RFO-25V221MG3P#-T8
RFO-25V221MG3P#-T8
    ELNA(伊娜)
RFO-25V221MG3P#-T8 数据手册
RFO ELECTROLYTIC CAPACITORS FOR AUDIO MINIATUREMINIATURE ALUMINUMALUMINUM ELECTROLYTIC CAPACITORS FOR AUDIO ® Miniature Capacitors for Audio (PURECAP) ● ● ® For Audio GREEN CAP A standard capacitor utilizing a newly developed material for a high grade of audio reproduction. All lead wires are copper plated steel wires. New type miniaturized capacitor for audio, New type using synthetic mica paper for the separator. RFO RA2 ALUMINUM ● RFO Marking color : Gold print on a black sleeve Specifications Item Performance ー40 to +85 ±20 Category temperature range (℃) Tolerance at rated capacitance (%) Leakage current (µA) (max.) (20℃,120Hz) 6.3 0.22 Rated voltage (V) tanδ (max.) Tangent of loss angle (tanδ) 10 0.19 16 0.16 25 0.14 35 0.12 50 0.10 63 0.09 100 0.08 (20℃,120Hz) 0.02 is added to every 1000µF increase over 1000µF 1000 hours The initial specified value or less Within ±20% of initial value 150% or less of the initial specified value Test time Leakage current Percentage of capacitance change Tangent of the loss angle Endurance (85℃) (Applied ripple current) Test time : 1000hours ; other items are same as the endurance. Voltage application treatment : According to JIS C5101-4 4.1 Shelf life (85℃) Applicable standards JIS C5101-1, -4 (IEC 60384-1, -4) Outline Drawing Coefficient of Frequency for Rated Ripple Current Unit : mm Sleeve Vent (except φ5) Frequency(Hz) Rated voltage(V) φd±0.05 copper plated steel wire (tinned) CV(µFxWV) 6.3 to 16 F±0.5 φD+0.5/0 5 2.0 0.5 6.3 2.5 0.5 8 3.5 0.6 10 5.0 0.6 12.5 5.0 0.6 1k 10k 100k 1 1 1 1 1 1.1 1.5 1.2 1.6 1.2 1.2 1.7 1.3 1.9 1.3 1.2 1.7 1.3 1.9 1.3 Part numbering system (example : 25V100µF) 16 7.5 0.8 RFO 18 7.5 0.8 ̶ 25 Rated voltage symbol Series code V 101 M Rated capacitance symbol 85℃ F3 P# ̶ Taping (Forming) symbol Capacitance Casing tolerance symbol symbol 2.0 (φ10,16L or less : 1.5) 1.5 α 50 to 100 5 min. 15min. 120 0.8 0.8 0.8 0.8 0.8 MINIATURE ALUMINUM L+α max. 50・60 All CV value ≤1000 1000< ≤1000 1000< 25 to 35 φD F φd (20℃) 0.01CV or 3 whichever is larger (after 2 minutes) C : Rated capacitance (µF) ; V : Rated voltage (V) Case symbol Casing Casing Casing Casing Case Case Case Case φD×L (mm) Symbol φD×L (mm) Symbol φD×L (mm) Symbol φD×L (mm) Symbol 5×11 E3 10×12.5 H3 12.5×20 Ⅰ5 16×31.5 J7 6.3×11 F3 10×16 H4 12.5×25 Ⅰ6 18×35.5 K8 8×11.5 G3 10×20 H5 16×25 J6 FOR AUDIO ALUMINUM Standard Ratings 6.3 Rated voltage (V) 10 Rated ripple 16 Rated ripple 25 Rated ripple 35 Rated ripple 50 Rated ripple 63 Rated ripple 100 Rated ripple Rated ripple Case Case Case Case Case Case Case Case Item current current current current current current current current Rated φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) φD×L (mm) (mArms) capacitance (µF) ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 5×11 15 5×11 15 1 2.2 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 5×11 20 ̶ ̶ 5×11 25 3.3 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 5×11 25 ̶ ̶ 5×11 30 4.7 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 5×11 30 5×11 30 5×11 35 5×11 35 10 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 5×11 45 5×11 45 5×11 50 6.3×11 60 22 ̶ ̶ ̶ ̶ 5×11 50 5×11 55 5×11 60 5×11 70 6.3×11 85 8×11.5 33 ̶ ̶ 5×11 55 5×11 60 5×11 70 5×11 80 6.3×11 100 6.3×11 100 10×12.5 160 47 ̶ ̶ 5×11 65 5×11 75 5×11 85 6.3×11 110 6.3×11 120 8×11.5 150 10×16 210 6.3×11 120 6.3×11 100 5×11 85 5×11 95 140 8×11.5 190 210 10×12.5 260 12.5×20 380 220 6.3×11 150 6.3×11 165 8×11.5 220 8×11.5 250 10×12.5 330 10×16 400 10×20 460 16×25 720 330 6.3×11 180 8×11.5 240 8×11.5 270 10×12.5 370 10×16 450 10×20 540 12.5×20 650 16×25 8×11.5 260 8×11.5 280 10×12.5 390 10×16 480 10×20 590 12.5×20 740 12.5×25 850 16×31.5 10×12.5 12.5×25 470 8×11.5 110 880 1150 450 10×16 540 10×20 680 12.5×20 880 1050 16×25 1350 1550 ̶ ̶ 2200 12.5×20 890 12.5×20 970 12.5×25 1200 16×25 1550 16×31.5 1750 18×35.5 2100 ̶ ̶ ̶ ̶ 3300 12.5×20 1050 12.5×25 1250 16×25 1600 16×31.5 1950 18×35.5 2250 ̶ ̶ ̶ ̶ ̶ ̶ 4700 16×25 1550 16×25 1650 16×31.5 2050 18×35.5 2500 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 6800 16×25 1750 16×31.5 2050 18×35.5 2550 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 10000 16×31.5 2150 18×35.5 2550 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 15000 18×35.5 2700 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 1000 ̶ 16×31.5 (Note) Rated ripple current : 85℃, 120Hz NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 215 CAT.No.2019/2020E
RFO-25V221MG3P#-T8 价格&库存
很抱歉,暂时无法提供与“RFO-25V221MG3P#-T8”相匹配的价格&库存,您可以联系我们找货
