XL7KI-111-32M
XL7KI-111-32M
    YXC(扬兴科技)
    SMD2016_4P
    无源晶振 32MHz ±10ppm 8pF -40℃~+85℃
XL7KI-111-32M 数据手册
Crystal Unit YSX211SL Applications ‧Mobile phone, Bluetooth, WLAN ISM band radio. Small Size Features ‧Dimensions: 2.05 x 1.65 x 0.50mm. ‧High precision and high frequency stability. ‧Standard Frequency: 16~54MHz ‧Excellent heat resistance and environmental characteristics. Specifications(规格参数) Item Symbol Specifications f_nom 16~54MHz or 96MHZ - AT Fundamental CL 8pF, 9pF, 12pF, or specify Frequency Tolerance(频率偏差) (at 25℃ ) f_tol ±10ppm, or specify Frequency Versus Temperature Characteristics(频率-温度特性) f_tem ±20ppm, or specify Operating Temperature(工作温度) T_use -40~+85℃ or specify Storage Temperature(储存温度) T_stg -55~+125℃ Shunt Capacitance(静态电容) C0 3pF Max. Level of Drive(激励电平) DL 10~200μW Max.(100μW typical) f_age ±3ppm/year Max. Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Aging (老化)(at 25℃ ) Equivalent Series Resistance(等效串联电阻(ESR)) YSX211SL 16 ~ 30MHz 100 Ω Max. 31 ~ 54MHz 80 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XL7KI-111-32M 价格&库存
很抱歉,暂时无法提供与“XL7KI-111-32M”相匹配的价格&库存,您可以联系我们找货
XL7KI-111-32M
  • 20+0.94000
  • 100+0.56070
  • 800+0.39250
  • 3000+0.28040
  • 6000+0.26630
  • 30000+0.24670
XL7KI-111-32M
  • 10+0.31000
  • 100+0.29000
  • 500+0.27000
  • 2000+0.24000
  • 5000+0.23000
  • 10000+0.22400
库存:4702
XL7KI-111-32M
  • 5+0.61485
  • 50+0.49302
  • 150+0.43211
  • 500+0.38643
  • 3000+0.34992
  • 6000+0.33156
库存:11204
XL7KI-111-32M
  • 1+0.45629
  • 200+0.29458
  • 1500+0.25647
  • 3000+0.22660
库存:965
XL7KI-111-32M
  • 5+0.40590
  • 50+0.33270
  • 150+0.28180
  • 500+0.26010
  • 1000+0.24440
  • 3000+0.23050
  • 6000+0.21960
库存:1925
