SN74HC165DTR
SN74HC165DTR
    XBLW(芯伯乐)
    SOP-16
    八位并入串出移位寄存器,工作电压(Vcc)(v)2-6V,静态电流Iq(Typ)8uA
SN74HC165DTR 数据手册
XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register General Description The SN74HC/HCT165 is 8-bit serial or parallel-in/serial-out shift registers. The device features a serial data input — (DS), eight parallel data inputs (D0 to D7) and two complementary serial outputs (Q7 and Q7). When the parallel — load input ( PL) is LOW the data from D0 to D7 is loaded into the shift register — asynchronously. When PL is HIGH data enters the register serially at DS. When the clock enable input ( — — CE) is LOW data is shifted on the LOW-to-HIGH transitions of the CP input. A HIGH on CE will disable the CP input. Inputs are overvoltage tolerant to 15V. This enables the device to be used in HIGH-to-LOW level shifting applications. Features Input levels: For SN74HC165: CMOS level For SN74HCT165: TTL level Asynchronous 8-bit parallel load Synchronous serial input Specified from -40℃ to +85℃ Packaging information: DIP16/SOP16/TSSOP16 Ordering Information DEVICE SN74HC165N SN74HC165DTR SN74HCT165DTR SN74HCT165TDTR XBLWversion1.0 Package Type DIP-16 SOP-16 SOP-16 TSSOP-16 MARKING Packing Packing QTY 74HC165N 74HC165 74HCT165 74HCT165 Tube Tape Tape Tape 1000/Box 2500/Reel 2500/Reel 3000/Reel 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 1 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 2 、Block Diagram And Pin Description 2.1 Block Diagram Figure 1. Logic symbol Figure 2. Functional diagram Figure 3. Functional diagram XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 2 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register Figure 4. Timing diagram 2.2 Pin Configurations XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 3 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 2.3 Pin Description Pin No. Pin Name Description 1 PL — asynchronous parallel load input (active LOW) 2 3 4 5 6 CP D4 D5 D6 D7 clock input ( LOW- to- HIGH, edge- triggered) 7 — Q7 complementary output from the last stage 8 9 10 11 12 13 14 GND Q7 DS D0 D1 D2 D3 ground ( 0 V) 15 — CE clock enable input (active LOW) 16 VCC supply voltage parallel data input ( also referred to as Dn) parallel data input ( also referred to as Dn) parallel data input ( also referred to as Dn) parallel data input ( also referred to as Dn) serial output from the last stage serial data input parallel data input ( also referred to as Dn) parallel data input ( also referred to as Dn) parallel data input ( also referred to as Dn) parallel data input ( also referred to as Dn) 2.4 Function Table Operating mode parallel load serial shift Input PL CE CP DS D0 to D7 Q0 Q1 to Q6 Q7 Q7 L L X X X X X X L H L H L to L H to H L H H L H L t l X L q0 to q5 q6 — H q0 to q5 q6 — L q0 to q5 q6 — H q0 to q5 q6 — q0 q1 to q6 q7 — q0 q1 to q6 q7 — H H H hold "do nothing" Output Qn register — — H H t L t L t L H X X H h l h X X X X X X X — q6 q6 q6 q6 q7 q7 Note: H= HIGH voltage level; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L=LOW voltage level; t=LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; q=state of the referenced output one set-up time prior to the LOW-to-HIGH clock transition; X=don’t care; t=LOW-to-HIGH clock transition. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 4 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 3 、Electrical Parameter 3.1 Absolute Maximum Ratings Symbol Parameter supply voltage VCC input clamping current output clamping current output current supply current ground current total power dissipation storage temperature soldering temperature - Min. -0.5 Max. +7 Unit V IIK VI < -0.5V or VI > VCC+0.5V - ±20 mA IOK VO < -0.5V or VO > VCC+0.5V - ±20 mA IO ICC IGND -0.5V < VO < VCC+0.5V - -50 ±25 50 - mA mA mA Ptot - - 500 mW Tstg - -65 +150 ℃ TL Conditions DIP SOP 10s ℃ ℃ 245 250 (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Note: [1] For DIP16 packages: above 70℃ the value ofPtot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value ofPtot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value ofPtot derates linearly with 5.5mW/K. 3.2 Recommended Operating Conditions Symbol Parameter supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb XBLWversion1.0 Conditions SN74HC165 Min. Typ. Max. Unit VCC=2.0V VCC=4.5V VCC=6.0V 2.0 0 0 5.0 - 6.0 VCC VCC 625 139 83 V V V ns/V ns/V ns/V - -40 - +85 ℃ VCC=2.0V VCC=4.5V VCC=6.0V 4.5 0 0 5.0 5.5 VCC VCC - -40 - 1.67 SN74HCT165 - - - V V V ns/V ns/V ns/V - +85 ℃ 1.67 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 139 第 5 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 3.3 Electrical Characteristics 3.3.1 DC Characteristics 1 ( Tamb=2 5 C, voltages are referenced to GND ( ground=0 V), unless otherwise specified.) Symbol Parameter Conditions Min. Typ. SN74HC165 VCC=2.0V 1.5 1.2 HIGH-level V =4.5V 3.15 2.4 CC V IH input voltage VCC=6.0V 4.2 3.2 VCC=2.0V 0.8 LOW-level V =4.5V CC 2.1 V IL input voltage VCC=6.0V 2.8 IO=-20uA; VCC=2.0V 1.9 2.0 IO=-20uA; VCC=4.5V 4.4 4.5 HIGH-level VI = VIH or VIL IO=-20uA; VCC=6.0V 5.9 6.0 VOH output voltage IO=-4.0mA; VCC=4.5V 3.98 4.32 IO=-5.2mA; VCC=6.0V 5.48 5.81 IO=20uA; VCC=2.0V 0 IO=20uA; VCC=4.5V 0 LOW-level I =20uA; V =6.0V V = V or V O CC I IH IL 0 V OL output voltage IO=4.0mA; VCC=4.5V 0.15 IO=5.2mA; VCC=6.0V 0.16 input leakage current II supply current ICC input capacitance CI Max. Unit 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V VI= VCC or GND; VCC= 6.0 V - - ±0. 1 uA VCC= 6 . 0 V - - 8 uA - - 3.5 - pF VI= VCC or GND; IO= 0 A; SN74HCT165 HIGH- level input voltage LOW- level input voltage VIH VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.98 - 4.5 4.32 0 0.16 0.1 0.26 V V V V - - ±0. 1 uA - - 8.0 uA - 35 126 uA CP, CE, and PL inputs - 65 234 uA - - 3.5 - pF HIGH-level output voltage VOH VI = VIH or VIL ; VCC= 4 . 5 V LOW-level output voltage VOL VI = VIH or VIL input leakage current II supply current ICC VI= VCC or GND; VCC= 6.0 V VI= VCC or GND; IO= 0 A; VCC= 6.0 V per input pin; VI= VCC-2 . 1 V; additional supply current ΔICC input capacitance CI XBLWversion1.0 IO=-20uA IO=-4.0mA IO=20uA; VCC=4.5V IO=5.2mA; VCC=6.0V other inputs at VCC or GND; VCC=4.5 V to 5.5V Dn and DS inputs — — 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 6 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 3.3.2 DC Characteristics 2 (Tamb=-40C to +85C, voltages are referenced to GND (ground=0V), unless otherwise specified.) Symbol Parameter Conditions Min. Typ. Max. Unit SN74HC165 VCC=2.0V 1.5 V HIGH-level VCC=4.5V 3.15 V VIH input voltage VCC=6.0V 4.2 V VCC=2.0V 0.5 V LOW-level VCC=4.5V 1.35 V VIL input voltage VCC=6.0V 1.8 V IO=-20uA; VCC=2.0V 1.9 V IO=-20uA; VCC=4.5V 4.4 V HIGH-level VI = VIH or VIL IO=-20uA; VCC=6.0V 5.9 V VOH output voltage IO=-4.0mA; VCC=4.5V 3.84 V IO=-5.2mA; VCC=6.0V 5.34 V IO=20uA; VCC=2.0V 0.1 V IO=20uA; VCC=4.5V 0.1 V LOW-level IO=20uA; VCC=6.0V VI = VIH or VIL 0.1 V VOL output voltage IO=4.0mA; VCC=4.5V 0.33 V IO=5.2mA; VCC=6.0V 0.33 V input leakage current II supply current ICC HIGH- level input voltage LOW- level input voltage VI= VCC or GND; VCC= 6.0 V VI= VCC or GND; IO= 0 A; VCC= 6.0 V SN74HCT165 ±1 uA - - 80 uA VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.84 - - 0.1 0.33 V V V V - - ±1 uA - - 80 uA - - 157.5 uA - - 292.5 uA VOH VI = VIH or VIL ; VCC= 4 . 5 V LOW-level output voltage VOL VI = VIH or VIL input leakage current II supply current ICC XBLWversion1.0 - VIH HIGH-level output voltage additional supply current - ΔICC IO=-20uA IO=-4.0mA IO=20uA; VCC=4.5V IO=5.2mA; VCC=6.0V VI= VCC or GND; VCC= 6.0 V VI= VCC or GND; IO= 0 A; VCC= 6 . 0 V per input pin; Dn and DS inputs VI= VCC-2 . 1 V; other inputs at VCC or GND; VCC=4.5V to 5.5V — — CP, CE, and PL inputs 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 7 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 3.3.3 DC Characteristics 3 (Tamb=25℃, GND=0V, CL=50pf, unless otherwise specified.) Symbol Parameter Conditions SN74HC165 VCC=2.0V — — VCC=4.5V CP, CE to Q7, Q7; VCC=5.0V;CL=15pF see Figure 6 propagation delay — — PL to Q7, Q7; see Figure 7 tpd — D7 to Q7, Q7; see Figure 8 transition time pulse width — Q7 , Q7 output; see Figure 6 tt tW CP input HIGH or LOW; see Figure 6 — PL input LOW; see Figure 7 recovery time — — PL to CP, CE; see Figure 7 trec — DS to CP, CE; see Figure 9 — set-up time tsu CE to CP and CP to — CE; see Figure 9 — Dn to PL; see Figure 1 0 — hold time th DS to CP, CE and — Dn to PL; see Figure 9 — CE to CP and CP to — CE; see Figure 9 maximum frequency XBLWversion1.0 f max CP input; see Figure 6 Min. Typ. Max. Unit 80 16 14 80 16 14 100 20 17 80 16 14 80 16 14 80 16 14 5 5 5 5 5 5 6 30 52 19 16 15 50 18 15 14 36 13 11 10 19 7 6 17 6 5 14 5 4 22 8 6 11 4 3 17 6 5 22 8 6 2 2 2 - 17 -6 -5 17 51 165 33 ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 28 165 33 28 120 24 20 75 15 13 - 第 8 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register VCC=5.0V;CL=15pF VCC=6.0V power dissipation capacitance 35 56 61 - MHz MHz per package; VI= GND to VCC - 35 - pF SN74HCT165 VCC=4.5V CP, CE to Q7, Q7; VCC=5.0V;CL=15pF see Figure 6 - 34 ns ns - 17 14 20 17 14 11 VCC=4.5V - VCC=4.5V CPD — propagation delay — 7 15 ns 16 6 - ns VCC=4.5V 20 9 - ns VCC=4.5V 20 8 - ns VCC=4.5V 20 2 - ns VCC=4.5V 20 7 - ns VCC=4.5V 20 10 - ns VCC=4.5V 7 -1 - ns CE; see Figure 9 VCC=4.5V 0 -7 - ns CP input; see Figure 6 VCC=4.5V VCC=5.0V;CL=15pF 26 - 44 48 - MHz MHz - 35 - pF — D7 to Q7, Q7; see Figure 8 transition time pulse width recovery time — Q7 , Q7 output; tt see Figure 6 CP input; see Figure 6 tW — PL input; see Figure 7 — — PL to CP, CE; see Figure 7 trec 40 - — PL to Q7, Q7; see Figure 7 tpd VCC=4.5V VCC=5.0V;CL=15pF VCC=4.5V VCC=5.0V;CL=15pF ns ns ns ns — — DS to CP, CE; see Figure 9 28 — set-up time tsu CE to CP and CP to — CE; see Figure 9 — Dn to PL; see Figure 1 0 — hold time th DS to CP, CE and — Dn to PL; see Figure 9 — CE to CP and CP to — maximum frequency f max power dissipation capacitance CPD per package; VI= GND to VCC- 1.5V Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH . [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD ×VCC2 ×fi ×N)+∑(CL ×VCC2 ×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL ×VCC2 ×fo)=sum of outputs. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 9 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 3.3.4 AC Characteristics 2 (Tamb=-40℃ to +85℃, GND=0V, CL=50pf, unless otherwise specified.) Parameter Symbol propagation delay tpd transition time tt pulse width tW recovery time trec set-up time tsu hold time th XBLWversion1.0 Conditions SN74HC165 VCC=2.0V — — CP, CE to Q7, Q7; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V — — PL to Q7, Q7; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — D7 to Q7, Q7; VCC=4.5V see Figure 8 VCC=6.0V VCC=2.0V — Q7 , Q7 output; VCC=4.5V see Figure 6 VCC=6.0V VCC=2.0V CP input HIGH or VCC=4.5V LOW; see Figure 6 VCC=6.0V VCC=2.0V — PL input LOW; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — — PL to CP, CE; VCC=4.5V see Figure 7 VCC=6.0V VCC=2.0V — DS to CP, CE; VCC=4.5V see Figure 9 VCC=6.0V — VCC=2.0V CE to CP and CP to — VCC=4.5V CE; VCC=6.0V see Figure 9 VCC=2.0V — Dn to PL; VCC=4.5V see Figure 1 0 VCC=6.0V — VCC=2.0V DS to CP, CE and — VCC=4.5V Dn to PL; VCC=6.0V see Figure 9 — VCC=2.0V CE to CP and CP to — VCC=4.5V CE; VCC=6.0V see Figure 9 Min. Typ. Max. Unit 100 20 17 100 20 17 125 25 21 100 20 17 100 20 17 100 20 17 5 5 5 5 5 5 - 205 41 35 205 41 35 150 30 26 95 19 16 ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 - 第 10 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register maximum frequency VCC=2.0V VCC=4.5V VCC=6.0V SN74HCT165 f max — — CP, CE to Q7, Q7; see Figure 6 propagation delay — — PL to Q7, Q7; see Figure 7 tpd — D7 to Q7, Q7; see Figure 8 transition time pulse width recovery time 5 24 28 - - MHz MHz MHz VCC=4.5V - - 43 ns VCC=4.5V - - 50 ns VCC=4.5V - - 35 ns VCC=4.5V - - 19 ns VCC=4.5V 20 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 9 - - ns VCC=4.5V 0 - - ns VCC=4.5V 21 - - MHz CP input; see Figure 6 — Q7 , Q7 output; tt see Figure 6 CP input; see Figure 6 tW — PL input; see Figure 7 — — PL to CP, CE; see Figure 7 trec — DS to CP, CE; see Figure 9 — set-up time tsu CE to CP and CP to — CE; see Figure 9 — Dn to PL; see Figure 1 0 — DS to CP, CE and — hold time th Dn to PL; see Figure 9 — CE to CP and CP to — maximum frequency Note: f max CE; see Figure 9 CP input; see Figure 6 [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH . [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=(CPD ×VCC2 ×fi ×N)+∑(CL ×VCC2 ×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL ×VCC2 ×fo)=sum of outputs. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 11 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 4 、Testing Circuit 4.1 AC Testing Circuit Figure 5. Test circuit for measuring switching times Definitions for test circuit: CL=load capacitance including jig and probe capacitance. RT=termination resistance should be equal to the output impedance Zo of the pulse generator. RL=Load resistance. S1=Test selection switch. 4.2 AC Testing Waveforms — — Figure 6. The clock (CP) or clock enable (CE) to output (Q7 or Q7) propagation delays, the clock pulse width, the maximum clock frequency and the output transition times XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 12 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register — — Figure 7. The parallel load (PL) pulse width, the parallel load to output (Q7 or Q7) propagation delays, the — parallel load to clock (CP) and clock enable (CE) recovery time — — Figure 8. The data input (D7) to output (Q7 or Q7) propagation delays when PL is LOW — Figure 9. The set-up and hold times from the serial data input (DS) to the clock (CP) and clock enable (CE) inputs, — from the clock enable input (CE) to the clock input (CP) and from the clock input (CP) to the clock — enable input (CE) XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 13 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register — Figure 10. The set-up and hold times from the data inputs (Dn) to the parallel load input (PL) 4.3 Measurement Points Input Type VI VCC 3V SN74 HC16 5 SN7 4 HCT1 6 5 4.4 Test Data Type SN74 HC16 5 SN7 4 HCT1 6 5 XBLWversion1.0 VM 0.5×VCC 1.3V Input VI VCC 3.0V Output VM 0.5×VCC 1.3V S1 position Load tr , tf 6.0ns 6.0ns CL 15pF, 50pF 15pF, 50pF RL 1kΩ 1kΩ tPHL, tPLH 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 open open 第 14 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 5 、Package Information 5.1 DIP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 15 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 5.2、SOP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 16 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register 5.3,TSSOP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 17 页 共 18 页 XBLW SN74HC/HCT165 8-bit Parallel-in, Serial out Shift Register Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 18 页 共 18 页
SN74HC165DTR 价格&库存
很抱歉,暂时无法提供与“SN74HC165DTR”相匹配的价格&库存,您可以联系我们找货
SN74HC165DTR
  • 1+0.63800
  • 100+0.42460
  • 1250+0.38610
  • 2500+0.35420
