GT298P
GT298P
    XBLW(芯伯乐)
    PowerSO20_16X11.1MM
    双路全桥驱动,工作电压(Vcc)(v)4.5-46V,静态电流Iq(Typ)10mA,驱动电流 Iout4A
GT298P 数据手册
XBLW GT298 DUAL FULL-BRIDGE DRIVER General Description XBLW GT298 is a high voltage, high current dual full-bridge driver designed to accept standard TTL logic levels and drive inductive loads such as relays,solenoids, DC and stepping motors. Features      OPRINAGCSTULIYSOITAGE UP TO 46 V TOTAL DC CURRENT UP TO 4 A LOW SATURATION VOLTAGE LOGICAL "0" INPUT VOLTAGE UP TO 1.5 V THE LOGIC POWER SUPPLY AND DRIVE POWER SUPPLY ARE INDEPENDENT OF EACH OTHER Ordering Information Product Model GT298P GT298N Package Type PowerSO-20 Multiwatt-15 Marking GT298P GT298N Packing Tape Tube Packing Qty 600PCS/Reel 250PCS/BOX Outside View XBLWversion1.0 www.xinboleic.com Technical support: 4009682003 1/7 XBLW GT298 DUAL FULL-BRIDGE DRIVER Pin Definition And Function XBLWversion1.0 www.xinboleic.com Technical support: 4009682003 2/7 XBLW GT298 DUAL FULL-BRIDGE DRIVER PINS AND DEFINITIONS OF XBLW GT298 MW.15 PowerSO Name Function Sense A; Sense Between this pin and ground is connected the sense resistor to control the B current of the load. Outputs of the Bridge A; the current that flows through the load connected Out 1; Out 2 between these two pins is monitored atpin 1. 1;15 2;19 2;3 4;5 4 6 VS Supply Voltage for the Power Output Stages. A non-inductive 100nF capacitor must be connected between this pin and ground. 5;7 7;9 Input 1; Input 2 TTL Compatible Inputs of the Bridge A. 6;11 8;14 8 1,10,11,20 GND 9 12 VSS 10; 12 13;15 Input 3; Input 4 13; 14 16;17 Out 3; Out 4 3;18 N.C. EnableA;Enable TTL Compatible Enable Input: the L state disables the bridge A (enable A) B and/or the bridge B (enable B). Ground. Supply Voltage for the Logic Blocks. A100nF capacitor must be connected between this pin and ground. TTL Compatible Inputs of the Bridge B. Outputs of the Bridge B. The current that flows through the load connected between these two pins is monitored atpin 15. Not Connected Block Diagram BLOCK DIAGRAM OF XBLW GT298 XBLWversion1.0 www.xinboleic.com Technical support: 4009682003 3/7 XBLW GT298 DUAL FULL-BRIDGE DRIVER ABSOLUTE MAXIMUM RATINGS Symbol VS VSS VI,Ven IO Vsens Ptot Top Tstg, Tj Parameter Power Supply Logic Supply Voltage Input and Enable Voltage Peak Output Current (each Channel) – Non Repetitive (t = 100μs) –Repetitive (80% on –20% off; ton = 10ms) –DC Operation Sensing Voltage Total Power Dissipation (Tcase = 75。C) Junction Operating Temperature Storage and Junction Temperature Electrical Characteristics ISS Unit V V V 3 2.5 2 –1 to 2.3 A A A 25 –25 to 130 V W 。C –40 to 150 。C (VS = 42V; VSS = 5V, Tj = 25°C; unless otherwise specified) Symbol Parameter Supply Voltage (pin 4) VS VSS IS Value 50 7 –0.3 to 7 Test Conditions Operative Condition Logic Supply Voltage (pin 9) Quiescent Supply Current (pin 4) Quiescent Current from VSS 9) Ven = H; IL = 0 Ven = L X (pin Ven = H; IL = 0 Ven = L X Min. VIH +2.5 4.5 Vi = L Vi = H Vi = Vi = L Vi = H Vi = Typ. Max . 46 Unit V 5 13 50 7 22 70 4 V mA mA 36 12 6 mA mA 24 7 mA mA ViL Input Low Voltage (pins 5, 7, 10, 12) –0.3 1.5 V ViH Input High Voltage (pins 5, 7, 10, 12) 2.3 VSS V –10 μA 100 μA 1.5 VSS V V –10 μA 30 100 μA 1.35 2 1.2 1.7 1.7 2.7 1.6 2.3 V V V V 3.2 4.9 2 V V V IiL Low Voltage Input Current (pins 5, 7, 10, 12) Vi = L High Voltage Input Current Vi = H ≤ VSS –0.6V (pins 5, 7, 10, 12) Ven = L Enable Low Voltage (pins 6, 11) Ven = H Enable High Voltage (pins 6, 11) 30 IiH Ien = L Low Voltage Enable Current (pins 6, 11) Ien = H High Voltage Enable Current (pins 6, 11) VCEsat (H) Source Saturation Voltage Ven = L Ven = H ≤ VSS –0.6V IL = 1A IL = 2A IL = 1A IL = 2A IL = 1A IL = 2A VCEsat (L) Sink Saturation Voltage VCEsat Total Drop Vsens Sensing Voltage (pins 1, 15) XBLWversion1.0 –0.3 2.3 0.95 (5) (5) (5) (5) www.xinboleic.com 0.85 1.80 –1 (1) Technical support: 4009682003 4/7 XBLW GT298 DUAL FULL-BRIDGE DRIVER Application 1 、 POWER OUTPUT STAGE The XBLW GT298 integrates two power output stages (A ; B).The power output stage is a bridge onfiguration and its outputs can drive an inductive load in common or differenzial mode, depending on the state of the inputs. The current that flows through the load comes out from the bridge at the sense output : an external resistor (RSA ; RSB.) allows to detect the intensity of this current. 2 、 INPUT STAGE All the inputs are TTL compatible 3 、 POWER A non inductive capacitor, usually of 100 nF, must be foreseen between both Vs and Vss, to ground, as near as possible to GND pin.The en terminal shall be in L state before the output protection is turned off and on. 4 、 OUTPUT PROTECTION The fast diode shall be selected as the output protection when driving inductive load. When I = 2 A, VF ≤ 1.2V, TRR ≤ 200 ns. 5 、 PARALLEL CONNECTION When the driving current is greater than 2A, two groups can be connected in parallel for current expansion. XBLWversion1.0 www.xinboleic.com Technical support: 4009682003 5/7 XBLW GT298 DUAL FULL-BRIDGE DRIVER Package Multiwatt15/ZIP-15 XBLWversion1.0 www.xinboleic.com Technical support: 4009682003 6/7 XBLW GT298 DUAL FULL-BRIDGE DRIVER PowerSO-20/HSOP-20 Declaration Shenzhen Xinbole Electronics Co., Ltd. reserves the right to modify the product manual without prior notice! Customers are advised to confirm if the information received is the latest version and verify the completeness of related information before placing an order. Under certain conditions, any semiconductor product may fail or malfunction. It is the buyer's responsibility to comply with safety standards and take appropriate safety measures when designing systems and manufacturing complete machines using products from Shenzhen Xinbole Electronics Co., Ltd. to avoid potential risks of failure that may cause personal injury or property damage. This document is for reference only, and the actual use should be based on the application test results. Product performance improvement is endless. Shenzhen Xinbole Electronics Co., Ltd. will sincerely provide customers with integrated circuit products with better performance and higher quality. XBLWversion1.0 www.xinboleic.com Technical support: 4009682003 7/7
GT298P 价格&库存
很抱歉,暂时无法提供与“GT298P”相匹配的价格&库存,您可以联系我们找货
