R1180N231C-TR-YE
R1180N231C-TR-YE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 150mA SOT-23-5
R1180N231C-TR-YE 数据手册
R1180x-Y Series 150 mA LDO Regulator for Industrial Applications NO.EA-340-220531 OUTLINE The R1180x is a CMOS-based voltage regulator IC with high output voltage accuracy, extremely low supply current, and low ON-resistance. This IC consists of a voltage reference unit, an error amplifier, resistor-net for voltage setting, a current limit circuit which prevents the destruction by excess current, and so on. The output voltage is fixed with high accuracy. B version has a chip enable pin, therefore ultra-low consumption current standby mode can be realized with the pin. The R1180x is available in SOT-23-5 and SON1612-6 package which is possible to mount at high density. This is a high-reliability semiconductor device for industrial applications (-Y) that has passed both the screening at high temperature and the reliability test with extended hours. This line of products operate in a wide temperature range from low temperature to high temperature to support harsh environment applications. FEATURES  Input Voltage (Maximum Rating).............................. 1.7V to 6.0V (6.5V)  Operating Temperature Range ................................ −50C to 105C  Supply Current ......................................................... Typ. 1.0A (Except the current through CE pull-down circuit)  Standby Mode .......................................................... Typ. 0.1A  Dropout Voltage ....................................................... Typ. 0.25V (IOUT150mA 3.0V Output type)  Temperature-Drift Coefficient of Output Voltage ...... Typ. 100ppm/C  Line Regulation ........................................................ Typ. 0.05%/V  Output Voltage Accuracy.......................................... 2.0%  Output Voltage Range.............................................. 1.2V, 1.5V, 1.8V, 1.85V, 2.0V, 2.3V, 2.5V, 2.8V, 3.0V, 3.3V, 3.4V Contact our sales representatives for other voltages.  Package ................................................................... SOT-23-5, SON1612-6  Built-in Fold Back Protection Circuit ........................ Typ. 40mA (Current at short mode)  Recommended Ceramic Capacitor to IC .................. 0.1F or more APPLICATIONS  Industrial equipments such as FAs and smart meters  Equipments used under high-temperature conditions such as surveillance camera and vending machine  Equipments accompanied by self-heating such as motor and lighting 1 R1180x-Y NO.EA-340-220531 BLOCK DIAGRAMS R1180xxx1B VDD R1180xxx1C VOUT VDD VOUT Vref CE Vref Current Limit Current Limit GND GND SELECTION GUIDE The output voltage and CE pin polarity for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free R1180Nxx1-TR-YE SOT-23-5 3,000 pcs Yes Yes R1180Dxx1-TR-YE SON1612-6 4,000 pcs Yes Yes xx : The set output voltage (VSET) can be designated by 1.2V (12), 1.5V (15), 1.8V (18), 1.85V (1815), 2.0V (20), 2.3V (23), 2.5V (25), 2.8V (28), 3.0V (30), 3.3V (33), and 3.4V (34). * Contact our sales representatives for other voltages.  : CE pin polarity is options as follows. (B) "H" Active (C) without CE pin 2 R1180x-Y NO.EA-340-220531 PIN DESCRIPTIONS  SOT-23-5 5  SON1612-6 4 6 5 4 3 1 2 3 (Mark side) 1   2 SOT-23-5 Pin No Symbol Pin Description 1 VDD 2 GND 3 CE or NC 4 NC No Connection 5 VOUT Output pin Input Pin Ground Pin Chip Enable Pin or No Connection SON1612-6 Pin No Symbol Pin Description 1 VDD 2 GND Ground Pin 3 VOUT Output pin 4 NC No Connection 5 GND 6 CE or NC Input Pin Ground Pin Chip Enable Pin or No Connection 3 R1180x-Y NO.EA-340-220531 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 6.5 V VCE Input Voltage (CE Pin) 6.5 V VOUT Output Voltage 0.3 to VIN0.3 V IOUT Output Current 180 mA PD Power Dissipation*1 Tj Junction Temperature 50 to 150 C Storage Temperature Range 55 to 150 C Tstg SOT-23-5 Standard Land Pattern 525 SON1612-6 Standard Land Pattern 625 mW *1 For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum rating is not assured. RECOMMENDED OPERATING CONDITIONS Symbol Item Rating Unit VIN Input Voltage 1.7 to 6.0 V Ta Operating Temperature Range −50 to 105 °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 4 R1180x-Y NO.EA-340-220531 ELECTRICAL CHARACTERISTICS VIN=VSET.0V, CIN=1.0μF, COUT=0.1μF, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at −50C ≤ Ta ≤ 105C.  R1180xxx1B/C Symbol (Ta25C) Item Conditions Min. Typ. Max. 0.980 1.020 −50°C≤Ta≤105°C 0.965 1.035 Ta=25°C Unit VOUT Output Voltage 1A≤IOUT≤30mA IOUT Output Current VINVSET1.0V(VSET≥1.4V) VIN2.4V(VSET
R1180N231C-TR-YE 价格&库存
很抱歉,暂时无法提供与“R1180N231C-TR-YE”相匹配的价格&库存,您可以联系我们找货
R1180N231C-TR-YE
    • 1+2.12577
    • 200+0.82264
    • 500+0.79380
    • 1000+0.77944
    R1180N231C-TR-YE
    • 1+7.503301+0.97076
    • 10+5.3579810+0.69320
    • 25+4.8226125+0.62394
    • 100+4.23409100+0.54780
    • 250+3.95287250+0.51141
    • 500+3.78340500+0.48949
    • 1000+3.646231000+0.47174
    R1180N231C-TR-YE
    • 3000+3.471303000+0.44911
    • 6000+3.386886000+0.43819
    • 9000+3.344609000+0.43272
    • 15000+3.2977715000+0.42666
    • 21000+3.2704121000+0.42312
