R1190J050B-T1-FE
R1190J050B-T1-FE
    NISSHINBO(日清纺)
    TO-252-6
    PMIC - 稳压器 - 线性 正 固定 1 输出 1A TO-252-5-P2
R1190J050B-T1-FE 数据手册
R1190x SERIES 1A VOLTAGE REGULATOR (Operating Voltage up to 16V) NO.EA-183-161011 OUTLINE The R1190x series are a low supply current voltage regulator with high output voltage accuracy. The maximum operating voltage is 16V and the output current is 1A. Each of these ICs consists of a voltage reference unit, an error amplifier, a resistor-net for voltage setting, as a short current protection, a peak current protection, a thermal shutdown, an inrush current limit and a chip enable circuit. The wide input voltage range (Max. 16V). Additionally, the output voltage is fixed internally, in the range from 2.0V to 12.0V by the 0.1V steps. The supply current of R1190x series is excellent (Typ. 150µA) moreover R1190x series has the standby mode (Typ. 0.1µA) by the chip enable function. Since the package for these ICs are TO-252-5-P2, SOT-89-5 and HSOP-6J with high power dissipation, high density mounting of the ICs on boards is possible. FEATURES • • • • • • • • • • • • • Input Voltage Range ............................................. 3.5V to 16V Supply Current ...................................................... Typ. 150µA Standby Current .................................................... Typ. 0.1µA Output Voltage Range ........................................... 2.0V to 12.0V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.) Output Voltage Accuracy....................................... ±1.5% Temperature-Drift Coefficient of Output Voltage ... Typ. ±100ppm/°C Dropout Voltage .................................................... Typ. 1.1V (IOUT=1A, VOUT=5V) Output Current ...................................................... Min. 1A (3.3V ≤ VOUT ≤ 12.0V) Line Regulation ..................................................... Typ. 0.02%/V Packages .............................................................. SOT-89-5, HSOP-6J, TO-252-5-P2 Built-in Fold Back Protection Circuit ..................... Typ.300mA (Current at short mode) Built-in Thermal Shutdown Circuit Built-in Inrush Current Limit Circuit ....................... The Delay Pin for setting Inrush Current Limit Time APPLICATIONS • Power source for digital home appliances. • Power source for audio visual equipments. 1 R1190x BLOCK DIAGRAMS R1190xxxxD R1190xxxxB Thermal Shutdown Thermal Shutdown VDD VOUT VDD Vref Short Protection VOUT Vref Inrush Current Limit Peak Current Protection CE Short Protection Inrush Current Limit Peak Current Protection GND CE GND DELAY DELAY SELECTION GUIDE The output voltage, auto discharge function, package for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free R1190Hxxx∗-T1-FE SOT-89-5 1,000 pcs Yes Yes R1190Sxxx∗-E2-FE HSOP-6J 1,000 pcs Yes Yes R1190Jxxx∗-T1-FE TO-252-5-P2 3,000 pcs Yes Yes xxx : The output voltage can be designated in the range of 2.0V(020) to 12.0V(120) in 0.1V steps. (For other voltages, please refer to MARK INFORMATIONS.) ∗ 2 : The auto discharge function at off state are options as follows. (B) without auto discharge function at off state (D) with auto discharge function at off state R1190x PIN CONFIGURATIONS • SOT-89-5 5 1 • HSOP-6J 6 5 4 1 2 3 • TO-252-5-P2 4 2 3 1 2 3 4 5 PIN DESCRIPTIONS • SOT-89-5 Pin No. Symbol Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE 4 DELAY 5 VDD Chip Enable Pin ("H" Active) Delay Pin (for setting Inrush Current Limit Time) Input Pin • HSOP-6J Pin No. Symbol Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE 4 DELAY 5 GND 6 VDD Chip Enable Pin ("H" Active) Delay Pin (for setting Inrush Current Limit Time) Ground Pin Input Pin • TO-252-5-P2 Pin No. Symbol Description 1 DELAY 2 VDD 3 GND Ground Pin 4 VOUT Output Pin 5 CE Chip Enable Pin ("H" Active) Delay Pin (for setting Inrush Current Limit Time) Input Pin 3 R1190x ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit −0.3 to 18 V VIN Input Voltage VCE Input Voltage (CE Pin) −0.3 to VIN+0.3 ≤ 18 V VOUT Output Voltage −0.3 to VIN+0.3 ≤ 18 V PD Power Dissipation (SOT-89-5) ∗ 900 Power Dissipation (HSOP-6J) ∗ 1700 Power Dissipation (TO-252-5-P2) ∗ 1900 mW Topt Operating Temperature Range −40 to 85 °C Tstg Storage Temperature Range −55 to 125 °C ∗) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 R1190x ELECTRICAL CHARACTERISTICS VIN=VCE=Set VOUT+2.0V, CIN=COUT=4.7µF, IOUT=1mA, unless otherwise noted. The specification in is checked and guaranteed by design engineering at −40°C ≤ Topt ≤ 85°C. • R1190x Symbol VOUT Topt=25°C Item Output Voltage Conditions IOUT=1mA Min. Typ. Max. Topt=25°C ×0.985 ×1.015 −40°C ≤ Topt ≤ 85°C ×0.973 ×1.027 Unit V ∆VOUT/∆IOUT Load Regulation Refer to the following table VDIF Dropout Voltage Refer to the following table ISS Supply Current IOUT=0mA 150 220 µA Istandby Standby Current (CE Off State) VIN=16V VCE=0V 0.1 1.0 µA ∆VOUT/∆VIN Line Regulation VOUT+0.5V (Min.3.5V) ≤ VIN ≤ 16V IOUT=1mA 0.02 0.10 %/V RR Ripple Rejection f=1kHz, IOUT=100mA VIN Input Voltage ∆VOUT /∆Topt Output Voltage Temperature Coefficient ILIM Output Current ISC Short Current Limit 60 3.5 IOUT=1mA, −40°C ≤ Topt ≤ 85°C dB 16 V ppm /°C ±100 Refer to the following table VOUT=0V 300 mA VCEH CE Input Voltage "H" 1.6 VIN V VCEL CE Input Voltage "L" 0 0.6 V TTSD Thermal Shutdown Temperature Junction Temperature 150 °C TTSR Thermal Shutdown Released Temperature Junction Temperature 130 °C RLOW Low Output Nch Tr. ON Resistance (of D version) VIN=5.0V VCE=0V VOUT=0.3V 150 Ω All of units are tested and specified under pulse load conditions such that Tj≈Topt=25°C except for Ripple Rejection, Output Voltage Temperature Coefficient, Thermal Shutdown, Load Regulation at 600mA (2.0V ≤ VOUT < 2.5V) and at 700mA (2.5V≤ VOUT < 3.3V) and at 1000mA (3.3V ≤ VOUT ≤ 12.0V), Dropout Voltage at 600mA (2.0V ≤ VOUT < 2.5V) and at 700mA (2.5V ≤ VOUT < 3.3V) and at 1000mA (3.3V ≤ VOUT ≤ 12.0V). 5 R1190x The specification in • is checked and guaranteed by design engineering at −40°C ≤ Topt ≤ 85°C. Output Current by Output Voltage Output Current ILIM (mA) Output Voltage VOUT Condition Min. 2.0V ≤ VOUT < 2.5V 600 2.5V ≤ VOUT < 3.3V VIN=VOUT+2.3V 700 3.3V ≤ VOUT ≤ 12.0V • 1000 Load Regulation by Output Voltage Topt=25°C Load Regulation ∆VOUT/∆IOUT (mV) Output Voltage VOUT Condition 2.0V ≤ VOUT < 5.0V 5.0V ≤ VOUT ≤ 12.0V Max. 20 60 40 100 2.0V ≤ VOUT < 2.5V VIN=VOUT+2.3V, 1mA ≤ IOUT ≤ 600mA 80 180 2.5V ≤ VOUT < 3.3V VIN=VOUT+2.3V, 1mA ≤ IOUT ≤ 700mA 90 200 120 230 130 250 3.3V ≤ VOUT < 5.0V 5.0V ≤ VOUT ≤ 12.0V • VIN=VOUT+2.3V, 1mA ≤ IOUT ≤ 200mA Typ. VIN=VOUT+2.3V, 1mA ≤ IOUT ≤ 1A Dropout Voltage by Output Voltage Output Voltage VOUT Topt=25°C Dropout Voltage VDIF (V) Condition Typ. Max. 2.0V 1.5 2.1V 1.4 2.2V 1.3 2.3V 1.2 2.4V 1.1 2.5V 1.0 2.6V 2.7V Condition Typ. Max. IOUT=600mA 1.6 2.2 IOUT=700mA 1.5 2.15 1.6 2.3 1.4 2.1 1.1 1.85 0.8 1.30 0.9 IOUT=200mA 0.8 2.8V ≤ VOUT < 3.1V 0.7 3.1V ≤ VOUT < 3.3V 0.4 0.7 3.3V ≤ VOUT < 4.0V 0.3 0.53 4.0V ≤ VOUT < 5.0V 0.25 0.42 5.0V ≤ VOUT < 9.0V 0.19 0.31 9.0V ≤ VOUT ≤ 12.0V 0.1 0.18 IOUT=1A All of units are tested and specified under pulse load conditions such that Tj≈Topt=25°C except for Ripple Rejection, Output Voltage Temperature Coefficient, Thermal Shutdown, Load Regulation at 600mA (2.0V ≤ VOUT < 2.5V) and at 700mA (2.5V≤ VOUT < 3.3V) and at 1000mA (3.3V ≤ VOUT ≤ 12.0V), Dropout Voltage at 600mA (2.0V ≤ VOUT < 2.5V) and at 700mA (2.5V ≤ VOUT < 3.3V) and at 1000mA (3.3V ≤ VOUT ≤ 12.0V). 6 R1190x TYPICAL APPLICATION VDD VOUT R1190x Series C1 CE C2 GND DELAY CD (External Components) C1, C2: Ceramic Capacitor 4.7µF VOUT DELAY pin is OPEN when CD pin is not used. Nippon Chemi-con Corporation KTD500B475M43A0T00 TECHNICAL NOTES When using these ICs, consider the following points: Phase Compensation In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor COUT with good frequency characteristics and ESR (Equivalent Series Resistance). (Note: If additional ceramic capacitors are connected with parallel to the output pin with an output capacitor for phase compensation, the operation might be unstable. Because of this, test these ICs with as same external components as ones to be used on the PCB.) PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor with a capacitance value as much as 4.7µF or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor, as close as possible to the ICs, and make wiring as short as possible. (Refer to the TYPICAL APPLICATION diagram above.) Thermal Shutdown There is the built-in thermal-shutdown function in R1190x series. It discontinues operation of the IC when the junction temperature becomes over 150°C (Typ.) and IC re-operates when the junction temperature under 130°C. If the temperature increasing keeps the IC repeats ON and OFF operating. The output becomes the pulse condition. Chip Enable Circuit For the output voltage stability, please do not use the intermediate electric potential (the voltage value between VCEH and VCEL) that causes the supply current increasing and the unstable of output voltage. 7 R1190x Inrush-Current Limit Function R1190x Series has the function to limit the inrush-current, it limited approximately 0.3A when the voltage regulator is turn ON. It is also possible to set time of the rush-current limitation by connecting capacitor with DELAY pin. The rush-current time (tD) and the value of capacitor (CD(F)) is calculatable by the following formula; tD=(0.000198+(3.79×107×CD))×VIN The inrush-current is limited even if the capacitor is not connected with the DELAY pin. In this case, the time is calculated as CD=0 by the formula above. Though, if the value of time is insufficient for controlling the inrush-current, please connect the capacitor with DELAY pin. The DELAY pin is used as OPEN when the capacitor is not used. Please use the DELAY pin as OPEN when the capacitor is not used. Auto-Discharge Function R1190xxxxD series has the auto-discharge function. When "L" signal is put into the Chip-enable pin (CE), the switch between VOUT and GND is turned ON and the charge at capacitor is discharge rapidly by the auto-discharge function. 8 R1190x TEST CIRCUITS VDD VOUT R1190x Series C2 C1 VIN CE GND DELAY V VOUT IOUT Basic Test Circuit VDD VOUT R1190x Series A C2 C1 CE GND DELAY VIN Test Circuit for Supply Current VDD R1190x Series Pulse Generator P.G. VOUT CE C2 GND DELAY IOUT Test Circuit for Ripple Rejection 9 R1190x VDD VOUT VOUT R1190x Series VIN C2 C1 CE GND DELAY IOUTa Test Circuit for Load Transient Response 10 IOUTb R1190x TYPICAL CHARACTERISTIC 1) Output Voltage vs. Output Current (C1=C2=4.7µF, Topt=25°C) R1190x020x R1190x033x R1190x050x R1190x090x R1190x120x 11 R1190x 2) Output Voltage vs. Input Voltage (C1=C2=4.7µF, Topt=25°C) R1190x020x R1190x033x R1190x050x R1190x090x R1190x120x 12 R1190x 3) Supply Current vs. Input Voltage (C1=C2=4.7µF, Topt=25°C) R1190x020x R1190x033x R1190x050x R1190x090x R1190x120x 13 R1190x 4) Output Voltage vs. Temperature (C1=C2=4.7µF, IOUT=1mA) R1190x020x R1190x033x R1190x050x R1190x090x R1190x120x 14 R1190x 5) Supply Current vs. Temperature (C1=C2=4.7µF) R1190x020x R1190x033x R1190x050x R1190x090x R1190x120x 15 R1190x 6) Dropout Voltage vs. Output Current (C1=C2=4.7µF) R1190x020x R1190x033x R1190x050x R1190x090x R1190x120x 16 R1190x 7) Dropout Voltage vs. Set Output Voltage (C1=C2=4.7µF, Topt=25°C) 8) Ripple Rejection vs. Input Voltage (C1=none, C2=4.7µF, IOUT=100mA, Ripple=0.2Vp-p, Topt=25°C) R1190x020x R1190x033x R1190x050x R1190x090x 17 R1190x R1190x120x 9) Ripple Rejection vs. Frequency (C1=none, C2=4.7µF, Ripple=0.2Vp-p, Topt=25°C) 18 R1190x020x R1190x033x R1190x050x R1190x090x R1190x R1190x120x 10) Input Transient Response (C1=none, C2=4.7µF, IOUT=1mA, tr=tf=0.5µs) R1190x020x R1190x033x R1190x050x R1190x090x 19 R1190x R1190x120x 11) Load Transient Response (C1=C2=4.7µF, tr=tf=0.5µs) 20 R1190x020x R1190x033x R1190x050x R1190x090x R1190x R1190x120x 12) Turn On Speed with CE Pin (IOUT=1mA, C1=C2=4.7µF, tr=tf=0.5µs) R1190x020x R1190x050x R1190x090x R1190x120x 21 R1190x 13) Turn Off Speed with CE Pin (D Version) (IOUT=1mA, C1=C2=4.7µF, tr=tf=0.5µs) R1190x020x R1190x050x R1190x090x R1190x120x 14) Inrush Current at Turn On (VIN=7.0V, C1=C2=4.7µF, CD=none, tr=tf=0.5µs ) 22 R1190x 15) Inrush Current Limit vs. CD Capacitance (C1=C2=4.7µF) R1190x050x 16) Inrush Current Limit Delay Time vs. Input Voltage (C1=C2=4.7µF) R1190x050x 17) Thermal Shutdown vs. Temperature (C1=C2=4.7µF) R1190x050x 23 R1190x ESR vs. Output Current When using these ICs, consider the following points: The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The conditions when the white noise level is under 40µVrms (Avg.) are marked as the hatched area in the graph. Measurement conditions • Frequency Band : 10Hz to 1MHz • Temperature : −40°C to 85°C • Hatched Area : Noise level is under 40µVrms (Avg.) : 4.7µF (KTD500B475M43A0T00) • CIN : 4.7µF (KTD500B475M43A0T00) • COUT : 10.0µF (FK22Y5V1H106Z) 24 R1190x020x R1190x020x R1190x033x R1190x033x R1190x 25 R1190x 26 R1190x050x R1190x050x R1190x090x R1190x090x R1190x120x R1190x120x 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
R1190J050B-T1-FE 价格&库存
很抱歉,暂时无法提供与“R1190J050B-T1-FE”相匹配的价格&库存,您可以联系我们找货
R1190J050B-T1-FE
  • 3000+5.576153000+0.72231
  • 6000+5.451656000+0.70618
  • 9000+5.389339000+0.69811
  • 15000+5.3203015000+0.68917
库存:5
R1190J050B-T1-FE
  • 1+11.543151+1.49524
  • 10+8.3647910+1.08354
  • 25+7.5730725+0.98098
  • 100+6.70142100+0.86807
  • 250+6.28659250+0.81434
  • 500+6.03646500+0.78194
  • 1000+5.933681000+0.76862
库存:5
