LM337CDTR(XBLW)
LM337CDTR(XBLW)
    XBLW(芯伯乐)
    TO263
    线性稳压器 输出电流Vout(Max)(A) 1.5A,可调整电压,三端稳压器,工作电压(Vcc)(v) 1.2V-37V
LM337CDTR(XBLW) 数据手册
LM337 3-Terminal Adjustable Negative Regulators General Description The LM337 is adjustable 3-terminal negative voltageregulators capable of supplying −1.5 A or more currents over an output voltage range of −1.25 V to −37 V. It requires only two external resistors to set the output voltage and one output capacitor for frequency compensation. The circuit design has been optimized for excellent regulation and low thermal transients. Further, the LM337 feature internal current limiting, thermal shutdown and safe-area compensation, making it virtually blowout-proof against overloads. Features        1.5-A Output Current Line Regulation 0.01%/V (Typical) Load Regulation 0.3% (Typical) 77-dB Ripple Rejection 50 ppm/°C Temperature Coefficient Thermal Overload Protection Internal Short-Circuit Current Limiting Protections Applications         Industrial Power Supplies Factory Automation Systems Building Automation Systems PLC Systems Instrumentation IGBT Drive Negative Gate Supplies Networking Set-Top Boxes Device Information(1) PART NUMBER PACKAGE SOT-223 (4) LM337 TO (3) TO-220 (3) BODY SIZE (NOM) 3.50 mm × 6.50 mm 8.255 mm × 8.255 mm 10.16 mm × 14.986 mm ( 1) For all available packages, see the orderable addendum at the end of the data sheet. The LF01 is a lead formed (bent) version of the TO-220 package. Adjustable Negative Voltage Regulator Full output current not available at high input- output voltages † C1 = 1 - μ F solid tantalum or 1 0 - μ F aluminum electrolytic required for stability * C2 = 1- μ F solid tantalum is required only if regulator is more than 4 ″ from power- supply filter capacitor Output capacitors in the range of 1- μF to 1000- μF of aluminum or tantalum electrolytic are commonly used to provide improved output impedance and rejection of transients XBLWversion 2.0 www.xinboleic.com Technicalsupport:4009682003 1/10 LM337 3-Terminal Adjustable Negative Regulators Ordering Information DEVICE Package Type MARKING Packing Packing QTY LM337S SOT-223 LM337S Tape 2500/Reel LM337T T0-220 LM337T Tube 1000/BOX LM337MDTR TO-252-2L LM337M Tape 2500/Reel LM337CDTR TO-263-3L LM337C Tape 800/Reel Pin Configuration and Functions TO- 2 2 0 TO Metal Can Package 3-Pin Package Number NDT0003A Bottom View Plastic Package Package Number NDE0 0 0 3 B Front View SOT-223 3-Lead Package Marked N02A Front View Pin Functions PIN NAME TO-220 TO SOT-223 1 1 1 2, TAB 3, CASE 3 2 ADJ V V IN OUT I/O DESCRIPTION Adjust pin 2, 4 — I 3 O Output voltage pin for the regulator Input voltage pin for the regulator Specifications 5. 1 Absolute Maximum Ratings MIN Power Internally dissipation Input- output voltage differential Operating Storage junction temperature temperature, XBLWversion 2.0 Tstg MAX UNIT Limited –0.3 40 V 0 125 °C –65 150 °C www.xinboleic.com Technicalsupport:4009682003 2/10 LM337 3-Terminal Adjustable Negative Regulators 5.2 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) Operating junction temperature LM337 MIN MAX UNIT 0 125 °C 5.3 Electrical Characteristics Unless otherwise specified, these specifications apply 0°C ≤ Tj ≤ 125 °C for the LM337; VIN − VOUT = 5 V; and IOUT = 0.1 A for the TO package and IOUT = 0. 5 A for the SOT-223 and TO-2 20 packages. Although power dissipation is internally limited, these specifications are applicable for power dissipations of 2 W for the TO and SOT-223, and 20 W for the TO-22 0. IMAX is 1 . 5 A for the SOT- 2 2 3 and TO- 2 2 0 packages, and 0 . 2 A for the TO package. PARAMETER Line regulation LM137 TEST CONDITIONS MIN TJ= 25°C, 3 V ≤ |VIN − VOUT| ≤ 40 V(1) LM337-N TYP MAX MIN TYP MAX 0.01 0.04 UNIT 0.01 0.02 Load regulation IL = 10 mA TJ = 25°C, 10 mA ≤ IOUT ≤ IMAX 0.3% 0.5% 0.3% 1% Thermal regulation TJ = 25°C, 10-ms Pulse 0.002 0.02 0.003 0.04 %/W 65 100 65 100 μA 2 5 2 5 μA −1.225 −1.25 −1.275 −1.213 −1.25 −1.287 −1.2 −1.25 −1.3 −1.2 −1.25 −1.3 V 0.02 0.05 0.02 0.07 %/V 0.3% 1% 0.3% 1.5% Adjustment pin current Adjustment pin current charge 10 mA ≤ IL ≤ IMAX 3 V ≤ |VIN − VOUT| ≤ 40 V, TA = 25°C (2) Reference voltage 3 V ≤ |VIN − VOUT| ≤ 40 V, (2) TJ = 25°C 10 mA ≤ IOUT ≤ IMAX, P ≤ PMAX −55°C ≤ TJ ≤ 150°C Line regulation 3 V ≤ |VIN − VOUT| ≤ 40 V, (1) Load regulation Temperature stability Minimum load current 10 mA ≤ IOUT ≤ IMAX, (1) T MIN ≤ T ≤ T j 0.6% MAX 2.5 5 2.5 10 mA 1.2 3 1.5 6 mA 1.5 2.2 3.5 1.5 2.2 3.7 A 0.5 0.8 1.8 0.5 0.8 1.9 A 0.24 0.4 0.15 0.4 A 0.17 0.1 0.17 A package NDT package Current limit K, DCY and NDE |VIN − VOUT| = 40 V, TJ = 25°C package NDT package Long- term stability (1) (2) 0.6% |VIN − VOUT| ≤ 10 V |VIN − VOUT| ≤ 15 V Ripple rejection ratio V |VIN − VOUT| ≤ 40 V K, DCY and NDE RMS output noise, % of VOUT %/V 0.15 Tj = 25 ° C, 10 Hz ≤ f ≤ 10 kHz 0.003% VOUT = −10 V, f = 120 Hz CADJ = 10 μF TJ = 125°C, 1000 Hours 0.003% 60 66 60 77 0.3% 66 1% dB 77 0.3% dB 1% Regulation is measured at constant junction temperature, using pulse testing with a low duty cycle. Changes in output voltage due to heating effects are covered under the specification for thermal regulation. Load regulation is measured on the output pin at a point ⅛ in. below the base of the TO packages. Selected devices with tightened tolerance reference voltage available. XBLWversion 2.0 www.xinboleic.com Technicalsupport:4009682003 3/10 LM337 3-Terminal Adjustable Negative Regulators 5.4 Typical Characteristics (NDE Package) Figure 1. Load Regulation Figure 3. Adjustment Current Figure 5. Temperature Stability XBLWversion 2.0 www.xinboleic.com Figure 2. Current Limit Figure 4. Dropout Voltage Figure 6. Minimum Operating Current Technicalsupport:4009682003 4/10 LM337 3-Terminal Adjustable Negative Regulators Typical Characteristics (continued) (NDE Package) Figure 7. Ripple Rejection Figure 8. Ripple Rejection Figure 9. Ripple Rejection Figure 10. Output Impedance Figure 11. Line Transient Response XBLWversion 2.0 www.xinboleic.com Figure 12. Load Transient Response Technicalsupport:4009682003 5/10 LM337 3-Terminal Adjustable Negative Regulators PLASTIC SMALL-OUTLINE SOT223-4 6,70 (0.264) 6,30 (0.248) 3,10 (0.122) 2,90 (0.114) 4 0,10 (0.004) M 7,30 (0.287) 3,70 (0.146) 3,30 (0.130) 6,70 (0.264) Gauge Plane 1 2 3 0 – 10 0,84 (0.033) 0,66 (0.026) 2,30 (0.091) 0,10 (0.004) M 4,60 (0.181) 0,25 (0.010) 0,75 (0.030) MIN 1,70 (0.067) 1,80 (0.071) MAX 1,50 (0.059) 0,35 (0.014) 0,23 (0.009) Seating Plane 0,08 (0.003) 0,10 (0.0040) 0,02 (0.0008) 4202506/B 06/2002 NOTES: A. B. C. All linear dimensions are in millimeters ( inches). This drawing is subject to change without notice. Body dimensions do not include mold flash or protrusion. D. Falls within JEDEC TO-2 61 Variation AA. XBLWversion 2.0 www.xinboleic.com Technicalsupport:4009682003 6/10 LM337 3-Terminal Adjustable Negative Regulators TO-263-3 XBLWversion 2.0 www.xinboleic.com Technicalsupport:4009682003 7/10 LM337 3-Terminal Adjustable Negative Regulators TO-92 H03A (Rev D) XBLWversion 2.0 www.xinboleic.com Technicalsupport:4009682003 8/10 LM337 3-Terminal Adjustable Negative Regulators TO-220 XBLWversion 2.0 www.xinboleic.com Technicalsupport:4009682003 9/10 LM337 3-Terminal Adjustable Negative Regulators Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products.  Thisdocumentisforreferenceonly,andtheactualuseshouldbebasedontheapplicationtestresults. Version revision history: Version version 1.0 version 2.0 XBLWversion 2.0 Event Date 2019-03 2023-11 New document 1. Update the whole package quantity of TO263-3 from 1,000 PCs to 800PCS; 2. Update the whole package quantity of SOT -223-4, from 3000PCS to 2500PCS. www.xinboleic.com Technicalsupport:4009682003 10/10
LM337CDTR(XBLW) 价格&库存
很抱歉,暂时无法提供与“LM337CDTR(XBLW)”相匹配的价格&库存,您可以联系我们找货
LM337CDTR(XBLW)
  • 1+5.45292
  • 10+4.40316
  • 30+3.87828
  • 100+3.35340
  • 500+3.04236
  • 1000+2.87712
库存:613
