SN74HC161N
SN74HC161N
    XBLW(芯伯乐)
    DIP16_19.2X6.6MM
    四位二进制同步计数器(异步清除),工作电压(Vcc)(v)2-6V,静态电流Iq(Typ)8uA
SN74HC161N 数据手册
XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS General Description The SN74HC/HCT161 is a synchronous presettable binary counter with an internal look-head carry. Synchronous operation is provided by having all flip-flops clocked simultaneously on the positive-going edge of the clock (CP). The outputs (Q0 to Q3) of the counters may be preset HIGH or LOW. A LOW at the parallel enable input (P�) disables the counting action and causes the data at the data inputs (D0 to D3) to be loaded into the counter on the positive-going edge of the clock. Preset takes place regardless of the levels at count enable inputs (CEP and CET). A LOW at the master reset input (M�) sets Q0 to Q3 LOW regardless of the levels at input pins CP, P�, CET and CEP (thus providing an asynchronous clear function). The look-ahead carry simplifies serial cascading of the counters. Both CEP and CET must be HIGH to count. The CET input is fed forward to enable the terminal count output (TC). The TC output thus enabled will produce a HIGH output pulse of a duration approximately equal to a HIGH output of Q0. This pulse can be used to enable the next cascaded stage. The maximum clock frequency for the cascaded counters is determined by the CP to TC propagation delay and CEP to CP set-up time, according to the following formula: fmax=1/(tP(max)(CP to TC)+tSU(CEP to CP)) Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Features  Input levels: For SN74HC161: CMOS level For SN74HCT161: TTL level  Synchronous counting and loading  2 count enable inputs for n-bit cascading  Asynchronous reset  Positive-edge triggered clock  Specified from -40℃ to +105℃  Packaging information: DIP16/SOP16/TSSOP16 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY SN74HC161N SN74HC161DTR SN74HCT161DTR SN74HCT161TDTR DIP-16 SOP-16 SOP-16 TSSOP-16 74HC161N 74HC161 74HCT161 74HCT161 Tube Tape Tape Tape 1000/Box 2500/Reel 2500/Reel 3000/Reel XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 1 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol Figure 2. IEC Logic symbol Figure 3. Functional diagram XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 2 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Figure 4. Logic diagram Figure 5. State diagram XBLW version 1.0 Figure 6. Typical timing sequence 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 3 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Pin Configurations Pin Description Pin No. Pin Name Description 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 M� CP D0 D1 D2 D3 CEP GND P� CET Q3 Q2 Q1 Q0 TC VCC asy nchronous master reset(active LOW) clock input(LOW-to-HIGH,edge triggered) data input data input data input data input count enable input ground(0V) parallel enable input(active LOW) count enable carry input flip-flop output flip-flop output flip-flop output flip-flop output terminal count output supply voltage XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 4 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Function Table Input Operating mode M� L H H H H H reset(clear) parallel load count hold(do nothing) CP X ↑ ↑ ↑ X X CEP X X X h l X CET X X X h X l Output P� X l l h h h Dn X l h X X X Qn L L H count qn qn TC L L [2] [2] [2] L Note: [1] H=HIGH voltage level; L=LOW voltage level; X=don’t care; ↑=LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition; q=lower case letters indicate the state of the referenced output one set-up time prior to the LOW-to-HIGH CP transition. [2] The TC output is HIGH when CET is HIGH and the counter is at terminal count (HLLH). Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage input clamping current output clamping current output current supply current ground current storage temperature total power dissipation VCC IIK IOK IO ICC IGND Tstg Ptot -0.5 -50 -65 - +7.0 ±20 ±20 ±25 +50 +150 500 V mA mA mA mA mA ℃ mW soldering temperature TL VI < -0.5V or VI > VCC +0.5V VO < -0.5V or VO > VCC +0.5V -0.5V < VO <VCC +0.5V DIP 10s SOP 245 250 ℃ Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 5 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage input transition rise and fall rate ambient temperature VCC VI VO Conditions SN74HC161 VCC=2.0V VCC=4.5V VCC=6.0V SN74HCT161 - Min. Typ. Max. Unit 2.0 0 0 -40 5.0 1.67 - 6.0 VCC VCC 625 139 83 +105 V V V ns/V ns/V ns/V ℃ 4.5 0 0 5.0 - 5.5 VCC VCC V V V Δt/ΔV VCC=4.5V - 1.67 139 ns/V Tamb - -40 - +105 ℃ Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL input leakage current supply current XBLW version 1.0 SN74HC161 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.98 5.48 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V II VI=Vcc or GND;VCC=6.0V - - ±0.1 μA ICC VI=VCC or GND;IO=0A;VCC=6.0V - - 8.0 μA 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 6 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS input apacitance HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current supply current Additional Supply currend CI SN74HCT161 VIH VIL 3.5 - pF VCC=4.5V to 5.5V 2.0 1.6 - V VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.98 - 4.5 4.32 0 0.15 0.1 0.26 V V V V VOH VI=VIH or VIL VCC=4.5V VOL VI=VIH or VIL VCC=4.5V IO=-20uA IO=-4.0uA IO=20uA IO=4.0uA II VI=Vcc or GND;VCC=5.5V - - ±0.1 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 8.0 μA pin M� - 95 342 μA pin CP - 110 396 μA pin CEP and Dn - 25 90 μA pin CET - 75 270 μA pin P� - 30 108 μA - 3.5 - pF ΔICC input apacitance - per input pin; VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V CI - DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL XBLW version 1.0 SN74HC161 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.84 5.34 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.33 0.33 V V V V V V V V V V V V V V V V 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 7 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS input leakage current supply current II Vi= VCC or GND;VCC=6.0V - - ±1.0 μA ICC Vi=Vcc or GND;Io=0A;VCC=6.0V - - 80 μA SN74HCT161 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.84 - - 0.1 0.33 V V V V HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL VCC=4.5V input leakage current supply current additional supply current IO=-20uA IO=-4.0mA IO=20uA IO=4.0mA II VI= VCC or GND;VCC=5.5V - - ±1.0 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 80 μA pin M� - - 427.5 μA pin CP - - 495 μA pin CEP and Dn - - 112.5 μA pin CET - - 337.5 μA pin P� - - 135 μA ΔICC per input pin; VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V DC Characteristics 3 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL XBLW version 1.0 SN74HC161 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.7 5.2 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.4 V V V V V V V V V V V V V V V 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 8 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS IO=5.2mA;VCC=6.0V input leakage current supply current - - 0.4 V II VI= VCC or GND;VCC=6.0V - - ±1.0 μA ICC VI=Vcc or GND;Io=0A;VCC=6.0V - - 160 μA SN74HCT161 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.7 - - 0.1 0.4 V V V V HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL VCC=4.5V input leakage current supply current additional supply current IO=-20uA IO=-4.0mA IO=20uA IO=4.0mA II VI= VCC or GND;VCC=5.5V - - ±1.0 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 160 μA pin M� - - 465.5 μA pin CP - - 539 μA pin CEP and Dn - - 122.5 μA pin CET - - 367.5 μA pin P� - - 147 μA ΔICC VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V AC Characteristics 1 (Tamb=25℃, GND =0V; tr=tf=6ns;, CL=50pF,unless otherwise specified.) Parameter Symbol Conditions CP to Qn; see Figure8 Propagation delay tpd CP to TC; see Figure8 CET to TC; see Figure9 High to LOW Propagation delay XBLW version 1.0 tPHL M� to Qn; see Figure10 SN74HC161 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V Min. Typ. Max. Unit - 61 22 19 18 69 25 21 20 33 12 10 10 63 23 20 18 190 38 32 215 43 37 150 30 26 210 42 36 ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 9 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS M� to TC; see Figure10 transition time pulse width tt tw see Figure8 and see Figure9 CP HIGH or LOW;see Figure8 M� LOW; see Figure10 Recovery time trec M� to CP; see Figure10 Dn to CP; see Figure11 Set-up time tsu P� to CP; see Figure11 CEP,CET to CP; see Figure12 Hold time th Dn, P� ,CEP,CETto CP; see Figure11,12 Maximum frequency fMAX CP;see Figure8 power dissipation capacitance CPD Propagation delay fi=1MHz; VI=GND to VCC CP to Qn; see Figure8[1] tpd CP to TC; see Figure8 CET to TC; XBLW version 1.0 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V SN74HCT161 VCC=4.5V VCC=5.0V;CL=15pF VCC=4.5V VCC=5.0V;CL=15pF VCC=4.5V 80 16 14 80 16 14 100 20 17 80 16 14 100 20 17 170 34 29 0 0 0 4.6 23 27 63 23 20 18 19 7 6 22 8 6 19 7 6 19 7 6 25 9 7 30 11 9 47 17 14 -14 -5 -4 13 40 44 48 220 44 37 75 15 13 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz MHz - 33 - pF - 25 20 28 24 17 43 48 35 ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 10 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS see Figure9 HIGH to LOW proapagation delay tPHL transition time tt pulse width tw Recovery time trec Set-up time tsu Hold time th Maximum frequency fMAX power dissipation capacitance Note: VCC=5.0V;CL=15pF VCC=4.5V M� to Qn; see Figure10 VCC=5.0V;CL=15pF VCC=4.5V M� to TC; see Figure10 VCC=5.0V;CL=15pF VCC=4.5V;see Figure8,9 CP HIGH or LOW;VCC=4.5V;see Figure8 M� LOW;VCC=4.5V;see Figure10 M� CP;VCC=4.5V;see Figure10 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 Dn, P� ,CEP, CET to CP; VCC=4.5V;see Figure11 VCC=4.5V CP;see Figure8 VCC=5.0V;CL=15pF CPD fi=1MHz;;VI=GND to VCC-1.5V 16 20 20 18 30 40 14 29 25 30 26 7 7 10 6 8 17 17 46 51 15 - ns ns ns ns ns ns ns ns ns ns ns ns 0 -7 - ns 23 - 41 45 - MHz MHz - 35 - pF [1]tpd is the same as tPLH and tPHL. [2]tt is the same as tTHL and tTLH. [3]CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi×N+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×f`)=sum of outputs. AC Characteristics 2 (Tamb=-40℃ to +85℃,GND=0V; tr=tf=6ns; CL=50pF, unless otherwise specified.) Parameter Propagation delay XBLW version 1.0 Symbol Conditions CP to Qn; see Figure8 tpd CP to TC; see Figure8 SN74HC161 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit - - 240 48 41 270 54 46 ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 11 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V M� to Qn; VCC=4.5V see Figure10 VCC=6.0V VCC=2.0V M� to TC; VCC=4.5V see Figure10 VCC=6.0V VCC=2.0V see Figure8 and VCC=4.5V see Figure9 VCC=6.0V VCC=2.0V CP HIGH or VCC=4.5V LOW;see Figure8 VCC=6.0V VCC=2.0V M� LOW; VCC=4.5V see Figure10 VCC=6.0V VCC=2.0V M� to CP; VCC=4.5V see Figure10 VCC=6.0V VCC=2.0V Dn to CP; VCC=4.5V see Figure11 VCC=6.0V VCC=2.0V P� to CP; VCC=4.5V see Figure11 VCC=6.0V VCC=2.0V CEP,CET to CP; VCC=4.5V see Figure12 VCC=6.0V VCC=2.0V Dn, P� CEP,CET, VCC=4.5V to CP; see Figure11,12 VCC=6.0V VCC=2.0V CP;see Figure8 VCC=4.5V VCC=6.0V SN74HCT161 CP to Qn; VCC=4.5V see Figure8 CP to TC; VCC=4.5V see Figure8 CET to TC; see Figure9 High to LOW Propagation delay tPHL transition time tt pulse width tw Recovery time trec Set-up time tsu Hold time th Maximum frequency fMAX Propagation delay tpd XBLW version 1.0 100 20 17 100 20 17 125 25 21 100 20 17 125 25 21 215 43 37 0 0 0 3.6 18 21 - 190 38 33 265 53 45 275 55 47 95 19 16 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz - - 54 ns - - 60 ns 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 12 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS High to LOW proapagation delay tPHL transition time tt pulse width tw Recovery time trec Set-up time tsu Hold time th Maximum frequency Note: fMAX CET to TC; VCC=4.5V see Figure9 M� to Qn; VCC=4.5V see Figure10 M� to TC; VCC=4.5V see Figure10 VCC=4.5V;see Figure8,9[2] CP HIGH or LOW;VCC=4.5V;see Figure8 M� LOW;VCC=4.5V;see Figure10 M� to CP;VCC=4.5V;see Figure10 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 Dn, P� ,CEP, CET to CP; VCC=4.5V;see Figure11 CP;see Figure8 VCC=4.5V - - 44 ns - - 58 ns - - 63 ns 20 25 25 23 38 50 - 19 - ns ns ns ns ns ns ns 0 - - ns 18 - - MHz [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. AC Characteristics 3 (Tamb=-40℃ to +105℃,GND=0V; tr=tf=6ns; CL=50pF, unless otherwise specified.) Parameter Symbol Conditions CP to Qn; see Figure8 Propagation delay tpd CP to TC; see Figure8 CET to TC; see Figure9 High to LOW Propagation delay XBLW version 1.0 tPHL M� to Qn; see Figure10 M� to TC; see Figure10 SN74HC161 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V Min. Typ. Max. Unit - - 248 57 48 325 65 55 225 45 38 315 63 54 330 66 ns ns ns ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 13 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS transition time pulse width tt tw see Figure8 and see Figure9 CP HIGH or LOW;see Figure8 M� LOW; see Figure10 Recovery time trec M� to CP; see Figure10 Dn to CP; see Figure11 Set-up time tsu P� to CP; see Figure11 CEP,CET to CP; see Figure12 Hold time Maximum frequency Propagation delay th fMAX tpd High to LOW proapagation delay tPHL transition time tt pulse width tw XBLW version 1.0 Dn, P� CEP,CET, to CP; see Figure11,12 VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V 120 24 20 120 24 20 150 30 26 120 24 20 150 30 26 255 51 43 0 0 - 56 110 22 19 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns VCC=6.0V 0 - - ns 3.0 15 18 - - MHz MHz MHz - - 65 ns - - 72 ns - - 53 ns - - 69 ns - - 77 ns 24 30 - 22 - ns ns ns VCC=2.0V CP;see Figure8 VCC=4.5V VCC=6.0V SN74HCT161 CP to Qn; VCC=4.5V see Figure8[1] CP to TC; VCC=4.5V see Figure8 CET to TC; VCC=4.5V see Figure9 M� to Qn; VCC=4.5V see Figure10 M� to TC; VCC=4.5V see Figure10 VCC=4.5V;see Figure8,9[2] CP HIGH or LOW;VCC=4.5V;see Figure8 M� LOW;VCC=4.5V;see Figure10 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 14 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Recovery time trec Set-up time tsu Hold time th Maximum frequency Note: fMAX M� to CP;VCC=4.5V;see Figure10 Dn to CP;VCC=4.5V;see Figure11 P� to CP;VCC=4.5V;see Figure11 CEP,CET to CP;VCC=4.5V;see Figure12 Dn, P� ,CEP, CET to CP; VCC=4.5V;see Figure11 CP;see Figure8 VCC=4.5V 30 27 45 60 - - ns ns ns ns 0 - - ns 15 - - MHz [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. Testing Circuit AC Testing Circuit Figure 7. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. RL=Load resistance S1=Test selection switch XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 15 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS AC Testing Waveforms Figure 8. The clock (CP) to outputs (Qn, TC) propagation delays, pulse width, output transition times and maximum frequency Figure 9. The count enable carry input (CET) to terminal count output (TC) propagation delays and output transition times Figure 10. The master reset (M�) pulse width, master reset to output (Qn, TC) propagation delays, and the master reset to clock (CP) recovery times XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 16 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Figure 11. The data input (Dn) and parallel enable input (P�) set-up and hold times Figure 12. The count enable input (CEP) and count enable carry input (CET) set-up and hold times Measurement Points Input Type VI GND to VCC GND to 3V SN74HC161 SN74HCT161 Output VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V Test Data Type VI Input tr,tf CL Load RL S1 position tPHL,tPLH SN74HC161 VCC 6.0ns 15pF,50pF 1KΩ open SN74HCT161 3.0V 6.0ns 15pF,50pF 1KΩ open XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 17 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Package Information DIP16 Symbol A A1 A2 B B1 C D E E1 e L E2 XBLW version 1.0 Dimensions In Millimeters Min Max 3.710 4.310 0.510 3.200 3.600 0.380 0.570 1.524(BSC) 0.204 0.360 18.800 19.200 6.200 6.600 7.320 7.920 2.540(BSC) 3.000 3.600 8.400 9.000 Dimensions In Inches Min Max 0.146 0.170 0.020 0.126 0.142 0.015 0.022 0.060(BSC) 0.008 0.014 0.740 0.756 0.244 0.260 0.288 0.312 0.100(BSC) 0.118 0.142 0.331 0.354 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 18 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS SOP16 Symbol A A1 A2 b C D E E1 e L θ XBLW version 1.0 Dimensions In Millimeters Min Max 1.350 1.750 0.100 0.250 1.350 1.550 0.330 0.510 0.170 0.250 9.800 10.200 3.800 4.000 5.800 6.200 1.270(BSC) 0.400 1.270 0° 8° Dimens ons In Inches Min Max 0.053 0.069 0.004 0.010 0.053 0.061 0.013 0.020 0.007 0.010 0.386 0.402 0.150 0.157 0.228 0.244 0.050(BSC) 0.016 0.050 0° 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 8° 第 19 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS TSSOP16 MILLIMETER MIN NOM MAX SYMBOL A Al A2 A3 b bl c cl D E E1 e L L1 θ 0.05 0.90 0.39 0.20 0.19 0.13 0.12 4.90 6.20 4.30 1.00 0.44 0.22 0.13 5.00 6.40 4.40 0.65BSC 0.60 1.00BSC - 0.45 0 1.20 0.15 1.05 0.49 0.28 0.25 0.17 0.14 5.10 6.60 4.50 0.75 8° Statements And Notes Part name Lead and lead compounds Lead frame ○ Plastic resin ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ The lead Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ explanation Cadmium and cadmium compounds ○ Hazardous substances or Elements Polybro Hexavalent Polybro minated Dibutyl chromium minated biphenyl phthalate compounds biphenyls ethers ○ ○ ○ ○ Mercury and mercury compounds ○ Butyl benzyl phthalate Di-2ethylhexyl phthalate Diisobutyl phthalate ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 20 页 共 21 页 XBLW 74HC/HCT161 SYNCHRONOUS 4-BIT COUNTERS Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 21 页 共 21 页
SN74HC161N 价格&库存
很抱歉,暂时无法提供与“SN74HC161N”相匹配的价格&库存,您可以联系我们找货
