VG039NCHXTB204
VG039NCHXTB204
    HOKURIKU(北陆电气)
    SMD
    可调电阻/电位器 200KΩ ±25% SMD
VG039NCHXTB204 数据手册
Chip Type Cermet Trimmer Potentiometer チップ型サーメット皮膜セラミック半固定可変抵抗器 3mm size, Low profile type 3mm サイズ、薄形 ■ Features ・Low profile type ( 1.2mm in height ) ・Achieved good endurance characteristics by using “Metal-glaze” for the material of resistor ・Conforms to RoHS Directives ・Reflow solderable ■Outline Dimensions (Unit : mm) 摺動子回転範囲 Wiper Rotating Area TERM.2 1.6 0.7 1.2 推奨ランドパターン寸法 Pattern Application Example 1.5 0.75 1.5 裏面封止樹脂 Maximum resin sealedResin area 0.8 0.65 TERM.3 2.7 1.2 0.95 1.2 2 3.8 (1) 0.5 1.75 φ3.7 3 2.1 1.2 0.8 1.2 TERM.1 C.W. Circuit Term. 1 Term. 3 Term. 2 ■Specification Item Nominal Total Resistance Resistance Tolerance Rotational Torque Effectively Rotary Angle Rated Wattage Max. Rated Voltage T.C.R(Temperature Coefficient) Operating Temp. Range Specification Unit 100~1M ±25 0.98~11.76 270 ± 20 0.15 Ω % mN.m ° W V ppm/℃ ℃ 50 or V= PR whichever is smaller ±250 -40 ~ +100 Note Non stopper ■Part Designation VG 039N SN XT B*** Resistance law and Resistance value ( 3 figures ) Taping type (8mm width×4mm pitch emboss taping for auto insertion) SMD Type ( Non stopper ) Size Resistive element type : Metal-glaze *Packaging Quantity : 2500 pcs / Reel 2018.7.1 HOKURIKU ※Specifications are subject to change without notice 1 Chip Type Cermet Trimmer Potentiometer 3mm size, Low profile type 䕔Features Low profile type (1.2mm in height) With rotation stopper Achieved exellent endurance characteristics by using "Metal-glaze" film. Conform to RoHS Directives Reflow solderable 䕔Dimensions (Unit: mm) 䃥3. 7 㸦Wiper Rotating Area) 3 1. 5 1. 2 Terminal 2 Maximum resin sealed area 0. 75 1.6 Terminal 1 0. 65 1.5 1.2 1.2 0. 8 Terminal 3 1.2 0. 95 2 3. 8 ( 1 ) 0. 5 1. 75 0.7 2. 1 0.8 1.2 2. 7 PCB Footprint C.W. Circuit Terminal 1 Terminal 3 Terminal 2 䕔Specification Item Specification Unit 100 ~ 1 M ±25 䃈 % Rotational Torque 0.98䡚 11.76 mN䞉m End Stop Strength 14.7 min. mN䞉m Total Mechanical Rotation Angle 270㼼20 0.15 㼻 W 50 or V= PR whichever is smaller V Nominal Total Rasistance Rasistance Tolerance Rated Wattage Max. Working Voltage T.C.R. (Temperature Coefficient of Resistance) Operating Temperature Range ±250 ppm/䉝 -40 䡚 100 䉝㻌 Note With rotation stopper 䕔Model Designation VG 039N CH XT B*** Characteristics and Resistance value (3 figures) Taping type (8mm width㽢4mm pitch emboss taping for auto insertion) SMD type Size Model No. Resistive element type (Metal glaze) *Packaging Quantity : 2,500pcs / Reel 2018.7.1 HOKURIKU Specifications are subject to change without notice. 2
VG039NCHXTB204 价格&库存
很抱歉,暂时无法提供与“VG039NCHXTB204”相匹配的价格&库存,您可以联系我们找货
