RP170N501D-TR-FE
RP170N501D-TR-FE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 300mA SOT-23-5
RP170N501D-TR-FE 数据手册
∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x SERIES 300mA 10V INPUT LDO REGULATOR No.EA-205-200219 OUTLINE The RP170x is LDO regulator featuring 300mA output current. Because of the 10V maximum input voltage, RP170x can be used in 2 cell lithium-ion battery powered portable appliances and besides a portable equipment. The supply current is Typ. 23µA though an excellent response characteristics. The output voltage range from 1.2V is possible. The output voltage accuracy and temperature-drift coefficient of output voltage of the RP170x Series are excellent. RP170x has a fold-back protection circuit and a thermal shutdown circuit. Moreover, a standby mode with ultra low supply current can be realized with the chip enable function. SC-88A, SOT-23-5 and SOT-89-5 with high power dissipation packages are available. FEATURES • Supply Current ···················································· Typ. 23µA • Standby Mode ····················································· Typ. 0.1µA • Dropout Voltage ··················································· Typ. 0.20V (IOUT=100mA, VOUT=3.0V) Typ. 0.77V (IOUT=300mA, VOUT=2.8V) • Ripple Rejection ··················································· Typ. 70dB (f=1kHz) • Temperature-Drift Coefficient of Output Voltage··········· Typ. ±80ppm/°C • Line Regulation ···················································· Typ. 0.02%/V • Output Voltage Accuracy ········································· ±1.0% • Packages ··························································· SC-88A, SOT-23-5, SOT-89-5 • Input Voltage Range ············································· 2.6V to 10.0V • Output Voltage Range ············································ 1.2V to 6.5V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.) • • • • Built-in Fold Back Protection Circuit ···························Typ. 40mA (Current at short mode) Built-in Thermal Shutdown Circuit ···························· Shutdown Temperature at 165°C Built-in Constant Slope Circuit (Soft-start Function) Ceramic capacitors are recommended to be used with this IC ······ 1.0µF or more APPLICATIONS • • • • Power source for portable communication equipment. Power source for electrical appliances such as cameras, VCRs and camcorders. Power source for battery-powered equipment. Power source for home appliances. 1 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 SELECTION GUIDE The output voltage, auto discharge(1) function, and package for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free RP170Qxx2∗-TR-FE SC-88A 3,000 pcs Yes Yes RP170Nxx1∗-TR-FE SOT-23-5 3,000 pcs Yes Yes RP170Hxx1∗-T1-FE SOT-89-5 1,000 pcs Yes Yes xx : The output voltage can be designated in the range from 1.2V(12) to 6.5V(65) in 0.1V steps. The voltage in 0.05 V step is shown as follows. Example 1.25 V: RP170x12x∗5 ∗ : The auto discharge function at off state are options as follows. (B) without auto discharge function at off state (D) with auto discharge function at off state BLOCK DIAGRAMS RP170xxxxB VDD RP170xxxxD VOUT VDD Vref Vref Current Limit Thermal Shutdown CE (1)Auto-discharge VOUT Current Limit Thermal Shutdown GND CE GND function quickly lowers the output voltage to 0V by releasing the electrical charge accumulated in the external capacitor when the chip enable signal is switched from the active mode to the standby mode. 2 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 PIN CONFIGURATIONS • SC-88A 5 • SOT-23-5 5 4 (mark side) 1 2 • SOT-89-5 4 5 3 1 4 (mark side) 3 1 2 2 3 PIN DESCRIPTIONS • • • SC-88A Pin No Symbol Pin Description 1 CE Chip Enable Pin ("H" Active) 2 NC No Connection 3 GND Ground Pin 4 VOUT Output Pin 5 VDD Input Pin SOT-23-5 Pin No Symbol Pin Description 1 VDD Input Pin 2 GND Ground Pin 3 CE Chip Enable Pin ("H" Active) 4 NC No Connection 5 VOUT Output Pin SOT-89-5 Pin No Symbol Pin Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE Chip Enable Pin ("H" Active) 4 NC No Connection 5 VDD Input Pin 3 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 12 V VCE Input Voltage (CE Pin) 12 V VOUT Output Voltage −0.3 to VIN+0.3 V IOUT Output Current 330 mA SC-88A (Our Standard Test Land Pattern) PD Power Dissipation (1) SOT-23-5 (JEDEC STD. 51-7) SOT-89-5 (JEDEC STD. 51-7) 380 660 mW 2600 Tj Junction Temperature Range −40 to 125 °C Tstg Storage Temperature Range −55 to 125 °C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECCOMENDED OPERATING CONDITIONS Symbol Parameter Rating Unit VIN Input Voltage 2.6 to 10 V Ta Operating Temperature Range −40 to 85 °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such ratings by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1)Refer 4 to POWER DISSIPATION for detailed information ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 ELECTRICAL CHARACTERISTICS RP170xxxxB/D VIN =Set VOUT+1V, IOUT =1mA, unless otherwise noted. values indicate −40°C ≤ Ta ≤ 85°C, unless otherwise noted. Symbol Item Conditions Ta=25°C VOUT Output Voltage −40°C ≤ Ta ≤ 85°C IOUT VDIF ISS Istandby Dropout Voltage Min. Typ. Max. Unit VOUT > 1.5V ×0.99 ×1.01 V VOUT ≤ 1.5V −15 +15 mV VOUT > 1.5V ×0.974 ×1.023 V VOUT ≤ 1.5V −40 +35 mV Output Current ∆VOUT/∆IOUT Load Regulation Ta=25°C 300 0.1mA ≤ IOUT ≤ 300mA IOUT=300mA mA 10 70 1.2V ≤ VOUT < 1.3V 1.400 1.800 1.3V ≤ VOUT < 1.5V 1.350 1.750 1.5V ≤ VOUT < 1.8V 1.200 1.550 1.8V ≤ VOUT < 2.3V 0.980 1.300 2.3V ≤ VOUT < 3.0V 0.770 1.080 3.0V ≤ VOUT < 4.0V 0.600 0.850 4.0V ≤ VOUT ≤ 6.5V 0.500 0.750 mV V Supply Current IOUT=0mA 23 40 µA Standby Current VIN=10.0V, VCE=GND 0.1 1.0 µA Set VOUT+0.5V ≤ VIN ≤ 10.0V (In case that VOUT ≤ 2.1V, 2.6V ≤ VIN ≤ 10.0V) 0.02 0.2 %/V ∆VOUT/∆VIN Line Regulation RR Ripple Rejection f=1kHz, Ripple 0.2Vp-p, IOUT=30mA (In case that VOUT < 2.0V, VIN=3.0V) 70 dB ISC Short Current Limit VOUT=0V 40 mA IPD CE Pull-down Current 0.30 µA VCEH CE Input Voltage "H" VCEL CE Input Voltage "L" TTSD Thermal Shutdown Temperature Junction Temperature 165 °C TTSR Thermal Shutdown Released Temperature Junction Temperature 110 °C Output Noise BW=10Hz to 100kHz 100 µVrms Low Output Nch Tr. ON Resistance (of D version) VIN=7.0V VCE=0V 250 Ω en RLOW 1.7 V 0.8 V All of unit are tested and specified under load conditions such that Tj≈Ta=25°C except for Output Noise, Ripple Rejection and Thermal Shutdown. 5 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 Product-specific Electrical Characteristics The specifications surrounded by are guaranteed by design engineering at –40°C ≤ Ta ≤ 85°C. (Ta = 25°C) RP170xxxxB/D Product Name 6 VOUT [V] VOUT [V] (Ta = 25°C) (Ta = –40 to 85°C) MIN. TYP. MAX. MIN. TYP. MAX. RP170x12xx 1.185 1.2 1.215 1.160 1.2 1.235 RP170x12xx5 1.235 1.25 1.265 1.210 1.25 1.285 RP170x13xx 1.285 1.3 1.315 1.260 1.3 1.335 RP170x14xx 1.385 1.4 1.415 1.360 1.4 1.435 RP170x15xx 1.485 1.5 1.515 1.460 1.5 1.535 RP170x16xx 1.584 1.6 1.616 1.558 1.6 1.637 RP170x17xx 1.683 1.7 1.717 1.656 1.7 1.739 RP170x18xx 1.782 1.8 1.818 1.753 1.8 1.841 RP170x18xx5 1.832 1.85 1.869 1.802 1.85 1.893 RP170x19xx 1.881 1.9 1.919 1.851 1.9 1.944 RP170x20xx 1.980 2.0 2.020 1.948 2.0 2.046 RP170x21xx 2.079 2.1 2.121 2.045 2.1 2.148 RP170x22xx 2.178 2.2 2.222 2.143 2.2 2.251 RP170x23xx 2.277 2.3 2.323 2.240 2.3 2.353 RP170x24xx 2.376 2.4 2.424 2.338 2.4 2.455 RP170x25xx 2.475 2.5 2.525 2.435 2.5 2.558 RP170x26xx 2.574 2.6 2.626 2.532 2.6 2.660 RP170x27xx 2.673 2.7 2.727 2.630 2.7 2.762 RP170x28xx 2.772 2.8 2.828 2.727 2.8 2.864 RP170x28xx5 2.822 2.85 2.879 2.776 2.85 2.916 RP170x29xx 2.871 2.9 2.929 2.825 2.9 2.967 RP170x30xx 2.970 3.0 3.030 2.922 3.0 3.069 RP170x31xx 3.069 3.1 3.131 3.019 3.1 3.171 RP170x32xx 3.168 3.2 3.232 3.117 3.2 3.274 RP170x33xx 3.267 3.3 3.333 3.214 3.3 3.376 RP170x34xx 3.366 3.4 3.434 3.312 3.4 3.478 RP170x35xx 3.465 3.5 3.535 3.409 3.5 3.581 RP170x36xx 3.564 3.6 3.636 3.506 3.6 3.683 RP170x37xx 3.663 3.7 3.737 3.604 3.7 3.785 RP170x38xx 3.762 3.8 3.838 3.701 3.8 3.887 RP170x39xx 3.861 3.9 3.939 3.799 3.9 3.990 VDIF [V] TYP. MAX. 1.400 1.800 1.350 1.750 1.200 1.550 0.980 1.300 0.770 1.080 0.600 0.850 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 The specifications surrounded by are guaranteed by design engineering at –40°C ≤ Ta ≤ 85°C. (Ta = 25°C) RP170xxxxB/D Product Name VOUT [V] VOUT [V] (Ta = 25°C) (Ta = –40 to 85°C) MIN. TYP. MAX. MIN. TYP. MAX. RP170x40xx 3.960 4.0 4.040 3.896 4.0 4.092 RP170x41xx 4.059 4.1 4.141 3.993 4.1 4.194 RP170x42xx 4.158 4.2 4.242 4.091 4.2 4.297 RP170x43xx 4.257 4.3 4.343 4.188 4.3 4.399 RP170x44xx 4.356 4.4 4.444 4.286 4.4 4.501 RP170x45xx 4.455 4.5 4.545 4.383 4.5 4.604 RP170x46xx 4.554 4.6 4.646 4.480 4.6 4.706 RP170x47xx 4.653 4.7 4.747 4.578 4.7 4.808 RP170x48xx 4.752 4.8 4.848 4.675 4.8 4.910 RP170x49xx 4.851 4.9 4.949 4.773 4.9 5.013 RP170x50xx 4.950 5.0 5.050 4.870 5.0 5.115 RP170x51xx 5.049 5.1 5.151 4.967 5.1 5.217 RP170x52xx 5.148 5.2 5.252 5.065 5.2 5.320 RP170x53xx 5.247 5.3 5.353 5.162 5.3 5.422 RP170x54xx 5.346 5.4 5.454 5.260 5.4 5.524 RP170x55xx 5.445 5.5 5.555 5.357 5.5 5.627 RP170x56xx 5.544 5.6 5.656 5.454 5.6 5.729 RP170x57xx 5.643 5.7 5.757 5.552 5.7 5.831 RP170x58xx 5.742 5.8 5.858 5.649 5.8 5.933 RP170x59xx 5.841 5.9 5.959 5.747 5.9 6.036 RP170x60xx 5.940 6.0 6.060 5.844 6.0 6.138 RP170x61xx 6.039 6.1 6.161 5.941 6.1 6.240 RP170x62xx 6.138 6.2 6.262 6.039 6.2 6.343 RP170x63xx 6.237 6.3 6.363 6.136 6.3 6.445 RP170x64xx 6.336 6.4 6.464 6.234 6.4 6.547 RP170x65xx 6.435 6.5 6.565 6.331 6.5 6.650 VDIF [V] TYP. MAX. 0.500 0.750 7 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 TYPICAL APPLICATION VDD C1 VOUT RP170x CE VOUT C2 GND CE Control (External Components) C2 1.0µF MURATA: GRM155B31A105KE15 Phase Compensation In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor C2 with 1.0µF or more and good ESR (Equivalent Series Resistance). (Note: If additional ceramic capacitors are connected with parallel to the output pin with an output capacitor for phase compensation, the operation might be unstable. Because of this, test these ICs with as same external components as ones to be used on the PCB.) PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor C1 with a capacitance value as much as 1.0µF or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor C2, as close as possible to the ICs, and make wiring as short as possible. 8 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 ESR vs. Output Current Ceramic type output capacitor is recommended for this series; however, the other output capacitors with low ESR also can be used. The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The conditions when the white noise level is under 40µV (Avg.) are marked as the hatched area in the graph. Measurement conditions Frequency Band : 10Hz to 2MHz Temperature : −40°C to 85°C C1, C2 : Ceramic 1.0µF (Murata GRM155B31A105KE) RP170x12xx RP170x30xx RP170x60xx RP170x65xx 9 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 TEST CIRCUITS VDD VOUT RP170x Series C1 CE C2 V VOUT IOUT GND C1=Ceramic 1.0µF C2=Ceramic 1.0µF Basic Test Circuit VDD A RP170x Series C1 ISS VOUT VOUT C2 GND CE C1=Ceramic 1.0µF C2=Ceramic 1.0µF Test Circuit for Supply Current Pulse Generator VDD VOUT RP170x Series P.G. CE C2 IOUT GND C2=Ceramic 1.0µF Test Circuit for Ripple Rejection VDD C1 RP170x Series CE VOUT VOUT C2 GND IOUTa IOUTb C1=Ceramic 1.0µF C2=Ceramic 1.0µF Test Circuit for Load Transient Response 10 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 TYPICAL CHARACTERISTICS Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1) Output Voltage vs. Output Current (Ta=25°C) RP170x12xx 1.4 3.0 Output Voltage V OUT (V) 1.2 Output Voltage V OUT(V) RP170x30xx 3.5 1.0 0.8 0.6 0.4 VIN=2.6V VIN=3.0V 0.2 2.5 2.0 1.5 1.0 VIN=3.3V VIN=3.6V 0.5 VIN=4.0V VIN=4.0V VIN=5.0V 0.0 0.0 0 100 200 300 400 500 600 0 100 Output Current IOUT (mA) 200 300 400 500 600 Output Current IOUT (mA) RP170x60xx 7.0 Output Voltage V OUT (V) 6.0 5.0 4.0 3.0 VIN=6.3V 2.0 VIN=6.6V VIN=7.0V 1.0 VIN=8.0V 0.0 0 100 200 300 400 500 600 Output Current IOUT (mA) 2) Output Voltage vs. Input Voltage (Ta=25°C) RP170x12xx 1.4 3.5 1.2 3.0 1.0 0.8 IOUT=1mA 0.6 IOUT=10mA 0.4 IOUT=50mA IOUT=150mA 0.2 RP170x30xx 4.0 Output Voltage V OUT(V) Output Voltage V OUT(V) 1.6 2.5 2.0 IOUT=1mA 1.5 IOUT=10mA 1.0 IOUT=50mA IOUT=150mA 0.5 IOUT=300mA 0.0 IOUT=300mA 0.0 0 1 2 3 4 5 6 7 Input Voltage VIN (V) 8 9 10 0 1 2 3 4 5 6 7 8 9 10 Input Voltage VIN (V) 11 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 RP170x60xx 7.0 Output Voltage VOUT(V) 6.0 5.0 4.0 3.0 IOUT=1mA IOUT=10mA 2.0 IOUT=50mA IOUT=150mA 1.0 IOUT=300mA 0.0 0 1 2 3 4 5 6 7 8 9 10 Input Voltage VIN (V) 3) Supply Current vs. Input Voltage (Ta=25°C) RP170x12xx 35 35 30 30 25 20 15 10 5 20 15 10 0 0 1 2 3 4 5 6 Input Voltage VIN (V) RP170x60xx 35 30 25 20 15 10 5 0 0 1 2 3 4 5 6 7 Input Voltage VIN (V) 0 1 2 3 4 Input Voltage VIN (V) 40 Supply Current Iss (μA) 25 5 0 12 RP170x30xx 40 Supply Current Iss (μA) Supply Current Iss (μA) 40 8 9 10 5 6 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 4) Supply Current vs. Output Current (Ta=25°C) RP170x 160 Supply Current Iss (μA) 140 120 100 80 60 40 20 0 0 50 100 150 200 250 300 Output Current IOUT (mA) 5) Output Voltage vs. Temperature RP170x12xx RP170x30xx 3.10 1.24 3.08 1.23 3.06 Output Voltage V OUT(V) Output Voltage V OUT(V) 1.25 1.22 1.21 1.20 1.19 1.18 1.17 1.16 3.04 3.02 3.00 2.98 2.96 2.94 2.92 1.15 -50 -25 0 25 50 75 100 2.90 -50 -25 0 25 50 75 100 Temperature Topt (°C) Temperature Topt (°C) RP170x60xx 6.20 6.16 Output Voltage V OUT(V) 6.12 6.08 6.04 6.00 5.96 5.92 5.88 5.84 5.80 -50 -25 0 25 50 75 100 Temperature Topt (°C) 13 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 6) Supply Current vs. Temperature RP170x12xx RP170x30xx 40 35 35 30 30 Supply Current Iss (μA) Supply Current Iss (μA) 40 25 20 15 10 5 25 20 15 10 5 0 0 -50 -25 0 25 50 75 100 -50 -25 Temperature Topt (°C) 0 25 50 75 100 250 300 Temperature Topt (°C) RP170x60xx 40 35 Supply Current Iss (μA) 30 25 20 15 10 5 0 -50 -25 0 25 50 75 100 Temperature Topt (°C) 7) Dropout Voltage vs. Output Current RP170x30xx 0.8 1.4 0.7 1.2 0.6 Dropout Voltage VDIF (V) Dropout Voltage VDIF (V) RP170x12xx 1.6 1.0 0.8 85°C 0.6 25°C 0.4 -40°C 0.2 25°C 0.5 -40°C 0.4 0.3 0.2 0.1 0.0 0 0 50 100 150 200 Output Current IOUT (mA) 14 85°C 250 300 0 50 100 150 200 Output Current IOUT (mA) ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 RP170x60xx 0.8 Dropout Voltage VDIF (V) 0.7 85°C 0.6 25°C -40°C 0.5 0.4 0.3 0.2 0.1 0 0 50 100 150 200 250 300 Output Current IOUT (mA) 8) Dropout Voltage vs. Set Output Voltage (Ta=25°C) RP170x 9) Minimum Operating Voltage RP170x12xx Hatched area is available for 1.2V output 15 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 10) Ripple Rejection vs. Input Bias Voltage (C1=none, C2=Ceramic 1.0µF, Ripple=0.2Vp-p, Ta=25°C) RP170x30xx IOUT=1mA 90 90 80 80 70 60 50 40 30 f=300Hz 20 f=1kHz f=10kHz 10 RP170x30xx 100 Ripple Rejection RR (dB) Ripple Rejection RR (dB) 100 IOUT=30mA 70 60 50 40 30 f=100Hz f=1kHz f=10kHz f=100kHz 20 10 f=100kHz 0 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 5.0 0 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 5.0 Input Voltage VIN (V) Input Voltage VIN (V) RP170x30xx IOUT=100mA 100 90 Ripple Rejection RR (dB) 80 70 60 50 40 30 f=300Hz f=1kHz f=10kHz f=100kHz 20 10 0 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 5.0 Input Voltage VIN (V) 11) Ripple Rejection vs. Frequency (C1=none, C2=Ceramic 1.0µF, Ta=25°C) RP170x12xx RP170x12xx VIN =2.6VDC+0.2Vp-p 120 110 90 80 90 Ripple Rejection RR (dB) Ripple Rejection RR (dB) 100 80 70 60 50 IOUT=1mA 40 IOUT=30mA 70 60 50 40 IOUT=1mA 30 IOUT=30mA 20 20 IOUT=100mA 10 10 30 IOUT=100mA 0 0 0.1 1 10 Frequency f (kHz) 16 VIN =3.0VDC+0.2Vp-p 100 100 0.1 1 10 Frequency f (kHz) 100 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 RP170x30xx RP170x30xx 110 90 100 VIN =5.0VDC+0.2Vp-p 90 80 Ripple Rejection RR (dB) Ripple Rejection RR (dB) VIN =4.0VDC+0.2Vp-p 100 70 60 50 40 IOUT=1mA 30 IOUT=30mA 20 IOUT=100mA 80 70 60 50 40 IOUT=1mA 30 IOUT=30mA IOUT=100mA 20 10 10 0 0 0.1 1 10 0.1 100 1 10 Frequency f (kHz) Frequency f (kHz) RP170x60xx RP170x60xx VIN =7.0VDC+0.2Vp-p 100 VIN =8.0VDC+0.2Vp-p 100 90 90 Ripple Rejection RR (dB) 80 Ripple Rejection RR (dB) 100 70 60 50 40 IOUT=1mA 30 IOUT=30mA 70 60 50 40 IOUT=1mA 30 IOUT=30mA 20 IOUT=100mA 20 80 IOUT=100mA 10 10 0 0 0.1 0.1 1 10 Frequency f (kHz) 1 10 Frequency f (kHz) 100 100 12) Input Transient Response (C1=none, IOUT=30mA, tr=tf=5µs, Ta=25°C) RP170x12xx 1.28 1.32 4 1.30 3 Input Voltage 1.26 2 1.24 1 1.22 0 1.20 -1 Output Voltage 1.18 1.16 0 10 20 30 40 50 60 Time t (μs) 70 80 90 100 C2=Ceramic 2.2μF 5 4 1.28 3 Input Voltage 1.26 2 1.24 1 1.22 0 1.20 -2 1.18 -3 1.16 -1 Output Voltage Input Voltage VIN (V) Output Voltage VOUT (V) 1.30 5 Output Voltage VOUT(V) 1.32 RP170x12xx Input Voltage VIN (V) C2=Ceramic 1.0μF -2 -3 0 10 20 30 40 50 60 70 80 90 100 Time t (μs) 17 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 RP170x30xx 5 3.10 4 Input Voltage 3 3.04 2 3.02 1 3.00 0 Output Voltage 2.98 2.96 0 10 20 30 40 50 60 70 5 3.08 4 Input Voltage 3.06 3 3.04 2 3.02 1 3.00 0 Output Voltage -1 2.98 -2 2.96 -1 -2 0 80 90 100 10 20 30 40 RP170x60xx 6.12 8 6.10 7 Input Voltage 6.06 6 6.04 5 6.02 4 6.00 3 Output Voltage 5.96 10 20 30 40 50 60 70 80 Output Voltage VOUT(V) 6.08 9 Input Voltage VIN (V) Output Voltage VOUT (V) 6.10 0 70 80 90 100 RP170x60xx C2=Ceramic 1.0μF 5.98 50 60 Time t (μs) Time t (μs) 6.12 6 C2=Ceramic 2.2μF 9 8 6.08 7 Input Voltage 6.06 6 6.04 5 6.02 4 6.00 2 5.98 1 5.96 90 100 3 Output Voltage Input Voltage VIN (V) 3.06 C2=Ceramic 2.2μF Input Voltage VIN (V) 3.12 Input Voltage VIN (V) 3.08 6 Output Voltage VOUT(V) 3.10 Output Voltage VOUT (V) RP170x30xx C2=Ceramic 1.0μF 3.12 2 1 0 10 20 30 Time t (μs) 40 50 60 70 80 90 100 Time t (μs) 13) Load Transient Response (C1=Ceramic 1.0µF, tr=tf=500ns, Ta=25°C) 1.7 100 1.7 30 1.6 1.5 50 Output Current : 50mA↔100mA 0 C2=1.0μF 1.4 C2=2.2μF -50 1.3 -100 1.2 -150 Output Voltage 1.0 -200 -250 -20 -10 0 10 20 30 40 50 60 70 80 Time t (μs) 1.6 0 Output Current : 0mA↔30mA 1.5 -30 C2=1.0μF 1.4 -60 C2=2.2μF 1.3 -90 1.2 -120 Output Voltage 1.1 -150 1.0 -180 -20 -10 0 10 20 30 40 Time t (μs) 50 60 70 80 Output Current IOUT(mA) 60 Output Voltage VOUT(V) 1.8 1.1 18 RP170x12xx 150 Output Current IOUT(mA) Output Voltage VOUT(V) RP170x12xx 1.8 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x 3.6 600 2.2 150 3.2 300 2.0 0 Output Current : 1mA↔150mA 1.8 -150 C2=1.0μF -300 C2=2.2μF -450 1.2 -600 Output Voltage 1.0 0.8 -40 -20 0 Output Current : 1mA↔300mA -300 2.4 C2=1.0μF 2 1.6 -1200 -750 0.8 -900 0.4 20 40 60 80 100 120 140 160 Output Voltage -1500 -1800 -40 -20 0 20 40 60 80 100 120 140 160 Time t (μs) RP170x30xx RP170x30xx 150 3.6 60 3.5 100 3.5 30 3.4 50 Output Current : 50mA↔100mA 3.3 0 C2=1.0μF 3.2 -50 C2=2.2μF 3.1 -100 3.0 -150 Output Voltage 2.9 2.8 -20 -10 0 Output Voltage VOUT(V) 3.6 Output Current IOUT(mA) Output Voltage VOUT(V) -900 1.2 Time t (μs) 3.4 0 Output Current : 0mA↔30mA 3.3 -30 C2=1.0μF 3.2 -60 C2=2.2μF 3.1 -90 3.0 -200 2.9 -250 2.8 -120 Output Voltage 10 20 30 40 50 60 70 80 -150 -180 -20 -10 0 10 20 30 40 50 60 70 80 Time t (μs) Time t (μs) RP170x30xx RP170x30xx 300 7.8 600 5.0 150 7.0 300 4.6 0 Output Current : 1mA↔150mA 4.2 -150 C2=1.0μF 3.8 C2=2.2μF 3.4 3.0 -300 -450 -600 Output Voltage 2.6 2.2 -40 -20 0 20 40 60 80 100 120 140 160 Time t (μs) Output Voltage VOUT(V) 5.4 Output Current IOUT(mA) Output Voltage VOUT(V) -600 C2=2.2μF Output Current IOUT(mA) 1.4 0 2.8 6.2 0 Output Current : 1mA↔300mA 5.4 C2=1.0μF 4.6 C2=2.2μF 3.8 3.0 -750 2.2 -900 1.4 -300 -600 -900 -1200 Output Voltage Output Current IOUT(mA) 1.6 Output Voltage VOUT(V) 300 Output Current IOUT(mA) Output Voltage VOUT(V) 2.4 Output Current IOUT(mA) No.EA-205-200219 RP170x12xx RP170x12xx -1500 -1800 -40 -20 0 20 40 60 80 100 120 140 160 Time t (μs) 19 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 60 6.5 100 6.5 30 6.4 50 6.3 C2=1.0μF 6.2 0 -50 C2=2.2μF 6.1 -100 6.0 -150 5.9 Output Voltage 5.8 -20 -10 0 6.4 0 Output Current : 0mA↔30mA 6.3 C2=1.0μF 6.2 6.1 -90 6.0 -120 -200 5.9 -250 5.8 Output Voltage -150 -180 -20 -10 10 20 30 40 50 60 70 80 0 10 20 30 40 50 60 70 80 Time t (μs) RP170x60xx RP170x60xx 300 10.8 600 8.0 150 10.0 300 7.6 0 Output Current : 1mA↔150mA 7.2 C2=1.0μF 6.8 -150 -300 C2=2.2μF 6.4 -450 6.0 -600 Output Voltage 5.6 5.2 -40 -20 0 20 40 60 80 100 120 140 160 Time t (μs) Output Voltage VOUT(V) 8.4 Output Current IOUT(mA) Output Voltage VOUT(V) -60 C2=2.2μF Time t (μs) 20 -30 9.2 8.4 0 Output Current : 1mA↔300mA C2=1.0μF 7.6 -300 -600 C2=2.2μF 6.8 -900 6.0 -1200 -750 5.2 -900 4.4 Output Voltage -1500 -1800 -40 -20 0 20 40 60 80 100 120 140 160 Time t (μs) Output Current IOUT(mA) Output Current : 50mA↔100mA Output Voltage VOUT(V) 6.6 Output Current IOUT(mA) RP170x60xx 150 Output Current IOUT(mA) Output Voltage VOUT(V) RP170x60xx 6.6 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 14) Turn On Speed with CE pin (C1=Ceramic 1.0µF, Ta=25°C) RP170x12xx RP170x30xx VIN=2.6V, C2=Ceramic1.0μF 2.5 900 5 800 4 VIN=4.0V, C2=Ceramic1.0μF 900 1.0 600 IOUT=0mA 0.5 500 IOUT=1mA IOUT=30mA 0.0 400 IOUT=300mA -0.5 300 -1.0 Inrush Current 200 -1.5 100 -2.0 0 -2.5 -50 0 50 100 150 200 250 -100 300 800 Output Voltage 3 700 CE Input Voltage 2 600 IOUT=0mA 1 500 IOUT=1mA IOUT=30mA 0 400 IOUT=300mA -1 300 -2 Inrush Current 200 -3 100 -4 0 -5 -50 0 50 100 150 200 250 Inrush Current Irush (mA) 700 Output Voltage Inrush Current Irush (mA) CE Input Voltage VCE / Output Voltage VOUT(V) 1.5 CE Input Voltage VCE / Output Voltage VOUT(V) CE Input Voltage 2.0 -100 300 Time t (μs) Time t (μs) RP170x60xx VIN=7.0V, C2=Ceramic1.0μF 10 800 Output Voltage 6 700 4 600 CE Input Voltage 2 500 IOUT=0mA IOUT=1mA 0 400 IOUT=30mA IOUT=300mA -2 300 Inrush Current -4 200 -6 100 -8 0 -10 -50 0 50 100 150 200 250 Inrush Current Irush (mA) CE Input Voltage VCE / Output Voltage VOUT(V) 8 900 -100 300 Time t (μs) 21 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 RP170x12xx RP170x30xx VIN=2.6V, IOUT=1mA 2.5 1800 5 1600 4 VIN=4.0V, IOUT=1mA 1800 1 1200 C2=1.0μF 0.5 1000 C2=2.2μF C2=4.7μF 0 800 C2=10μF -0.5 600 -1 400 Inrush Current -1.5 200 -2 -2.5 -50 0 0 50 100 150 200 250 -200 300 VIN=7.0V, IOUT=1mA 1600 Output Voltage 6 1400 4 1200 CE Input Voltage 2 1000 C2=1.0μF C2=2.2μF C2=4.7μF C2=10μF 800 -2 600 Inrush Current -4 400 -6 200 -8 0 -10 -50 0 50 100 150 Time t (μs) 22 1800 200 250 -200 300 Inrush Current Irush (mA) CE Input Voltage VCE / Output Voltage VOUT(V) 8 0 1400 CE Input Voltage 2 1200 C2=1.0μF 1 1000 C2=2.2μF C2=4.7μF 0 800 C2=10μF -1 600 -2 400 Inrush Current -3 200 -4 0 0 50 100 150 Time t (μs) RP170x60xx 10 3 -5 -50 Time t (μs) 1600 Output Voltage 200 250 -200 300 Inrush Current Irush (mA) 1400 Output Voltage Inrush Current Irush (mA) CE Input Voltage VCE / Output Voltage VOUT(V) 1.5 CE Input Voltage VCE / Output Voltage VOUT(V) CE Input Voltage 2 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 RP170x30xx IOUT=1mA, C2=Ceramic1.0μF 2.5 900 5 800 4 700 Output Voltage 1.0 600 VIN=2.6V 0.5 500 VIN=4V VIN=10V 0.0 400 -0.5 300 -1.0 200 Inrush Current -1.5 100 -2.0 0 -2.5 -100 300 -50 0 50 100 150 200 250 Inrush Current Irush (mA) CE Input Voltage VCE / Output Voltage VOUT(V) 1.5 CE Input Voltage VCE / Output Voltage VOUT(V) CE Input Voltage 2.0 IOUT=1mA, C2=Ceramic1.0μF 900 800 Output Voltage 3 700 CE Input Voltage 2 600 1 VIN=4V 500 VIN=6V 0 VIN=10V 400 -1 300 -2 200 Inrush Current Irush (mA) RP170x12xx Inrush Current -3 100 -4 0 -5 -50 0 50 100 150 200 250 -100 300 Time t (μs) Time t (μs) RP170x60xx IOUT=1mA, C2=Ceramic1.0μF 10 900 800 Output Voltage 6 700 4 600 CE Input Voltage 2 500 0 VIN=7V 400 VIN=8V -2 VIN=10V -4 300 Inrush Current Irush (mA) CE Input Voltage VCE / Output Voltage VOUT(V) 8 200 Inrush Current -6 100 -8 0 -10 -50 0 50 100 150 200 250 -100 300 Time t (μs) 23 ∗ RP170Q (SC-88A) is the discontinued product as of April, 2016. RP170x No.EA-205-200219 15) Turn Off Speed with CE pin (D Version) (C1=Ceramic 1.0µF, Ta=25°C) 4 6 2 5 CE Input Voltage 1.6 0 IOUT=0mA 1.2 -2 IOUT=1mA 0.8 -4 IOUT=30mA IOUT=300mA 0.4 -6 0.0 -8 VIN=4.0V 2 CE Input Voltage 4 0 3 IOUT=1mA 2 IOUT=300mA 1 1.0 1.5 2.0 -8 -1 2.5 -0.5 Time t (ms) RP170x601D VIN=7.0V 4 2 CE Input Voltage 8 0 -2 IOUT=0mA IOUT=1mA 4 -4 IOUT=30mA IOUT=300mA 2 -6 0 -8 Output Voltage -2 -0.5 -10 0.0 0.5 1.0 1.5 Time t (ms) 24 2.0 2.5 CE Input Voltage VCE (V) Output Voltage VOUT(V) 10 6 -10 0.0 0.5 1.0 Time t (ms) 12 -6 0 -10 0.5 -4 IOUT=30mA Output Voltage -0.4 0.0 -2 IOUT=0mA Output Voltage -0.5 4 1.5 2.0 2.5 CE Input Voltage VCE (V) Output Voltage VOUT(V) 2.0 RP170x301D Output Voltage VOUT(V) 2.4 VIN=2.6V CE Input Voltage VCE (V) RP170x121D POWER DISSIPATION SC-88A Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following conditions are used in this measurement. Measurement Conditions Item Standard Test Land Pattern Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Double-Sided Board) Board Dimensions 40 mm × 40 mm × 1.6 mm Top Side: Approx. 50% Copper Ratio Bottom Side: Approx. 50% φ 0.5 mm × 44 pcs Through-holes Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Standard Test Land Pattern Power Dissipation 380 mW Thermal Resistance (θja) θja = 263°C/W Thermal Characterization Parameter (ψjt) ψjt = 75°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 600 40 475 400 380 300 40 Power Dissipation (mW) 500 200 100 0 0 25 50 75 85 100 125 Ambient Temperature (°C) 150 Power Dissipation vs. Ambient Temperature Measurement Board Pattern The above graph shows the power dissipation of the package at Tjmax = 125°C and Tjmax = 150°C. Operating the device in the hatched range might have a negative influence on its lifetime. The total hours of use and the total years of use must be limited as follows: Total Hours of Use Total Years of Use (4 hours/day) 13,000 hours 9 years i PACKAGE DIMENSIONS SC-88A Ver. A SC-88A Package Dimensions i POWER DISSIPATION SOT-23-5 Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Board Material Mounting on Board (Wind Velocity = 0 m/s) Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square φ 0.3 mm × 7 pcs Copper Ratio Through-holes Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 660 mW Thermal Resistance (θja) θja = 150°C/W Thermal Characterization Parameter (ψjt) ψjt = 51°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 1000 900 830 Power Dissipation (mW) 800 700 600 660 500 400 300 200 100 0 0 25 50 75 85 100 125 Ambient Temperature (°C) 150 Power Dissipation vs. Ambient Temperature Measurement Board Pattern The above graph shows the power dissipation of the package at Tjmax = 125°C and Tjmax = 150°C. Operating the device in the hatched range might have a negative influence on its lifetime. The total hours of use and the total years of use must be limited as follows: Total Hours of Use Total Years of Use (4 hours/day) 13,000 hours 9 years i SOT-23-5 PACKAGE DIMENSIONS Ver. A 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 1 2 0~0.1 0.2min. +0.2 1.6-0.1 5 2.8±0.3 (0.95) 3 0.4±0.1 +0.1 0.15-0.05 SOT-23-5 Package Dimensions i POWER DISSIPATION SOT-89-5 Ver. A The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Environment Board Material Board Dimensions Copper Ratio Through-holes Measurement Conditions Mounting on Board (Wind Velocity = 0 m/s) Glass Cloth Epoxy Plastic (Four-Layer Board) 76.2 mm × 114.3 mm × 0.8 mm Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square φ 0.3 mm × 13 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation Thermal Resistance (θja) Thermal Characterization Parameter (ψjt) 2600 mW θja = 38°C/W ψjt = 13°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 4000 Power Dissipation (mW) 3500 3200 3000 2200 2500 2600 2000 1500 1000 500 0 0 25 50 75 85 100 125 150 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern The above graph shows the power dissipation of the package at Tjmax = 125°C and Tjmax = 150°C. Operating the device in the hatched range might have a negative influence on its lifetime. The total hours of use and the total years of use must be limited as follows: Total Hours of Use Total Years of Use (4 hours/day) 13,000 hours 9 years i SOT-89-5 PACKAGE DIMENSIONS Ver. A 4.5±0.1 1.5±0.1 0.4±0.3 2 5 4.35±0.1 φ1.0 1 4 4 2.5±0.1 1.00±0.2 5 0.4±0.1 0.3±0.2 0.42±0.1 0.1 S 3 0.4±0.1 3 2 1 0.3±0.2 1.6±0.2 S 0.42±0.1 0.42±0.1 0.47±0.1 1.5±0.1 1.5±0.1 SOT-89-5 Package Dimensions i 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP170N501D-TR-FE 价格&库存
很抱歉,暂时无法提供与“RP170N501D-TR-FE”相匹配的价格&库存,您可以联系我们找货
RP170N501D-TR-FE
  • 1+3.979571+0.51369
  • 10+2.7685910+0.35737
  • 25+2.4664825+0.31838
  • 100+2.13827100+0.27601
  • 250+1.98097250+0.25571
  • 500+1.88632500+0.24349
  • 1000+1.808191000+0.23341
库存:6936
RP170N501D-TR-FE
    • 5+0.90105
    • 50+0.71442
    • 150+0.62111
    • 500+0.55113
    • 3000+0.49508
    库存:2919
    RP170N501D-TR-FE
    • 3000+1.711763000+0.22096
    • 6000+1.664576000+0.21487
    • 9000+1.640929000+0.21181
    • 15000+1.6147415000+0.20843
    • 21000+1.5994321000+0.20646
    • 30000+1.5847030000+0.20456
    库存:6936
