CO53C6-100.000-33JDTSTL 数据手册
O
OSCILLATOR UNIT
WITH
HCSL
OUTPUT IN
SMD 5.0X3.2MM
S C I L L A T O R
U
N I T
CO53C6
CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 5.0x3.2x1.3 with 6 solder pads.
Highly reliable seam sealed ceramic package.
Wide frequency range.
Low jitter and phase noise.
RoHS compliant, LEAD-FREE and HALOGEN-FREE.
APPLICATIONS
High speed communication
Telecom equipment
Handheld equipment
PRODUCT SPECIFICATIONS
CO53C6
PARAMETER
Nominal frequency range
CONDITIONS / REMARKS
10 ~ 220MHz
Supply voltage
2.5VDC
Supply current
Fund., Overtone or PLL
3.3VDC
Other option possible
40mA
Frequency stability
±25ppm
Operating temperature range
±50ppm
Maximum, Fund mode lower ICC
±100ppm
–10 to +70°C or –40 to 85°C
Output waveform and load
HCSL
Output voltage level HIGH
Output voltage level LOW
Rise and Fall times
50Ω
0.74V
Typical
0V
Typical
@ 20~80~20%VCC
45~55%
Phase Jitter RMS
Other options available.
RL to Ground on each output
0.5ns
Symmetry (duty cycle)
See note below.
@ outputs cross point
CO53C6-100.000-33JDTSTL 价格&库存
很抱歉,暂时无法提供与“CO53C6-100.000-33JDTSTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 型号:CO53C6-100.000-33JDTSTL
- 品牌:HCI(杭晶)
- 封装:SMD5032_6P
- 描述:低抖动,差分有源,封装:5032,6P,频率:100MHz,输出模式:HCSL,工作电压:2.5V-3.3V,常温频差:±10ppm,工作温度:-40℃~+85℃,频率稳定度:±15ppm,型号升级变更为:1553C-100.000K33DTSTL
- 国内价格
- 1+15.84000
- 100+14.13500
- 1000+13.75000
- 品牌:HCI(杭晶)
- 封装:SMD5032_6P
- 国内价格
- 1+18.89892
- 10+16.27236
- 30+14.37426
- 100+12.69162
- 500+11.92212
- 1000+11.59380
