L78M05HDTR
L78M05HDTR
    XBLW(芯伯乐)
    TO-252(DPAK)
    线性稳压器/LDO 固定 输入20V 输出5V 700mA
L78M05HDTR 数据手册
XBLW L78MXX General Description The L78MXX three- terminal positive regulators are available in the TO-2 5 2 package with several fixed output voltages making it useful in a wide range of applications. Features Output Current up to 700mA Output Voltages of 5,6,8,9, 12, 15, 18,24V Thermal Overload Protection Short Circuit Protection Output Transistor Safe Operating area ( SOA) Protection Ordering Information DEVICE XBLW L78MXXHDTR MARKING Package Type TO-252-2 78MXXH Packing Packing QTY Tape 2500/Reel Remarks:"XXrepresents the output voltage value,such as L78M05HDTR stands for 5V Absolute Maximum Ratings Symbol Ratings Unit Input Voltage VIN 35 V Output Current IOUT 700 mA Parameter SOT-22 3 TO-251/ TO-252 TO-252-3 Power Dissipation (TC=25℃ ) Operating Junction Temperature Storage Temperature Thermal 1 PO 2 W TJ TSTG - 20 ~12 5 ℃ -55 ~+150 ℃ Symbol Ratings Unit Data Parameter SOT-22 3 Power Dissipation (TC=25℃) XBLWversion1 . 0 TO-251/ TO-252 TO-252-3 15 θJC 12.5 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 ℃/W 第 1页 共 9页 XBLW L78MXX Block Digram Electrical Characteristics L78M05 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI= 10V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Value Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO lO = 200mA Tj=25 ℃ Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 IO=2 00 mA,VI=8 ~2 5V 0.8 Output Voltage Drift ΔV/ΔT Output Noise Voltage Conditions IO= 5 mA~ 3 5 0 mA VI= 7 ~ 2 0 V Min Typ Max 4.75 5 5.25 VI= 7 V~ 2 5 V 100 VI= 8 V~ 2 5 V 50 IO= 5 mA~ 5 0 0 mA 100 IO= 5 mA~ 2 0 0 mA 50 Unit V mV mV mA mA IO =5 mA,Tj=0 ~125 ℃ -0.5 mV/ ℃ VN f= 1 0 Hz~ 1 0 0 KHz 40 μV Ripple Rejection RR f=120 Hz,VI=8 ~1 8 V 80 dB Dropout Voltage VD Tj=25℃ ,IO = 500mA 2 V Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA Peak Current IPK Tj=25 ℃ 900 mA Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 2页 共 9页 XBLW L78MXX Electrical Characteristics L78M06 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI= 11V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Value Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO lO = 200mA Tj=25 ℃ Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 IO=2 00 mA,VI=9 ~2 5V 0.8 Output Voltage Drift ΔV/ΔT Output Noise Voltage Conditions IO= 5 mA~ 3 5 0 mA VI= 8 ~ 2 1 V Min Typ Max 5.7 6 6.3 VI= 8 V~ 2 5 V 100 VI= 9 V~ 2 5 V 50 IO= 5 mA~ 5 0 0 mA 120 IO= 5 mA~ 2 0 0 mA 60 Unit V mV mV mA mA IO =5 mA,Tj=0 ~125 ℃ -0.5 mV/ ℃ VN f= 1 0 Hz~ 1 0 0 KHz 45 μV Ripple Rejection RR f= 120 Hz,VI=9 ~19 V 80 dB Dropout Voltage VD Tj=25℃ ,IO = 500mA 2 V Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA Peak Current IPK Tj=25 ℃ 900 mA Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. Electrical Characteristics L78M08 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI= 14V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Value Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO lO = 200mA Tj=25 ℃ Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 IO= 200mA,VI= 10.5~25V 0.8 Output Voltage Drift ΔV/ΔT Output Noise Voltage VN Ripple Rejection Dropout Voltage XBLWversion1 . 0 Conditions IO= 5 mA~ 3 5 0 mA VI= 10.5~23V Min Typ Max 7.6 8 8.4 VI= 10.5V~25V 100 VI= 11 V~25 V 50 IO= 5 mA~ 5 0 0 mA 160 IO= 5 mA~ 2 0 0 mA 80 IO =5 mA,Tj=0 ~125 ℃ Unit V mV mV mA mA -0.8 mV/ ℃ f= 1 0 Hz~ 1 0 0 KHz 52 μV RR f=120Hz,VI= 11.5~21.5 V 80 dB VD Tj=25℃ ,IO = 500mA 2 V 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 3页 共 9页 XBLW L78MXX Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA Peak Current IPK Tj=25 ℃ 900 mA Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. Electrical Characteristics L78M09 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI= 15V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Value Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO lO = 200mA Tj=25 ℃ Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 IO= 200mA,VI= 11.5~25V 0.8 Output Voltage Drift ΔV/ΔT Output Noise Voltage VN Ripple Rejection Conditions IO= 5 mA~ 3 5 0 mA VI= 11.5~24V Min Typ Max 8.45 9 9.55 VI= 11.5V~25V 100 VI= 12 V~25 V 50 IO= 5 mA~ 5 0 0 mA 180 IO= 5 mA~ 2 0 0 mA 90 IO =5 mA,Tj=0 ~125 ℃ Unit V mV mV mA mA -0.8 mV/ ℃ f= 1 0 Hz~ 1 0 0 KHz 52 μV RR f=120Hz,VI= 12.5~22.5 V 80 dB Dropout Voltage VD Tj=25℃ ,IO = 500mA 2 V Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA Peak Current IPK Tj=25 ℃ 900 mA Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. Electrical Characteristics L78M12 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI= 19V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Value Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO lO = 200mA Tj=25 ℃ Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 mA Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 mA XBLWversion1 . 0 Conditions IO= 5 mA~ 3 5 0 mA VI= 14.5~27V Min Typ Max 11.4 12 12.6 VI= 14.5V~30V 100 VI= 16 V~30 V 50 IO= 5 mA~ 5 0 0 mA 240 IO= 5 mA~ 2 0 0 mA 120 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 Unit V mV mV 第 4页 共 9页 XBLW L78MXX IO=200mA,VI= 14.5~30V Output Voltage Drift ΔV/ΔT Output Noise Voltage VN Ripple Rejection 0.8 IO =5 mA,Tj=0 ~125 ℃ -0.8 mV/ ℃ f= 1 0 Hz~ 1 0 0 KHz 75 μV RR f=120Hz,VI= 15~25 V 80 dB Dropout Voltage VD Tj=25℃ ,IO = 500mA 2 V Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA Peak Current IPK Tj=25 ℃ 900 mA Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. Electrical Characteristics L78M15 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI=23V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Value Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO lO = 200mA Tj=25 ℃ Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 IO=200mA,VI= 17.5V~30V 0.8 Output Voltage Drift ΔV/ΔT Output Noise Voltage Conditions IO= 5 mA~ 3 5 0 mA VI= 17.5~30V Min Typ Max 14.25 15 15.75 VI= 17.5V~30V 100 VI= 2 0 V~ 3 0 V 50 IO= 5 mA~ 5 0 0 mA 300 IO= 5 mA~ 2 0 0 mA 150 Unit V mV mV mA mA IO =5 mA,Tj=0 ~ 125 ℃ - 1.0 mV/ ℃ VN f= 10 Hz~ 1 0 0 KHz 100 μV Ripple Rejection RR f=120Hz,VI= 18.5~28.5 V 70 dB Dropout Voltage VD Tj=25℃ ,IO = 500mA 2 V Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA IPK Tj=25 ℃ 900 mA Peak Current Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. Electrical Characteristics L78M18 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI=26V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO XBLWversion1 . 0 Conditions IO= 5 mA~ 3 5 0 mA VI= 20 .5 ~33 V lO = 200mA VI= 2 1 V~ 3 3 V Value Typ Max 17. 1 18 18.9 V 100 mV 文档仅供参考,实际应用测试为准 www.xinboleic.com Unit Min 技术支持热线:4009682003 第 5页 共 9页 XBLW L78MXX Tj=25℃ VI= 2 4 V~ 3 3 V 50 IO= 5 mA~ 5 0 0 mA 360 IO= 5 mA~ 2 0 0 mA 180 Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 IO= 200 mA,VI=21 V~33 V 0.8 Output Voltage Drift ΔV/ΔT Output Noise Voltage mV mA mA IO =5 mA,Tj=0 ~125 ℃ - 1.2 mV/ ℃ VN f= 1 0 Hz~ 1 0 0 KHz 100 μV Ripple Rejection RR f= 120 Hz,VI=22 ~32 V 70 dB Dropout Voltage VD Tj=25℃ ,IO = 500mA 2 V Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA Peak Current IPK Tj=25 ℃ 900 mA Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. Electrical Characteristics L78M24 (Refer to the test circuits, 0 < TJ < +125℃, IO=350mA, VI=33V, unless otherwise specified, CI = 0.33μF, CO=0. 1μF) Value Parameter Symbol Output Voltage VO Line Regulation( Note) ΔVO lO = 200mA Tj=25 ℃ Load Regulation( Note) ΔVO Tj=25 ℃ Quiescent Current IQ Tj=25 ℃ 6.0 Quiescent Current Change ΔIQ IO= 5 mA~ 3 5 0 mA 0.5 IO= 200 mA,VI=27 V~38 V 0.8 Output Voltage Drift ΔV/ΔT Output Noise Voltage Ripple Rejection Conditions IO= 5 mA~ 3 5 0 mA VI= 2 7 ~ 3 8 V Min Typ Max 22.8 24 25.2 VI= 2 7 V~ 3 8 V 100 VI= 2 8 V~ 3 8 V 50 IO= 5 mA~ 5 0 0 mA 480 IO= 5 mA~ 2 0 0 mA 240 Unit V mV mV mA mA IO =5 mA,Tj=0 ~125 ℃ - 1.2 mV/ ℃ VN f= 1 0 Hz~ 1 0 0 KHz 170 μV RR f= 120 Hz,VI=28 ~38 V 70 dB Dropout Voltage VD Tj=25℃ ,IO = 500mA 2 V Short Circuit Current ISC Tj=25℃ ,VI=35 V 800 mA Peak Current IPK Tj=25 ℃ 900 mA Notes: Load and line regulation are specified at constant junction temperature. Change in Vo due to heating effects must be taken into account separately. Pulse testing with low duty is used. XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 6页 共 9页 XBLW L78MXX SOT-223 Package Information SOT-223 Symbo l MILLIMETERS MIN. A XBLWversion1 . 0 E1 3.30 3.70 MAX. e 2.30 BSC 1.80 e1 4.60 BSC A1 0.02 0. 10 L 0.90 A2 1.55 1.65 θ 0° b 0.66 0.84 b2 2.90 3. 10 c 0.23 0.33 D 6.30 6.70 E 6.70 7.30 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 8° 第 7页 共 9页 XBLW L78MXX TO252 Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 2.200 2.400 0.087 0.094 A1 0.000 0. 127 0.000 0.005 B 1.350 1.650 0.053 0.065 b 0.500 0.700 0.020 0.028 b1 0.700 0.900 0.028 0.035 c 0.43 0 0.580 0.017 0.023 c1 0.430 0.580 0.017 0.023 D 6.350 0.650 0.250 0.262 D1 5.200 5.400 0.205 0.213 E 5.400 5.700 0.213 0.224 Symbol 0.091 TYP 2.300 TYP e e1 4.500 4.700 0. 177 0. 185 L 9.500 9.900 0.374 0.390 L1 2.550 2.900 0. 100 0. 114 L2 1.400 1.780 0.055 0.070 V XBLWversion1 . 0 3.80 REF 0. 150 REF 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 8页 共 9页 XBLW L78MXX Statement: Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information. Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co. , ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred! Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1 . 0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 9页 共 9页
L78M05HDTR 价格&库存
很抱歉,暂时无法提供与“L78M05HDTR”相匹配的价格&库存,您可以联系我们找货
L78M05HDTR
  • 10+0.27900
  • 100+0.26100
  • 500+0.24300
  • 2000+0.21600
  • 5000+0.20700
  • 10000+0.20160
库存:2500
L78M05HDTR(XBLW)
  • 1+0.50050
  • 100+0.31350
  • 1250+0.27170
  • 2500+0.23870
库存:498
L78M05HDTR
    库存:2500
    L78M05HDTR(XBLW)
    • 5+0.50489
    • 50+0.40188
    • 150+0.35028
    • 500+0.31161
    • 2500+0.27641
    • 5000+0.26091
    库存:107411
    L78M05HDTR
    • 10+0.24800
    • 100+0.23200
    • 500+0.21600
    • 2000+0.19200
    • 5000+0.18400
    • 10000+0.17920
    库存:2500
