LM336Z-2.5
LM336Z-2.5
    HGSEMI(华冠)
    TO-92-3
    4V~6V
LM336Z-2.5 数据手册
LM236/LM336 Description The LM236 and LM336 are precision 2.5V regulator diodes. These voltage reference monolithic ICs operate like 2.5V zener diodes with a low temperature coefficient and a dynamic impedance of 0.2 Ω . A third pin enables adjusting the reference voltage and the temperature coefficient. Features SOP-8  Low temperature coefficient  Wide operating current of 400µA to 10 mA  0.2Ω dynamic impedance  ± 1% initial tolerance available  Guaranteed temperature stability  Fast turn-on TO-92 DFN-8 3*3 Ordering Information DEVICE Package Type MARKING Packing Packing Qty LM236M-2.5/TR SOP-8 236-2.5 Reel 2500pcs/reel LM336M-2.5/TR SOP-8 336-2.5 Reel 2500pcs/reel LM236Z-2.5 TO-92 LM236-2.5 Tape 1000pcs/box LM336Z-2.5 TO-92 LM336-2.5 Tape 1000pcs/box LM236DQ-2.5/TR DFN-8 3*3 236-2.5 Reel 2500pcs/reel LM336DQ-2.5/TR DFN-8 3*3 336-2.5 Reel 2500pcs/reel Schematic Diagram http://www.hgsemi.com.cn 1 / 11 2018 SEP LM236/LM336 Pin Connections DFN-8 3*3 SOP-8 TO-92 Absolute Maximum Ratings Symbol Parameter IR IF Current Reverse Forward Toper Operating Free-air Temperature Range TStg Storage Temperature Range TL LM336 Unit 15 10 mA LM336-2.5: 0 to +70 °C LM236-2.5: -40 to +85 °C -65 to +150 °C 245 °C Lead Temperature (Soldering, 10 seconds) Note:Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is intended to be functional, but specific performance is not ensured. Electrical Characteristics Symbol LM236/LM336 Parameter Unit Min. Typ. Max. 2.44 2.49 2.54 V 2.6 10 mV 3 12 Reference Breakdown Voltage VR Tamb = +25°C, IR = 1mA LM336 Reverse Breakdown Voltage Change with Current VR 400µA ≤ IR ≤ 10mA - Tamb = +25°C Tmin. ≤ Tamb ≤ Tmax. Reverse Dynamic Impedance (IR = 1mA) ZD Tamb = +25°C Tmin. ≤ Tamb ≤ Tmax. - KVT Temperature Stability (VR = 2.49V, I KVH Long Term Stability (Tamb = +25°C ±0.1°C, IR= 1mA) http://www.hgsemi.com.cn R = 1mA) 2 / 11 0.2 1 0.4 1.4 Ω - 1.8 6 mV - 20 - ppm 2018 SEP LM236/LM336 Typical Performance Characteristics http://www.hgsemi.com.cn 3 / 11 2018 SEP LM236/LM336 Typical Performance Characteristics (Continued) Application Hints The LM336 voltage references are easier to use than zener diodes. Their low impedance and wide current range facilitate biasing in any circuits. Besides, the breakdown voltage or the temperature coefficient can be adjusted so as to optimize the performance of the circuit. Figure 1 represents a LM336 with a 10kΩ potentiometer to adjust the reverse breakdown voltage which can be adjusted without altering the temperature coefficient of the circuit. The adjustment range is generally sufficient to adjust the initial tolerance of the circuit and the inaccuracy of the amplifier circuit. To obtain a lower temperature coefficient two diodes can be connected in series as indicated in Figure 2. When the circuit is adjusted to 2.49V the temperature coefficient is minimized. For a correct temperature coefficient, the diodes should be at the same ambient temperature as the LM336. The value of R1 is not critical (2-20kΩ). FIGURE1.LM336 with Pot for Adjustment of FIGURE 2. Temperature Coefficient Adjustment Breakdown Voltage http://www.hgsemi.com.cn 4 / 11 2018 SEP LM236/LM336 Typical Applications Figure 3 :2.5V Reference Figure 4 :Wide Input Range Reference Figure 5 :Precision Power Regulator with Low Temperature Coefficient Figure 5 :Adjustable Shunt Regulator http://www.hgsemi.com.cn 5 / 11 2018 SEP LM236/LM336 Figure 7 :Linear Ohmmeter Figure 8 :Bipolar Output Reference http://www.hgsemi.com.cn 6 / 11 2018 SEP LM236/LM336 Figure 9 : 5V Buffered Reference Figure 10 : Low Noise Buffered Reference http://www.hgsemi.com.cn 7 / 11 2018 SEP LM236/LM336 Physical Dimensions SOP-8 Q A C C1 B D A1 a 0.25 b Dimensions In Millimeters(SOP-8) A A1 B C C1 D Min: 1.35 0.05 4.90 5.80 3.80 0.40 0° 0.35 Max: 1.55 0.20 5.10 6.20 4.00 0.80 8° 0.45 Symbol: Q a b 1.27 BSC TO-92 B C D1 D L C1 A b a Dimensions In Millimeters(TO-92) A B C C1 D D1 L a Min: 3.43 4.44 11.2 4.32 3.17 2.03 0.33 0.40 Max: 3.83 5.21 12.7 5.34 4.19 2.67 0.42 0.52 Symbol: http://www.hgsemi.com.cn 8 / 11 b 1.27BSC 2018 SEP LM236/LM336 Physical Dimensions DFN-8 3*3 B1 F B A a E A1 b Dimensions In Millimeters(DFN-8 3*3) A A1 B B1 E F a Min: 0.85 0.00 2.90 2.90 0.20 0.30 0.20 Max: 0.95 0.05 3.10 3.10 0.25 0.50 0.34 Symbol: http://www.hgsemi.com.cn 9 / 11 b 0.65 BSC 2018 SEP LM236/LM336 Revision History DATE REVISION 2018-9-5 New 2023-9-13 Update Lead Temperature、Add annotation for Maximum Ratings. http://www.hgsemi.com.cn PAGE 1-11 10 / 11 2 2018 SEP LM236/LM336 IMPORTANT STATEMENT: Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the altered documents. Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design and machine manufacturing. You will bear all the following responsibilities: Select the appropriate Huaguan Semiconductor products for your application; Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety,security or other requirements. To avoid the occurrence of potential risks that may lead to personal injury or property loss. Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor will not bear the consequences caused by the application of products in these fields. All problems, responsibilities and losses arising from the user's use beyond the applicable area of the product shall be borne by the user and have nothing to do with Huaguan Semiconductor, and the user shall not claim any compensation liability against Huaguan Semiconductor by the terms of this Agreement. The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance scope of Huaguan Semiconductor. Not all parameters of each device need to be tested. The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages, costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement. http://www.hgsemi.com.cn 11 / 11 2018 SEP
LM336Z-2.5 价格&库存
很抱歉,暂时无法提供与“LM336Z-2.5”相匹配的价格&库存,您可以联系我们找货
