SN74HC240N
SN74HC240N
    XBLW(芯伯乐)
    DIP20
    八位反相缓冲器/驱动器,工作电压(Vcc)(v)2-6V,静态电流Iq(Typ)8uA
SN74HC240N 数据手册
XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs General Description The 74HC/HCT240 is an 8-bit inverting buffer/line driver with 3-state outputs. The device can be used as two 4-bit buffers or one 8-bit buffer. The device features two output enables (1O� and 2O�), each controlling four of the 3-state outputs. A HIGH on nO� causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. Features  Input levels: For 74HC240: CMOS level For 74HCT240: TTL level  Inverting 3-state outputs  Specified from -40℃ to +105℃  Packaging information: DIP20/SOP20/TSSOP20 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY SN74HC240N SN74HC240DTR SN74HCT240DTR SN74HCT240TDTR DIP-20 SOP-20 SOP-20 TSSOP-20 74HC240N 74HC240 74HCT240 74HCT240 Tube Tape Tape Tape 720/Box 2000/Reel 2000/Reel 2000/Reel XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 1 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol Figure 2. IEC Logic symbol Figure 3. Functional diagram Pin Configurations XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 2 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Pin Description Pin No. Pin Name Description 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 1O� 1A0 2Y0 1A1 2Y1 1A2 2Y2 1A3 2Y3 GND 2A3 1Y3 2A2 1Y2 2A1 1Y1 2A0 1Y0 2O� VCC output enable input(active LOW) data input bus output data input bus output data input bus output data input bus output ground(0V) data input bus output data input bus output data input bus output data input bus output output enable input(active LOW) supply voltage Function Table Input nO� L Output nAn L nYn H L H L H X Z Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; Z=high-impedance OFF-state. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 3 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage input clamping current output clamping current output current supply current ground current storage temperature total power dissipation VCC IIK IOK IO ICC IGND Tstg Ptot -0.5 -70 -65 - +7.0 ±20 ±20 ±35 70 +150 500 V mA mA mA mA mA ℃ mW soldering temperature TL VI < -0.5V or VI > VCC +0.5V VO < -0.5V or VO > VCC +0.5V -0.5V < VO < VCC +0.5V DIP 10s SOP 245 250 ℃ Note: [1] For DIP20 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP20 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP20 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage input transition rise and fall rate ambient temperature VCC VI VO XBLW version 1.0 Conditions - 74HC240 VCC=2.0V VCC=4.5V VCC=6.0V 74HCT240 - Min. Typ. Max. Unit 2.0 0 0 -40 5.0 1.67 - 6.0 VCC VCC 625 139 83 +105 V V V ns/V ns/V ns/V ℃ 4.5 0 0 5.0 - 5.5 VCC VCC V V V Δt/ΔV VCC=4.5V - 1.67 139 ns/V Tamb - -40 - +105 ℃ 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 4 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL input leakage current OFF-state output current supply current IOZ input apacitance CI HIGH-level input voltage LOW-level input voltage II ICC 74HC240 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-6.0mA;VCC=4.5V IO=-7.8mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=6.0mA;VCC=4.5V IO=7.8mA;VCC=6.0V VI=Vcc or GND;VCC=6.0V VI=VIH or VIL;VCC=6.0V; VO=VCC or GND VI=VCC or GND;IO=0A;VCC=6.0V 74HCT240 Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.98 5.48 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V - - ±0.1 μA - - ±0.5 μA - - 8.0 μA - 3.5 - pF VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.98 - 4.5 4.32 0 0.16 0.1 0.26 V V V V - - ±0.1 μA - - ±0.5 μA - - 8.0 μA VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL VCC=4.5V XBLW version 1.0 Typ. VIH HIGH-level output voltage input leakage current OFF-state output current supply current Min. II IOZ ICC IO=-20uA IO=-6.0uA IO=20uA IO=6.0uA VI=Vcc or GND;VCC=5.5V VI=VIH or VIL;VCC=5.5V; VO=VCC or GND VI=VCC or GND;IO=0A;VCC=5.5V 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 5 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Additional Supply currend ΔICC input apacitance CI per input pin; VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V nAn or inputs - 150 540 μA nO� input - 70 252 μA - 3.5 - pF - DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL input leakage current OFF-state output current supply current II IOZ ICC 74HC240 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-6.0mA;VCC=4.5V IO=-7.8mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=6.0mA;VCC=4.5V IO=7.8mA;VCC=6.0V VI=Vcc or GND;VCC=6.0V VI=VIH or VIL;VCC=6.0V; VO=VCC or GND VI=VCC or GND;IO=0A;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.84 5.34 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.33 0.33 V V V V V V V V V V V V V V V V - - ±1.0 μA - - ±5.0 μA - - 80 μA 74HCT240 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.84 - - 0.1 0.33 V V V V - - ±1.0 μA HIGH-level output voltage VOH VI=VIH or VIL VCC=4.5V LOW-level output voltage VOL VI=VIH or VIL VCC=4.5V input leakage II XBLW version 1.0 IO=-20uA IO=-6.0uA IO=20uA IO=6.0uA VI=Vcc or GND;VCC=5.5V 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 6 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs current OFF-state output current supply current IOZ ICC Additional Supply currend ΔICC VI=VIH or VIL;VCC=5.5V; VO=VCC or GND VI=VCC or GND;IO=0A;VCC=5.5V per input pin; nAn or inputs VI=VCC-2.1V; other inputs at VCC nO� input or GND;IO=0V; VCC=4.5V to 5.5V - - ±5.0 μA - - 80 μA - - 675 μA - - 315 μA DC Characteristics 3 (Tamb=-40℃ to +105℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL input leakage current OFF-state output current supply current II IOZ ICC 74HC240 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-6.0mA;VCC=4.5V IO=-7.8mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=6.0mA;VCC=4.5V IO=7.8mA;VCC=6.0V VI=Vcc or GND;VCC=6.0V VI=VIH or VIL;VCC=6.0V; VO=VCC or GND VI=VCC or GND;IO=0A;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.7 5.2 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.4 0.4 V V V V V V V V V V V V V V V V - - ±1.0 μA - - ±10 μA - - 160 μA 74HCT240 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage XBLW version 1.0 VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.7 - - V V VOH VI=VIH or VIL VCC=4.5V IO=-20uA IO=-6.0uA 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 7 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs LOW-level output voltage VOL input leakage current OFF-state output current supply current II IOZ ICC Additional Supply currend ΔICC IO=20uA IO=6.0uA VI=VIH or VIL VCC=4.5V VI=Vcc or GND;VCC=5.5V VI=VIH or VIL;VCC=5.5V; VO=VCC or GND VI=VCC or GND;IO=0A;VCC=5.5V per input pin; nAn or inputs VI=VCC-2.1V; other inputs at VCC nO� input or GND;IO=0V; VCC=4.5V to 5.5V - - 0.1 0.4 V V - - ±1.0 μA - - ±10 μA - - 16 μA - - 735 μA - - 343 μA AC Characteristics 1 (Tamb=25℃, voltages are referenced to GND(ground=0V),unless otherwise specified.) Parameter Symbol Conditions nAn to nYn propagation delay tpd see Figure5 nO� to nYn enable time ten see Figure6 nO� to nYn disable time tdis see Figure6 transition time tt see Figure5 power dissipation capacitance CPD Min. Typ. Max. Unit - 30 11 9 9 39 14 11 41 15 12 14 5 4 100 20 17 150 30 26 150 30 26 60 12 10 ns ns ns ns ns ns ns ns ns ns ns ns ns - 30 - pF VCC=4.5V - 11 20 ns VCC=5.0V;CL=15pF - 9 - ns 74HC240 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V per buffer;VI=GND to VCC 74HCT240 nAn to nYn propagation delay nO� to nYn enable time nO� to nYn disable time transition time power dissipation capacitance XBLW version 1.0 tpd see Figure5 ten VCC=4.5V;see Figure6 - 13 30 ns tdis VCC=4.5V;see Figure6 - 13 25 ns tt VCC=4.5V;see Figure5 - 5 12 ns CPD per buffer;VI=GND to VCC -1.5V - 30 - pF 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 8 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Note: [1]tpd is the same as tPLH and tPHL. [2]tt is the same as tTHL and tTLH. [3]CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi×N+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×f`)=sum of outputs. AC Characteristics 2 (Tamb=40℃ to 85℃, voltages are referenced to GND(ground=0V),unless otherwise specified.) Parameter Symbol Conditions nAn to nYn propagation delay tpd see Figure5 nO� to nYn enable time ten see Figure6 nO� to nYn disable time tdis see Figure6 transition time tt see Figure5 tpd see Figure5 nAn to nYn propagation delay nO� to nYn enable time nO� to nYn disable time transition time Note: Min. Typ. Max. Unit 74HC240 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V 74HCT240 - - 125 25 21 190 38 33 190 38 33 75 15 13 ns ns ns ns ns ns ns ns ns ns ns ns VCC=4.5V - - 25 ns ten VCC=4.5V;see Figure6 - - 38 ns tdis VCC=4.5V;see Figure6 - - 31 ns tt VCC=4.5V;see Figure5 - - 15 ns [1] tpd is the same as tPLH and tPHL. [2] ten is the same as tPZL and tPZH. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 9 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs [3] tdis is the same as tPLZ and tPHZ. [4] tt is the same as tTHL and tTLH. AC Characteristics 2 (Tamb=40℃ to 105℃, voltages are referenced to GND(ground=0V),unless otherwise specified.) Parameter Symbol Conditions nAn to nYn propagation delay tpd see Figure5 nO� to nYn enable time ten see Figure6 nO� to nYn disable time tdis see Figure6 transition time tt see Figure5 tpd see Figure5 nAn to nYn propagation delay nO� to nYn enable time nO� to nYn disable time transition time Note: Min. Typ. Max. Unit 74HC240 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V 74HCT240 - - 150 30 26 225 45 38 225 45 38 90 18 15 ns ns ns ns ns ns ns ns ns ns ns ns VCC=4.5V - - 30 ns ten VCC=4.5V;see Figure6 - - 45 ns tdis VCC=4.5V;see Figure6 - - 38 ns tt VCC=4.5V;see Figure5 - - 18 ns [1] tpd is the same as tPLH and tPHL. [2] ten is the same as tPZL and tPZH. [3] tdis is the same as tPLZ and tPHZ. [4] tt is the same as tTHL and tTLH. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 10 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Testing Circuit AC Testing Circuit Figure 4. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. RL=Load resistance S1=Test selection switch AC Testing Waveforms XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 11 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Figure 5. Input (nAn) to output (nYn) propagation delays and output transition times Figure 6. 3-state enable and disable times Measurement Points Type 74HC240 74HCT240 Input VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V Output VM 0.1×VCC 0.1×VCC VY 0.9×VCC 0.9×VCC Test Data XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 12 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs Type Input Load S1 position tPZH,tPHZ VI tr,tf CL RL tPHL,tPLH tPZL,tPLZ 74HC240 VCC 6.0ns 15pF,50pF 1KΩ open GND VCC 74HCT240 3.0V 6.0ns 15pF,50pF 1KΩ open GND VCC Package Information DIP20 Symbol A A1 A2 XBLW version 1.0 Dimensions In Millimeters Min Max 3.710 4.310 0.510 3.200 3.600 Dimensions In Inches Min Max 0.146 0.170 0.020 0.126 0.142 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 13 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs B B1 C D E E1 e L E2 0.380 0.570 0.015 1.524(BSC) 0.204 18.800 6.200 7.320 0.060(BSC) 0.360 19.200 6.600 7.920 0.008 0.740 0.244 0.288 2.540(BSC) 3.000 8.400 0.022 0.014 0.756 0.260 0.312 0.100(BSC) 3.600 9.000 0.118 0.331 0.142 0.354 SOP20 Symbol XBLW version 1.0 Dimensions In Millimeters Min Max Dimens ons Min 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 In Inches Max 第 14 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs A A1 A2 b C D E E1 e L 2.350 0.100 2.100 0.330 0.204 12.520 7.400 10.210 2.650 0.300 2.500 0.510 0.330 13.000 7.600 10.610 0.093 0.004 0.083 0.013 0.008 0.493 0.291 0.402 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 1.270(BSC) 0.104 0.012 0.098 0.020 0.013 0.512 0.299 0.418 0.050(BSC) TSSOP20 Symbol XBLW version 1.0 Dimensions In Millimeters Min Max Dimensions In Inches Min Max 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 15 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs D E b c E1 A A2 A1 e L H 6.400 4. 300 0.190 0.090 6.250 θ 1° 6.600 4. 500 0.300 0.200 6. 550 1. 200 1.000 0.150 0. 800 0.050 0. 252 0.169 0.007 0.004 0. 246 0.031 0.002 0.65(BSC) 0. 500 0. 259 0.177 0.012 0.008 0.258 0.047 0.039 0.006 0.026(BSC) 0.700 0.020 0.25(TYP) 0.028 0.01(TYP) 7° 1° 7° Statements And Notes Part name Lead and lead compounds Lead frame ○ Plastic resin ○ ○ ○ ○ ○ ○ Chip ○ ○ ○ ○ ○ The lead Plastic sheet installed ○ ○ ○ ○ ○ ○ ○ ○ explanation Cadmium and cadmium compounds ○ Hazardous substances or Elements Polybro Hexavalent Polybro minated Dibutyl chromium minated phthalate biphenyl compounds biphenyls ethers ○ ○ ○ ○ Mercury and mercury compounds ○ Butyl benzyl phthalate Di-2ethylhexyl phthalate Diisobutyl phthalate ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○: Indicates that the content of hazardous substances or elements in the detection limit of the following the SJ/T11363-2006 standard. ×: Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006 Standard limit requirements Statement: XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 16 页 共 17 页 XBLW 74HC/HCT240 Octal Buffers and Line Drivers With 3-State Outputs  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 17 页 共 17 页
SN74HC240N 价格&库存
很抱歉,暂时无法提供与“SN74HC240N”相匹配的价格&库存,您可以联系我们找货
