SMF15A
SMF15A
    GOODWORK(固得沃克)
    SOD-123FL
    单向TVS 15V截止 峰值脉冲电流:8.2A
SMF15A 数据手册
SMF SERIES SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSORS VOLTAGE RANGE FEATURES 5.0 to 440 Volts • For surface mounted applications in order to optimize board space. 200 Watts Peak Power • Low profile package • Glass passivated junction SOD-123FL • Low inductance .114(2.9) .102(2.6) • Plastic package has Underwriters Laboratory Flammability .043(1.1) .031(0.8) MECHANICAL DATA .148(3.75) .140(3.55) MECHANICAL DATA .008(0.20) .005(0.12) .043(1.10) .036(0.90) ▪Case: SOD-123FL ▪Terminals: Solderable per MIL-STD-750, Method 2026 .075(1.9) .067(1.7) ▪Approx. Weight:15mg 0.00048oz .033(0.85) .022(0.55) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. RATINGS SYMBOL VALUE UNITS PPK Minimum 200 Watts IFSM 30 Amps VF 3.5 Volts TJ, TSTG -55 to +150 C Peak Power Dissipation at TA=25 C, TP=1ms(NOTE 1) Peak Forward Surge Current at 8.3ms Single Half Sine-Wave superimposed on rated load (JEDEC method) (NOTE 3) Maximum Instantenous Forward Voltage at 25.0A for Unidirectional only Operating and Storage Temperature Range NOTES: 1. Non-repetitive current pulse per Fig. 3 and derated above TA=25 C per Fig. 2. 2 2. Mounted on Copper Pad area of 5.0mm (.013mm Thick) to each terminal. 3. 8.3ms single half sine-wave, duty cycle = 4 pulses per minute maximum. DEVICES FOR BIPOLAR APPLICATIONS 1. For Bidirectional use C or CA Suffix for types SMFJ5.0 thru SMFJ440. 2. Electrical characteristics apply in both directions. REV 1.0 2017 JAN PAGE:1/3 RATING AND CHARACTERISTIC CURVES (SMF SERIES) FIG.1-PEAK PULSE POWER DERATING CURVE Non-Repetitive Pulse Waveform Shown in Fig. 3 TA=25 C 10 1.0 0.1 0.1ms 100 75 50 25 0 1.0ms 10ms 100ms 1.0ms 0 10ms 25 50 75 100 125 150 175 TA, AMBIENT TEMPERATURE ( C) td, PULSE WIDTH, sec. FIG.4-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT FIG.3-PULSE WAVE FORM 150 80 tf=10ms Peak Value IPPM TA=25 C Pulse Width (td) is defined as the point where the Peak Current Deacys to 50% of Ipp 100 Half Value-IPPM 2 50 TJ=TJmax 8.3ms Single Half Sine-wave JEDEC Method 60 IFSM, PEAK FORWARD SURGE CURRENT, AMPERES IPPM, PEAK PULSE CURRENT, % PPPM, PEAK PULSE POWER, KW 100 PEAK PULSE POWER(PPP) OR CURRENT(IPP) DERATING IN PERCENTAGE FIG.2-PULSE DERATING CURVE 10/1000msec Waveform as Defined by R.E.A. 40 20 10 td e-kt 0 0 1.0 2.0 t, TIME, ms 3.0 4.0 0 1 5 10 20 50 100 NUMBER OF CYCLES AT 60Hz REV 1.0 2017 JAN PAGE:2/3 200 Watt Surface Mount TVS PART NUMBER ADD C FOR BIDIRECTIONAL V RMW Reverse Leakage Max. Clamp Voltage Peak Pulse Current IT I R @ V RWM V C @ I PP I PP A Uni Bi 21.7 AE CAE Test Current Breakdown Voltage Marking V BR @ I T Min Max See Note 1 V V V mA μA V SMF5.0(C) A 5 6.4 7 10 400 9.2 SMF6.0(C) A 6 6.67 7.37 10 400 10.3 19.4 AG CAG SMF6.5(C) A 6.5 7.22 7.98 10 250 11.2 17.9 AK CAK SMF7.0(C) A 7 7.78 8.6 10 100 12 16.7 AM CAM SMF7.5(C) A 7.5 8.33 9.21 1 50 12.9 15.5 AP CAP S M F 8 . 0 (C) A 8 8.89 9.83 1 25 13.6 14.7 AR CAR S M F 8 . 5 (C) A 8.5 9.44 10.4 1 10 14.4 13.9 AT CAT S M F 9 . 0 (C) A 9 10 11.1 1 5 15.4 13 AV CAV S M F l 0 (C) A 10 11.1 12.3 1 2.5 17 11.8 AX CAX S M F 1 1 (C) A 11 12.2 13.5 1 2.5 18.2 11 AZ CAZ S M F 1 2 (C) A 12 13.3 14.7 1 2.5 19.9 10.1 BE CBE S M F 1 3 (C)A 13 14.4 15.9 1 1 21.5 9.3 BG CBG S M F 1 4 (C) A 14 15.6 17.2 1 1 23.2 8.6 BK CBK S M F 1 5 (C) A 15 16.7 18.5 1 1 24.4 8.2 BM CBM S M F 1 6 (C) A 16 17.8 19.7 1 1 26 7.7 BP CBP S M F 1 7 (C) A 17 18.9 20.9 1 1 27.6 7.2 BR CBR S M F 1 8 (C) A 18 20 22.1 1 1 29.2 6.8 BT CBT S M F 2 0 (C)A 20 22.2 24.5 1 1 32.4 6.2 BV CBV S M F 2 2 (C)A 22 24.4 26.9 1 1 35.5 5.6 BX CBX S M F 2 4 (C)A 24 26.7 29.5 1 1 38.9 5.1 BZ CBZ S M F 2 6 (C)A 26 28.9 31.9 1 1 42.1 4.8 CE CCE S M F 2 8 (C)A 28 31.1 34.4 1 1 45.4 4.4 CG CCG S M F 3 0 (C) A 30 33.3 36.8 1 1 48.4 4.1 CK CCK S M F 3 3 (C) A 33 36.7 40.6 1 1 53.3 3.8 CM CCM S M F 3 6 (C) A 36 40 44.2 1 1 58.1 3.4 CP CCP S M F 4 0 (C)A 40 44.4 49.1 1 1 64.5 3.1 CR CCR S M F 4 3 (C) A 43 47.8 52.8 1 1 69.4 2.9 CT CCT S M F 4 5 (C) A 45 50 55.3 1 1 72.7 2.8 CV CCV S M F 4 8 (C) A 48 53.3 58.9 1 1 77.4 2.6 CX CCX S M F 5 1 (C) A 51 56.7 62.7 1 1 82.4 2.4 CZ CCZ S M F 5 4 (C) A 54 60 66.3 1 1 87.1 2.3 DE CDE S M F 5 8 (C) A 58 64.4 71.2 1 1 93.6 2.1 DG CDG S M F 6 0 (C) A 60 66.7 73.7 1 1 96.8 1.8 DK CDK S M F 6 4 (C) A 64 71.1 78.6 1 1 103 1.7 DM CDM S M F 7 0 (C) A 70 77.8 86 1 1 113 1.5 DP CDP S M F 7 5 (C) A 75 83.3 92.1 1 1 121 1.4 DR CDR S M F 7 8 (C) A 78 86.7 95.8 1 1 126 1.4 DT CDT S M F 8 5 (C) A 85 94.4 104 1 1 137 1.3 DV CDV S M F 9 0 (C) A 90 100 111 1 1 146 1.2 DX CDX S M F l 0 0 (C) A 100 111 123 1 1 162 1.1 DZ CDZ SMF110(C) A 110 122 135 1 1 177 1 EE CEE SMF120(C) A 120 133 147 1 1 193 0.9 EG CEG SMF130(C) A 130 144 159 1 1 209 0.8 EK CEK SMF150(C) A 150 167 185 1 1 243 0.7 EM CEM SMF160(C) A 160 178 197 1 1 259 0.7 EP CEP SMF170 (C) A 170 189 209 1 1 275 0.6 ER CER SMF180(C) A 180 201 222 1 1 292 0.5 ET CET SMF200(C) A 200 224 247 1 1 324 0.5 EX CEX SMF220(C) A 220 246 272 1 1 356 0.5 E22 CE22 SMF250(C) A 250 279 309 1 1 405 0.5 E25 CE25 SMF300(C) A 300 335 371 1 1 486 0.45 E30 CE30 SMF350(C) A 350 391 432 1 1 567 0.4 E35 CE35 SMF400(C) A 400 447 494 1 1 648 0.35 E40 CE40 SMF440(C) A 440 492 543 1 1 713 0.3 E44 CE44 REV 1.0 2017 JAN PAGE:3/3
SMF15A 价格&库存
很抱歉,暂时无法提供与“SMF15A”相匹配的价格&库存,您可以联系我们找货
SMF15A
  • 1+0.33330
  • 200+0.11110
  • 1500+0.06952
  • 3000+0.05511
库存:11214
SMF15A
  • 20+0.13781
  • 200+0.10982
  • 600+0.09427
  • 3000+0.08018
  • 9000+0.07206
  • 30000+0.06766
库存:88426
