R1191x SERIES
300mA LDO REGULATOR with the Reverse Current Protection
NO.EA-229-230529
OUTLINE
R1191x Series are a low supply current voltage regulator with high output voltage accuracy. The maximum
operating voltage is 16V. These ICs can switch to the fast mode and the low power mode by the low power / fast
mode changer pin (ECO pin) without changing the output voltage value.
Each of these ICs consists of a voltage reference unit, an error amplifier, a resistor-net for voltage setting, a
short current limit circuit, a thermal shutdown circuit and a chip enable circuit.
Moreover, the R1191x Series has the reverse current protection function, which protects the reverse current
flow into VDD pin when the output pin voltage becomes higher than the VDD pin voltage. Thus it is suitable for the
back-up circuit.
Since the packages for these ICs are SOT-89-5, SOT-23-5 and DFN1616-6, therefore high density mounting
of the ICs on boards is possible.
FEATURES
• Supply Current ..................................................... Typ. 50µA (Fast Mode),
Typ. 6.0µA (Low Power Mode)
• Standby Mode ...................................................... Typ. 0.3µA
• Reverse Current ................................................... Max. 0.1µA
• Output Current ..................................................... Min. 300mA
• Input Voltage Range ............................................ 3.5V to 16.0V
• Output Voltage Range .......................................... 2.0V to 15.0V (0.1V steps)
(For other voltages, please refer to MARK INFORMATIONS.)
• Output Voltage Accuracy...................................... ±1.5% (Fast Mode)
±2.5% (Low Power Mode)
• Temperature-Drift Coefficient of Output Voltage .. Typ. ±80ppm/°C
• Dropout Voltage ................................................... Typ. 0.55V (Fast Mode, IOUT=300mA ,VOUT=5.0V)
Typ. 0.70V (Low Power Mode, IOUT=300mA,VOUT=5.0V)
• Ripple Rejection ................................................... Typ. 60dB (f=1kHz,VOUT=5.0V, Fast Mode)
• Line Regulation .................................................... Typ. 0.02%/V (Fast Mode)
• Packages ............................................................ DFN1616-6, SOT-23-5, SOT-89-5
• Built-in fold-back protection circuit ....................... Typ. 50mA (Current at short mode)
• Built-in Thermal Shutdown Circuit........................ Shutdown Temperature at 150°C
• Ceramic capacitors are recommended to be used with this IC ··· CIN=2.2µF or more, COUT=4.7µF or more
APPLICATIONS
• Power source for digital home appliances
• Power source for audio visual equipment
1
R1191x
NO.EA-229-230529
BLOCK DIAGRAM
R1191xxxxB
R1191xxxxD
ECO
ECO
Thermal Shutdown
VDD
VOUT
Thermal Shutdown
VDD
Vref
Peak
Short
Current
Protection Protection
VOUT
Vref
Peak
Short
Current
Reverse
Detector
CE
Reverse
Detector
GND CE
GND
SELECTION GUIDE
The output voltage, auto-discharge function, and package, for the ICs can be selected at the user’s request.
Product Name
Package
Quantity per Reel
Pb Free
Halogen Free
DFN1616-6
5,000 pcs
Yes
Yes
R1191Nxxx∗-TR-FE
SOT-23-5
3,000 pcs
Yes
Yes
R1191Hxxx∗-T1-FE
SOT-89-5
1,000 pcs
Yes
Yes
R1191Lxxx∗-TR
xxx : The output voltage can be designated in the range from 2.0V(020) to 15.0V(150) in 0.1V steps.
: The auto discharge function at off state are options as follows.
(B) without auto discharge function at off state.
(D) with auto discharge function at off state.
2
R1191x
NO.EA-229-230529
PIN CONFIGURATIONS
• DFN1616-6*1
Top View
6
5
4
• SOT-23-5
Bottom View
4
5
2
3
3
2
4
5
3
1
4
6
1
5
• SOT-89-5
(mark side)
1
1
2
2
3
PIN DISCRIPTIONS
DFN1616-6*1
Pin No
Symbol
Pin Description
1
ECO
2
NC
No Connection
3
VDD
Input Pin
4
VOUT
Output pin
5
GND
Ground Pin
6
CE
Low Power / Fast Mode Changer Pin ("H": Fast Mode)
Chip Enable Pin ("H" Active)
∗1) Tab is GND level. (They are connected to the reverse side of this IC.)
The tab is better to be connected to the GND, but leaving it open is also acceptable.
SOT-23-5
Pin No
Symbol
Pin Description
1
ECO
2
GND
Ground Pin
3
CE
4
VOUT
Output pin
5
VDD
Input Pin
SOT-89-5
Pin No
Symbol
Pin Description
1
VOUT
Output pin
2
GND
Ground Pin
3
CE
4
ECO
5
VDD
Input Pin
3
R1191x
NO.EA-229-230529
ABSOLUTE MAXIMUM RATINGS
Symbol
Item
Rating
Unit
VIN
Input Voltage
−0.3 to 18.0
V
VCE
Input Voltage (CE Pin)
−0.3 to 18.0
V
VECO
Input Voltage (ECO Pin)
−0.3 to VIN + 0.3 ≤ 18.0
V
VOUT
Output Voltage
−0.3 to 18.0
V
IOUT
Output Current
400
mA
PD
Power Dissipation
Ta
Operating Temperature Range
−40 to +85
°C
Storage Temperature Range
−55 to +125
°C
Tstg
Refer to the Power Dissipation
supplementary item
in the
Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the
permanent damages and may degrade the life time and safety for both device and system using the device
in the field.
The functional operation at or over these absolute maximum ratings is not assured.
RECOMMENDED OPERATING CONDITIONS
(ELECTRICAL CHARACTERISTICS)
All of electronic equipment should be designed that the mounted semiconductor devices operate within the
recommended operating conditions. The semiconductor devices cannot operate normally over the
recommended operating conditions, even if when they are used over such conditions by momentary
electronic noise or surge. And the semiconductor devices may receive serious damage when they continue
to operate over the recommended operating conditions.
4
R1191x
NO.EA-229-230529
VIN=VCE=Set VOUT+3.0V (Max.16V), CIN=2.2μF, COUT=4.7μF IOUT=1mA, unless otherwise noted.
The values in
are applicable under the condition of −40°C ≤ Topt ≤ 85°C.
R1191xxxxB/D
Symbol
Topt=25°C
Item
Conditions
Fast Mode VECO=VIN
VOUT
Output Voltage
Low Power
VECO=0V
Mode
Topt=25°C
−40°C ≤ Topt ≤ 85°C
Topt=25°C
−40°C ≤ Topt ≤ 85°C
Min.
Typ.
Max.
×0.985
×0.970
×1.015
×1.030
×0.975
×1.025
×0.960
×1.040
Unit
V
120
VDIF
Output Voltage Deviation between Fast Mode and Low Power
−1.5
Mode
Output Current
300
VECO=VIN,
Fast Mode
50
1mA ≤ IOUT ≤ 300mA
Load Regulation
Low Power VECO=GND,
60
Mode
1mA ≤ IOUT ≤ 300mA
Dropout Voltage
Refer to the following table
ISS1
Supply Current (Fast Mode) VECO=VIN, IOUT=0mA
50
100
µA
ISS2
Supply Current
(Low Power Mode)
6
15
µA
∆VOUT
IOUT
∆VOUT/
∆IOUT
VECO=GND, IOUT=0mA
1.5
mA
130
mV
Istandby Supply Current (Standby)
VIN=16V, VCE=0V
(If VOUT < 3.0V, VIN=14V)
0.3
1.0
µA
∆VOUT/
∆VIN
Line Regulation
Set VOUT+0.5V ≤ VIN ≤ 16V
(If Set VOUT < 3.0V, 3.5V ≤ VIN ≤ 14V)
0.02
0.10
%/V
Ripple Rejection
f=1kHz, IOUT=30mA 2.0V≤VOUT
很抱歉,暂时无法提供与“R1191N033B-TR-FE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+3.721413000+0.48143
- 6000+3.632046000+0.46986
- 9000+3.587299000+0.46407
- 15000+3.5377115000+0.45766
- 21000+3.5087321000+0.45391
- 国内价格 香港价格
- 1+8.037681+1.03980
- 10+5.7203110+0.74001
- 25+5.1552225+0.66691
- 100+4.52928100+0.58594
- 250+4.23147250+0.54741
- 500+4.05191500+0.52418
- 1000+3.916681000+0.50669
