SN74HC192N
SN74HC192N
    XBLW(芯伯乐)
    DIP16_19.2X6.6MM
    四位二进制同步加/减计数器,工作电压(Vcc)(v)2-6V,静态电流Iq(Typ)8uA
SN74HC192N 数据手册
XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter General Description The SN74HC/HCT192 is a synchronous BCD up/down counter. Separate up/down clocks, CPU and CPD respectively, simplify operation. The outputs change state synchronously with the LOW-to-HIGH transition of either clock input. If the CPU clock is pulsed while CPD is held HIGH, the device will count up. If the CPD clock is pulsed while CPU is held HIGH, the device will count down. Only one clock input can be held HIGH at any time to guarantee predictable behavior. The device can be cleared at any time by the asynchronous master reset input (MR); it may also be loaded in parallel by activating the asynchronous parallel load input (P�). The terminal count up (T�U) and terminal count down (T�D) outputs are normally HIGH. When the circuit has reached the maximum count state of 15, the next HIGH-to-LOW transition of CPU will cause T�U to go LOW. T�U will stay LOW until CPU goes HIGH again, duplicating the count up clock Likewise, the T�D output will go LOW when the circuit is in the zero state and the CPD goes LOW. The terminal count outputs can be used as the clock input signals to the next higher order circuit in a multistage counter, since they duplicate the clock waveforms. Multistage counters will not be fully synchronous, since there is a slight delay time difference added for each stage that is added. The counter may be preset by the asynchronous parallel load capability of the circuit. Information present on the parallel data inputs (D0 to D3) is loaded into the counter and appears on the outputs (Q0 to Q3) regardless of the conditions of the clock inputs when the parallel load (P�) input is LOW. A HIGH level on the master reset (MR) input will disable the parallel load gates, override both clock inputs and set all outputs (Q0 to Q3) LOW. If one of the clock inputs is LOW during and after a reset or load operation, the next LOW-to-HIGH transition of that clock will be interpreted as a legitimate signal and will be counted. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Features  Input levels: For SN74HC192: CMOS level For SN74HCT192: TTL level  Synchronous reversible counting  Asynchronous parallel load  Asynchronous reset  Expandable without external logic  Specified from -40℃ to +85℃  Packaging information: DIP16/SOP16/TSSOP16 XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 1 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing QTY SN74HC192N SN74HC192DTR SN74HCT192DTR SN74HCT192TDTR DIP-16 SOP-16 SOP-16 TSSOP-16 74HC192N 74HC192 74HCT192 74HCT192 Tube Tape Tape Tape 1000/Box 2500/Reel 2500/Reel 3000/Reel Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol Figure 2. IEC Logic symbol Figure 3. Functional diagram Figure 4. Logic diagram XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 2 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Figure 5. Typical clear, load and count sequence Pin Configurations XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 3 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Pin Description Pin No. Pin Name Description 1 D1 2 Q1 3 Q0 4 CPD 5 CPU 6 Q2 7 Q3 8 GND 9 D3 10 D2 11 P� 12 T�U 13 T�D 14 MR 15 D0 16 VCC Note: CPD, CPU is LOW-to-HIGH, edge triggered. data input 1 flip-flop output 1 flip-flop output 0 count down clock input count up clock input flip-flop output 2 flip-flop output 3 ground(0V) data input 3 data input 2 asynchronous parallel load input(active LOW) terminal count up (carry)output(active LOW) terminal count down (borrow)output(active LOW) asynchronous master reset input(active HIGH) data input 0 supply voltage Function Table Operating mode reset (clear) parallel load count up count down Note: MR H H L L L L L L P� X X L L L L H H CPU X X X X L H 个 H Input CPD D0 L X H X L L H L X H X H H X ↑ X D1 X X L L X X X X D2 X X L L X X X X D3 X X L L H H X X Output Q0 Q1 Q2 Q3 T�U L I L L H I L L L H L L L L H L I L L H Qn=Dn L Qn=Dn H count up H count down H T�D L H L H H H H H [1] H=HIGH voltage level; L=LOW voltage level; X=don’t care; ↑=LOW-to-HIGH transition. [2] T�U=CPU at terminal count up (HLLH). [3] T�D=CPD at terminal count down (LLLL). XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 4 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Max. Unit supply voltage input clamping current output clamping current output current supply current ground current storage temperature total power dissipation VCC IIK IOK IO ICC IGND Tstg Ptot -0.5 -65 - +7.0 ±20 ±20 ±25 50 -50 +150 500 V mA mA mA mA mA ℃ mW soldering temperature TL VI < -0.5V or VI > VCC+0.5V VO < -0.5V or VO > VCC+0.5V VO=-0.5V to (VCC+0.5V) DIP 10s SOP 245 250 ℃ Note: [1] For DIP16 packages: above 70℃ the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70℃ the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K. Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb XBLW version 1.0 Conditions SN74HC192 VCC=2.0V VCC=4.5V VCC=6.0V SN74HCT192 VCC=2.0V VCC=4.5V VCC=6.0V - Min. Typ. Max. Unit 2.0 0 0 -40 5.0 1.67 - 6.0 VCC VCC 625 139 83 +85 V V V ns/V ns/V ns/V ℃ 4.5 0 0 -40 5.0 1.67 - 5.5 VCC VCC 139 +85 V V V ns/V ns/V ns/V ℃ 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 5 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Electrical Characteristics DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL SN74HC192 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.98 5.48 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.5 1.35 1.8 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V input leakage current supply current II VI=Vcc or GND;VCC=6.0V - - ±0.1 μA ICC VI=VCC or GND;IO=0A;VCC=6.0V - - 8.0 μA input apacitance CI SN74HCT192 - 3.5 - pF VIH VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.98 - 4.5 4.32 0 0.15 0.1 0.26 V V V V HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current supply current Additional Supply currend input apacitance XBLW version 1.0 VOH VI=VIH or VIL VCC=4.5V VOL VI=VIH or VIL VCC=4.5V IO=-20uA IO=-4.0uA IO=20uA IO=4.0uA II VI=Vcc or GND;VCC=5.5V - - ±0.1 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 8.0 μA pin Dn - 35 126 μA pins CPU,CPD - 140 504 μA pin P� - 65 234 μA pin MR - 105 378 μA - 3.5 - pF ΔICC CI per input pin; VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V - 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 6 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL LOW-level output voltage VOL VI=VIH or VIL SN74HC192 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA;VCC=2.0V IO=-20uA;VCC=4.5V IO=-20uA;VCC=6.0V IO=-4.0mA;VCC=4.5V IO=-5.2mA;VCC=6.0V IO=20uA;VCC=2.0V IO=20uA;VCC=4.5V IO=20uA;VCC=6.0V IO=4.0mA;VCC=4.5V IO=5.2mA;VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 1.9 4.4 5.9 3.84 5.34 - - 0.5 1.35 1.8 0.1 0.1 0.1 0.33 0.33 V V V V V V V V V V V V V V V V input leakage current supply current II VI=Vcc or GND;VCC=6.0V - - ±0.1 μA ICC VI=VCC or GND;IO=0A;VCC=6.0V - - 80 μA input apacitance CI SN74HCT192 - - - pF VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.84 - - 0.1 0.33 V V V V HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current supply current Additional Supply currend input apacitance XBLW version 1.0 VOH VI=VIH or VIL VCC=4.5V VOL VI=VIH or VIL VCC=4.5V IO=-20uA IO=-4.0uA IO=20uA IO=4.0uA II VI=Vcc or GND;VCC=5.5V - - ±1.0 μA ICC VI=VCC or GND;IO=0A;VCC=5.5V - - 80 μA pin Dn - - 157.5 μA pins CPU,CPD - - 630 μA pin P� - - 292.5 μA pin MR - - 472.5 μA - - - pF ΔICC CI per input pin; VI=VCC-2.1V; other inputs at VCC or GND;IO=0V; VCC=4.5V to 5.5V - 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 7 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter AC Characteristics 1 (Tamb=25℃, GND =0V, tr=tf=6ns,CL=50pF,unless otherwise specified.) Parameter Symbol Conditions CPU,CPD to Qn; see Figure7 CPU to T�U; see Figure8 CPU to T�D; see Figure8 P� to Qn; see Figure9 Propagation delay tpd MR to Qn; see Figure10 Dn to Qn; see Figure9 P� to T�U; P� to T�D; see Figure12 MR to T�U; MR to T�D; see Figure12 Dn to T�U; Dn to T�D; see Figure12 transition time pulse width XBLW version 1.0 tt tw see Figure10 up clock pulse width HIGH or LOW;see Figure7 down clock pulse width HIGH or LOW;see Figure7 SN74HC192 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 120 24 20 140 28 24 66 23 24 19 33 12 10 39 14 11 69 25 20 63 23 18 91 33 26 102 37 30 96 35 28 83 30 24 19 7 6 39 14 11 50 18 14 215 43 37 125 25 21 125 25 21 215 43 37 200 40 34 275 55 47 315 63 54 285 57 48 290 58 49 75 15 13 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 8 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter master reset pulse width HIGH; see Figure10 parallel load pulse width LOW; see Figure9 P� to CPU,CPD; see Figure9 Recovery time trec MR to CPU,CPD; see Figure10 Set-up time Dn to P�; see Figure11;note: CPU=CPD=HIGH tsu Dn to P� see Figure11 Hold time th Maximum frequency fMAX power dissipation capacitance CPD CPU to CPD, CPD to CPU; see Figure13 CPU,CPD; see Figure8 XBLW version 1.0 tpd 80 16 14 80 16 22 8 6 22 8 - ns ns ns ns ns VCC=6.0V 14 6 - ns VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V 50 10 9 50 10 9 80 16 14 0 0 0 80 16 14 4.0 20 24 3 1 1 0 0 0 22 8 6 -14 -5 -4 19 7 6 12 36 40 43 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz MHz - 24 - pF - 23 20 43 - ns ns VCC=4.5V - 16 30 ns VCC=4.5V - 17 30 ns VCC=4.5V - 28 46 ns VCC=4.5V - 24 40 ns VCC=4.5V - 36 62 ns VCC=4.5V - 36 64 ns VI=GND to VCC CPU,CPD to Qn; see Figure7 Propagation delay VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V CPU to T�U; see Figure8 CPU to T�D; see Figure8 P� to Qn; see Figure9 MR to Qn; see Figure10 Dn to Qn; see Figure9 P� to T�U; P� to T�D; SN74HCT192 VCC=4.5V VCC=5.0V;CL=15pF 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 9 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter transition time pulse width tt tw Recovery time trec Set-up time tsu Hold time th Maximum frequency fMAX power dissipation capacitance Note: see Figure12 MR to T�U; VCC=4.5V MR to T�D; see Figure12 Dn to T�U; VCC=4.5V Dn to T�D; see Figure12 VCC=4.5V;see Figure10 up down clock pulse width HIGH or LOW; see Figure7 master reset pulse VCC=4.5V width HIGH; see Figure10 parallel load pulse width LOW; see Figure9 P� to CPU,CPD; see Figure9 VCC=4.5V MR to CPU,CPD; see Figure10 Dn to P�;see Figure11; Note:CPU=CPD=HIGH;VCC=4.5V Dn to P� see Figure11 VCC=4.5V CPU to CPD, CPD to CPU; see Figure13 VCC=4.5V CPU,CPD; see Figure7 VCC=5.0V;CL=15pF CPD VI=GND to VCC-1.5V - 36 64 ns - 33 58 ns - 7 15 ns 25 14 - ns 16 6 - ns 20 10 - ns 10 1 - ns 10 2 - ns 16 8 - ns 0 -6 - ns 20 9 - ns 20 - 41 45 - MHz MHz - 28 - pF [1]tpd is the same as tPLH and tPHL. [2]tt is the same as tTHL and tTLH. [3]CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi×N+∑(CL×VCC2×fo) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL×VCC2×f`)=sum of outputs. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 10 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter AC Characteristics 2 (Tamb=-40℃ to +85℃, GND =0V, tr=tf=6ns,CL=50pF,unless otherwise specified.) Parameter Symbol Conditions CPU,CPD to Qn; see Figure7 CPU to T�U; see Figure8 CPU to T�D; see Figure8 P� to Qn; see Figure9 Propagation delay tpd MR to Qn; see Figure10 Dn to Qn; see Figure9 P� to T�U; P� to T�D; see Figure12 MR to T�U; MR to T�D; see Figure12 Dn to T�U; Dn to T�D; see Figure12 transition time pulse width XBLW version 1.0 tt tw see Figure10 up clock pulse width HIGH or LOW;see Figure7 down clock pulse width HIGH or LOW;see Figure7 SN74HC192 VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 150 30 26 175 35 30 - 270 54 46 155 31 26 155 31 26 270 54 46 25 50 43 345 69 59 395 79 67 355 71 60 365 73 62 95 19 16 - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 11 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter master reset pulse width HIGH; see Figure10 parallel load pulse width LOW; see Figure9 P� to CPU,CPD; see Figure9 Recovery time trec MR to CPU,CPD; see Figure10 Set-up time Dn to P�; see Figure11;note: CPU=CPD=HIGH tsu Dn to P� see Figure11 Hold time th Maximum frequency fMAX power dissipation capacitance CPD CPU to CPD, CPD to CPU; see Figure13 CPU,CPD; see Figure8 XBLW version 1.0 tpd 100 20 17 100 20 - - ns ns ns ns ns VCC=6.0V 17 - - ns VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=5.0V;CL=15pF VCC=6.0V 65 13 11 65 13 11 100 20 17 0 0 0 100 20 17 3.2 16 19 - - ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns MHz MHz MHz MHz - - - pF - - 54 - ns ns VCC=4.5V - - 38 ns VCC=4.5V - - 38 ns VCC=4.5V - - 58 ns VCC=4.5V - - 50 ns VCC=4.5V - - 78 ns VCC=4.5V - - 80 ns VI=GND to VCC CPU,CPD to Qn; see Figure7 Propagation delay VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V CPU to T�U; see Figure8 CPU to T�D; see Figure8 P� to Qn; see Figure9 MR to Qn; see Figure10 Dn to Qn; see Figure9 P� to T�U; P� to T�D; SN74HCT192 VCC=4.5V VCC=5.0V;CL=15pF 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 12 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter transition time pulse width tt tw Recovery time trec Set-up time tsu Hold time th Maximum frequency fMAX power dissipation capacitance Note: see Figure12 MR to T�U; VCC=4.5V MR to T�D; see Figure12 Dn to T�U; VCC=4.5V Dn to T�D; see Figure12 VCC=4.5V;see Figure10 up down clock pulse width HIGH or LOW; see Figure7 master reset pulse VCC=4.5V width HIGH; see Figure10 parallel load pulse width LOW; see Figure9 P� to CPU,CPD; see Figure9 VCC=4.5V MR to CPU,CPD; see Figure10 Dn to P�;see Figure11; Note:CPU=CPD=HIGH;VCC=4.5V Dn to P� see Figure11 VCC=4.5V CPU to CPD,CPD to CPU; see Figure13 VCC=4.5V CPU,CPD; see Figure7 VCC=5.0V;CL=15pF CPD VI=GND to VCC-1.5V - - 80 ns - - 73 ns - - 19 ns 31 - - ns 20 - - ns 25 - - ns 13 - - ns 13 - - ns 20 - - ns 0 - - ns 25 - - ns 16 - - - MHz MHz - - - pF [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in uW). PD=CPD×VCC2×fi+∑(CL×VCC2×f o) where: fi=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; ∑(CL×VCC 2×fo)=sum of outputs. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 13 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Testing Circuit AC Testing Circuit Figure 6. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. RL=Load resistance S1=Test selection switch AC Testing Waveforms Figure 7. The clock (CPU, CPD) to output (Qn) propagation delays, the clock pulse width, and the maximum clock pulse frequency XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 14 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Figure 8. The clock (CPU, CPD) to terminal count output (T�U, T�D) propagation delays Figure 9. The parallel load input (P�) and data (Dn) to Qn output propagation delays and P� removal time to clock input (CPU, CPD) XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 15 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Figure 10. The master reset input (MR) pulse width, MR to Qn propagation delays, MR to CPU, CPD removal time and output transition times Figure 11. The data input (Dn) to parallel load input (P�) set-up and hold times XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 16 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Figure 12. The data input (Dn), parallel load input (P�) and the master reset input (MR) to the terminal count outputs (T�U, T�D) propagation delays Figure 13. The CPU to CPD or CPD to CPU hold times XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 17 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Measurement Points Input Type VI GND to VCC GND to 3V SN74HC192 SN74HCT192 Output VM 0.5×VCC 1.3V VM 0.5×VCC 1.3V Test Data VI tr,tf CL RL S1 position tPHL,tPLH SN74HC192 VCC 6.0ns 15pF,50pF 1KΩ open SN74HCT192 3.0V 6.0ns 15pF,50pF 1KΩ open Type XBLW version 1.0 Input Load 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 18 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Package Information DIP16 Symbol A A1 A2 B B1 C D E E1 e L E2 XBLW version 1.0 Dimensions In Millimeters Min Max 3.710 4.310 0.510 3.200 3.600 0.380 0.570 1.524(BSC) 0.204 0.360 18.800 19.200 6.200 6.600 7.320 7.920 2.540(BSC) 3.000 3.600 8.400 9.000 Dimensions In Inches Min Max 0.146 0.170 0.020 0.126 0.142 0.015 0.022 0.060(BSC) 0.008 0.014 0.740 0.756 0.244 0.260 0.288 0.312 0.100(BSC) 0.118 0.142 0.331 0.354 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 19 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter SOP16 Symbol A A1 A2 b C D E E1 e L θ XBLW version 1.0 Dimensions In Millimeters Min Max 1.350 1.750 0.100 0.250 1.350 1.550 0.330 0.510 0.170 0.250 9.800 10.200 3.800 4.000 5.800 6.200 1.270(BSC) 0.400 1.270 0° 8° Dimens ons In Inches Min Max 0.053 0.069 0.004 0.010 0.053 0.061 0.013 0.020 0.007 0.010 0.386 0.402 0.150 0.157 0.228 0.244 0.050(BSC) 0.016 0.050 0° 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 8° 第 20 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter TSSOP16 SYMBOL A Al A2 A3 b bl c cl D E E1 e L L1 θ XBLW version 1.0 MILLIMETER MIN NOM MAX 0.05 0.90 0.39 0.20 0.19 0.13 0.12 4.90 6.20 4.30 0.45 0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 1.00 0.44 0.22 0.13 5.00 6.40 4.40 0.65BSC 0.60 1.00BSC - 1.20 0.15 1.05 0.49 0.28 0.25 0.17 0.14 5.10 6.60 4.50 0.75 8° 第 21 页 共 22 页 XBLW 74HC/HCT192 Synchronous BCD Up/Down Counter Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLW version 1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com       技术支持热线:4009682003 第 22 页 共 22 页
SN74HC192N 价格&库存
很抱歉,暂时无法提供与“SN74HC192N”相匹配的价格&库存,您可以联系我们找货
