SN74HC153N
SN74HC153N
    XBLW(芯伯乐)
    DIP16_19.2X6.6MM
    多路转换器,工作电压(Vcc)(v)2-6V,静态电流Iq(Typ)8uA
SN74HC153N 数据手册
XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers General Description The 74HC/HCT153 is a dual 4-input multiplexer. The device features independent enable inputs (n�) and common data select inputs (S0 and S1). For each multiplexer, the select inputs select one of the four binary inputs and routes it to the multiplexer output (nY). A HIGH on � forces the corresponding multiplexer outputs LOW. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Features  Input levels: For 74HC153: CMOS level For 74HCT153: TTL level  Non-inverting outputs  Separate enable input for each output  Common select inputs  Permits multiplexing from n lines to 1 line  Enable line provided for cascading (n lines to 1 line)  Specified from -40℃ to +105℃  Packaging information: DIP16/SOP16/TSSOP16 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY SN74HC153N SN74HC153DTR SN74HCT153DTR SN74HCT153TDTR DIP-16 SOP-16 SOP-16 TSSOP-16 74HC153N 74HC153 74HCT153 74HCT153 Tube Tape Tape Tape 1000/Box 2500/Reel 2500/Reel 3000/Reel XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 1 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol Figure 2. Functional diagram Figure 3. Logic diagram XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 2 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers Pin Configurations Pin Description Pin No. Pin Name Description 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 1� S1 1I3 1I2 1I1 1I0 1Y GND 2Y 2I0 2I1 2I2 2I3 S0 2� VCC out enable input(active LOW) data select input data input source1 data input source1 data input source1 data input source1 multiplexer output source1 ground(0V) multiplexer output source2 data input source2 data input source2 data input source2 data input source2 data select input out enable input(active LOW) supply voltage XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 3 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers Function Table Select Input Input Output Enable Output n� H L L L L L L L L nY L L H L H L H L H S0 S1 nI0 nI1 nI2 nI3 X X X X X X L L L X X X L L H X X X H L X L X X H L X H X X L H X X L X L H X X H X H H X X X L H H X X X H Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care. Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage input clamping current output clamping current output current supply current ground current storage temperature total power dissipation VCC IIK IOK IO ICC IGND Tstg Ptot -0.5 -50 -65 - +7.0 ±20 ±20 ±25 50 +150 500 V mA mA mA mA mA ℃ mW soldering temperature TL VI < -0.5V or VI > VCC+0.5V VO < -0.5V or VO > VCC+0.5V -0.5V < VO <VCC +0.5V DIP 10s SOP 245 250 ℃ Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 4 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage input transition rise and fall rate ambient temperature VCC VI VO Conditions 74HC153 VCC=2.0V VCC=4.5V VCC=6.0V 74HCT153 - Min. Typ. Max. Unit 2.0 0 0 -40 5.0 1.67 - 6.0 VCC VCC 625 139 83 +105 V V V ns/V ns/V ns/V ℃ 4.5 0 0 5.0 - 5.5 VCC VCC V V V Δt/ΔV VCC=4.5V - 1.67 139 ns/V Tamb - -40 - +105 ℃ Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL input leakage current II XBLW version 1.0 74HC153 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V VI=Vcc or GND;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.98 5.48 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V - - ±0.1 μA 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 5 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers supply current ICC input apacitance CI HIGH-level input voltage LOW-level input voltage VI=VCC or GND;IO=0A;VCC=6.0V 74HCT153 - 8.0 μA - 3.5 - pF VIH VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.98 - 4.5 4.32 0 0.15 0.1 0.26 V V V V HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL input leakage current supply current - IO=-20uA IO=-4.0uA IO=20uA;VCC=4.5V IO=5.2uA;VCC=6.0V II VI=Vcc or GND;VCC=5.5V - - ±0.1 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 8.0 μA 1In,2In - 45 162 μA n� - 60 216 μA Sn - 135 486 μA - 3.5 - pF Additional Supply currend ΔICC input apacitance CI VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V - DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL input leakage current II XBLW version 1.0 Conditions 74HC153 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V Vi= VCC or GND;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.84 5.34 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.33 0.33 V V V V V V V V V V V V V V V V - - ±1.0 μA 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 6 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers supply current ICC Vi=Vcc or GND;Io=0A;VCC=6.0V - - 80 μA 74HCT153 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current supply current VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.84 - - 0.1 0.33 V V V V - - ±1.0 μA - - 80 μA - - 203 μA - - 270 μA - - 608 μA VOH VI=VIH or VIL VCC=4.5V VOL VI=VIH or VIL II ICC additional supply current ΔICC IO=-20uA IO=-4.0mA IO=20uA;VCC=4.5V IO=5.2uA;VCC=6.0V VI= VCC or GND;VCC=5.5V VI=VCC or GND;IO=0A;VCC=5.5V VI=VCC-2.1V; 1In,2In other inputs at VCC or n� GND;IO=0V; VCC=4.5V to 5.5V Sn DC Characteristics 3 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit VCC=2.0V 1.5 - - V VCC=4.5V 3.15 - - V VCC=6.0V 4.2 - - V VCC=2.0V - - 0.5 V VCC=4.5V - - 1.35 V VCC=6.0V - - 1.8 V IO=-20uA;VCC=2.0V 1.9 - - V IO=-20uA;VCC=4.5V 4.4 - - V IO=-20uA;VCC=6.0V 5.9 - - V IO=-4.0mA;VCC=4.5V 3.7 - - V IO=-5.2mA;VCC=6.0V 5.2 - - V IO=20uA;VCC=2.0V - - 0.1 V IO=20uA;VCC=4.5V - - 0.1 V IO=20uA;VCC=6.0V - - 0.1 V IO=4.0mA;VCC=4.5V - - 0.4 V IO=5.2mA;VCC=6.0V - - 0.4 V 74HC153 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage XBLW version 1.0 VIH VIL VOH VOL VI=VIH or VIL VI=VIH or VIL 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 7 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers input leakage current supply current II VI= VCC or GND;VCC=6.0V - - ±1.0 μA ICC VI=Vcc or GND;Io=0A;VCC=6.0V - - 160 μA 74HCT153 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V IO=-20uA 4.4 - - V IO=-4.0mA 3.7 - - V IO=20uA;VCC=4.5V - - 0.1 V IO=5.2uA;VCC=6.0V - - 0.4 V - - ±1.0 μA - - 160 μA - - 221 μA - - 294 μA - - 662 μA HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL input leakage current supply current additional supply current II VI= VCC or GND;VCC=5.5V ICC ΔICC VI=VCC or GND;IO=0A;VCC=5.5V VI=VCC-2.1V; 1In,2In other inputs at VCC or n� GND;IO=0V; VCC=4.5V to 5.5V Sn AC Characteristics 1 (Tamb=25℃, GND =0V; tr=tf=6ns; CL=50pF,unless otherwise specified.) Parameter Symbol Conditions 1In to nY,2In to nY; see Figure5[1] Propagation delay tpd Sn to nY; see Figure6 n� to nY see Figure6 transition time tt power dissipation capacitance CPD XBLW version 1.0 see Figure5[2] 74HC153 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V per package;VI=GND to VCC[3] Min. Typ. Max. Unit - 47 17 14 14 50 18 15 14 33 12 10 10 19 7 6 145 29 25 150 30 26 100 20 17 75 15 13 ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns - 30 - pF 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 8 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers HIGH to LOW proapagation delay LOW to HIGH proapagation delay Propagation delay transition time power dissipation capacitance Note: 1In to nY,2In to nY; see Figure5[1] 1In to nY,2In to nY; see Figure5 74HCT153 VCC=4.5V - 19 34 ns VCC=5.0V;CL=15pF - 16 - ns VCC=4.5V - 13 24 ns VCC=5.0V;CL=15pF - 16 - ns tt VCC=4.5V VCC=5.0V;CL=15pF VCC=4.5V n� to nY see Figure6 VCC=5.0V;CL=15pF VCC=4.5V;see Figure5[2] - 20 17 14 11 7 34 27 15 ns ns ns ns ns CPD per package;VI=GND to VCC-1.5V[3] - 30 - pF tPHL tPLH Sn to nY see Figure6 tpd [1]tpd is the same as tPLH and tPHL. [2]tt is the same as tTHL and tTLH. [3]CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi×N+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×f`)=sum of outputs. AC Characteristics 2 (Tamb=-40℃ to +85℃,GND=0V; tr=tf=6ns;CL=50pF, unless otherwise specified.) Parameter Symbol Conditions 1In to nY,2In to nY; see Figure5[1] Propagation delay tpd Sn to nY; see Figure6 n� to nY see Figure6 XBLW version 1.0 74HC153 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit - - 180 36 31 190 38 33 125 25 21 ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 9 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers transition time HIGH to LOW proapagation delay LOW to HIGH proapagation delay Propagation delay transition time Note: tt tPHL tPLH tpd tt see Figure5[2] VCC=2.0V VCC=4.5V VCC=6.0V 74HCT153 1In to nY,2In to nY; VCC=4.5V see Figure5[1] 1In to nY,2In to nY; VCC=4.5V see Figure5 Sn to nY VCC=4.5V see Figure6 n� to nY VCC=4.5V see Figure6 VCC=4.5V;see Figure5[2] - - 95 19 16 ns ns ns - - 43 ns - - 30 ns - - 43 ns - - 34 ns - - 19 ns [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. AC Characteristics 3 (Tamb=-40℃ to +105℃,GND=0V; tr=tf=6ns; CL=50pF, unless otherwise specified.) Parameter Symbol Conditions 1In to nY,2In to nY; see Figure5[1] Propagation delay tpd Sn to nY; see Figure6 n� to nY see Figure6 transition time HIGH to LOW proapagation delay LOW to HIGH proapagation delay Propagation delay XBLW version 1.0 tt tPHL tPLH tpd see Figure5[2] 1In to nY,2In to nY; see Figure5[1] 1In to nY,2In to nY; see Figure5 Sn to nY see Figure6 n� to nY Min. Typ. Max. Unit - - 220 44 38 225 45 38 150 30 26 110 22 19 ns ns ns ns ns ns ns ns ns ns ns ns VCC=4.5V - - 51 ns VCC=4.5V - - 36 ns VCC=4.5V - - 51 ns VCC=4.5V - - 41 ns 74HC153 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V 74HCT153 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 10 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers see Figure6 transition time Note: tt VCC=4.5V;see Figure5[2] - - 22 ns [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. Testing Circuit AC Testing Circuit Figure 4. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 11 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers AC Testing Waveforms Figure 5. Waveforms showing the input (1In, 2In) to output (1Y, 2Y) propagation delays and output transition times Figure 6. Waveforms showing input (Sn,n�) to output (nY) propagation delays Measurement Points Type 74HC153 74HCT153 Input VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V Output VX 0.1×VCC 0.1×VCC VY 0.9×VCC 0.9×VCC Test Data Type 74HC153 74HCT153 XBLW version 1.0 Input VI VCC 3.0V tr,tf 6.0ns 6.0ns Load CL 15pF,50pF 15pF,50pF 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 Test tPHL,tPLH tPHL,tPLH 第 12 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers Package Information DIP16 Symbol A A1 A2 B B1 C D E E1 e L E2 XBLW version 1.0 Dimensions In Millimeters Min Max 3.710 4.310 0.510 3.200 3.600 0.380 0.570 1.524(BSC) 0.204 0.360 18.800 19.200 6.200 6.600 7.320 7.920 2.540(BSC) 3.000 3.600 8.400 9.000 Dimensions In Inches Min Max 0.146 0.170 0.020 0.126 0.142 0.015 0.022 0.060(BSC) 0.008 0.014 0.740 0.756 0.244 0.260 0.288 0.312 0.100(BSC) 0.118 0.142 0.331 0.354 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 13 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers SOP16 Symbol A A1 A2 b C D E E1 e L θ XBLW version 1.0 Dimensions In Millimeters Min Max 1.350 1.750 0.100 0.250 1.350 1.550 0.330 0.510 0.170 0.250 9.800 10.200 3.800 4.000 5.800 6.200 1.270(BSC) 0.400 1.270 0° 8° Dimens ons In Inches Min Max 0.053 0.069 0.004 0.010 0.053 0.061 0.013 0.020 0.007 0.010 0.386 0.402 0.150 0.157 0.228 0.244 0.050(BSC) 0.016 0.050 0° 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 8° 第 14 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers TSSOP16 MILLIMETER MIN NOM MAX SYMBOL A Al A2 A3 b bl c cl D E E1 e L L1 θ 0.05 0.90 0.39 0.20 0.19 0.13 0.12 4.90 6.20 4.30 1.00 0.44 0.22 0.13 5.00 6.40 4.40 0.65BSC 0.60 1.00BSC - 0.45 0 1.20 0.15 1.05 0.49 0.28 0.25 0.17 0.14 5.10 6.60 4.50 0.75 8° Statements And Notes Hazardous substances or Elements Part name Lead and lead compounds Mercury and mercury compounds Cadmium and cadmium compounds Hexavalent chromium compounds Polybro minated biphenyls Polybro minated biphenyl ethers Dibutyl phthalate Butyl benzyl phthalate Di-2ethylhexyl phthalate Diisobutyl phthalate Lead frame ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic resin ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ The lead ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ explanation ○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 15 页 共 16 页 XBLW 74HC/HCT153 Dual 4-Line To 1-Line Data Selectors/Multiplexers Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com        技术支持热线:4009682003 第 16 页 共 16 页
SN74HC153N 价格&库存
很抱歉,暂时无法提供与“SN74HC153N”相匹配的价格&库存,您可以联系我们找货
