FM93C46A-SO-T-G
FM93C46A-SO-T-G
    FM(富满)
FM93C46A-SO-T-G 数据手册
FM93C46A/56A/66A Three-wire Serial EEPROM Datasheet Aug. 2017 Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 1 INFORMATION IN THIS DOCUMENT IS INTENDED AS A REFERENCE TO ASSIST OUR CUSTOMERS IN THE SELECTION OF SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCT BEST SUITED TO THE CUSTOMER'S APPLICATION; THEY DO NOT CONVEY ANY LICENSE UNDER ANY INTELLECTUAL PROPERTY RIGHTS, OR ANY OTHER RIGHTS, BELONGING TO SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD OR A THIRD PARTY. WHEN USING THE INFORMATION CONTAINED IN THIS DOCUMENTS, PLEASE BE SURE TO EVALUATE ALL INFORMATION AS A TOTAL SYSTEM BEFORE MAKING A FINAL DECISION ON THE APPLICABILITY OF THE INFORMATION AND PRODUCTS. PURCHASERS ARE SOLELY RESPONSIBLE FOR THE CHOICE, SELECTION AND USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN, AND SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD ASSUMES NO LIABILITY WHATSOEVER RELATING TO THE CHOICE, SELECTION OR USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN. UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD REPRESENTATIVE, SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS ARE NOT RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. FUTURE ROUTINE REVISIONS WILL OCCUR WHEN APPROPRIATE, WITHOUT NOTICE. CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD SALES OFFICE TO OBTAIN THE LATEST SPECIFICATIONS AND BEFORE PLACING YOUR PRODUCT ORDER. PLEASE ALSO PAY ATTENTION TO INFORMATION PUBLISHED BY SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD BY VARIOUS MEANS, INCLUDING SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD HOME PAGE (HTTP://WWW.FMSH.COM/). PLEASE CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD LOCAL SALES OFFICE FOR THE SPECIFICATION REGARDING THE INFORMATION IN THIS DOCUMENT OR SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS. Trademarks Shanghai Fudan Microelectronics Group Co., Ltd name and logo, the “复旦” logo are trademarks or registered trademarks of Shanghai Fudan Microelectronics Group Co., Ltd or its subsidiaries in China. Shanghai Fudan Microelectronics Group Co., Ltd, Printed in the China, All Rights Reserved. Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 2 Packaging Type Description FM93C46A/56A/66A provides 1k/2k/4k bits of serial electrically erasable programmable read-only memory (EEPROM), organized as 64/128/256 words of 16 bits each (when the ORG pin is connected to VCC), and 128/256/512 words of 8 bits each (when the ORG pin is connected to ground). PDIP8 The FM93C46A/56A/66A is enabled through the Chip Select pin (CS) and accessed via a three-wire serial interface consisting of Data Input (DI), Data Output (DO), and Serial Clock (SK). Upon receiving a read instruction at DI, the address is decoded and the data is clocked out serially on the data output pin DO. The write cycle is completely self-timed and no separate erase cycle is required before write. The write cycle is only enabled when the part is in the Erase/Write Enable State. When CS is brought “high” following the initiation of a write cycle, The DO pin outputs the Ready/ Busy status of the part. CS 1 8 VCC SK 2 7 NC DI 3 6 ORG DO 4 5 GND SOP8 The device is the best choice for use in many industrial and commercial applications where low-power and low-voltage operations are essential. CS SK 1 2 8 7 VCC NC DI DO 3 4 6 5 ORG GND TSSOP8 CS SK DI DO Features  Three-wire Serial Interface  Low-voltage and Standard-voltage Operation 1.7V~5.5V  2MHz (2.5V) and 1MHz (1.7V) Compatibility  Dual organization: by word (x16) or byte (x8)  Sequential read operation  Programming instructions that work on: byte, word or entire memory  Self-timed Write Cycle (5 ms max)  READY/ BUSY signal during programming  High Reliability – Endurance: 1 Million Write Cycles – Data Retention: 40 Years  PDIP8, (RoHS Compliant)  SOP8, TSSOP8, TDFN8, TSOT23-6L Packages (RoHS Compliant and Halogen-free) 8 7 6 5 1 2 3 4 VCC NC ORG GND TSOT23-6L DO 1 6 VCC GND 2 5 CS DI 3 4 SK TDFN8 CS SK DI DO 1 2 3 4 8 7 6 5 VCC NC ORG GND Pin Configurations Absolute Maximum Ratings Pin Name Operating Temperature Storage Temperature Voltage on Any Pin with Respect to Ground Maximum Operating Voltage DC output current -55°C ~ +125°C -65°C ~ +150°C CS SK DI DO GND ORG NC VCC -1.0V ~ +7.0V 6.25V 5.0 mA *NOTICE: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification are not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Function Chip Select Serial Clock Serial Data Input Serial Data Output Ground Organization Select No connect Power Supply Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 3 Figure 1 Block Diagram VCC ORG GND EEPROM Storage array 128/256/512 x 8 OR 64/128/256 x 16 Address Decoder Data Register Read/Write Amplifiers DI CS SK Mode Decode Logic DO Clock Generator Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 4 Memory Organization The FM93C46A/56A/66A memory is organized either as bytes (x8) or as words (x16). If Organization Select (ORG) is left unconnected (or connected to VCC) the x16 organization is selected; when Organization Select (ORG) is connected to Ground (VSS) the x8 organization is selected. When the FM93C46A/56A/66A is in Standby mode, Organization Select (ORG) should be set either to VSS or VCC for minimum power consumption. Any voltage between VSS and VCC applied to Organization Select (ORG) may increase the Standby current. Memory size versus organization Device Number of bits FM93C66A 4096 FM93C56A 2048 FM93C46A 1024 Number of 8-bit bytes 512 256 128 Number of 16-bit words 256 128 64 Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 5 Instruction Set The instruction set of the FM93C46A/56A/66A devices contains seven instructions, as summarized in the table below.  Each instruction is preceded by a rising edge on Chip Select Input (CS) with Serial Clock (SK) being held low.  A start bit, which is the first „1‟ read on Serial Data Input (DI) during the rising edge of Serial Clock (SK).  Two op-code bits, read on Serial Data Input (DI) during the rising edge of Serial Clock (SK). (Some instructions also use the first two bits of the address to define the op-code).  The address bits of the byte or word that is to be accessed. For the FM93C46A, the address is made up of 6 bits for the x16 organization or 7 bits for the x8 organization. For the FM93C56A and FM93C66A, the address is made up of 8 bits for the x16 organization or 9 bits for the x8 organization. Instruction READ EWEN ERASE WRITE ERAL WRAL EWDS Device Type SB FM93C46A FM93C56A FM93C66A FM93C46A FM93C56A FM93C66A FM93C46A FM93C56A FM93C66A FM93C46A FM93C56A FM93C66A FM93C46A FM93C56A FM93C66A FM93C46A FM93C56A FM93C66A FM93C46A FM93C56A FM93C66A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Op Code 10 10 10 00 00 00 11 11 11 01 01 01 00 00 00 00 00 00 00 00 00 Address Data x8 x16 (1) (2) (1) (3) A6-A0 A8-A0 A8-A0 11XXXXX 11XXXXXXX 11XXXXXXX A6-A0 A8-A0 A8-A0 A6-A0 A8-A0 A8-A0 10XXXXX 10XXXXXXX 10XXXXXXX 01XXXXX 01XXXXXXX 01XXXXXXX 00XXXXX 00XXXXXXX 00XXXXXXX A5-A0 A7-A0 A7-A0 11XXXX 11XXXXXX 11XXXXXX A5-A0 A7-A0 A7-A0 A5-A0 A7-A0 A7-A0 10XXXX 10XXXXXX 10XXXXXX 01XXXX 01XXXXXX 01XXXXXX 00XXXX 00XXXXXX 00XXXXXX x8 x16 Comments Read Address AN–A0 Write Enable Clear Address AN–A0 D7-D0 D15-D0 D7-D0 D15-D0 Write Address AN–A0 D7-D0 D15-D0 Clear All Addresses D7-D0 D15-D0 D7-D0 D15-D0 Write All Addresses D7-D0 D15-D0 Write Disable Note: 1. X = Don't Care bit. 2. Address bit A8 is not decoded by the FM93C56A. 3. Address bit A7 is not decoded by the FM93C56A. Functional Description The FM93C46A/56A/66A is accessed via a simple and versatile three-wire serial communication interface. Device operation is controlled by seven instructions issued by the host processor. A valid instruction starts with a rising edge of CS and consists of a start bit (logic “1”) followed by the appropriate op code and the desired memory address location. READ (READ): The Read (READ) instruction contains the address code for the memory location to be read. After the instruction and address are decoded, data from the selected memory location is available at the serial output pin DO. Output data changes are synchronized with the rising edges of serial clock (SK).. It should be noted that a dummy bit (logic “0”) precedes the 8- or 16-bit data output string. Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 6 ERASE/WRITE (EWEN): To assure data integrity, the part automatically goes into the Erase/Write Disable (EWDS) state when power is first applied. An Erase/Write Enable (EWEN) instruction must be executed first before any programming instructions can be carried out. Please note that once in the EWEN state, programming remains enabled until an EWDS instruction is executed or VCC power is removed from the part. ERASE (ERASE): The Erase (ERASE) instruction programs all bits in the specified memory location to the logical “1” state. The self-timed erase cycle starts once the ERASE instruction and address are decoded. The DO pin outputs the Ready/ Busy status of the part if CS is brought high after being kept low for a minimum of 250 ns (tCS). A logic “1” at pin DO indicates that the selected memory location has been erased, and the part is ready for another instruction. WRITE (WRITE): The Write (WRITE) instruction contains the 8 or 16 bits of data to be written into the specified memory location. The self-timed programming cycle, tWP, starts after the last bit of data is received at serial data input pin DI. The DO pin outputs the Ready/ Busy status of the part if CS is brought high after being kept low for a minimum of 250 ns (tCS). A logic “0” at DO indicates that programming is still in progress. A logic “1” indicates that the memory location at the specified address has been written with the data pattern contained in the instruction and the part is ready for further instructions. A Ready/ Busy status cannot be obtained if the CS is brought high after the end of the selftimed programming cycle, tWP. ERASE ALL (ERAL): The Erase All (ERAL) instruction programs every bit in the memory array to the logic “1” state and is primarily used for testing purposes. The DO pin outputs the Ready/ Busy status of the part if CS is brought high after being kept low for a minimum of 250 ns (tCS). The ERAL instruction is valid only at Vcc = 2.5V ~5.5V WRITE ALL (WRAL): The Write All (WRAL) instruction programs all memory locations with the data patterns specified in the instruction. The DO pin outputs the Ready/ Busy status of the part if CS is brought high after being kept low for a minimum of 250 ns (tCS). The WRAL instruction is valid only at Vcc = 2.5V ~5.5V. ERASE/WRITE DISABLE (EWDS): To protect against accidental data disturb, the Erase/Write Disable (EWDS) instruction disables all programming modes and should be executed after all programming operations. The operation of the Read instruction is independent of both the EWEN and EWDS instructions and can be executed at any time. READY/ BUSY status: While the Write or Erase cycle is underway, for a WRITE, ERASE, WRAL or ERAL instruction, the Busy signal (DO=0) is returned whenever Chip Select input (CS) is driven high. (Please note, though, that there is an initial delay, of tCS, before this status information becomes available). In this state, the FM93C46A/56A/66A ignores any data on the bus. When the Write cycle is completed, and Chip Select Input (CS) is driven high, the Ready signal (DO=1) indicates that the FM93C46A/56A/66A is ready to receive the next instruction. Serial Data Output (DO) remains set to 1 until the Chip Select Input (CS) is brought low or until a new start bit is decoded. Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 7 Timing Diagrams Figure 2 READ Timing tCS CS SK 1 DI DO 1 0 AN ... A0 HIGH IMPEDANCE 0 ... DN D0 Figure 3 EWEN Timing tCS CS SK DI 1 0 0 1 1 ... Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 8 Figure 4 ERASE Timing tCS CHECK STATUS CS STANDBY SK 1 DI 1 AN 1 AN-1 AN-2 ... A0 tSV DO HIGH IMPEDANCE tDF HIGH IMPENDAMCE BUSY READY tWR Figure 5 WRITE Timing tCS CS SK DI 1 DO HIGH IMPEDANCE 0 1 AN ... A0 DN ... D0 BUSY READY tWR Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 9 Figure 6 ERAL Timing tCS CHECK STATUS CS STANDBY SK DI 1 0 0 1 0 tSV DO tDF HIGH IMPEDANCE BUSY HIGH IMPENDAMCE READY tWR Figure 7 WRAL Timing tCS CS SK DI 1 DO HIGH IMPEDANCE 0 0 0 1 ... DN ... D0 BUSY READY tWR Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 10 Figure 8 EWDS Timing tCS CS SK DI 1 0 0 0 ... 0 Figure 9 BUS Timing CS VIH VIL tCSS tSKH tSKL tCSH VIH SK V IL tDIS tDIH DI VIH VIL tPD1 tPD0 tDF DO (READ) VOH VOL tSV DO (PROGRAM) VOH VOL tDF STATUS VALID Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 11 Pin Capacitance Symbol (1) CIN COUT (1) Parameter Input Capacitance Output Capacitance Test Condition Max Units VIN = 0V, f = 1 MHz VOUT = 0V, f = 1 MHz 6 8 pF pF Note: 1. This parameter is characterized and is not 100% tested. DC Characteristics Applicable over recommended operating range from: TA = -40°C to +85°C, VCC = +1.7V to +5.5V, (unless otherwise noted). Symbol Parameter VCC Supply Voltage ICC Supply ISB Standby Current ILI ILO VIL (1) VIH (1) Input Leakage Output Leakage Input Low Voltage Input High Voltage VOL VOH Test Condition VCC = 5.0V, fsk = 2.0 MHz VCC = 1.7V, fsk = 1.0 MHz VCC=5V VCC = 1.7V 0V ≤ VIN ≤ Vcc 0V ≤ VOUT ≤ Vcc ; DO = Hi-Z VCC = 5V VCC = 1.7V VCC = 5V Output High Voltage VCC = 1.7V Output Low Voltage Min Max Units 1.7 5.5 2.0 1.0 15.0 2.0 1.0 1.0 0.2Vcc VCC+0.5 0.4 0.2 V mA mA µA µA µA µA V V V V V V CS = VIH, DO =open CS = SK = GND, ORG = VCC/GND -1.0 -1.0 -0.45 0.8VCC IOL = 2.1 mA IOL = 100 µA IOH = -400 µA IOH = -100 µA 0.8Vcc VCC-0.2 Note: 1. VIL min and VIH max are reference only and are not tested. Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 12 AC Characteristics Applicable over recommended operating range from: TA = -40°C to +85°C, VCC = 1.7V to 5.5V, CL = 100 pF (unless otherwise noted). Test conditions are listed in Note 2. Symbol Parameter f SK t SKL t SKH t CS t CSS t CSH tDIS t DIH t PD1 t PD0 t SV t DF t WR SK Clock Frequency SK Low Time SK High Time Minimum CS Low CS Setup Time CS Hold Time DI Setup Time DI Hold Time Output Delay to “1” Output Delay to “0” CS to Status Valid CS to DO in High Write Cycle B B B B B B B B B B B B B B B B B B Endurance (1) 1.7V ≤ Vcc ≤ 2.5V Min Max 2.5V < Vcc ≤ 5.5V Min 1 Max 2 250 250 250 50 0 100 100 200 200 200 50 0 50 50 400 400 400 200 5 3.3V, 25°C 1,000,000 200 200 200 100 5 Units MHz ns ns ns ns ns ns ns ns ns ns ns ms Write Cycles Notes: 1. This parameter is characterized and is not 100% tested. 2. AC measurement conditions: Input pulse voltages: 0.2 VCC to 0.8 VCC Input rise and fall times: ≤ 50 ns Input and output timing reference voltages: 0.3 VCC ~ 0.7 VCC Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 13 Ordering Information FM 93C DD A -PP -C -H Company Prefix FM = Shanghai Fudan Microelectronics Group Co.,ltd Product Family 93C = Three-wire Serial EEPROM Product Density 46 = 1K-bit 56 = 2K-bit 66 = 4K-bit Supply Voltage A = 1.7V to 5.5V Package Type (1) PD = 8-pin PDIP SO = 8-pin SOP TS = 8-pin TSSOP DN = 8-pin TDFN ST = 6-pin TSOT23 Product Carrier U = Tube T = Tape and Reel HSF ID Code (2) Blank or R = RoHS Compliant G = RoHS Compliant, Halogen-free, Antimony-free Note: 1. For SO, TS, DN package, MSL1 package are available, for detail please contact local sales office.. 2. For PD package: R class offer only For SO, TS, DN and ST package: G class offer only. Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 14 Part Marking Scheme PDIP8 FM93CDDA YYWWALH Product Density HSF ID Code R = RoHS Compliant Lot Number(just with 0~9、A~Z) Assembly’s Code Work week during which the product was molded (eg..week 12) The last two digits of the year In which the product was sealed / molded. SOP8 FM93CDDA YYWWALHM Product Density MSL Code Blank = MSL3 1 = MSL1 HSF ID Code G = RoHS Compliant, Halogen-free, Antimony-free Lot Number(just with 0~9、A~Z) Assembly’s Code Work week during which the product was molded (eg..week 12) The last two digits of the year In which the product was sealed / molded. TSSOP8 FM93CDDA YYWWALHM Product Density MSL Code Blank = MSL3 1 = MSL1 HSF ID Code G = RoHS Compliant, Halogen-free, Antimony-free Lot Number(just with 0~9、A~Z) Assembly’s Code Work week during which the product was molded (eg..week 12) The last two digits of the year In which the product was sealed / molded. Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 15 TDFN8 3 C A Product Density (“4”for FM93C46A; “5” for FM93C56A; “6” for FM93C66A) A Y M A L H The month (hexadecimal digit) in which the product was molded. The last one digit of year in which the product was sealed/molded HSF ID Code M G = RoHS Compliant, Halogen-free, Antimony-free Moisture Sensitivity Level 1=MSL1 Lot Number(just with 0~9、A~Z) Assembly’s Code TSOT23-6L DDYMLH HSF ID Code G = ROHS Compliant, Halogen-free, Antimony-free Lot Number(just with 0~9、A~Z) The month (hexadecimal digit) in which the product was molded. The last one digit of the year In which the product was sealed / molded. Product Density (“4U”for FM93C46A; “5U” for FM93C56A; “6U” for FM93C66A) Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 16 Packaging Information PDIP 8 Symbol MIN --A A1 0.380 b 0.380 b2 1.300 C 0.200 D 9.000 E1 6.100 E 7.320 e L 2.920 --eB NOTE: 1. Dimensions are in Millimeters. MAX 5.000 --0.570 1.700 0.360 10.000 7.000 8.250 2.540(BSC) 3.810 10.900 Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 17 SOP 8 Symbol MIN A 1.350 A1 0.050 b 0.330 c 0.150 D 4.700 E1 3.700 E 5.800 e L 0.400 θ 0° NOTE: 1. Dimensions are in Millimeters. MAX 1.750 0.250 0.510 0.260 5.150 4.100 6.200 1.270(BSC) 1.270 8° Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 18 TSSOP8 Symbol MIN D 2.900 E1 4.300 b 0.190 c 0.090 E 6.200 A A1 0.050 e L 0.450 θ 0° NOTE: 1. Dimensions are in Millimeters. MAX 3.100 4.500 0.300 0.200 6.600 1.200 0.150 0.650 (BSC) 0.750 8° Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 19 TDFN8 Symbol MIN A 0.700 A1 0.000 D 1.900 E 2.900 D2 1.400 E2 1.400 k b 0.200 e L 0.200 NOTE: 1. Dimensions are in Millimeters. MAX 0.800 0.050 2.100 3.100 1.600 1.700 0.150(MIN) 0.300 0.500(TYP) 0.500 Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 20 TSOT23-6L Symbol MIN A 0.700 A1 0.000 b 0.350 c 0.080 D 2.820 E 1.600 E1 2.650 e e1 L 0.300 θ 0° NOTE: 1. Dimensions are in Millimeters. MAX 0.900 0.100 0.500 0.200 3.020 1.700 2.950 0.950(BSC) 1.900(BSC) 0.600 8° Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 21 Revision History Version 1.0 Publication Pages date May. 2013 23 1.1 Feb. 2016 23 1.2 Aug. 2017 23 Paragraph or Illustration Revise Description Initial Document Release 1. Updated “ Part Marking Scheme” 2. Updated “packaging information” 1. Updated “packaging information” Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 22 Sales and Service Shanghai Fudan Microelectronics Group Co., Ltd. Address: Bldg No. 4, 127 Guotai Rd, Shanghai City China. Postcode: 200433 Tel: (86-021) 6565 5050 Fax: (86-021) 6565 9115 Shanghai Fudan Microelectronics (HK) Co., Ltd. Address: Unit 506, 5/F., East Ocean Centre, 98 Granville Road, Tsimshatsui East, Kowloon, Hong Kong Tel: (852) 2116 3288 2116 3338 Fax: (852) 2116 0882 Beijing Office Address: Room 423, Bldg B, Gehua Building, 1 QingLong Hutong, Dongzhimen Alley north Street, Dongcheng District, Beijing City, China. Postcode: 100007 Tel: (86-010) 8418 6608 Fax: (86-010) 8418 6211 Shenzhen Office Address: Room.1301, Century Bldg, No. 4002, Shengtingyuan Hotel, Huaqiang Rd (North), Shenzhen City, China. Postcode: 518028 Tel: (86-0755) 8335 0911 8335 1011 8335 2011 8335 0611 Fax: (86-0755) 8335 9011 Shanghai Fudan Microelectronics (HK) Ltd Taiwan Representative Office Address: Unit 1225, 12F., No 252, Sec.1 Neihu Rd., Neihu Dist., Taipei City 114, Taiwan Tel : (886-2) 7721 1889 (886-2) 7721 1890 Fax: (886-2) 7722 3888 Shanghai Fudan Microelectronics (HK) Ltd Singapore Representative Office Address : 237, Alexandra Road, #07-01 The Alexcier, Singapore 159929 Tel : (65) 6472 3688 Fax: (65) 6472 3669 Shanghai Fudan Microelectronics Group Co., Ltd NA Office Address :2490 W. Ray Road Suite#2 Chandler, AZ 85224 USA Tel : (480) 857-6500 ext 18 Web Site: http://www.fmsh.com/ Datasheet FM93C46A/56A/66A Three-wire Serial EEPROM Ver.1.2 23
FM93C46A-SO-T-G 价格&库存
很抱歉,暂时无法提供与“FM93C46A-SO-T-G”相匹配的价格&库存,您可以联系我们找货
