R1114Q331A-TR-FE
R1114Q331A-TR-FE
    NISSHINBO(日清纺)
    SC-82A
    PMIC - 稳压器 - 线性 正 固定 1 输出 150mA SC-82AB
R1114Q331A-TR-FE 数据手册
R1114x SERIES LOW NOISE 150mA LDO REGULATOR NO.EA-094-111026 OUTLINE The R1114x Series are CMOS-based voltage regulator ICs with high output voltage accuracy, low supply current, low ON-resistance, and high ripple rejection. Each of these ICs consists of a voltage reference unit, an error amplifier, resistor-net for voltage setting, a current limit circuit, and a chip enable circuit. These ICs perform with low dropout voltage and a chip enable function. The line transient response and load transient response of the R1114x Series are excellent, thus these ICs are very suitable for the power supply for hand-held communication equipment. The output voltage of these ICs is fixed with high accuracy. Since the packages for these ICs are SOT-23-5, SC-82AB, and SON1612-6 therefore high density mounting of the ICs on boards is possible. FEATURES • • • • • • • • • • • Supply Current ..................................................................... Typ. 75μA Standby Mode ...................................................................... Typ. 0.1μA Dropout Voltage ................................................................... Typ. 0.22V (IOUT=150mA 3.0V Output type) Ripple Rejection................................................................... Typ. 70dB (f=1kHz 3.0V Output type) Typ. 60dB (f=10kHz) Temperature-Drift Coefficient of Output Voltage .................. Typ. ±100ppm/°C Line Regulation .................................................................... Typ. 0.02%/V Output Voltage Range.......................................................... 1.5V to 4.0V (0.1V steps) (For other voltages, please refer to MARK INFORMATIONS.) Output Voltage Accuracy...................................................... ±2.0% Packages ............................................................................ SON1612-6, SC-82AB, SOT-23-5 Built-in Fold Back Protection Circuit .................................... Typ. 40mA (Current at short mode) Ceramic capacitors are recommended to be used with this IC ... CIN=COUT=1μF (VOUT = 2.5V) APPLICATIONS • Power source for portable communication equipment. • Power source for electrical appliances such as cameras, VCRs and camcorders. • Power source for battery-powered equipment. 1 R1114x BLOCK DIAGRAMS R1114xxx1A 1 R1114xxx1B 5 VOUT VDD VOUT VDD + Vref Vref Current Limit CE 3 CE R1114xxx1D VOUT VDD + Vref Current Limit CE 2 Current Limit GND 2 GND GND R1114x SELECTION GUIDE The output voltage, auto discharge function, package, and the taping type, etc. for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free R1114Dxx1∗-TR-FE SON1612-6 4,000 pcs Yes Yes R1114Qxx1∗-TR-FE SC-82AB 3,000 pcs Yes Yes R1114Nxx1∗-TR-FE SOT-23-5 3,000 pcs Yes Yes xx : The output voltage can be designated in the range from 1.5V(15) to 4.0V(40) in 0.1V steps. (For other voltages, please refer to MARK INFORMATIONS.) ∗ : CE pin polarity and auto discharge function at off state are options as follows. (A) "L" active, without auto discharge function at off state (B) "H" active, without auto discharge function at off state (D) "H" active, with auto discharge function at off state 3 R1114x PIN CONFIGURATION z SON1612-6 z SC-82AB 6 4 5 4 z SOT-23-5 3 5 (mark side) 1 2 1 3 (mark side) 2 1 PIN DESCRIPTIONS • • • 4 R1114D Pin No. Symbol 1 VDD 2 GND Ground Pin 3 VOUT Output pin 4 NC No Connection 5 GND 6 CE or CE Description Input Pin Ground Pin Chip Enable Pin R1114Q Pin No. Symbol 1 CE or CE 2 GND Ground Pin 3 VOUT Output pin 4 VDD Input Pin Description Chip Enable Pin R1114N Pin No. Symbol 1 VDD Description 2 GND 3 CE or CE Chip Enable Pin 4 NC No Connection 5 VOUT Output pin Input Pin Ground Pin 4 2 3 R1114x ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit VIN Input Voltage 6.5 V VCE Input Voltage ( CE or CE Pin) 6.5 V VOUT Output Voltage −0.3~VIN+0.3 V IOUT Output Current 200 mA Power Dissipation (SON1612-6) ∗ PD Power Dissipation (SC-82AB) ∗ Power Dissipation (SOT-23-5) ∗ 500 380 mW 420 Topt Operating Temperature Range −40~85 °C Tstg Storage Temperature Range −55~125 °C ∗) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 5 R1114x ELECTRICAL CHARACTERISTICS • R1114xxx1A Topt=25°C Symbol Conditions VOUT Output Voltage VIN = Set VOUT+1V 1mA < = IOUT < = 30mA IOUT Output Current VIN−VOUT = 1.0V VDIF Dropout Voltage ISS Supply Current VIN = Set VOUT+1V, IOUT = 0mA Istandby Supply Current (Standby) ΔVOUT/ΔVIN Line Regulation VIN = Set VOUT+1V VCE = VDD VOUT > 1.7V, Set VOUT+0.5V < = VIN < = 6.0V < (VOUT = 1.7V, 2.2V ≤ VIN < = 6.0V) IOUT = 30mA Ripple Rejection VIN Input Voltage ×0.980 f=1kHz f=10kHz Ripple 0.5Vp−p VOUT > 1.7V, VIN−VOUT = 1.0V VOUT < = 1.7, VIN−VOUT = 1.2V IOUT = 30mA ×1.020 Unit V mA 75 95 μA 0.1 1.0 μA 0.02 0.10 %/V dB 2.0 IOUT = 30mA −40°C < = Topt ISC Short Current Limit VOUT = 0V RPU CE Pull-up Resistance 0.7 VCEH CE Input Voltage “H” VCEL CE Input Voltage “L” Output Noise Max. 70 60 Output Voltage Temperature Coefficient en Typ. VIN = Set VOUT+1V 22 40 mV 1mA < = IOUT < = 150mA Refer to the ELECTRICAL CHARACTERISTICS by OUTPUT VOLTAGE Load Regulation RR Min. 150 ΔVOUT/ΔIOUT ΔVOUT/ ΔTopt 6 Item < = 85°C BW = 10Hz to 100kHz 6.0 V ±100 ppm /°C 40 mA 2.0 8.0 MΩ 1.5 6.0 V 0.0 0.3 V 30 μVrms R1114x • R1114xxx1B/D Topt=25°C Symbol Item Conditions VOUT Output Voltage VIN = Set VOUT+1V 1mA < = IOUT < = 30mA IOUT Output Current VIN−VOUT = 1.0V ΔVOUT/ΔIOUT Load Regulation VDIF Dropout Voltage ISS Supply Current Istandby ΔVOUT/ΔVIN Supply Current (Standby) Line Regulation RR Ripple Rejection VIN Input Voltage ΔVOUT/ ΔTopt Min. ×0.980 Unit ×1.020 V mA VIN = Set VOUT+1V 22 40 mV 1mA < = IOUT < = 150mA Refer to the ELECTRICAL CHARACTERISTICS by OUTPUT VOLTAGE VIN = Set VOUT+1V, IOUT = 0mA VIN = Set VOUT+1V VCE = GND VOUT > 1.7V, Set VOUT+0.5V < = VIN < = 6.0V (VOUT < = 1.7V, 2.2V ≤ VIN < = 6.0V) IOUT = 30mA f=1kHz f=10kHz Ripple 0.5Vp−p VOUT > 1.7V, VIN−VOUT = 1.0V VOUT < = 1.7, VIN−VOUT = 1.2V IOUT = 30mA 75 95 μA 0.1 1.0 μA 0.02 0.10 %/V 70 60 dB 2.0 IOUT = 30mA −40°C < = Topt ISC Short Current Limit VOUT = 0V RPD CE Pull-down Resistance 0.7 VCEH CE Input Voltage “H” VCEL CE Input Voltage “L” RLOW Max. 150 Output Voltage Temperature Coefficient en Typ. < = 85°C 6.0 V ±100 ppm /°C 40 mA 2.0 8.0 MΩ 1.5 6.0 V 0.0 0.3 V Output Noise BW = 10Hz to 100kHz 30 μVrms On Resistance of Nch for auto-discharge (Only for D version) VCE = 0V 60 Ω 7 R1114x • ELECTRICAL CHARACTERISTICS by OUTPUT VOLTAGE Topt = 25°C Dropout Voltage Output Voltage VOUT (V) VDIF (V) Condition Typ. Max. VOUT = 1.5 0.38 0.70 VOUT = 1.6 0.36 0.65 0.34 0.60 0.32 0.55 VOUT = 1.7 IOUT = 150mA 1.8 < = VOUT < = 2.0 2.1 < = VOUT < = 2.7 0.28 0.50 2.8 < = VOUT < = 4.0 0.22 0.35 TECHNICAL NOTES When using these ICs, consider the following points: Phase Compensation In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor COUT with good frequency characteristics and ESR (Equivalent Series Resistance). (Note: If additional ceramic capacitors are connected with parallel to the output pin with an output capacitor for phase compensation, the operation might be unstable. Because of this, test these ICs with as same external components as ones to be used on the PCB.) PCB Layout Make VDD and GND lines sufficient. If their impedance is high, noise pickup or unstable operation may result. Connect a capacitor with a capacitance value as much as 1.0μF or more between VDD and GND pin, and as close as possible to the pins. Set external components, especially the output capacitor, as close as possible to the ICs, and make wiring as short as possible. 8 R1114x TEST CIRCUITS CE VOUT VDD IN CE R1114xxx1B/D SERIES OUT IN IOUT 1.0μF 1.0μF ISS 1.0μF 1.0μF GND Fig.1 Standard test Circuit Fig.2 Supply Current Test Circuit CE CE VOUT VDD R1114xxx1B/D SERIES P.G. OUT R1114xxx1B/D SERIES GND IN VOUT VDD OUT IN IOUT 1.0μF 1.0 F GND VOUT VDD OUT R1114xxx1B/D SERIES 1.0μF GND I1 Fig.3 Ripple Rejection, Line Transient Response Test Circuit I2 Fig.4 Load Transient Response Test Circuit 9 R1114x TYPICAL APPLICATIONS CE IN VDD CE R1114Nxx1A SERIES OUT IN VOUT + + Cap. Cap. GND VDD R1114xxx1B SERIES OUT VOUT + + Cap. Cap. GND (External Components) Output Capacitor; Ceramic 0.47μF (Set Output Voltage in the range from 2.5 to 4.0V) Ceramic 1.0μF (Set Output Voltage in the range from 1.5 to 2.4V) Input Capacitor; Ceramic 1.0μF TYPICAL CHARACTERISTICS 1) Output Voltage vs. Output Current (Topt=25°C) R1114x151x R1114x281x 3.0 1.4 1.8V 1.2 1.0 0.8 0.6 VIN=3.5V 0.4 2.0V 0.2 2.5V 0 100 200 300 400 VIN=4.8V 2.0 1.5 3.1V 1.0 3.8V 3.5V 0.5 R1114x401x 4.5 4.0 3.5 VIN=6.0V 3.0 2.5 2.0 4.5V 1.5 4.3V 5.0V 1.0 0.5 0.0 0 100 200 300 Output Current IOUT(mA) 0 100 200 300 Output Current IOUT(mA) Output Current IOUT(mA) Output Voltage VOUT(V) 2.5 0.0 0.0 10 Output Voltage VOUT(V) Output Voltage VOUT(V) 1.6 400 400 R1114x 2) Output Voltage vs. Input Voltage (Topt=25°C) R1114x281x 2.9 1.6 2.8 Output Voltage VOUT(V) Output Voltage VOUT(V) R1114x151x 1.7 1.5 1.4 1.3 IOUT=1mA 1.2 IOUT=30mA 1.1 IOUT=50mA 2.7 2.6 2.5 2.4 IOUT=1mA 2.3 IOUT=30mA 2.2 IOUT=50mA 2.1 2.0 1.0 1 2 3 4 5 2 6 3 Input Voltage VIN(V) 4 5 6 Input Voltage VIN(V) R1114x401x Output Voltage VOUT(V) 4.2 IOUT=1mA 4.0 IOUT=30mA 3.8 IOUT=50mA 3.6 3.4 3.2 3.0 1 2 3 4 5 6 Input Voltage VIN(V) 3) Supply Current vs. Input Voltage (Topt=25°C) R1114x281x 90 80 80 Supply Current ISS(μA) Supply Current ISS(μA) R1114x151x 90 70 60 50 40 30 20 10 70 60 50 40 30 20 10 0 0 0 1 2 3 4 Input Voltage VIN(V) 5 6 0 1 2 3 4 5 6 Input Voltage VIN(V) 11 R1114x R1114x401x Supply Current ISS(μA) 90 80 70 60 50 40 30 20 10 0 0 1 2 3 4 5 6 Input Voltage VIN(V) 4) Output Voltage vs. Temperature R1114x151x R1114x281x 2.86 1.52 Output Voltage VOUT(V) Output Voltage VOUT(V) 1.53 1.51 1.50 1.49 1.48 1.47 1.46 -40 -15 10 35 60 85 Temperature Topt(°C) R1114x401x Output Voltage VOUT(V) 4.06 4.04 4.02 4.00 3.98 3.96 3.94 -15 10 35 60 Temperature Topt(°C) 12 2.82 2.80 2.78 2.76 2.74 -40 -15 10 35 60 Temperature Topt(°C) 4.08 3.92 -40 2.84 85 85 R1114x 5) Supply Current vs. Temperature R1114x281x 90 80 80 Supply Current ISS(μA) Supply Current ISS(μA) R1114x151x 90 70 60 50 40 30 20 10 70 60 50 40 30 20 10 0 -40 -15 10 35 60 0 -40 85 -15 10 35 60 85 Temperature Topt(°C) Temperature Topt(°C) R1114x401x Supply Current ISS(μA) 90 80 70 60 50 40 30 20 10 0 -40 -15 10 35 60 85 Temperature Topt(°C) 6) Dropout Voltage vs. Temperature R1114x151x R1114x161x 0.6 85°C 25°C -40°C 0.5 Dropout Voltage VDIF(V) Dropout Voltage VDIF(V) 0.6 0.4 0.3 0.2 0.1 0.0 0 25 50 75 100 125 Output Current IOUT(mA) 150 85°C 25°C -40°C 0.5 0.4 0.3 0.2 0.1 0.0 0 25 50 75 100 125 150 Output Current IOUT(mA) 13 R1114x R1114x171x R1114x181x 0.6 85°C 25°C -40°C 0.5 Dropout Voltage VDIF(V) Dropout Voltage VDIF(V) 0.6 0.4 0.3 0.2 0.1 85°C 25°C -40°C 0.5 0.4 0.3 0.2 0.1 0.0 0.0 0 25 50 75 100 125 0 150 25 R1114x211x 125 150 R1114x281x 85°C 25°C -40°C 0.35 0.30 Dropout Voltage VDIF(V) Dropout Voltage VDIF(V) 100 0.40 0.40 0.25 0.20 0.15 0.10 0.05 0.00 85°C 25°C -40°C 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.00 0 25 50 75 100 125 150 R1114x401x 0.40 85°C 25°C -40°C 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.00 0 25 50 75 100 125 Output Current IOUT(mA) 0 25 50 75 100 125 Output Current IOUT(mA) Output Current IOUT(mA) Dropout Voltage VDIF(V) 75 Output Current IOUT(mA) Output Current IOUT(mA) 14 50 150 150 R1114x 7) Dropout Voltage vs. Set Output Voltage (Topt=25°C) Dropout Voltage VDIF(V) 0.60 10mA 30mA 50mA 150mA 0.50 0.40 0.30 0.20 0.10 0.00 1.0 1.5 2.0 2.5 3.0 3.5 4.0 Set Output Voltage VREG(V) 8) Ripple Rejection vs. Input Bias Voltage (Topt=25°C, CIN=none, COUT=ceramic0.47μF) R1114x281x Ripple Rejection RR(dB) 80 70 60 50 40 30 f=1kHz f=10kHz f=100kHz 20 10 0 2.9 3.0 3.1 3.2 80 70 60 50 40 30 10 0 2.9 3.3 f=1kHz f=10kHz f=100kHz 20 3.0 3.1 3.2 Input Voltage VIN(V) Input Voltage VIN(V) R1114x281x R1114x281x Ripple 0.2Vp-p, IOUT=30mA 90 80 70 60 50 40 30 f=1kHz f=10kHz f=100kHz 20 10 0 2.9 Ripple 0.5Vp-p, IOUT=1mA 90 3.0 3.1 3.2 Input Voltage VIN(V) 3.3 3.3 Ripple 0.5Vp-p, IOUT=30mA 90 Ripple Rejection RR(dB) Ripple Rejection RR(dB) 90 Ripple Rejection RR(dB) R1114x281x Ripple 0.2Vp-p, IOUT=1mA 80 70 60 50 40 30 f=1kHz f=10kHz f=100kHz 20 10 0 2.9 3.0 3.1 3.2 3.3 Input Voltage VIN(V) 15 R1114x R1114x281x 90 80 70 60 50 40 30 f=1kHz f=10kHz f=100kHz 20 10 0 2.9 3.0 3.1 3.2 Ripple 0.5Vp-p, IOUT=50mA 90 Ripple Rejection RR(dB) Ripple Rejection RR(dB) R1114x281x Ripple 0.2Vp-p, IOUT=50mA 80 70 60 50 40 30 20 10 0 2.9 3.3 f=1kHz f=10kHz f=100kHz Input Voltage VIN(V) 3.0 3.1 3.2 3.3 Input Voltage VIN(V) 9) Ripple Rejection vs. Frequency (CIN=none) R1114x151x VIN=2.5VDC+0.5Vp-p, COUT=Ceramic 1.0μF 90 80 70 60 50 40 30 20 IOUT=1mA IOUT=30mA IOUT=50mA 10 0 0.1 1 10 80 70 60 50 40 30 20 0 0.1 100 60 50 40 IOUT=1mA IOUT=30mA IOUT=50mA 10 1 10 Frequency f(kHz) 16 100 100 VIN=3.8VDC+0.5Vp-p, COUT=Ceramic 1.0μF 90 Ripple Rejection RR(dB) Ripple Rejection RR(dB) 70 0 0.1 10 R1114x281x VIN=3.8VDC+0.5Vp-p, COUT=Ceramic 0.47μF 80 20 1 Frequency f(kHz) R1114x281x 30 IOUT=1mA IOUT=30mA IOUT=50mA 10 Frequency f(kHz) 90 VIN=2.5VDC+0.5Vp-p, COUT=Ceramic 2.2μF 90 Ripple Rejection RR(dB) Ripple Rejection RR(dB) R1114x151x 80 70 60 50 40 30 20 IOUT=1mA IOUT=30mA IOUT=50mA 10 0 0.1 1 10 Frequency f(kHz) 100 R1114x R1114x401x 90 80 70 60 50 40 IOUT=1mA IOUT=30mA IOUT=50mA 30 20 10 0 0.1 1 10 VIN=5.0VDC+0.5Vp-p, COUT=Ceramic 1.0μF 90 Ripple Rejection RR(dB) Ripple Rejection RR(dB) R1114x401x VIN=5.0VDC+0.5Vp-p, COUT=Ceramic 0.47μF 80 70 60 50 40 IOUT=1mA IOUT=30mA IOUT=50mA 30 20 10 0 0.1 100 1 Frequency f(kHz) 10 100 Frequency f(kHz) 10) Input Transient Response (IOUT=30mA, CIN=none, tr=tf=5μs, COUT=Ceramic 0.47μF) R1114x151x 4 1.54 Input Voltage 3 1.53 2 1.52 1 1.51 0 Output Voltage 1.50 Input Voltage VIN(V) Output Voltage VOUT(V) 1.55 1.49 0 10 20 30 40 50 60 70 80 90 100 Time T(μs) 6 2.84 5 Input Voltage 2.83 2.82 4 3 2.81 2 Output Voltage 2.80 Input Voltage VIN(V) Output Voltage VOUT(V) R1114x281x 2.85 1 2.79 0 10 20 30 40 50 60 70 80 90 0 100 Time T(μs) 17 R1114x 11) Load Transient Response (tr=tf=0.5μs, CIN=Ceramic 1.0μF) R1114x151x Output Voltage VOUT(V) 1.70 150 100 Output Current 1.65 50 1.60 0 1.55 Output Voltage 1.50 Output Current IOUT(mA) VIN=2.5V, COUT=Ceramic 1.0μF 1.75 1.45 0 2 4 6 8 10 12 14 16 18 20 Time T(μs) R1114x151x Output Voltage VOUT(V) 1.70 150 100 Output Current 1.65 50 1.60 0 1.55 Output Voltage 1.50 Output Current IOUT(mA) VIN=2.5V, COUT=Ceramic 2.2μF 1.75 1.45 0 2 4 6 8 10 12 14 16 18 20 Time T(μs) R1114x281x Output Voltage VOUT(V) 3.00 100 Output Current 2.95 50 2.90 0 2.85 Output Voltage 2.80 2.75 0 2 4 6 8 10 Time T(μs) 18 150 12 14 16 18 20 Output Current IOUT(mA) VIN=3.8V, COUT=Ceramic 0.47μF 3.05 R1114x R1114x281x Output Voltage VOUT(V) 3.00 150 100 Output Current 2.95 50 2.90 0 2.85 Output Voltage 2.80 Output Current IOUT(mA) VIN=3.8V, COUT=Ceramic 1.0μF 3.05 2.75 0 2 4 6 8 10 12 14 16 18 20 Time T(μs) R1114x281x Output Voltage VOUT(V) 3.00 150 100 Output Current 2.95 50 2.90 0 2.85 Output Voltage 2.80 Output Current IOUT(mA) VIN=3.8V, COUT=Ceramic 2.2μF 3.05 2.75 0 2 4 6 8 10 12 14 16 18 20 Time T(μs) 12) Turn-on/off speed with CE pin (D version) 5 2 4 VIN IOUT= 0mA IOUT= 30mA IOUT= 150mA 1 0 3 2 1 0 -5 0 5 10 15 Time T(μs) 20 25 6 3 2 1 5 VIN IOUT= 0mA IOUT= 30mA IOUT= 150mA 0 4 3 2 1 0 -50 0 Output Voltage VOUT(V) 3 4 CE Input Voltage VCE(V) 6 Output Voltage VOUT(V) CE Input Voltage VCE(V) R1114x151D (VIN=2.5V, CIN=Ceramic 1.0μF, COUT=Ceramic 1.0μF) 4 50 100 150 200 250 300 350 400 450 Time T(μs) 19 R1114x 8 3 7 2 6 1 5 2 VIN IOUT= 0mA IOUT= 30mA IOUT= 150mA 1 0 6 5 4 3 -1 2 1 0 -5 0 5 10 15 20 25 4 0 -1 VIN IOUT= 0mA IOUT= 30mA IOUT= 150mA 3 2 1 0 -20 0 Time T(μs) Output Voltage VOUT(V) 4 7 CE Input Voltage VCE(V) 8 3 Output Voltage VOUT(V) CE Input Voltage VCE(V) R1114x281D (VIN=3.8V, CIN=Ceramic 0.47μF, COUT=Ceramic 0.47μF) 4 20 40 60 80 100 120 140 160 180 Time T(μs) 8 6 12 6 4 10 VIN IOUT= 0mA IOUT= 30mA IOUT= 150mA 2 0 8 6 -2 4 2 0 4 2 0 5 10 15 Time T(μs) 20 20 25 VIN IOUT= 0mA IOUT= 30mA IOUT= 150mA 12 10 8 0 6 -2 4 2 0 -2 -5 14 -20 0 -2 20 40 60 80 100 120 140 160 180 Time T(μs) Output Voltage VOUT(V) 14 CE Input Voltage VCE(V) 8 Output Voltage VOUT(V) CE Input Voltage VCE(V) R1114x401D (VIN=5.0V, CIN=Ceramic 0.47μF, COUT=Ceramic 0.47μF) R1114x ESR vs. Output Current When using these ICs, consider the following points: In these ICs, phase compensation is made for securing stable operation even if the load current is varied. For this purpose, use a capacitor COUT with good frequency characteristics and ESR (Equivalent Series Resistance) of which is in the range described as follows: CE VOUT Ceramic Cap. R1114xxx1B/D Spectrum Analyzer S.A. VIN Ceramic Cap. VIN GND ESR IOUT Measuring Circuit for white noise; R1114xxx1B/D The relations between IOUT (Output Current) and ESR of an output capacitor are shown below. The conditions when the white noise level is under 40μV (Avg.) are marked as the hatched area in the graph. (Note: If additional ceramic capacitors are connected to the Output Pin with Output capacitor for phase compensation, the operation might be unstable. Because of this, test these ICs with as same external components as ones to be used on the PCB.) (1) VIN=VOUT+1V (2) Frequency Band: 10Hz to 2MHz (3) Temperature: −40°C to 25°C R1114x151x R1114x161x CIN=Ceramic 1.0μF, COUT=Ceramic 1.0μF 100 100 10 ESR (Ω) ESR (Ω) 10 1 0.1 0.01 0 CIN=Ceramic 0.47μF, COUT=Ceramic 0.68μF 1 0.1 30 60 90 120 Load Current IOUT (mA) 150 0.01 0 30 60 90 120 150 Load Current IOUT (mA) 21 R1114x R1114x211x R1114x281x CIN=Ceramic 0.47μF, COUT=Ceramic 0.47μF 100 100 10 ESR (Ω) ESR (Ω) 10 1 0.1 0.01 0 1 0.1 30 60 90 120 Load Current IOUT (mA) 22 CIN=Ceramic 0.47μF, COUT=Ceramic 0.47μF 150 0.01 0 30 60 90 120 Load Current IOUT (mA) 150 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
R1114Q331A-TR-FE 价格&库存
很抱歉,暂时无法提供与“R1114Q331A-TR-FE”相匹配的价格&库存,您可以联系我们找货
R1114Q331A-TR-FE
  • 1+5.034591+0.65136
  • 10+3.5274210+0.45637
  • 25+3.1541625+0.40808
  • 100+2.74647100+0.35533
  • 250+2.55185250+0.33015
  • 500+2.43427500+0.31494
  • 1000+2.337741000+0.30245
库存:8440
R1114Q331A-TR-FE
  • 3000+2.218293000+0.28700
  • 6000+2.159876000+0.27944
  • 9000+2.130619000+0.27565
  • 15000+2.0981915000+0.27146
  • 21000+2.0792521000+0.26901
  • 30000+2.0610130000+0.26665
库存:8440
R1114Q331A-TR-FE
    • 1+1.34072
    • 200+0.51884
    • 500+0.50069
    • 1000+0.49162
