RP130N331B-TR-YE
RP130N331B-TR-YE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 150mA SOT-23-5
RP130N331B-TR-YE 数据手册
RP130x-Y Series Low Noise 150mA LDO Regulator for Industrial Applications NO.EA-336-230725 OUTLINE The RP130x is a CMOS-based positive voltage regulator IC with high ripple rejection, low dropout voltage, high output voltage accuracy and extremely low supply current. The RP130x consists of a voltage reference unit, an error amplifier, a resistor network for voltage setting, a short current limit circuit, and a chip enable circuit. The RP130x has low supply current characteristics in the CMOS process. In addition, the RP130x can supply a low dropout voltage, which becomes the smallest difference between the input voltage and output voltage by having a low on-resistance and also can achieve the battery's long life by a chip enable function. When compared with the conventional products of high-speed type, the RP130x achieves low consumption current of 38µA (Typ.) while improving the input transient response, the load transient response, and the ripple rejection. The RP130x supports two package types: DFN(PL)1010-4 and SOT-23-5. By the adoption of the ultra-compact DFN(PL)1010-4, the RP130x can achieve a higher density mounting than ever. This is a high-reliability semiconductor device for industrial applications (-Y) that has passed both the screening at high temperature and the reliability test with extended hours. FEATURES  Input Voltage Range (Max. Rating) ···················· 1.7V to 6.5V (7.0V)  Operating Temperature Range ························· - 40°C to 105°C  Supply Current·············································· Typ. 38µA  Supply Current (Standby Mode) ························ Typ. 0.1µA  Ripple Rejection ············································ Typ. 80dB (f = 1kHz)  Output Voltage Range ···································· 1.2V, 1.5V, 1.8V, 2.5V, 2.8V, 2.9V, 3.0V, 3.3V, 3.4V, 3.6V, 4.2V and 5.0V Contact our sales representatives for other voltages.  Output Voltage Accuracy ································· ±1.0% (VSET > 2.0V, Ta = 25°C)  Temperature-Drift Coefficient of Output Voltage ···· Typ. ±20 ppm / °C  Dropout Voltage ············································ Typ. 0.32V (IOUT = 150mA, VSET = 2.8V)  Line Regulation ············································· Typ. 0.02% / V  Packages ···················································· DFN(PL)1010-4, SOT-23-5  Built-in Fold Back Protection Circuit ··················· Typ. 40mA  Recommended Ceramic Capacitors ·················· 0.47µF or more  Output Noise Voltage ····································· Typ. VSET × 20 [µVrms] (BW = 10Hz to 100kHz, IOUT = 30mA) APPLICATIONS  Industrial equipments such as FAs and smart meters  Equipments used under high-temperature conditions such as surveillance camera and vending machine  Equipments accompanied by self-heating such as motor and lighting 1 RP130x-Y NO.EA-336-230725 BLOCK DIAGRAMS RP130xxx1B VDD RP130xxx1D VOUT VDD Vref VOUT Vref Current Limit Current Limit CE GND CE GND SELECTION GUIDE The output voltage, chip-enable polarity, auto-discharge function, and package type for this device can be selected at the user’s request. Product Name RP130Kxx1∗-TR-Y RP130Nxx1∗-TR-YE Package Quantity per Reel Pb Free Halogen Free DFN(PL)1010-4 10,000pcs Yes Yes SOT-23-5 3,000pcs Yes Yes xx : Specify the set output voltage (VSET) 1.2 V (12) / 1.5 V (15) / 1.8 V (18) / 2.5 V (25) / 2.8 V (28) / 2.9 V (29) / 3.0 V (30) / 3.3 V (33) / 3.4 V (34) / 3.6 V (36) / 4.2 V (42) / 5.0 V (50) Note: Contact our sales representatives for other voltages. ∗ : Specify the desired functions for chip-enable polarity and auto-discharge B: "H" active / No auto-discharge function D: "H" active / Auto-discharge function Auto-Discharge function quickly lowers the output voltage to 0V by releasing the electrical charge in the external capacitor when the chip enable signal is switched from the active mode to the standby mode. 2 RP130x-Y NO.EA-336-230725 PIN DESCRIPTION • DFN(PL)1010-4 Top View 4 3 • SOT-23-5 Bottom View 3 4 5 (mark side) *1 1 2 2 4 1 1 2 3 DFN(PL)1010-4 *1 Pin No. Symbol Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE Chip Enable Pin ("H" Active) 4 VDD Input Pin The tab on the bottom of the package enhances thermal performance and is electrically connected to GND (substrate level). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. SOT-23-5 Pin No. Symbol Description 1 VDD 2 GND 3 CE Chip Enable Pin ("H" Active) 4 NC No Connection 5 VOUT Input Pin Ground Pin Output Pin 3 RP130x-Y NO.EA-336-230725 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage - 0.3 to 7.0 V VCE Input Voltage (CE Pin) - 0.3 to 7.0 V VOUT Output Voltage - 0.3 to VIN+0.3 V IOUT Output Current 200 mA PD Power Dissipation Tj Junction Temperature - 40 to 125 °C Strong Temperature Range - 55 to 125 °C Tstg Refer to “PACKAGE INFORMATION” ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum rating is not assured. RECOMMENDED OPERATING CONDITIONS Symbol Item VIN Input Voltage Ta Operating Temperature Range Rating Unit 1.7 to 6.5 V - 40 to 105 °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 RP130x-Y NO.EA-336-230725 ELECTRICAL CHARACTERISTICS VIN = VSET+1.0V (VSET > 1.5V), VIN = 2.5V (VSET ≤ 1.5V), IOUT = 1mA, CIN = COUT = 0.47µF, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at - 40ºC ≤ Ta ≤ 105ºC. RP130xxx1B/D Symbol (Ta = 25°C) Item Conditions Ta = 25°C VOUT Output Voltage - 40°C ≤ Ta ≤ 105°C IOUT ∆VOUT /∆IOUT VDIF Min. Dropout Voltage Max. Unit VSET > 2.0V ×0.99 ×1.01 V VSET ≤ 2.0V - 20 20 mV VSET > 2.0V ×0.985 ×1.015 V VSET ≤ 2.0V - 30 30 mV Output Current Load Regulation Typ. 150 1mA ≤ IOUT ≤ 150mA IOUT = 150mA mA 10 30 1.2V ≤ VSET < 1.5V 0.67 1.03 1.5V ≤ VSET < 1.7V 0.54 0.84 1.7V ≤ VSET < 2.0V 0.46 0.75 2.0V ≤ VSET < 2.5V 0.41 0.63 2.5V ≤ VSET < 4.0V 0.32 0.51 4.0V ≤ VSET ≤ 4.2V 0.24 0.39 VSET = 5V 0.24 0.31 mV V ISS Supply Current IOUT = 0mA 38 58 µA Istandby Supply Current (at Standby) VCE = 0 0.1 1.0 µA ∆VOUT /∆VIN Line Regulation VSET + 0.5V ≤ VIN ≤ 6.5V 0.02 0.10 %/V ISC Short Current Limit VOUT = 0V IPD CE Pull-down Current VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" RLOW Nch ON Resistance for Auto Discharge (D Version Only) 40 mA 0.4 µA 1.0 V 0.36 VIN = 4.0V, VCE = 0V 30 V Ω All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C) 5 RP130x-Y NO.EA-336-230725 Product-specific Electrical Characteristics The specifications surrounded by are guaranteed by design engineering at - 40ºC ≤ Ta ≤ 105ºC. (Ta = 25°C) Product Name VOUT [V] (Ta = 25°C) VOUT [V] (Ta = − 40 to 105°C) VDIF [V] Min. Typ. Max. Min. Typ. Max. Typ. Max. RP130x121x 1.180 1.200 1.220 1.170 1.200 1.230 0.67 1.03 RP130x151x 1.480 1.500 1.520 1.470 1.500 1.530 0.54 0.84 RP130x181x 1.780 1.800 1.820 1.770 1.800 1.830 0.46 0.75 RP130x251x 2.475 2.500 2.525 2.463 2.500 2.538 RP130x281x 2.772 2.800 2.828 2.758 2.800 2.842 RP130x291x 2.871 2.900 2.929 2.857 2.900 2.944 RP130x301x 2.970 3.000 3.030 2.955 3.000 3.045 0.32 0.51 RP130x331x 3.267 3.300 3.333 3.251 3.300 3.350 RP130x341x 3.366 3.400 3.434 3.349 3.400 3.451 RP130x361x 3.564 3.600 3.636 3.546 3.600 3.654 RP130x421x 4.158 4.200 4.242 4.137 4.200 4.263 0.24 0.39 RP130x501x 4.950 5.000 5.050 4.925 5.000 5.075 0.24 0.31 6 RP130x-Y NO.EA-336-230725 TYPICAL APPLICATION VDD C1 CE Control VOUT RP130x CE VOUT C2 GND External Components: Symbol Description C2 0.47µF (Ceramic) TECHNICAL NOTES Phase Compensation In the ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor C2 with 0.47µF or more. If a tantalum capacitor is used, and its ESR (Equivalent Series Resistance) of C2 is large, the loop oscillation may result. Because of this, select C2 carefully considering its frequency characteristics. PCB Layout Make VDD and GND lines sufficient. If their impedance is too high, noise pickup or unstable operation may result. Connect 0.47µF or more of the capacitor C1 between the VDD and GND, and as close as possible to the pins. In addition, connect the capacitor C2 between VOUT and GND, and as close as possible to the pins. 7 RP130x-Y NO.EA-336-230725 TYPICAL APPLICATION FOR IC CHIP BREAKDOWN PREVENTION VDD C1 CE Control VOUT RP130x CE VOUT C2 D1 GND When a sudden surge of electrical current travels along the VOUT pin and GND due to a short-circuit, electrical resonance of a circuit involving an output capacitor (C2) and a short circuit inductor generates a negative voltage and may damage the device or the load devices. Connecting a schottky diode (D1) between the VOUT pin and GND has the effect of preventing damage to them. 8 RP130x-Y NO.EA-336-230725 PACKAGE INFORMATION Power Dissipation (DFN(PL)1010-4) PD-DFN(PL)1010-4-(105125)-JE-B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2mm × 114.3mm × 0.8mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50mm Square Outer Layer (Fourth Layer): Approx. 100% of 50mm Square Through-holes φ 0.2mm × 21pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 800mW Thermal Resistance (θja) θja = 125°C/W Thermal Characterization Parameter (ψjt) ψjt = 58°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 1000 900 800 Power Dissipation (mW) 800 700 600 500 400 300 200 100 0 0 25 50 75 100105 Ambient Temperature (°C) 125 Power Dissipation vs. Ambient Temperature Measurement Board Pattern 9 RP130x-Y NO.EA-336-230725 Package Dimensions (DFN(PL)1010-4) DM-DFN(PL)1010-4-JE-C UNIT : mm DFN(PL)1010-4 Package Dimensions 10 RP130x-Y NO.EA-336-230725 ● Mark Specifications (DFN(PL)1010-4) MK-RP130K-JYEY-A : Product Code … Refer to “RP130K Mark Specification Table” : Lot Number …Alphanumeric Serial Number   DFN(PL)1010-4 Mark Specifications RP130K Mark Specification Table (DFN(PL)1010-4) RP130Kxx1B Product Name  VSET RP130Kxx1D Product  VSET RP130K121B TA 1.2 V RP130K121D VA 1.2 V RP130K151B TD 1.5 V RP130K151D VD 1.5 V RP130K181B TG 1.8 V RP130K181D VG 1.8 V RP130K251B TQ 2.5 V RP130K251D VQ 2.5 V RP130K281B TT 2.8 V RP130K281D VT 2.8 V RP130K291B TV 2.9 V RP130K291D VV 2.9 V RP130K301B TW 3.0 V RP130K301D VW 3.0 V RP130K331B TZ 3.3 V RP130K331D VZ 3.3 V RP130K341B UA 3.4 V RP130K341D WA 3.4 V RP130K361B UC 3.6 V RP130K361D WC 3.6 V RP130K421B UJ 4.2 V RP130K421D WJ 4.2 V RP130K501B US 5.0 V RP130K501D WS 5.0 V 11 RP130x-Y NO.EA-336-230725 Power Dissipation (SOT-23-5) PD-SOT-23-5-(105125)-JE-B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2mm × 114.3mm × 0.8mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50mm Square Outer Layer (Fourth Layer): Approx. 100% of 50mm Square Through-holes φ 0.3 mm × 7 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 660mW Thermal Resistance (θja) θja = 150°C/W Thermal Characterization Parameter (ψjt) ψjt = 51°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 800 Power Dissipation PD (mW) 700 660 600 500 400 300 200 100 0 0 25 50 75 100 105 Ambient Temperature (°C) 125 Power Dissipation vs. Ambient Temperature Measurement Board Pattern 12 RP130x-Y NO.EA-336-230725 Package Dimensions (SOT-23-5) DM-SOT-23-5-JE-A 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 1 2 0~0.1 0.2min. +0.2 1.6-0.1 5 2.8±0.3 (0.95) 3 0.4±0.1 +0.1 0.15-0.05 Unit : mm SOT-23-5 Package Dimensions 13 RP130x-Y NO.EA-336-230725 Mark Specifications (SOT-23-5) MK-RP130N-JYEY-A : Product Code … Refer to “RP130N Mark Specification Table” : Lot Number …Alphanumeric Serial Number 5 4  1 2 3 SOT-23-5 Mark Specifications RP130N Mark Specification Table (SOT-23-5) RP130Nxx1B Product Name  VSET RP130N121B H1A RP130N151B RP130Nxx1D Product Name  VSET 1.2 V RP130N121D H2A 1.2 V H1D 1.5 V RP130N151D H2D 1.5 V RP130N181B H1G 1.8 V RP130N181D H2G 1.8 V RP130N251B H1Q 2.5 V RP130N251D H2Q 2.5 V RP130N281B H1T 2.8 V RP130N281D H2T 2.8 V RP130N291B H1V 2.9 V RP130N291D H2V 2.9 V RP130N301B H1W 3.0 V RP130N301D H2W 3.0 V RP130N331B H1Z 3.3 V RP130N331D H2Z 3.3 V RP130N341B J1A 3.4 V RP130N341D J2A 3.4 V RP130N361B J1C 3.6 V RP130N361D J2C 3.6 V RP130N421B J1J 4.2 V RP130N421D J2J 4.2 V RP130N501B J1S 5.0 V RP130N501D J2S 5.0 V 14 RP130x-Y NO.EA-336-230725 TEST CIRCUITS VDD VOUT RP130x C1 CE V C2 VOUT ↓ IOUT GND C1 = Ceramic 0.47µF C2 = Ceramic 0.47µF Standard Test Circuit VDD A ISS VOUT VOUT RP130x C1 CE C2 GND C1 = Ceramic 0.47µF C2 = Ceramic 0.47µF Supply Current Test Circuit VDD Pulse Generator VOUT RP130x P.G. CE C2 ↓ IOUT GND C2 = Ceramic 0.47µF Ripple Rejection, Line Transient Response Test Circuit VDD C1 RP130x CE VOUT VOUT C2 GND ↓ IOUTa ↓ IOUTb C1 = Ceramic 0.47µF C2 = Ceramic 0.47µF Load Transient Response Test Circuit 15 RP130x-Y NO.EA-336-230725 TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) Output Voltage vs. Output Current (C1 = C2 = 0.47µF, Ta = 25°C) RP130x121x RP130x281x RP130x501x 2) Output Voltage vs. Input Voltage (C1 = C2 = 0.47µF, Ta = 25°C) RP130x121x RP130x281x 16 RP130x-Y NO.EA-336-230725 RP130x501x 3) Supply Current vs. Input Voltage (C1 = C2 = 0.47µF, Ta = 25°C) RP130x121x RP130x281x RP130x501x 17 RP130x-Y NO.EA-336-230725 4) Output Voltage vs. Temperature (IOUT = 1mA, C1 = C2 = 0.47µF) RP130x121x RP130x281x VIN=2.2V 1.24 2.84 1.23 2.83 1.22 1.21 1.20 1.19 1.18 1.17 VIN=3.8V 2.85 Output Voltage V OUT (V) Output Voltage V OUT (V) 1.25 1.16 2.82 2.81 2.80 2.79 2.78 2.77 2.76 1.15 -40 -25 0 25 50 Temperature Ta (℃) 2.75 105 75 100 -40 -25 0 25 50 Temperature Ta (℃) 75 105 100 RP130x501x VIN=6.0V 5.05 Output Voltage V OUT (V) 5.04 5.03 5.02 5.01 5.00 4.99 4.98 4.97 4.96 4.95 -40 -25 0 25 50 Temperature Ta (℃) 75 105 100 5) Supply Current vs. Temperature (IOUT = 0mA, C1 = C2 = 0.47µF) RP130x121x RP130x281x VIN=2.2V 38 36 34 32 30 -40 -25 0 25 50 Temperature Ta (℃) 75 105 100 VIN=3.8V 40 Supply Current Iss (μA) Supply Current Iss (μA) 40 38 36 34 32 30 -40 -25 0 25 50 Temperature Ta (℃) 75 105 100 18 RP130x-Y NO.EA-336-230725 RP130x501x VIN=6.0V Supply Current Iss (μA) 40 38 36 34 32 30 -40 -25 0 25 50 Temperature Ta (℃) 75 105 100 6) Dropout Voltage vs. Output Current (C1 = C2 = 0.47µF) RP130x121x RP130x281x RP130x501x 19 RP130x-Y NO.EA-336-230725 7) Dropout Voltage vs. Set Output Voltage (C1 = C2 = 0.47µF) 8) Ripple Rejection vs. Input Bias Voltage (C1 = none, C2 = 0.47µF, Ripple = 0.2Vp-p, Ta = 25°C) RP130x281x RP130x281x 9) Ripple Rejection vs. Frequency (C1 = none, C2 = 0.47µF, Ripple = 0.2Vp-p, Ta = 25°C) RP130x121x RP130x281x 20 RP130x-Y NO.EA-336-230725 RP130x501x 10) Input Transient Response (IOUT = 30mA, tr = tf = 5µs, C1 = none, C2 = 0.47µF, Ta = 25°C) RP130x121x RP130x281x RP130x501x 21 RP130x-Y NO.EA-336-230725 11) Load Transient Response (tr = tf = 0.5µs, C1 = C2 = 0.47µF, IOUT = 50mA 100mA, Ta = 25°C) RP130x121x RP130x281x RP130x501x 12) Load Transient Response (tr = tf = 0.5µs, C1 = C2 = 0.47µF, IOUT = 1mA  150mA, Ta = 25°C) RP130x121x RP130x281x 22 RP130x-Y NO.EA-336-230725 RP130x501x 13) Rise Time with CE Pin (C1 = C2 = 0.47µF, Ta = 25°C) RP130x121x RP130x121x RP130x121x RP130x281x 23 RP130x-Y NO.EA-336-230725 RP130x281x RP130x281x RP130x501x RP130x501x RP130x501x 24 RP130x-Y NO.EA-336-230725 14) Fall Time with CE Pin in D-Version (C1 = C2 = 0.47µF, Ta = 25°C) RP130x121D RP130x121D RP130x121D RP130x281D RP130x281D RP130x281D 25 RP130x-Y NO.EA-336-230725 RP130x501D RP130x501D RP130x501D 15) Minimum Operating Voltage (C1 = C2 = 0.47µF) Hatched area is available for 1.2V output. 26 RP130x-Y NO.EA-336-230725 ESR vs. Output Current The RP130x is recommended to use a ceramic type capacitor, but the RP130x can be used other capacitors of the lower ESR type. The relation between the output current (IOUT) and the ESR of output capacitor is shown below. Measurement conditions Frequency Band: 10Hz to 3MHz Measurement Temperature: − 40°C to 85°C Hatched area: Noise level is 40μV (average) or below Ceramic Capacitor: C1 = Ceramic 0.47μF, C2 = 0.47μF RP130x121x RP130x281x V IN=1.4V to 6.5V 100 Ta=85℃ 10 Ta=85℃ 10 Ta=-40℃ ESR (Ω) ESR (Ω) V IN=3.0V to 6.5V 100 1 0.1 Ta=-40℃ 1 0.1 0.01 0.01 0 25 50 75 100 125 Output Current IOUT (mA) 150 0 25 50 75 100 125 Output Current lOUT (mA) 150 RP130x501x V IN=5.2V to 6.5V 100 Ta=85℃ 10 ESR (Ω) Ta=-40℃ 1 0.1 0.01 0 25 50 75 100 125 Output Current lOUT (mA) 150 27 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. The materials in this document may not be copied or otherwise reproduced in whole or in part without the prior written consent of us. This product and any technical information relating thereto are subject to complementary export controls (so-called KNOW controls) under the Foreign Exchange and Foreign Trade Law, and related politics ministerial ordinance of the law. (Note that the complementary export controls are inapplicable to any application-specific products, except rockets and pilotless aircraft, that are insusceptible to design or program changes.) Accordingly, when exporting or carrying abroad this product, follow the Foreign Exchange and Foreign Trade Control Law and its related regulations with respect to the complementary export controls. The technical information described in this document shows typical characteristics and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our or any third party's intellectual property rights or any other rights. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death should first contact us. • Aerospace Equipment • Equipment Used in the Deep Sea • Power Generator Control Equipment (nuclear, steam, hydraulic, etc.) • Life Maintenance Medical Equipment • Fire Alarms / Intruder Detectors • Vehicle Control Equipment (automotive, airplane, railroad, ship, etc.) • Various Safety Devices • Traffic control system • Combustion equipment In case your company desires to use this product for any applications other than general electronic equipment mentioned above, make sure to contact our company in advance. Note that the important requirements mentioned in this section are not applicable to cases where operation requirements such as application conditions are confirmed by our company in writing after consultation with your company. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. The products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. We shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. Quality Warranty 8-1. Quality Warranty Period In the case of a product purchased through an authorized distributor or directly from us, the warranty period for this product shall be one (1) year after delivery to your company. For defective products that occurred during this period, we will take the quality warranty measures described in section 8-2. However, if there is an agreement on the warranty period in the basic transaction agreement, quality assurance agreement, delivery specifications, etc., it shall be followed. 8-2. Quality Warranty Remedies When it has been proved defective due to manufacturing factors as a result of defect analysis by us, we will either deliver a substitute for the defective product or refund the purchase price of the defective product. Note that such delivery or refund is sole and exclusive remedies to your company for the defective product. 8-3. Remedies after Quality Warranty Period With respect to any defect of this product found after the quality warranty period, the defect will be analyzed by us. On the basis of the defect analysis results, the scope and amounts of damage shall be determined by mutual agreement of both parties. Then we will deal with upper limit in Section 8-2. This provision is not intended to limit any legal rights of your company. Anti-radiation design is not implemented in the products described in this document. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. Warning for handling Gallium and Arsenic (GaAs) products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP130N331B-TR-YE 价格&库存
很抱歉,暂时无法提供与“RP130N331B-TR-YE”相匹配的价格&库存,您可以联系我们找货
RP130N331B-TR-YE
    • 1+1.52183
    • 200+0.60729
    • 500+0.58698
    • 1000+0.57694
    RP130N331B-TR-YE
    • 1+5.504081+0.71047
    • 10+3.9129410+0.50509
    • 25+3.5067425+0.45265
    • 100+3.05933100+0.39490
    • 250+2.84603250+0.36737
    • 500+2.71739500+0.35076
    • 1000+2.611351000+0.33708
    库存:7124
    RP130N331B-TR-YE
    • 3000+2.480363000+0.32017
    • 6000+2.416256000+0.31189
    • 9000+2.384159000+0.30775
    • 15000+2.3485915000+0.30316
    • 21000+2.3278121000+0.30048
    • 30000+2.3078230000+0.29790
    库存:7124
