5HVA.10
5HVA.10
    TLC(竞沃)
    FUSE_D5.2X20MM
    一次性保险丝(熔断) 10A 600VAC 500VDC 5x20mm
5HVA.10 数据手册
5x20mm Fast Acting Ceramic Tube Fuses DOC.No. : ISS-5HVA Series INDIVIDUAL SPECIFICATION SHEET Product Name: 600VAC/500VDC 5x20mm Fast Acting Ceramic Tube Fuses Part Number: 5HVA Series Revision: A/1 Dongguan TLC Electronic Technology Co., LTD No.18,5th GaoLi Road, TangXia Town, DongGuan, GuangDong, P.R China 523710 TEL: 86-0769-3892 0511 FAX: 86-0769-8793 2077 Http: www.tlcet.com.cn Rev. Effective Date Changed Contents A/0 2022-9-27 New Release A/1 2023-1-3 Update Template ☞The individual specification sheet are the property of Dongguan TLC electronic technology Co., Ltd and shall not be copied or used as commercial purposes without permission. PREPARED BY APPROVED BY 5HVA Series Description  Ceramic tube, Silver plated copper cap construction  One time positive disconnect  5x20mm physical size  Available axial lead options  Lead Free and Halogen free material Regulation/Standard Features  Fast Acting, high breaking capacity  0.4 A to 20 A current ratings  200A AC Interrupting Rating  300A DC Interrupting Rating  Designed to UL248-1 / UL248-13  AEC-Q200 Automotive Grade Certified Electrical Characteristics Rated Current 100% In 200% In 400mA-20A 4hour min 120s max Note: In is the rated current Dimensions (Unit: mm) 5HVA.XX Item A1 Spec.(mm) 20±0.5 Email:customer-service@winvast.net www.tlcet.com.cn www.winvast.cn 5HVA.XXP B1 5.2+0.1 −0.2 A2 B2 21±1.0 Φ5.5±0.2 -1- C Φ0.65(In<6.3A) Φ0.80(6.3A ≤In≤20A) D 38±2.0 Version No.: A/1 5HVA Series Electrical Characteristics Electrical Characteristics Part No. Rated Current(A) Rated Voltage Breaking Capacity Typical Cold. Resistance(mΩ) Typical Voltage Drop(mV) Typical Pre‐ Arcing I2t (A2S) 5HVA.0.4 400mA 600VAC 500VDC 200A@600VAC 300A@500VDC 663 278 0.172 5HVA.0.5 500mA 600VAC 500VDC 200A@600VAC 300A@500VDC 382 190 0.287 5HVA.0.6 600mA 600VAC 500VDC 200A@600VAC 300A@500VDC 360 234 0.396 5HVA.1 1A 600VAC 500VDC 200A@600VAC 300A@500VDC 230 280 0.28 5HVA.1.6 1.6A 600VAC 500VDC 200A@600VAC 300A@500VDC 148 310 2.56 5HVA.2 2A 600VAC 500VDC 200A@600VAC 300A@500VDC 100 248 1.68 5HVA.2.5 2.5A 600VAC 500VDC 200A@600VAC 300A@500VDC 90 360 1.48 5HVA.3.15 3.15A 600VAC 500VDC 200A@600VAC 300A@500VDC 49 215 4.86 5HVA.4 4A 600VAC 500VDC 200A@600VAC 300A@500VDC 38 220 8 5HVA.5 5A 600VAC 500VDC 200A@600VAC 300A@500VDC 29 200 16 5HVA.6 6A 600VAC 500VDC 200A@600VAC 300A@500VDC 24 150 30 5HVA.6.3 6.3A 600VAC 500VDC 200A@600VAC 300A@500VDC 19 162 48 5HVA.8 8A 600VAC 500VDC 200A@600VAC 300A@500VDC 14 149 64 5HVA.10 10A 600VAC 500VDC 200A@600VAC 300A@500VDC 12 166 90 5HVA.12 12A 600VAC 500VDC 200A@600VAC 300A@500VDC 9.5 160 130 5HVA.15 15A 600VAC 500VDC 200A@600VAC 300A@500VDC 7.3 165 225 5HVA.16 16A 600VAC 500VDC 200A@600VAC 300A@500VDC 6.8 164 256 5HVA.20 20A 600VAC 500VDC 200A@600VAC 300A@500VDC 5 150 520  DC Cold Resistance are measured at
5HVA.10 价格&库存
很抱歉,暂时无法提供与“5HVA.10”相匹配的价格&库存,您可以联系我们找货
