SN74HC14N
SN74HC14N
    XBLW(芯伯乐)
    DIP14_19.2X6.6MM
    四路二输入或门 ,工作电压(Vcc)(v)2-6V,静态电流Iq(Typ)2uA
SN74HC14N 数据手册
XBLW 74HC/HCT14 General Description The SN74HC/HCT14 is a hex inverter with Schmitt-trigger inputs. This device features reduced input threshold levels to allow interfacing to TTL logic levels. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. Features  Input levels: For SN74HC14: CMOS level For SN74HCT14: TTL level  Low-power dissipation  Specified from -40℃ to +125℃  Packaging information: DIP14/SOP14/TSSOP14 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY SN74HC14N SN74HC14DTR SN74HCT14DTR SN74HCT14TDTR DIP-14 SOP-14 SOP-14 TSSOP-14 74HC14N 74HC14 74HCT14 74HCT14 Tube Tape Tape Tape 1000/Box 2500/Reel 2500/Reel 3000/Reel Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol XBLW version 1.0 Figure 2. IEC logic symbol Figure 3. Logic diagram for one gate 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 1 页 共 16 页 XBLW 74HC/HCT14 Pin Configurations Pin Description Pin No. Pin Name Description 1 2 3 4 5 6 7 8 9 10 11 12 13 14 1A 1Y 2A 2Y 3A 3Y GND 4Y 4A 5Y 5A 6Y 6A VCC data input data output data input data output data input data output ground (0V) data output data input data output data input data output data input supply voltage Function Table Input Output nA L nY H H Note: H=HIGH voltage level; L=LOW voltage level. XBLW version 1.0 L 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 2 页 共 16 页 XBLW 74HC/HCT14 Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol supply voltage input clamping current output clamping current output current supply current ground current total power dissipation storage temperature VCC soldering temperature Conditions Min. Max. Unit -0.5 +7 V IIK VIVCC+0.5V - ±20 mA IOK VOVCC+0.5V - ±20 mA IO ICC IGND -0.5V
SN74HC14N 价格&库存
很抱歉,暂时无法提供与“SN74HC14N”相匹配的价格&库存,您可以联系我们找货
