Technical Data
Materlal:
Pin(outer sleeve):Brass,machined CuZn38Pb2
Plating(outer sleeve):
Tin Plated:2μm/80μm"NI,5μm/200μ"Sn
Gold Plated:2 μm"/80μm"Ni,0.8μ" gold
Plating(Contact ):2 μm/80μ"NI,gold or Tin plated
Insuiator:PPS UL94V-0
Cllp(Contact 4 Flnger):Beryllium copper,heat teated
Electrical:
Current rating:3Amps/contact max.
Contact resistance:≤4m Ω/contact
Insuiation resistance:≥1000M Ω at V=100V
Dleiectrlc Withstanding Voltage:1000V AV Min
Operaling voltage:60VAC/DC
Mechanical:
Average Insertlon force with steel pin of ∅0.66mm/0.38":<250g
Average withdrawal force with steel pin of ∅0.66mm/0.38":<70g
Mechanlcal lige cycle:min 200
Operaling temperature:-40 °C to+105°C
Soldering temperature:+255 °C
P.C.B LAYOUT
2.54mm Machined Female Header
MF254V-12-xx-0743
很抱歉,暂时无法提供与“MF254V-12-20-0743”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.63204
- 10+2.89332
- 30+2.38032
- 100+1.99044
- 500+1.81602
- 1000+1.70316
