SS1060
SS1060
    GOODWORK(固得沃克)
    SMC(DO-214AB)
    电压:60V 电流:10A
SS1060 数据手册
SS1045 SS10200 THRU 10.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 45 to 200 Volts CURRENT 10.0Ampere FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Low forward voltage drop DO-214AB(SMC) .245(6.22) .220(5.59) .124(3.15) .108(2.75) MECHANICAL DATA .280(7.11) .260(6.60) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.21 grams .012(0.31) .006(0.15) .103(2.62) .079(2.00) .008 MAX. (.203) .320(8.13) .305(7.75) .050(1.27) .030(0.76) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current SS104 5 SS106 0 SS10100 100 60 70 42 100 60 45 32 45 See Fig. 1 Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 10.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=125 C Typical Junction Capacitance (Note1) Typical Thermal Resistance R JA (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG SS1015 0 SS10200 UNITS 200 150 V 105 140 V 150 200 V A 10.0 175 0.55 0.7 0.92 0.85 0.02 0.70 0.85 2 0.1 0.70 0.85 5 440 250 60 to10+150 -55 -55 to +150 A V A mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (SS1045 THRU SS10200) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 50 4 2 0 0 20 40 60 80 100 120 140 160 180 200 CASE TEMPERATURE,( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 10 5.0 SS 101 50SS 102 00 6 SS 106 0 SS 101 00 8 SS 10 45 10 INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 12 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 .01 200 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz FIG.4-TYPICAL JUNCTION CAPACITANCE REVERSE LEAKAGE CURRENT, (mA) 2800 JUNCTION CAPACITANCE,(pF) PEAK FORWARD SURGE CURRENT,(A) 250 2400 2000 1600 1200 800 400 0 10 Tj=100 C 1.0 Tj=75 C .1 Tj=25 C .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) REV 1.0 2017 JAN PAGE:2/2
SS1060 价格&库存
很抱歉,暂时无法提供与“SS1060”相匹配的价格&库存,您可以联系我们找货
SS1060
  • 5+0.83537
  • 50+0.68763
  • 150+0.61376
  • 500+0.55835
  • 3000+0.42620
  • 6000+0.40393
库存:3810
SS1060
  • 1+0.41360
  • 3000+0.38830
库存:5629
