RQ5RW19BA-TR-FE
RQ5RW19BA-TR-FE
    NISSHINBO(日清纺)
    SC-82A
    PMIC - 稳压器 - 线性 正 固定 1 输出 50mA SC-82AB
RQ5RW19BA-TR-FE 数据手册
Rx5RW SERIES ULTRA SMALL PACKAGE VOLTAGE REGULATOR NO.EA-048-111020 OUTLINE The Rx5RW Series are CMOS-based voltage regulator ICs with high accuracy output voltage and ultra-low supply current developed. Each of these ICs consists of a driver transistor, a voltage reference unit, an error amplifier, resistors for setting output volt-age and a current limit circuit. The output voltage of these ICs is fixed with high accuracy. Even if VOUT is shorted to GND, the included current limit circuit protects the ICs from the destruction. Furthermore, Rx5RWxxA/B have a chip enable function, so that the supply current on standby can be minimized. Since the packages for these ICs are SC-82AB and SON1612-6, high density mounting of the ICs on boards is possible. FEATURES • Supply Current ............................................................. Typ. 1.5μA (except pull-up/pull-down current for CE /CE pin) • Standby Current ........................................................... Typ. 0.1μA (applied to A/B version) • Dropout Voltage ........................................................... Typ. 40mV (IOUT=1mA, Rx5RW30A/B/C) • Temperature-Drift Coefficient of Output Voltage .......... Typ. ±100ppm/°C • Line Regulation ............................................................ Typ. 0.05%/V • Input Voltage Range .................................................... Max. 8.0V • Output Voltage Range.................................................. 1.5V to 6.0V (0.1V steps) • Output Voltage Accuracy..............................................±2.0% • Packages .....................................................................SC-82AB, SON1612-6 • Built-in Current Limit Circuits APPLICATIONS • Power source for battery-powered equipment. • Power source for cameras, VCRs, camcorders, hand-held audio instruments and hand-held communication equipment. • Precision voltage references. 1 Rx5RW BLOCK DIAGRAMS Rx5RWxxA Rx5RWxxB VOUT VDD VOUT VDD + + - - Vref Vref Current Limit GND CE Current Limit GND CE Rx5RWxxC VOUT VDD + Vref Current Limit GND NC SELECTION GUIDE The output voltage, chip enable polarity, and package, etc. for the ICs can be selected at the user’s request. Product Name Package Quantity per Reel Pb Free Halogen Free RD5RWxx∗A-TR-FE SON1612-6 4,000 pcs Yes Yes RQ5RWxx∗A-TR-FE SC-82AB 3,000 pcs Yes Yes xx : The output voltage can be designated in the range from 1.5V(15) to 6.0V(60) in 0.1V steps. ∗ : CE pin polarity are options as follows. (A) "L" active (B) "H" active (C) without chip enable 2 Rx5RW PIN CONFIGURATION z SC-82AB 4 z SON1612-6 6 3 4 (mark side) (mark side) 1 5 1 2 2 3 PIN DESCRIPTION • • SC-82AB Pin No Symbol Pin Description 1 GND 2 VDD Input Pin 3 VOUT Output Pin 4 CE or CE or NC Ground Pin Chip Enable Pin ("L" active/"H" active) or No Connection SON1612-6 Pin No Symbol Pin Description 1 CE or CE or NC 2 VDD Input Pin 3 VOUT Output Pin 4 NC No Connection 5 VDD Input Pin 6 GND Chip Enable Pin ("L" active/"H" active) or No Connection Ground Pin 3 Rx5RW ABSOLUTE MAXIMUM RATINGS Symbol Item Rating Unit 9.0 V VIN Input Voltage VCE Input Voltage for CE /CE Pin (applied to A/B version) −0.3 to VIN +0.3 V VOUT Output Voltage −0.3 to VIN +0.3 V IOUT Output Current 150 mA PD Power Dissipation (SC-82AB) ∗ Power Dissipation (SON1612-6) 380 ∗ mW 500 Topt Operating Temperature −40 to +85 °C Tstg Storage Temperature −55 to +125 °C ∗ ) For Power Dissipation, please refer to PACKAGE INFORMATION. ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. 4 Rx5RW ELECTRICAL CHARACTERISTICS • Rx5RW30A Symbol Item Conditions Min. Typ. Max. Unit 2.940 3.000 3.060 V VOUT Output Voltage VIN=5.0V 10μA≤IOUT≤10mA IOUT Output Current VIN=5.0V ΔVOUT/ΔIOUT Load Regulation VIN=5.0V, 1mA≤IOUT≤50mA 40 60 mV VDIF Dropout Voltage IOUT=1mA 40 60 mV ISS Supply Current VIN=5.0V 1.5 3.0 μA Istandby Standby Current VIN=5.0V, VCE=5.0V 0.1 1.0 μA ΔVOUT/ΔVIN Line Regulation IOUT=1mA VOUT+0.5V≤VIN≤8V 0.05 0.20 %/V 8.0 V VIN ΔVOUT/ΔTopt • Topt=25°C 50 0 mA Input Voltage Output Voltage Temperature Coefficient IOUT=10mA −40°C≤Topt≤85°C ISC Short Current Limit RPU Pull up resistance for CE pin 1.5 VCEH CE Input Voltage “H” 1.5 VCEL CE Input Voltage “L” ±100 ppm/ °C 40 mA 4.0 12.0 V 0.25 Rx5RW30B Symbol MΩ V Topt=25°C Item Conditions Min. Typ. Max. Unit 2.940 3.000 3.060 V VOUT Output Voltage VIN=5.0V 10μA≤IOUT≤10mA IOUT Output Current VIN=5.0V ΔVOUT/ΔIOUT Load Regulation VIN=5.0V 1mA≤IOUT≤50mA 40 60 mV VDIF Dropout Voltage IOUT=1mA 40 60 mV ISS Supply Current VIN=5.0V 1.5 3.0 μA Istandby Standby Current VIN=5.0V, VCE=GND 0.1 1.0 μA ΔVOUT/ΔVIN Line Regulation IOUT=1mA VOUT+0.5V≤VIN≤8V 0.05 0.20 %/V 8.0 V VIN ΔVOUT/ΔTopt 50 0 mA Input Voltage Output Voltage Temperature Coefficient IOUT=1mA −40°C≤Topt≤85°C ISC Short Current Limit RPD Pull down resistance for CE pin 1.5 VCEH CE Input Voltage “H” 1.5 VCEL CE Input Voltage “L” ±100 ppm/ °C 40 mA 4.0 12.0 MΩ V 0.25 V 5 Rx5RW • Rx5RW30C Symbol Topt=25°C Item Conditions Min. Tyo. Max. Unit 2.940 3.000 3.060 V VOUT Output Voltage VIN=5.0V 10μA≤IOUT≤10mA IOUT Output Current VIN=5.0V ΔVOUT/ΔIOUT Load Regulation VIN=5.0V 1mA≤IOUT≤50mA 40 60 mV VDIF Dropout Voltage IOUT=1mA 40 60 mV ISS Supply Current VIN=5.0V 1.5 3.0 μA ΔVOUT/ΔVIN Line Regulation IOUT=1mA 3.5V≤VIN≤8.0V 0.05 0.20 %/V 8.0 V VIN 0 mA Input Voltage ΔVOUT/ΔTopt ISC 50 Output Voltage Temperature Coefficient Short Current Limit IOUT=10mA −40°C≤Topt≤85°C ±100 ppm/ °C 40 mA RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. 6 Rx5RW ELECTRICAL CHARACTERISTICS BY OUTPUT VOLTAGE Topt=25°C Part Number Conditions Rx5RW15 Rx5RW16 Rx5RW17 Rx5RW18 Rx5RW19 Rx5RW20 Rx5RW21 Rx5RW22 Rx5RW23 Rx5RW24 Rx5RW25 Rx5RW26 Rx5RW27 Rx5RW28 Rx5RW29 Rx5RW30 Rx5RW31 Rx5RW32 Rx5RW33 Rx5RW34 Rx5RW35 Rx5RW36 Rx5RW37 Rx5RW38 Rx5RW39 Rx5RW40 Rx5RW41 Rx5RW42 Rx5RW43 Rx5RW44 Rx5RW45 Rx5RW46 Rx5RW47 Rx5RW48 Rx5RW49 Rx5RW50 Rx5RW51 Rx5RW52 Rx5RW53 Rx5RW54 Rx5RW55 Rx5RW56 Rx5RW57 Rx5RW58 Rx5RW59 Rx5RW60 VIN-VOUT =2.0V 10μA≤IOUT ≤10mA Output Voltage Output Current Load Regulation VOUT (V) IOUT (mA) ΔVOUT/ΔIOUT (mV) Min. 1.470 1.568 1.666 1.764 1.862 1.960 2.058 2.156 2.254 2.352 2.450 2.548 2.646 2.744 2.842 2.940 3.038 3.136 3.234 3.332 3.430 3.528 3.626 3.724 3.822 3.920 4.018 4.116 4.214 4.312 4.410 4.508 4.606 4.704 4.802 4.900 4.998 5.096 5.194 5.292 5.390 5.488 5.586 5.684 5.782 5.880 Typ. 1.500 1.600 1.700 1.800 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 3.700 3.800 3.900 4.000 4.100 4.200 4.300 4.400 4.500 4.600 4.700 4.800 4.900 5.000 5.100 5.200 5.300 5.400 5.500 5.600 5.700 5.800 5.900 6.000 Max. 1.530 1.632 1.734 1.836 1.938 2.040 2.142 2.244 2.346 2.448 2.550 2.652 2.754 2.856 2.958 3.060 3.162 3.264 3.366 3.468 3.570 3.672 3.774 3.876 3.978 4.080 4.182 4.284 4.386 4.488 4.590 4.692 4.794 4.896 4.998 5.100 5.202 5.304 5.406 5.508 5.610 5.712 5.814 5.916 6.018 6.120 Conditions Min. Conditions Typ. Dropout Voltage Max. VDIF (mV) Conditions VIN-VOUT =2.0V 30 35 Typ. 120 Max. 200 90 135 60 90 50 75 40 60 35 55 30 45 25 40 45 1mA≤IOUT ≤35mA VIN-VOUT =2.0V 50 40 60 1mA≤IOUT ≤50mA VIN-VOUT =2.0V IOUT=1mA VIN-VOUT =2.0V 65 50 70 1mA≤IOUT ≤65mA VIN-VOUT =2.0V 60 80 90 1mA≤IOUT ≤80mA 7 Rx5RW ELECTRICAL CHARACTERISTICS BY OUTPUT VOLTAGE (common characteristics) Symbol Topt=25°C Item Conditions Min. Typ. Max. Unit Supply Current VIN=Set VOUT+2.0 1.5 3.0 μA Istandby Standby Current VIN=Set VOUT+2.0V VCE=VIN (Rx5RWxxA), VCE=GND (Rx5RWxxB) 0.1 1.0 μA ΔVOUT/ΔVIN Line Regulation IOUT=1mA Set VOUT+0.5V≤VIN≤8V 0.05 0.20 %/V 8.0 V ISS VIN Input Voltage ΔVOUT/ΔTopt ISC 0 Output Voltage Temperature Coefficient IOUT=10mA −40°C≤Topt≤85°C Short Current Limit RPU/RPD CE Pull-up / CE Pull-down Resistance applied to A/B version 1.5 VCEH CE /CE Input Voltage "H" applied to A/B version 1.5 VCEL CE /CE Input Voltage "L" applied to A/B version ±100 ppm/ °C 40 mA 4.0 12.0 MΩ V 0.25 V RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS) All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. OPERATION Rx5RWxxB 3 VOUT VDD 2 + R1 Current Limit R2 Vref CE 4 1 GND In these ICs, output voltage VOUT is detected by Feedback Registers R1, R2, and the detected output voltage is compare with a reference voltage by the error amplifier, so that a constant voltage is output. A current limit circuit working for short protect, and a chip enable circuit are included. 8 Rx5RW TEST CIRCUITS 4 4 CE IOUT Rx5RWxxB CE VIN2 3 VOUT Rx5RWxxB 3 VOUT 2 VDD A GND 1 VIN 2 VDD GND 1 C2 C1 VIN1 VIN1=VIN2 C1,C2=1μF Standard Test Circuit 4 Supply Current Test Circuit 4 CE IOUT Rx5RWxxB CE Rx5RWxxB 3 VOUT 2 P.G. VDD 2 GND 1 VIN C2=1μF Ripple Rejection and Line Transient Response Test Circuit VDD GND 1 C2 VIN 3 VOUT C2 C1 1mA 10mA C1,C2=1μF Load Transient Response Test Circuit 9 Rx5RW TYPICAL APPLICATION 4 4 CE IOUT Rx5RWxxA CE Rx5RWxxB 3 VOUT 2 VDD VIN VIN NC VDD GND C2 C1 VOUT Rx5RWxxC 2 VDD 1 C2 C1 4 IOUT 3 GND 1 VIN VOUT 2 GND 1 IOUT 3 C2 C1 In Rx5RW Series, a constant voltage can be obtained without using capacitors, C1 and C2. However, when the wire connected VIN is long, use capacitor C1. Output noise can be reduced with using capacitor 2. Insert capacitors C1 and C2 with the capacitance of 0.1μF to 2μF between input/output pins and GND pin with minimum wiring. 10 Rx5RW TYPICAL CHARACTERISTICS 1) Output Voltage vs. Output Current Rx5RW30B Rx5RW30B Topt=25°C 3.0 VIN=5.0V 3.0 VIN=3.3V 2.0 5.0V 5.5V 1.5 1.0 0.5 Output Voltage VOUT(V) Output Voltage VOUT(V) 8.0V 2.5 0.0 2.5 Topt=85°C 2.0 -40°C 1.5 25°C 1.0 0.5 0.0 0 20 40 60 80 100 120 0 Output Current IOUT(mA) 30 Rx5RW40B Output Voltage VOUT(V) Output Voltage VOUT(V) 6.0V VIN=4.3V 3.0 6.5V 2.5 2.0 1.5 1.0 0.5 0.0 150 VIN=6.0V 3.5 Topt=85°C 3.0 2.5 -40°C 25°C 2.0 1.5 1.0 0.5 0.0 0 40 80 120 160 0 Output Current IOUT(mA) 30 8.0V 7.5V 3.0 150 180 2.0 1.0 0 VIN=7.0V 5.0 Output Voltage VOUT(V) 7.0V VIN=5.3V 4.0 120 Rx5RW50B Topt=25°C 5.0 90 60 Output Current IOUT(mA) Rx5RW50B Output Voltage VOUT(V) 120 4.0 8.0V 3.5 90 Rx5RW40B Topt=25°C 4.0 60 Output Current IOUT(mA) Topt=85°C 4.0 3.0 25°C -40°C 2.0 1.0 0.0 0 40 80 120 160 Output Current IOUT(mA) 200 0 40 80 120 160 200 Output Current IOUT(mA) 11 Rx5RW 2) Output Voltage vs. Input Voltage Rx5RW30B Rx5RW30B Topt=25°C 3.1 3.0 IOUT=1mA 2.9 5mA 10mA 2.8 2.7 2.8 2.9 3.0 3.1 3.2 3.05 Output Voltage VOUT(V) Output Voltage VOUT(V) 3.2 Topt=25°C IOUT=1mA 3.04 3.03 3.02 3.01 3.00 2.99 2.98 2.97 2.96 2.95 3.3 3 Rx5RW40B Topt=25°C IOUT=1mA 5mA 10mA 3.8 3.7 3.8 3.9 4.0 4.1 4.2 4.01 4.00 3.99 3.98 3.97 3.96 3.95 4.3 4 5.0 IOUT=1mA 5mA 10mA 5.1 Input Voltage VIN(V) 12 7 8 5.2 5.3 Topt=25°C IOUT=1mA 5.05 Output Voltage VOUT(V) Output Voltage VOUT(V) 5.1 5.0 6 Rx5RW50B 5.2 4.9 5 Input Voltage VIN(V) Topt=25°C 4.8 8 4.04 4.03 4.02 Rx5RW50B 4.8 4.7 7 Topt=25°C IOUT=1mA Input Voltage VIN(V) 4.9 6 4.05 Output Voltage VOUT(V) Output Voltage VOUT(V) 4.1 3.9 5 Rx5RW40B 4.2 4.0 4 Input Voltage VIN(V) Input Voltage VIN(V) 5.04 5.03 5.02 5.01 5.00 4.99 4.98 4.97 4.96 4.95 5 6 7 Input Voltage VIN(V) 8 Rx5RW Rx5RW40B 2.0 2.0 1.8 1.6 1.4 1.8 1.6 1.4 Dropout Voltage VDIF(V) Dropout Voltage VDIF(V) 3) Dropout Voltage vs. Output Current Rx5RW30B 85°C 1.2 1.0 Topt=25°C 0.8 0.6 0.4 0.2 0.0 -40°C 0 10 20 30 40 1.2 1.0 85°C Topt=25°C 0.8 0.6 0.4 0.2 0.0 50 -40°C 0 Output Current IOUT(mA) 10 20 30 40 50 Output Current IOUT(mA) Rx5RW50B Dropout Voltage VDIF(V) 2.0 1.8 1.6 1.4 1.2 1.0 85°C 0.8 0.6 0.4 0.2 0.0 Topt=25°C -40°C 0 10 20 30 40 50 Output Current IOUT(mA) 4) Output Voltage vs. Temperature Rx5RW30B 3.10 3.08 3.06 3.04 3.02 3.00 2.98 2.96 2.94 2.92 2.90 -50 -25 0 25 50 Temperature Topt(°C) 75 100 VIN=6.0V IOUT=10mA 4.10 Output Voltage VOUT(V) Output Voltage VOUT(V) Rx5RW40B VIN=5.0V IOUT=10mA 4.08 4.06 4.04 4.02 4.00 3.98 3.96 3.94 3.92 3.90 -50 -25 0 25 50 75 100 Temperature Topt(°C) 13 Rx5RW Rx5RW50B VIN=7.0V IOUT=10mA Output Voltage VOUT(V) 5.10 5.08 5.06 5.04 5.02 5.00 4.98 4.96 4.94 4.92 4.90 -50 -25 0 25 50 75 100 Temperature Topt(°C) 5) Supply Current vs. Input Voltage Rx5RW30B Rx5RW40B Topt=25°C 2.0 1.9 Supply Current ISS(μA) Supply Current ISS(μA) 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 4 5 6 7 8 Input Voltage VIN(V) 1.6 1.5 1.4 1.3 1.2 1.1 Topt=25°C 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 5 6 7 Input Voltage VIN(V) 4 5 6 7 Input Voltage VIN(V) Rx5RW50B Supply Current ISS(μA) 1.8 1.7 1.0 3 14 Topt=25°C 2.0 8 8 Rx5RW 6) Supply Current vs. Temperature Rx5RW30B Rx5RW40B VIN=5.0V 2.0 1.9 Supply Current ISS(μA) 1.9 Supply Current ISS(μA) VIN=6.0V 2.0 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 -50 -25 0 25 50 75 100 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 -50 -25 0 25 50 75 100 Temperature Topt(°C) Temperature Topt(°C) Rx5RW50B VIN=7.0V 2.0 Supply Current ISS(μA) 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 -50 -25 0 25 50 75 100 Temperature Topt(°C) 7) Dropout Voltage vs. Set Output Voltage Rx5RWxxB Dropout Voltage VDIF(V) 0.7 0.6 0.5 0.4 0.3 IOUT=10mA 0.2 5mA 0.1 1mA 0.0 0 1 2 3 4 5 6 Set Output Voltage VREG(V) 15 Rx5RW 8) Line Transient Response Rx5RW30B 6.0 5.5 Input Voltage 5.0 4.5 4.0 3.5 Output Voltage 3.0 2.5 0.0 COUT=1.0μF,IOUT=10mA 6.0 Dropout Voltage (V) Dropout Voltage (V) Rx5RW30B COUT=1.0μF,IOUT=1mA 5.5 Input Voltage 5.0 4.5 4.0 3.5 Output Voltage 3.0 1.0 2.0 3.0 2.5 0.0 4.0 1.0 Time T(ms) Input Voltage 6.0 5.5 5.0 Output Voltage COUT=1.0μF,IOUT=10mA 7.0 Dropout Voltage (V) Dropout Voltage (V) 6.5 6.5 Input Voltage 6.0 5.5 5.0 4.5 Output Voltage 4.0 4.0 3.5 0.0 1.0 2.0 3.0 3.5 0.0 4.0 1.0 Rx5RW50B Input Voltage 7.0 6.5 6.0 Output Voltage 5.0 7.5 Input Voltage 7.0 6.5 6.0 5.5 Output Voltage 5.0 1.0 2.0 Time T(ms) 16 4.0 COUT=1.0μF,IOUT=10mA 8.0 Dropout Voltage (V) Dropout Voltage (V) 7.5 5.5 3.0 Rx5RW50B COUT=1.0μF,IOUT=1mA 8.0 2.0 Time T(ms) Time T(ms) 4.5 0.0 4.0 Rx5RW40B COUT=1.0μF,IOUT=1mA 4.5 3.0 Time T(ms) Rx5RW40B 7.0 2.0 3.0 4.0 4.5 0.0 1.0 2.0 Time T(ms) 3.0 4.0 Rx5RW 9) Load Transient Response Rx5RW30B COUT=Tantal 1.0μF 5.0 20 10 4.5 Output Current 0 4.0 1mA -10 3.5 -20 Output Voltage 3.0 -30 2.5 2.0 0.0 -40 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Output Current IOUT(mA) Output Voltage VOUT(V) 10mA -50 5.0 Time T(ms) Rx5RW40B COUT=Tantal 1.0μF 6.0 20 10 5.5 Output Current 0 5.0 1mA -10 4.5 -20 Output Voltage 4.0 -30 3.5 3.0 0.0 -40 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Output Current IOUT(mA) Output Voltage VOUT(V) 10mA -50 5.0 Time T(ms) Rx5RW50B COUT=Tantal 1.0μF 7.0 20 10 6.5 Output Current 0 6.0 1mA -10 5.5 -20 Output Voltage 5.0 -30 4.5 4.0 0.0 -40 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Output Current IOUT(mA) Output Voltage VOUT(V) 10mA -50 5.0 Time T(ms) 17 Rx5RW 10) Ripple Rejection Rx5RW30B 80 70 60 50 40 30 20 10 0 0.1 1 10 100 Frequency f(kHZ) VIN=7Vdc+0.5Vp-p IOUT=10mA COUT=1μF Ripple Rejection RR(dB) 70 60 50 40 30 20 10 0 0.1 1 10 Frequency f(kHZ) 18 70 60 50 40 30 20 10 0 0.1 1 10 Frequency f(kHZ) Rx5RW50B 80 VIN=6Vdc+0.5Vp-p IOUT=10mA COUT=1μF 80 Ripple Rejection RR(dB) Ripple Rejection RR(dB) Rx5RW40B VIN=5Vdc+0.5Vp-p IOUT=10mA COUT=1μF 100 100 1. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. 2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written consent of our company. 3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise taking out of your country the products or the technical information described herein. 4. The technical information described in this document shows typical characteristics of and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our company's or any third party's intellectual property rights or any other rights. 5. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us. 6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. 7. Anti-radiation design is not implemented in the products described in this document. 8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. 9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. 10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use AOI. 11. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RQ5RW19BA-TR-FE 价格&库存
很抱歉,暂时无法提供与“RQ5RW19BA-TR-FE”相匹配的价格&库存,您可以联系我们找货
RQ5RW19BA-TR-FE
  • 1+5.016901+0.65029
  • 10+3.5150210+0.45562
  • 25+3.1426525+0.40735
  • 100+2.73682100+0.35475
  • 250+2.54283250+0.32960
  • 500+2.42567500+0.31442
  • 1000+2.329481000+0.30195
库存:2964
RQ5RW19BA-TR-FE
  • 3000+2.210453000+0.28652
  • 6000+2.152246000+0.27897
  • 9000+2.123089000+0.27519
  • 15000+2.0907815000+0.27101
  • 21000+2.0719021000+0.26856
  • 30000+2.0537330000+0.26621
库存:2964
