai-tech.com.tw
TAI-TECH
P15
www.tai-tech.com.tw
TAI-TECH
P16
www.tai-tech.com.tw
TAI-TECH
P17
www.tai-tech.com.tw
TAI-TECH
P18
www.tai-tech.com.tw
TAI-TECH
P19
www.tai-tech.com.tw
TAI-TECH
P20
5. Schematic Diagram
6. Materials
No.
Description
Specification
a.
Upper Plate
Ferrite
b.
Core
Ferrite Core
c
Termination
Ag/Ni/Sn
d
Wire
Enameled Copper Wire
www.tai-tech.com.tw
TAI-TECH
P21
7. Reliability and Test Condition (HSF1210, HSF2012)
Item
Performance
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Z(common mode)
DCR
Keysight E4991B + Keysight 16197A
Refer to standard electrical characteristics list.
I.R.
Temperature Rise Test
Agilent-34420A
Agilent-4338B
Chroma 19073
Rated Current ΔT 40℃Max
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through reflow for 3 times.( IPC/JEDEC
J-STD-020E Classification Reflow Profiles)
Temperature:125±2℃
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24 hrs.
Humidity:85±3% R.H,
Load Humidity
Temperature:85℃±2℃
Duration : 1000hrs Min. Bead : with 100% rated current ,
Inductance: with 10% rated current
Moisture Resistance
Appearance:No damage.
Impedance:within±15% of initial value
RDC:within ±15% of initial value and shall not
exceed the specification value
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Thermal
shock
Step2:125±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Vibration
www.tai-tech.com.tw
TAI-TECH
Item
P22
Performance
Bending
Shock
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805:1kg ,
HSF 2012F2SF-900T03-H 价格&库存
很抱歉,暂时无法提供与“HSF 2012F2SF-900T03-H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.644281+0.34208
- 10+2.0940110+0.27090
- 25+1.9128725+0.24746
- 50+1.7901950+0.23159
- 100+1.67521100+0.21672
- 250+1.53634250+0.19875
- 500+1.43937500+0.18621
- 1000+1.349201000+0.17454
- 国内价格 香港价格
- 2000+1.265252000+0.16368
- 4000+1.186964000+0.15356
- 6000+1.143636000+0.14795
- 10000+1.0914910000+0.14120
- 14000+1.0585614000+0.13694
- 20000+1.0248520000+0.13258
