R1287Z001B-E2-F
R1287Z001B-E2-F
    NISSHINBO(日清纺)
    12-VFBGA,WLCSP
    降压,升压 开关稳压器 IC 正和负 可调式 -5.8V 2 输出 200mA 12-VFBGA,WLCSP
R1287Z001B-E2-F 数据手册
R1287x Series PWM/ VFM, Dual-channel Step-up/ Inverting DC/DC Converter with Synchronous Rectifier for LCD NO.EA-325-180907 OUTLINE The R1287x is a PWM/ VFM dual-channel step-up/ inverting DC/DC converter with synchronous rectifier for LCD. The step-up DC/DC converter (CH1) generates a 4.5 V to 5.8 V boosted output voltage and the inverting DC/DC converter (CH2) generates a −4.5 V to −6.0 V inverting output voltage. Internally, the R1287x consists of an oscillator circuit, PWM control circuits, a reference voltage unit, error amplifiers, soft-start circuits, a LX peak current limit circuit, short protection circuits, thermal shutdown circuit, an under voltage lockout circuit (UVLO), a NMOS transistor driver and a synchronous PMOS transistor driver for CH1, and a PMOS transistor driver and a synchronous NMOS transistor driver for CH2. The R1287x is employing synchronous rectification for improving the efficiency of rectification by replacing diodes with built-in switching transistors. Using synchronous rectification not only increases circuit performance but also allows a design to reduce parts count. The R1287x provides the PWM control or the PWM/VFM auto switching control. The PWM control switches at fixed frequency rate in low output current in order to reduce noise. Likewise, the PWM/VFM auto switching control automatically switches from PWM mode to VFM mode in low output current in order to achieve high efficiency. Our unique control method can suppress a ripple voltage in the VFM mode, thus the R1287x can achieve both low ripple voltage at light load and high efficiency. Both CH1 and CH2 can independently control the ON/ OFF control and freely set the starting sequence and shutdown sequence. Both CH1 and CH2 own an auto-discharge function which actively discharges the output voltage to ground when the device is placed in shutdown mode. The R1287x is offered in a 12-pin WLCSP-12-P1 package and a 12-pin DFN3030-12 package. FEATURES  Operating Voltage Range ·············································· 2.5 V to 5.5 V [Step-up DC/DC Converter (CH1)]  Selectable Step-up Output Voltage (VOUTP) ······················ R1287xxxxy: 4.5 V to 5.8 V (0.1 V Step)  Step-up Output Voltage (Externally adjustable) ················· R1287x001y: 4.5 V to 5.8 V  Maximum Output Current (Dependent on inductance) ········· R1287xxxxB/D/F/H: 200 mA, R1287xxxxC/G: 100 mA [Inverting DC/DC Converter (CH2)]  Selectable Inverting Output Voltage (VOUTN) ····················· R1287xxxxy: −4.5 V to −5.8 V (0.1 V Step)  Inverting Output Voltage (externally adjustable) ················· R1287x001y: −4.5 V to −6.0 V  Maximum Output Current (dependent on inductance) ·········· R1287xxxxB/D/F/H: 200 mA, R1287xxxxC/G: 100 mA 1 R1287x NO.EA-325-180907 [Controller]  ON/ OFF Control: Operates CH1/ CH2 separately by the EN1/ EN2 pin.  Auto-discharge Function: Discharges the output voltage to GND within a short time in shutdown mode.  Latch-type Short Circuit Protection: Short-circuiting of either one of CH1 or CH2 activates this circuit.  Maximum Duty Cycle  LX Peak Current Limit Function  Undervoltage Lockout (UVLO) Threshold ························ Typ. 2.25 V  Thermal Shutdown Temperature ···································· Typ. 150°C  Oscillator Frequency ··················································· R1287xxxxB/D/F/H:1 MHz, R1287xxxxC/G: 300 kHz  Package ··································································· WLCSP-12-P1, DFN3030-12 APPLICATIONS  Power source for hand-held equipment  Power source for LCD 2 R1287x NO.EA-325-180907 SELECTION GUIDE The output voltage types are user-selectable options that can be selected from either fixed output voltage type or adjustable output voltage type. With the fixed output voltage type, the combination of a CH1 output voltage and a CH2 output voltage can be selected. The combination of an oscillator frequency, a power controlling method, and a discharge current can also be selected. Selection Guide Product Name Package Quantity per Reel Pb Free Halogen Free R1287Zxxxy-E2-F WLCSP-12-P1 4,000 pcs Yes Yes R1287Lxxxy-TR DFN3030-12 3,000 pcs Yes Yes xxx: Specify the set output voltage (VSET). 001: Adjustable Output Voltage Type, The output voltage is adjustable using external resistors. 002 to 009: Fixed Output Voltage Type CH1 Output Voltage (VOUTP): selectable from +4.5 V to +5.8 V by 0.1 V step (1) CH2 Output Voltage (VOUTN): selectable from −4.5 V to −5.8 V by 0.1 V step (1) Notes: Refer to Output Voltage for All Combinations of VOUTP and VOUTN. y: Specify the oscillator frequency, the power controlling method, and the discharge current. (B) 1 MHz, PWM/ VFM Auto Switching Control, discharge current 0.06 mA (C) 300 kHz, PWM Control, discharge current 0.06 mA (D) 1 MHz, PWM Control, discharge current 0.06 mA (F) 1 MHz, PWM/ VFM Auto Switching Control, discharge current 0.4 mA (2) (G) 300 kHz, PWM Control, discharge current 0.4 mA (2) (H) 1 MHz, PWM Control, discharge current 0.4 mA (3) Output Voltage for All Combinations of VOUTP and VOUTN VSET Code No. (xxx) CH1 Output Voltage (VOUTP) 001 Adjustable using external resistors 002 5.0 003 5.4 004 5.75 005 5.6 006 4.5 007 5.8 008 5.5 (4) 009 5.1 (1) (2) (3) (4) CH2 Output Voltage (VOUTN) Adjustable using external resistors −5.0 −5.4 −5.75 −5.6 −4.5 −5.8 −5.5 −5.1 0.05 V step is also available as a custom code F/G versions are only available for R1287Z H version is only available for R1287Z and R1287L002H, R1287L003H, R1287L007H VSET Code No.009 is only available for R1287Z 3 R1287x NO.EA-325-180907 BLOCK DIAGRAMS R1287xxxxy Block Diagram (Fixed Output Voltage Type) 4 R1287x NO.EA-325-180907 R1287x001y Block Diagram (Adjustable Output Voltage Type) 5 R1287x NO.EA-325-180907 PIN DESCRIPTIONS Bottom View Top View 3 3 2 2 1 1 A B C D D C B A WLCSP-12-P1 Pin Configurations WLCSP-12-P1 Pin Description Pin No. Symbol A1 VOUTN CH2 Output Voltage Pin A2 PGND Power Ground Pin A3 LXP CH1 Switching Output Pin B1 LXN CH2 Switching Output Pin B2 GND Analog Ground Pin B3 VOUTP CH1 Output Voltage Pin C1 PVCC Power Input Voltage Pin C2 VCC C3 D1 6 VOUTPS R1287Zxxxy VFBP R1287Z001y VOUTNS R1287Zxxxy VFBN R1287Z001y Description Analog Power Input Voltage Pin CH1 Feedback Voltage Pin CH2 Feedback Voltage Pin D2 EN2 CH2 Enable Control Pin D3 EN1 CH1 Enable Control Pin R1287x NO.EA-325-180907 Bottom View Top View 12 11 10 9 8 7 1 2 3 4 5 6 12 11 10 9 8 7 1  2 3 4 5 6 DFN3030-12 Pin Configuration DFN3030-12 Pin Description Pin No. Symbol 1 EN2 2 VOUTNS R1287Lxxxy VFBN R1287L001y Description CH2 Enable Control Pin CH2 Feedback Voltage Pin 3 VCC 4 PVCC 5 LXN 6 VOUTN CH2 Output Voltage Pin 7 PGND Power Ground Pin 8 LXP 9 VOUTP 10 Analog Power Input Voltage Pin Power Input Voltage Pin CH2 Switching Output Pin CH1 Switching Output Pin VOUTPS R1287Lxxxy VFBP R1287L001y CH1 Output Voltage Pin CH1 Feedback Voltage Pin 11 GND Analog Ground Pin 12 EN1 CH1 Enable Control Pin  The tab on the bottom of the package enhances thermal performance and is electrically connected to GND (substrate level). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. 7 R1287x NO.EA-325-180907 ABSOLUTE MAXIMUM RATINGS Absolute Maximum Ratings Symbol (GND = PGND = 0 V) Item Rating Unit VCC VCC / PVCC Pin Voltage −0.3 to 6.0 V VEN EN1/ EN2 Pin Voltage −0.3 to 6.0 V VLXP LXP Pin Voltage −0.3 to 6.5 V VOUTP VOUTP Pin Voltage VLXN LXN Pin Voltage −0.3 to 6.5 V VCC − 14 to VCC + 0.3 V VOUTN VOUTN Pin Voltage VCC − 14 to 0.3 V VOUTPS VOUTPS Pin Voltage R1287xxxxy −0.3 ~ 6.5 V VOUTNS VOUTNS Pin Voltage R1287xxxxy VCC − 14 ~ VCC + 0.3 V VFBP VFBP Pin Voltage R1287x001y −0.3 to VCC + 0.3 V VFBN VFBN Pin Voltage R1287x001y −0.3 to VCC + 0.3 V PD Power Dissipation (1) (WLCSP-12-P1, Standard Test Land Pattern) (DFN3030-12, JEDEC STD.51-7 Test Land Pattern) 1000 mW 3400 Tj Junction Temperature Range −40 to 125 °C Tstg Storage Temperature Range −55 to 125 °C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the lifetime and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS Recommended Operating Conditions Symbol Parameter VCC Operating Input Voltage Ta Operating Temperature Range Rating 2.5 to 5.5 −40 to 85 Unit V °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) 8 Refer to POWER DISSIPATION for detailed information. R1287x NO.EA-325-180907 ELECTRICAL CHARACTERISTICS The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. R1287x Electrical Characteristics Symbol Item (Ta = 25°C) Conditions Min. Typ. Max. Unit VCC Consumption Current (at no switching) VCC = 5.5 V, R1287xxxxy 470 ISTANDBY Standby Current VCC = VLXP = 5.5 V, VEN = VLXN = 0 V, R1287xxxxy 0.1 VUVLO1 UVLO Detector Threshold Falling, R1287xxxxy VUVLO2 UVLO Released Voltage Rising, R1287xxxxy VEN1H EN1 “H” Input Voltage VCC = 3.7 V, R1287xxxxy VEN1L EN1 “L” Input Voltage VCC = 3.7 V, R1287xxxxy REN1 EN1 Pull-down Resistance VCC = 3.7 V, R1287xxxxy VEN2H EN2 “H” Input Voltage VCC = 3.7 V, R1287xxxxy VEN2L EN2 “L” Input Voltage VCC = 3.7 V, R1287xxxxy REN2 EN2 Pull-down Resistance VCC = 3.7 V, R1287xxxxy tPROT Protection Delay Time VCC = 3.7 V, R1287xxxxy TTSD Thermal Shutdown Temperature VCC = 3.7 V, R1287xxxxy 150 °C TTSR Thermal Shutdown Released Temperature VCC = 3.7 V, R1287xxxxy 125 °C 3.2 V ≤ VCC ≤ 4.2 V, 10 mA ≤ IOUT ≤ 100 mA, R1287xxxxB/F ±0.3 % 3.2 V ≤ VCC ≤ 4.2 V, 10 mA ≤ IOUT ≤ 100 mA, R1287xxxxC/D/G/H ±0.2 % ICC 2.15 µA 5 2.25 VUVLO1 +0.10 V 2.48 1.2 V V 0.4 1000 V kΩ 1.2 V 0.4 1000 21 µA 30 V kΩ 39 ms STEP-UP DC/DC CONVERTER (CH1) ∆VOUTP /∆IOUT fOSCP Maxduty1 IVOUTP tSSP VOUTP Load Regulation R1287xxxxB/F 700 900 1100 kHz R1287xxxxC/G 240 300 360 kHz R1287xxxxD/H 800 1000 1200 kHz CH1 PWM Oscillator Frequency VCC = 3.7 V CH1 Maximum Duty Cycle VCC = 3.7 V VOUTP Discharge Current VCC = 3.7 V, VOUTP = 0.1 V R1287xxxxB/F CH1 Soft-start Time VCC = 3.7 V, EN1 = “H” to VOUTP = VSET R1287xxxxB/D/F/H 90 % R1287xxxxC/G 97 % R1287xxxxB/C/D 0.06 mA R1287xxxxF/G/H 0.4 mA 1.91 5.54 ms R1287xxxxC/G 4.5 ms R1287xxxxD/H 4.5 ms 9 R1287x NO.EA-325-180907 ELECTRICAL CHARACTERISTICS (continued) The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. R1287x Electrical Characteristics Symbol Item tRP RLXP (Ta = 25°C) Conditions VCC = 3.7 V, VOUTP = VSET x 10% to 90%, R1287xxxxB/F CH1 Rising Time Min. Typ. 1.53 Max. Unit 4.99 ms CH1 Nch Tr. ON Resistance VCC = 3.7 V, R1287xxxxy 400 mΩ RSYNCP CH1 Pch Tr. ON Resistance VCC = 3.7 V, R1287xxxxy 700 mΩ ILIMLXP CH1 Nch Tr. Current Limit VCC = 3.7 V, R1287xxxxy 1.1 A VUVP VOUTP Low Voltage Detector Threshold VCC = 3.7 V, R1287xxxxy 2.7 V [R1287xxxxB, R1287xxxxC, R1287xxxxD, R1287xxxxF, R1287xxxxG, R1287xxxxH] VOUTP VOUTP/∆Ta 0.991 VOUTP Voltage VCC = 3.7 V VOUTP Voltage Temperature Coefficient VCC = 3.7 V, −40°C ≤ Ta ≤ 85°C VSET 1.009 V ppm /°C ±50 [R1287x001B, R1287x001C, R1287x001D, R1287x001F, R1287x001G, R1287x001H] VFBP VFBP Voltage VCC = 3.7 V 0.985 IFBP VFBP Input Current VCC = 5.5 V, VFBP = 0 V or 5.5 V −0.1 VFBP Voltage Temperature Coefficient VCC = 3.7 V, −40°C ≤ Ta ≤ 85°C ∆VFBP/∆Ta 1.000 1.015 V 0.1 µA ppm /°C ±50 All test items listed under ELECTRICAL CHARACTERISTICS are done under the pulse load condition (Tj ≈ Ta = 25°C) except VOUTP Voltage Temperature Coefficient, VFBP Voltage Temperature Coefficient, VOUTP Load Regulation, CH1 Rising Time, CH1 Nch Tr. ON Resistance and CH1 Pch Tr. ON Resistance. INVERTING DC/DC CONVERTER (CH2) ∆VOUTN /∆IOUT foscn VOUTN Load Regulation CH2 PWM Oscillator Frequency 3.2 V ≤ VCC ≤ 4.2 V, 10 mA ≤ IOUT ≤ 100 mA, R1287xxxxB/F ±0.4 % 3.2V ≤ VCC ≤ 4.2 V, 10 mA ≤ IOUT ≤ 100 mA, R1287xxxxC/D/G/H ±0.2 % VCC = 3.7 V Maxduty2 CH2 Maximum Duty Cycle VCC = 3.7 V IVOUTN 10 VOUTN Discharge Current VCC = 3.7 V, VOUTN = −0.1 R1287xxxxB/F 900 1100 1300 kHz R1287xxxxC/G 240 300 360 kHz R1287xxxxD/H 800 1000 1200 kHz R1287xxxxB/D/F/ H 90 % R1287xxxxC/G 97 % R1287xxxxB/C/D 0.2 mA R1287xxxxF/G/H 0.4 mA R1287x NO.EA-325-180907 ELECTRICAL CHARACTERISTICS (continued) The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. R1287x Electrical Characteristics Symbol tssn trn (Ta = 25°C) Item Conditions CH2 Soft-start Time VCC = 3.7V, EN2 = “H” to VOUTN = VSET CH2 Rising Time Min. R1287xxxxB/F Typ. 0.73 Max. Unit 4.11 ms R1287xxxxC/G 2.6 ms R1287xxxxD/H 2.6 ms VCC = 3.7 V, VOUTN = VSET x 10% to 90%, R1287xxxxB/F 0.58 3.29 ms RLXN CH2 Pch Tr. ON Resistance VCC = 3.7 V, R1287xxxxy 400 mΩ RSYNCN CH2 Nch Tr. ON Resistance VCC = 3.7 V, R1287xxxxy 600 mΩ ILIMLXN CH2 Pch Tr. Current Limit 1.5 A VCC = 3.7 V, R1287xxxxy [R1287xxxxB, R1287xxxxC, R1287xxxxD, R1287xxxxF, R1287xxxxG, R1287xxxxH] VOUTN ∆VOUTN /∆Ta VOUTN Voltage VCC = 3.7 V VOUTN Voltage Temperature Coefficient VCC = 3.7 V, −40°C ≤ Ta ≤ 85°C 0.990 VSET 1.0 1 V ppm /°C ±50 [R1287x001B, R1287x001C, R1287x001D, R1287x001F, R1287x001G, R1287x001H] VFBNO IFBN VFBN Voltage VCC = 3.7 V VFBN Input Current VCC = 3.7 V, VFBN = VFBNO x 1.2 ∆IFBN IFBN Current Temperature /∆Ta Coefficient VCC = 3.7 V, −40°C ≤ Ta ≤ 85°C −30 0 30 mV 6.541 6.667 6.794 µA ±150 ppm /°C All test items listed under ELECTRICAL CHARACTERISTICS are done under the pulse load condition (Tj ≈ Ta = 25°C) except VOUTN Load Regulation, CH2 Rising Time, CH2 Pch Tr. ON Resistance, CH2 Nch Tr. ON Resistance, VOUTN Voltage Temperature Coefficient and IFBN Current Temperature Coefficient. 11 R1287x NO.EA-325-180907 ELECTRICAL CHARACTERISTICS (continued) CH1 Electrical Characteristics by Different Output Voltage foscp ΔVOUTP/ΔIOUT Product Name R1287x001B/F R1287x001C/G R1287x001D/H R1287x002B/F R1287x002C/G R1287x002D/H R1287x003B/F R1287x003C/G R1287x003D/H R1287x004B/F R1287x004C/G R1287x004D/H R1287x005B/F R1287x005C/G R1287x005D/H R1287x006B/F R1287x006C/G R1287x006D/H R1287x007B/F R1287x007C/G R1287x007D/H R1287x008B/F R1287x008C/G R1287x008D/H R1287x009B/F R1287x009C/G R1287x009D/H 12 [%] [kHz] Maxduty1 VOUT [%] [V] Typ. Min. Typ. Max. Typ. ±0.3 700 900 1100 90 240 300 360 97 800 1000 1200 90 ±0.2 ±0.3 ±0.2 ±0.3 ±0.2 ±0.3 ±0.2 ±0.3 ±0.2 ±0.3 ±0.2 ±0.3 ±0.2 ±0.3 ±0.2 ±0.3 ±0.2 700 900 1100 90 240 300 360 97 800 1000 1200 90 700 900 1100 90 240 300 360 97 800 1000 1200 90 700 900 1100 90 240 300 360 97 800 1000 1200 90 700 900 1100 90 240 300 360 97 800 1000 1200 90 700 900 1100 90 240 300 360 97 800 1000 1200 90 700 900 1100 90 240 300 360 97 800 1000 1200 90 700 900 1100 90 240 300 360 97 800 1000 1200 90 700 900 1100 90 240 300 360 97 800 1000 1200 90 Min. Typ. Max. - - - 4.955 5.0 5.045 5.351 5.4 5.449 5.698 5.75 5.802 5.550 5.6 5.650 4.460 4.5 4.541 5.748 5.8 5.852 5.451 5.5 5.550 5.054 5.1 5.146 R1287x NO.EA-325-180907 ELECTRICAL CHARACTERISTICS (continued) CH2 Electrical Characteristics by Different Output Voltage foscn ΔVOUTN/ΔIOUT Product Name R1287x001B/F R1287x001C/G R1287x001D/H R1287x002B/F R1287x002C/G R1287x002D/H R1287x003B/F R1287x003C/G R1287x003D/H R1287x004B/F R1287x004C/G R1287x004D/H R1287x005B/F R1287x005C/G R1287x005D/H R1287x006B/F R1287x006C/G R1287x006D/H R1287x007B/F R1287x007C/G R1287x007D/H R1287x008B/F R1287x008C/G R1287x008D/H R1287x009B/F R1287x009C/G R1287x009D/H [%] [kHz] Maxduty2 VOUT [%] [V] Typ. Min. Typ. Max. Typ. ±0.4 900 1100 1200 90 240 300 360 97 800 1000 1200 90 ±0.2 ±0.4 ±0.2 ±0.4 ±0.2 ±0.4 ±0.2 ±0.4 ±0.2 ±0.4 ±0.2 ±0.4 ±0.2 ±0.4 ±0.2 ±0.4 ±0.2 900 1100 1200 90 240 300 360 97 800 1000 1200 90 900 1100 1200 90 240 300 360 97 800 1000 1200 90 900 1100 1200 90 240 300 360 97 800 1000 1200 90 900 1100 1200 90 240 300 360 97 800 1000 1200 90 900 1100 1200 90 240 300 360 97 800 1000 1200 90 900 1100 1200 90 240 300 360 97 800 1000 1200 90 900 1100 1200 90 240 300 360 97 800 1000 1200 90 900 1100 1200 90 240 300 360 97 800 1000 1200 90 Min. Typ. Max. - - - −4.950 −5.0 −5.050 −5.346 −5.4 −5.454 −5.693 −5.75 −5.808 −5.544 −5.6 −5.656 −4.455 −4.5 −4.545 −5.742 −5.8 −5.858 −5.445 −5.5 −5.555 −5.049 −5.1 −5.151 13 R1287x NO.EA-325-180907 THEORY OF OPERATION EN1 / EN2 Enabled Timing When enabled the EN1 pin first and then the EN2 pin If the EN1 pin is switched from low to high, CH1 performs soft-start operation. If the EN2 pin is switched from low to high while the EN1 pin is high, CH2 will not perform soft-start operaton until CH1 detects that the output voltage of CH1 (VOUTP) has reached the preset voltage. EN1 input EN2 input CH1 output (VOUTP) tssp tssn 0V CH2 output (VOUTN) When enabled the EN2 pin first and then the EN1 pin If the EN2 pin is switched from low to high, CH2 performs soft-start operation. If the EN1 pin is switched from low to high while the EN2 pin is high, CH1 will not perform soft-start operaton until CH2 detects that the output voltage of CH2 (VOUTN) has reached the preset voltage. EN1 input EN2 input tssp CH1 output (VOUTP) tssn 0V CH2 output (VOUTN) 14 R1287x NO.EA-325-180907 When enabled the EN1 Pin and the EN2 Pin while Short-circuiting If the EN1 pin and the EN2 pin are switched from low to high while they are short-circuited, CH1 performs softstart operation. CH2 will not perform soft-start operaton until CH1 detects that the output voltage of CH1 (VOUTP) has reached the preset voltage. EN input CH1 output (VOUTP) 0V tssp CH2 output (VOUTN) tssn Auto Discharge Function CH1 can be turned off by setting the EN1 pin low, and CH2 can be turned off by setting the EN2 pin low. Both CH1 and CH2 can be controlled indivudally. If CH1/ CH2 is turned off by setting the EN1/ EN2 pin low, the auto-discharge function is enabled. The switch between the VOUTP/ VOUTN pin and the GND pin is turned on while the auto-discharge function is enabled. While both EN1 and EN2 pins are set low, the device is in the standby mode. If CH1/ CH2 is turned off by other reasons, such as the VCC pin voltage is dropped below the UVLO detector threshold or the timer-latch circuit is triggered due to short-circuit, the auto-discharge function is disabled. Example of R1287xxxxB/C/D Falling Waveform EN1 (= EN2) VOUTP 0V VOUTN Discharge 15 R1287x NO.EA-325-180907 Example of R1287xxxxF/G/H Falling Waveform EN1 EN2 VOUTP 0V VOUTN Discharge Discharge Thermal Shutdown Protection Thermal shutdown circuit detects the overheating of the device and stops the device operation to protect the device from damages. If the internal temperature of the device exceeds the thermal shutdown temperature, the thermal shutdown circuit turns off the drivers and synchronous transistors. If the internal temperature of the device falls below the thermal shutdown release temperature, the thermal shutdown circuit resets the device and restarts the device operation. Please note that the re-starting sequence of the device is performed by the following order: CH2 first and then CH2. Low Output Voltage Detection Circuit for CH1 If CH1 detects a significant voltage drop, after the completion of soft-start operation, CH1 resets the device and restarts the device operation. Please note that the re-starting sequence of the device is performed by the following order: CH first and then CH2. LX Peak Current Limit Timer/ Latch-type Short Circuit Protection Timer The LX peak current limit circuit supervises the peak current of the inductor, which is passing through NMOS transistor of CH1 and PMOS transistor of CH2, in every switching cycle. If the peak current exceeds the LX peak current limit (ILIMLXP/ ILIMLXN), the LX peak current limit circuit turns off the NMOS transistor of CH1 or PMOS transistor of CH2. The latch-type short circuit protection circuit latches the built-in drivers of CH and CH2 off to stop the operation of the device if the overcurrent state continues more than the protection delay time (tprot). Please note that ILIMLXP/ ILIMLXN and tprot can be easily affected by self-heating and ambient environment. Also, the significant voltage drop or the unstable voltage caused by short-circuiting may affect on the protection operation and the delay time. To release the latch-type short circuit protection, switch the EN1/ EN2 pin from high to low to reset the device or make the input voltage (VIN) lower than the UVLO detector threshold (VUVL01). 16 R1287x NO.EA-325-180907 During the softstart operation of CH1 and CH2, both LX peak current limit circuit timer and latch-type short circuit protection circuit timer operate until CH1 and CH2 reach their preset voltages. Therefore, the normal operation of circuit timers will not be affected by the abnormal completion of soft-start operation due to shortcircuit or etc. Protection Resistors between VOUTN and VOUTNS in Fixed Output Voltage Type (R1287Lxxxy) If the VOUTNS pin and the VOUTN pin are connected to each other on PCB while the VOUTNS pin and the VCC pin or the EN2 pin are short-circuited due to some failure, the voltage higher than the rated voltage will be applied to the VOUTN pin. To prevent this, it is recommended that an approximately 100 Ω protection resistor be connected between the VOUTN pin and the VOUTNS pin. Operation of CH1 and Output Current IL2 Inductor VIN Pch Tr IOUT VOUT IL1 Nch Tr CL Basic Circuit Discontinuous Inductor Current Mode Continuous Inductor Current Mode ILxmax IL IL ILxma x ILxmin ILxmin Tf t t ton toff T=1/fosc 1/ton ton toff T=1/fosc 1/ton Inductor Current Waveshapes (IL) through Indictor (L) The PWM control type of CH1 has two operation modes characterized by the continuity of inductor current: discontinuous inductor current mode and continuous inductor current mode. 17 R1287x NO.EA-325-180907 When a NMOS Tr. is in On-state, the voltage to be applied to the inductor (L) is described as VIN. An increase in the inductor current (IL1) can be written as follows: IL1 = VIN x ton / L ··········································································································Equation 1 In the CH1 circuit, the energy accumulated during the On-state is transferred into the capacitor even in the Offstate. A decrease in the inductor current (IL2) can be written as follows: IL2 = (VOUT − VIN) x tf / L ·································································································Equation 2 In the PWM control, IL1 and IL2 become continuous when tf = toff, which is called continuous inductor current mode. When the device is in continuous inductor current mode and operates in steady-state conditions, the variations of IL1 and IL2 are same: VIN x ton / L = (VOUT − VIN) x toff / L ···················································································Equation 3 Therefore, the duty cycle in continuous inductor current mode is: Duty = ton / (ton + toff) = (VOUT − VIN) / VOUT ········································································Equation 4 If the input voltage (VIN) is equal to VOUT, the output current (IOUT) is: IOUT = VIN2 x ton / (2 x L x VOUT) ························································································Equation 5 If IOUT is larger than Equation 5, the device switches to continuous inductor current mode. The LX peak current flowing through L (ILxmax) is: ILxmax = IOUT x VOUT / VIN + VIN x ton / (2 x L) ······································································Equation 6 ILxmax = IOUT x VOUT / VIN + VIN x T x (VOUT − VIN) / (2 x L x VOUT) ·············································Equation 7 As a result, ILxmax becomes larger compared to IOUT. In discontinuous inductor current mode, ILxmax is: ILxmax = √ (2 x IOUT x (VOUT − VIN) x T / L) ··········································································Equation 8 18 R1287x NO.EA-325-180907 The LX peak current limit circuit operates in both modes if the ILxmax becomes more than the LX peak current limit. When considering the input and output conditions or selecting the external components, please pay attention to ILxmax. Notes: The above calculations are based on the ideal operation of the device. They do not include the losses caused by the external components or LX switch. The actual maximum output current will be 70% to 90% of the above calculation results. Especially, if IL is large or VIN is low, it may cause the switching losses. Operation of CH2 and Output Current Pch Tr Nch Tr IOUT VOUT VIN IL1 IL2 CL Inductor Basic Circuit Discontinuous Inductor Current Mode Continuous Inductor Current Mode ILxmax IL IL ILxma x ILxmin ILxmin Tf t t ton toff T=1/fosc 1/ton ton toff T=1/fosc 1/ton Inductor Current Waveshapes (IL) through Indictor (L) The PWM control type of CH2 has two operation modes characterized by the continuity of inductor current: discontinuous inductor current mode and continuous inductor current mode. When a PMOS Tr. is in ON-state, the voltage to be applied to the inductor (L) is described as VIN. An increase in the inductor current (IL1) can be written as follows: IL1 = VIN x ton / L ··········································································································Equation 9 19 R1287x NO.EA-325-180907 In the CH2 circuit, the energy accumulated during the On-state is transferred into the capacitor even in the Offstate. A decrease in the inductor current (IL2) can be written as follows: IL2 = |VOUT| x tf / L······································································································· Equation 10 In the PWM control type, when tf = toff, the inductor current will be continuous and the operation of CH2 will be continuous inductor current mode. When the device is in continuous inductor current mode and operates in steady-state conditions, the variation of IL1 and IL2 are same: VIN x ton / L = |VOUT| x toff / L ························································································· Equation 11 Therefore, the duty cycle in continuous inductor current mode is: Duty = ton / (ton + toff) = |VOUT| / (|VOUT| + VIN) ··································································· Equation 12 If the input voltage (VIN) equal to VOUT, the output current (IOUT) is: IOUT = VIN2 x ton / (2 x L x |VOUT|) ····················································································· Equation 13 If IOUT is larger than Equation 13, the device switches to continuous inductor current mode. The LX peak current flowing through L (ILxmax) is: ILxmax = IOUT x (|VOUT| + VIN) / VIN + VIN x ton / (2 x L) ························································· Equation 14 ILxmax = IOUT x (|VOUT| + VIN) / VIN + VIN x |VOUT| x T / { 2 x L x (|VOUT| + VIN) } ··························· Equation 15 As a result, ILxmax becomes larger compared to IOUT. In discontinuous inductor current mode, ILxmax is: ILxmax = √ (2 x IOUT x |VOUT| x T / L) ················································································ Equation 16 The LX peak current limit circuit operates in both modes if the ILxmax becomes more than the LX peak current limit. When considering the input and output conditions or selecting the external components, please pay attention to ILxmax. Notes: The above calculations are based on the ideal operation of the device. They do not include the losses caused by the external components or LX switch. The actual maximum output current will be 70% to 90% of the above calculation results. Especially, if IL is large or VIN is low, it may cause the switching losses. 20 R1287x NO.EA-325-180907 VFM Mode Operation (R1287xxxxB/F) The PWM/VFM auto switching control automatically switches from PWM mode to VFM mode in low output current in order to achieve high efficiency. With the VFM mode operation, ton is preset inside the IC. In continuous inductor current mode, if the inductor current is set to 4.7 µH, ton is set in a way that ILmax becomes 600 mA or less. In discontinuous inductor current mode, if the inductor current is set to 4.7 µH, ton is set in a way that ILpp becomes 400 mA or less. ILmax IL 0 ILmin t ton toff VFM Mode Operation (Discontinuous Inductor Current Mode) IL ILpp 0 t ton toff VFM Mode Operation (Continuous Inductor Current Mode) 21 R1287x NO.EA-325-180907 APPLICATION INFORMATION Typical Application Circuit VOUTN C3 L2 C1 VOUTNS EN2 VOUTN EN1 LXN EN control for VOUTN EN control for VOUTP VOUTPS PVCC VOUTP VCC LXP GND PGND VOUTP L1 C2 R1287xxxxy Typical Application (Fixed Output Voltage Type) R3 VOUTN C3 L2 VFBN EN2 VOUTN EN1 LXN VFBP PVCC C1 VCC GND VOUTP LXP EN control for VOUTN EN control for VOUTP C4 R1 R2 L1 VOUTP C2 PGND R1287x001y Typical Application (Adjustable Output Voltage Type) Recommended Components Symbol L1, L2 22 Descriptions VLF302510M-4R7M, TDK DFE252010C, TOKO, 1269AS-H-4R7M=P2 C1 (CIN) 10 µF, 2012 size, X5R T = Max. 0.85, C2012X5R0J106M, TDK C2 (COUTP) 10 µF, 2012 size, X5R T = Max. 0.85, C2012X5R0J106M, TDK C3 (COUTN) 10 µF, 2012 size, X5R T = Max. 0.85, C2012X5R0J106M, TDK R1287x NO.EA-325-180907 TECHNICAL NOTES The performance of a power source circuit using this device is highly dependent on a peripheral circuit. A peripheral component or the device mounted on PCB should not exceed a rated voltage, a rated current or a rated power. When designing a peripheral circuit, please be fully aware of the following points.  Place a 10 µF or more ceramic capacitor (C1) between the VCC pin and the GND pin, or the PVCC pin and the PGND pin in a shortest distance. The GND pin should be connected to the GND plane of the PCB.  Make GND and PGND to the same potential.  Make VCC and PVCC to the same potential.  The wiring between LXP pin, LXN pin and inductor each should be as short as possible and mount output capacitors (C2 and C3) as close as possible to the VOUTP, VOUTN each.  Input impedance of VOUTPS pin, VOUTNS pin, VFBP pin, and VFBN pin is high, therefore, the external noise may affect on the performance. The coupling capacitance between these nodes and switching lines must be as short as possible.  For stable operation of the device, the R1287x provides a phase compensation circuit according to the values of inductors (L1, L2) and capacitors (C2, C3). Use L1 or L2 which is having a low equivalent series resistance, having enough tolerable current and which is less likely to cause magnetic saturation. A large load current causes a significant drop of the inductance value. Therefore, select the inductor value in consideration of the amount of load current under using condition. A significant drop of the inductance value can cause an increase in the LX peak current along with an increase in the load current. When the LX peak current reaches the current limit, the LX peak current limit circuit starts operating.  CH1 Output Voltage Setting (R1287x001y: Adjustable Output Voltage Type) The output voltage of CH1 (VOUTP) controls the output voltage of CH1 feedback pin voltage (VFBP) to 1.0 V. VOUTP, depending on the resistors (R1 and R2), can be calculated as follows: VOUTP = VFBP x (R1 + R2) / R1 VOUTP can be set within the range of 4.5 V to 5.8 V. R1 between 20 kΩ to 60 kΩ is recommended.  CH2 Output Voltage Setting (R1287x001y: Adjustable Output Voltage Type) The output voltage of CH2 (VOUTN) controls the output voltage of CH2 feedback pin voltage (VFBN) to 0 V. VOUTN, depending on the resistor (R3) and the VFBN pin input current (IFBN), can be calculated as follows: VOUTN = −IFBN x R3 VOUTN can be set within the range of −4.5 V to −6.0 V. The reommended value for R3 is as follows: VOUTN Setting −5.0 V −5.4 V −5.6 V R3 750 kΩ 810 kΩ (310 kΩ + 500 kΩ) 840 kΩ (680 kΩ + 160 kΩ) 23 R1287x NO.EA-325-180907  Phase Compensation of CH1 (R1287x001y: Adjustable Output Voltage Type) The phase compensation of CH1 can be delayed 180 degree because of the external components (L, C) and the load current. The phase delay causes the loss in phase margins and stability. Therefore, the phase advance should be ensured. A zero-point can be formed with R1 and C4 as follows: C4 [pF] = 300/ R1 [kΩ]  Protection Resistor between VOUTN and VOUTNS Pins (R1287Lxxxy: Fixed Output Voltage Type) If the VOUTNS pin and the VOUTN pin are connected to each other on PCB while the VOUTNS pin and the VCC pin or the EN2 pin are short-circuited due to some failure, the voltage higher than the rated voltage will be applied to the VOUTN pin. To prevent this, it is recommended that an approximately 100 Ω protection resistor (R4) be connected between the VOUTN pin and the VOUTNS pin.  Current Path on PCB The current paths of boost DC/DC converter are shown in Fig.3 and Fig.4, and the current path of inverting DC/DC converter are shown in Fig.5 and Fig. 6. The parasitic impedance, inductance, and the capacitance in the parts pointed with red arrows in Fig.4 and Fig.6 have an influence against the stability of the DC/DC converters and become a cause of the noise. Therefore, such parasitic elements must be made as small as possible. Wiring of the current paths shown in Fig3 to Fig6 must be short and thick. 【Boost DCDC Converter】 NMOSFET-ON (BOOST) PMOSFET-ON (BOOST) 【Inverting DCDC Converter】 PMOSFET-ON (INVERTING) 24 NMOSFET-ON (INVERTING) R1287x NO.EA-325-180907 PCB Layout R1287Zxxxy (PKG: WLCSP-12) Top Side Bottom Side R1287Z001y (PKG: WLCSP-12) Top Side Bottom Side 25 R1287x NO.EA-325-180907 R1287Lxxxy (PKG: DFN3030-12) Top Side Bottom Side R4 is protection resistor, see TECHNICAL NOTES for details. R1287L001y (PKG: DFN30303-12) Top Side 26 Bottom Side R1287x NO.EA-325-180907 TYPICAL CHARACTERISTICS 5.05 5.05 5.04 5.04 5.03 5.03 5.02 5.02 VOUTP [V] VOUTP [V] Notes: Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) Output Voltage vs. Output Current R1287x001B/F (VOUTP = 5.0 V) R1287x001C/G (VOUTP = 5.0 V) (Ta = 25°C) (Ta = 25°C) 5.01 5.00 4.99 5.01 5.00 4.99 Vcc = 3.2 V 4.98 Vcc = 3.7 V 4.97 Vcc = 4.2 V 4.96 4.95 0 20 40 60 4.98 Vcc = 3.2 V 4.97 Vcc = 3.7 V 4.96 Vcc = 4.2 V 4.95 80 100 120 140 160 180 200 IOUTP [mA] 0 5.05 5.65 5.04 5.64 5.03 5.63 5.02 5.62 5.01 5.00 80 100 5.61 5.60 5.59 4.99 Vcc = 3.2 V 4.98 Vcc = 3.7 V 5.57 Vcc = 4.2 V 4.96 Vcc = 3.2 V 5.58 Vcc = 3.7 V 4.97 Vcc = 4.2 V 5.56 5.55 4.95 0 20 40 60 0 80 100 120 140 160 180 200 IOUTP [mA] R1287x001C/G (VOUTP = 5.6 V) (Ta = 25°C) 5.65 -4.95 5.64 -4.96 5.63 -4.97 5.62 -4.98 5.61 5.60 5.59 Vcc = 3.2 V 5.58 60 80 100 120 140 160 180 200 IOUTP [mA] -4.99 -5.00 -5.01 Vcc = 3.2 V Vcc = 3.7 V -5.03 Vcc = 4.2 V 5.56 40 -5.02 Vcc = 3.7 V 5.57 20 R1287x001B/F (VOUTN = −5.0 V) (Ta = 25°C) VOUTN [V] VOUTP [V] 40 60 IOUTP [mA] R1287x001B/F (VOUTP = 5.6 V) (Ta = 25°C) VOUTP [V] VOUTP [V] R1287x001D/H (VOUTP = 5.0 V) (Ta = 25°C) 20 Vcc = 4.2 V -5.04 -5.05 5.55 0 20 40 60 IOUTP [mA] 80 100 0 20 40 60 80 100 120 140 160 180 200 IOUTN [mA] 27 R1287x NO.EA-325-180907 R1287x001D/H (VOUTN = −5.0 V) (Ta = 25°C) -4.95 -4.95 -4.96 -4.96 -4.97 -4.97 -4.98 -4.98 VOUTN [V] VOUTN [V] R1287x001C/G (VOUTN = −5.0 V) (Ta = 25°C) -4.99 -5.00 -4.99 -5.00 -5.01 Vcc = 3.2 V -5.01 -5.02 Vcc = 3.7 V -5.02 Vcc = 3.2 V -5.03 Vcc = 4.2 V -5.03 Vcc = 3.7 V -5.04 Vcc = 4.2 V -5.04 -5.05 -5.05 0 20 40 60 IOUTN [mA] 80 0 100 -5.56 -5.56 -5.57 -5.57 -5.58 -5.58 VOUTN [V] VOUTN [V] -5.55 80 100 120 140 160 180 200 -5.59 -5.60 -5.61 -5.61 Vcc = 3.2 V -5.62 Vcc = 3.7 V -5.63 Vcc = 4.2 V -5.64 -5.65 -5.62 Vcc = 3.2 V -5.63 Vcc = 3.7 V Vcc = 4.2 V -5.64 -5.65 0 28 60 R1287x001C/G (VOUTN = −5.6 V) (Ta = 25°C) -5.55 -5.60 40 IOUTN [mA] R1287x001B/F (VOUTN = −5.6 V) (Ta = 25°C) -5.59 20 20 40 60 80 100 120 140 160 180 200 IOUTN [mA] 0 20 40 60 IOUTN [mA] 80 100 R1287x NO.EA-325-180907 R1287x001C/G (VOUTP = 5.0 V, VOUTN = −5.0 V) (Ta = 25°C) 95 95 90 90 Efficiency [%] Efficiency [%] 2) Efficiency vs. Output Current R1287x001B/F (VOUTP = 5.0 V, VOUTN = −5.0 V) (Ta = 25°C) 85 80 Vcc = 3.2 V 75 80 Vcc = 3.2 V 75 Vcc = 3.7 V Vcc = 3.7 V Vcc = 4.2 V 70 Vcc = 4.2 V 70 65 65 0 20 40 60 80 100 120 140 160 180 200 IOUT = IOUTP = IOUTN [mA] 0 R1287x001D/H (VOUTP = 5.0 V, VOUTN = −5.0 V) (Ta = 25°C) 95 95 90 90 85 80 Vcc = 3.2 V 75 10 20 0 20 40 60 80 100 120 140 160 180 200 IOUT = IOUTP = IOUTN [mA] 100 Vcc = 3.2 V Vcc = 3.7 V Vcc = 4.2 V 70 65 90 80 Vcc = 4.2 V 70 80 85 75 Vcc = 3.7 V 30 40 50 60 70 IOUT = IOUTP = IOUTN [mA] R1287x001B/F (VOUTP = 5.6 V, VOUTN = −5.6 V) (Ta = 25°C) Efficiency [%] Efficiency [%] 85 65 0 20 40 60 80 100 120 140 160 180 200 IOUT = IOUTP = IOUTN [mA] R1287x001C/G (VOUTP = 5.6 V, VOUTN = −5.6 V) (Ta = 25°C) 95 Efficiency [%] 90 85 80 Vcc = 3.2 V 75 Vcc = 3.7 V Vcc = 4.2 V 70 65 0 10 20 30 40 50 60 70 IOUT = IOUTP = IOUTN [mA] 80 90 100 29 R1287x NO.EA-325-180907 R1287x001B/F (VOUTP = 5.6 V) (Ta = 25°C) 1000 1000 900 900 800 800 700 600 500 400 Vcc = 3.2V 300 Vcc = 3.7V 200 Vcc = 4.2V Boost Freqency [kHz] Boost Freqency [kHz] 3) Frequency vs. Output Current (VFM mode) R1287x001B/F (VOUTP = 5.0 V) (Ta = 25°C) 700 600 500 400 Vcc = 3.2V 300 Vcc = 3.7V 200 Vcc = 4.2V 100 100 0 0 0 20 40 60 80 0 100 120 140 160 180 200 IOUTP [mA] 1000 1000 Vcc = 3.2V Vcc = 3.7V 200 Inverting Freqency [kHz] Inverting Freqency [kHz] 1200 400 60 80 100 120 140 160 180 200 R1287x001B/F (VOUTN = −5.6 V) (Ta = 25°C) 1200 600 40 IOUTP [mA] R1287x001B/F (VOUTN = −5.0 V) (Ta = 25°C) 800 20 800 600 400 Vcc = 3.2V Vcc = 3.7V 200 Vcc = 4.2V Vcc = 4.2V 0 0 0 20 40 60 80 100 120 140 160 180 200 IOUTN [mA] 4) Turn-on Waveform by EN1 & EN2 VCC = PVCC = 3.7 V, IOUTP = IOUTN = 0 mA R1287x001B/F (VOUTP = 5.0 V, VOUTN = −5.0 V ) (Ta = 25°C) 20 40 60 80 100 120 140 160 180 200 IOUTN [mA] R1287x001C/G (VOUTP = 5.0 V, VOUTN = −5.0 V) (Ta = 25°C) EN1&EN2 EN1&EN2 VOUTP VOUTP VOUTN VOUTN IIN 30 0 IIN R1287x NO.EA-325-180907 R1287x001D/H (VOUTP = 5.0 V, VOUTN = −5.0 V) (Ta = 25°C) EN1&EN2 VOUTP VOUTN IIN 5) Turn-on Waveform by EN1 -> EN2 6) Turn-on Waveform by EN2 -> EN1 VCC = PVCC = 3.7 V, IOUTP = IOUTN = 0 mA VCC = PVCC = 3.7 V, IOUTP = IOUTN = 0 mA R1287x001B/F (VOUTP = 5.0 V, VOUTN = −5.0 V) R1287x001D/H (VOUTP = 5.0 V, VOUTN = −5.0 V ) (Ta = 25°C) (Ta = 25°C) EN1 EN2 EN2 VOUTP EN1 VOUTP VOUTN VOUTN 7) Turn-off Waveform by EN1 & EN2 VCC = PVCC = 3.7 V, IOUTP = IOUTN = 0 mA R1287x001B/C/D (VOUTP = 5.0 V, VOUTN = −5.0 V) (Ta = 25°C) R1287x001F/G/H (VOUTP = 5.0 V, VOUTN = −5.0 V) (Ta = 25°C) EN1&EN2 EN1&EN2 VOUTP VOUTP VOUTN VOUTN IIN IIN 31 R1287x NO.EA-325-180907 8) Load Transient Response Waveform VCC = PVCC = 3.7 V R1287x001B/F (VOUTP = 5.0 V) (Ta = 25°C) VOUTP IOUTP R1287x001C/G (VOUTP = 5.0 V) (Ta = 25°C) VOUTN IOUTN R1287x001C/G (VOUTN = −5.0 V) (Ta = 25°C) VOUTP VOUTN IOUTP IOUTN R1287x001D/H (VOUTP = 5.0 V) (Ta = 25°C) 32 R1287x001B/F (VOUTN = −5.0 V) (Ta = 25°C) R1287x001D/H (VOUTN = −5.0 V) (Ta = 25°C) VOUTP VOUTN IOUTP IOUTN R1287x NO.EA-325-180907 9) Standby Current vs. Temperature R1287xxxxy 10) UVLO Voltage vs. Temperature R1287xxxxy 2.36 1.0 2.34 VUVLO [V] Istandyby [µA] 0.8 0.6 Vcc=3.7V 0.4 Vcc=5.5V 2.32 2.30 UVLO Release Voltage 2.28 UVLO Detect Voltage 2.26 0.2 2.24 0.0 2.22 -0.2 -40 -20 0 20 Ta [°C] 40 60 -40 -20 0 20 40 60 80 Ta [°C] 11) VOUTP Voltage vs. Temperature VCC = 3.7 V R1287x002y 12) VOUTN Voltage vs. Temperature VCC = 3.7 V R1287x002y 5.05 -4.95 5.04 -4.96 5.03 -4.97 5.02 -4.98 VOUTN [V] VOUTP [V] 2.20 80 5.01 5.00 -4.99 -5.00 4.99 -5.01 4.98 -5.02 4.97 -5.03 4.96 -5.04 -5.05 4.95 -40 -20 0 20 Ta [°C] 40 60 -40 80 13) VFBP Voltage vs. Temperature VCC = 3.7 V R1287x001y -20 0 20 40 60 80 Ta [°C] 14) VFBN Voltage vs. Temperature VCC = 3.7 V R1287x001y 1.010 0.03 1.008 0.02 1.004 VFBNO [V] VFBP [V] 1.006 1.002 1.000 0.01 0.00 0.998 -0.01 0.996 0.994 -0.02 0.992 -0.03 0.990 -40 -20 0 20 Ta [°C] 40 60 80 -40 -20 0 20 Ta [°C] 40 60 80 33 R1287x NO.EA-325-180907 15) IFBN Current vs. Temperature VCC = 3.7 V R1287x001y 6.80 IFBN [µA] 6.75 6.70 6.65 6.60 6.55 6.50 -40 -20 0 20 Ta [°C] 40 60 80 16) PWM Oscillator Frequency vs. Temperature VCC = 3.7 V R1287xxxxC R1287xxxxD 1100 330 1080 1060 fosc[kHz] fosc[kHz] 320 310 300 1040 1020 1000 980 290 960 940 280 920 900 270 -40 -20 0 20 Ta [°C] 40 60 100 100 98 98 96 96 R1287xxxxC 94 R1287xxxxB/D 92 90 -20 0 20 Ta [°C] 40 60 80 18) CH2 Maximum Duty Cycle vs. Temperature VCC = 3.7 V R1287xxxxy Maxduty2[%] Maxduty1[%] 17) CH1 Maximum Duty Cycle vs. Temperature VCC = 3.7 V R1287xxxxy R1287xxxxC 94 R1287xxxxB/D 92 90 88 -40 34 -40 80 -20 0 20 Ta [°C] 40 60 80 88 -40 -20 0 20 Ta [°C] 40 60 80 R1287x NO.EA-325-180907 20) EN2 H/L Input Voltage vs. Temperature VCC = 3.7 V R1287xxxxy 0.94 0.94 0.92 0.92 0.90 0.90 VEN2 [V] VEN1 [V] 19) EN1 H/L Input Voltage vs. Temperature VCC = 3.7 V R1287xxxxy 0.88 0.86 0.86 0.84 0.84 0.82 0.82 -40 -20 0 20 Ta [°C] 40 60 -20 0 20 40 60 80 Ta [°C] 22) Inverting Pch Current Limit vs. Temperature R1287xxxxy 1300 1800 1200 1700 1100 1600 ILIMXLN [mA] ILIMLXP [mA] -40 80 21) Boost Nch Current Limit vs. Temperature R1287xxxxy 1000 Vcc=2.5V 900 Vcc=3.7V 800 1500 Vcc=2.5V 1400 Vcc=3.7V 1300 Vcc=5.5V Vcc=5.5V 1200 700 600 1100 -40 -20 0 20 Ta [°C] 40 60 -40 80 23) CH1 Soft-Start Time vs. Temperature R1287xxxxy -20 0 20 Ta [°C] 40 60 4.0 2.6 3.9 2.5 3.8 2.4 3.7 2.3 3.6 3.5 2.2 2.1 3.4 Vcc=2.5V 2.0 Vcc=2.5V 3.3 Vcc=3.7V 1.9 Vcc=3.7V Vcc=5.5V 1.8 Vcc=5.5V 3.2 80 24) CH2 Soft-Start Time vs. Temperature R1287xxxxy tssn [ms] tssp [ms] 0.88 1.7 3.1 1.6 3.0 -40 -20 0 20 Ta [°C] 40 60 80 -40 -20 0 20 Ta [°C] 40 60 80 35 R1287x NO.EA-325-180907 25) Delay Time for Protection vs. Temperature VCC = 3.7 V R1287xxxxy 34 32 tprot [ms] 30 28 26 R1287xxxxB 24 R1287xxxxC 22 R1287xxxxD 20 -40 36 -20 0 20 Ta [°C] 40 60 80 POWER DISSIPATION WLCSP-12-P1 Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following conditions are used in this measurement. Measurement Conditions Standard Test Land Pattern Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Double-sided) Board Dimensions 40 mm x 40 mm x 1.6 mm Top Side: Approx. 80% Copper Ratio Bottom Side: Approx. 90% φ 0.6 mm × 31 pcs Through-holes Measurement Result (Ta = 25°C, Tjmax = 125°C) Standard Test Land Pattern Power Dissipation 1000 mW Thermal Resistance θja = (125 − 25°C) / 1.0 W = 100°C /W 40 1200 1000 Standard Test Land Pattern 800 40 Power Dissipation PD (mW) 1000 600 400 200 0 0 25 50 75 85 100 125 150 IC Mount Area (mm) Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern i PACKAGE DIMENSIONS WLCSP-12-P1 Ver. A WLCSP-12-P1 Package Dimensions (Unit: mm) i Visual Inspection Criteria WLCSP VI-160823 No. 1 Inspection Items Package chipping 2 Si surface chipping 3 No bump Marking miss 4 Inspection Criteria Figure A≥0.2mm is rejected B≥0.2mm is rejected C≥0.2mm is rejected And, Package chipping to Si surface and to bump is rejected. A≥0.2mm is rejected B≥0.2mm is rejected C≥0.2mm is rejected But, even if A≥0.2mm, B≤0.1mm is acceptable. No bump is rejected. To reject incorrect marking, such as another product name marking or 5 6 7 No marking Reverse direction of marking Defective marking 8 Scratch 9 Stain and Foreign material another lot No. marking. To reject no marking on the package. To reject reverse direction of marking character. To reject unreadable marking. (Microscope: X15/ White LED/ Viewed from vertical direction) To reject unreadable marking character by scratch. (Microscope: X15/ White LED/ Viewed from vertical direction) To reject unreadable marking character by stain and foreign material. (Microscope: X15/ White LED/ Viewed from vertical direction) i POWER DISSIPATION DFN3030-12 Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes φ 0.3 mm × 32 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 3400 mW Thermal Resistance (θja) θja = 29°C/W Thermal Characterization Parameter (ψjt) ψjt = 3.1°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 4000 3400 Power Dissipation (mW) 3500 3000 2500 2000 1500 1000 500 0 0 25 50 75 85 100 125 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern i PACKAGE DIMENSIONS DFN3030-12 Ver. A 3.0 A B 7 12 X4 0.40±0.05 ※ 0.1 1.7±0.1 3.0 2.5±0.1 C 0.35 0.203 typ 0.8 max. INDEX S 6 1 0.5 0.25±0.05 0.05 M AB Bottom View 0.05 S DFN3030-12 Package Dimensions (Unit: mm) * ∗ The tab on the bottom of the package is substrate level (GND). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. i 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
R1287Z001B-E2-F 价格&库存
很抱歉,暂时无法提供与“R1287Z001B-E2-F”相匹配的价格&库存,您可以联系我们找货
