RP118N231B-TR-FE
RP118N231B-TR-FE
    NISSHINBO(日清纺)
    SOT23-5
    PMIC - 稳压器 - 线性 正 固定 1 输出 100mA SOT-23-5
RP118N231B-TR-FE 数据手册
RP118x Series 100 mA Ultra-Low Supply Current Voltage Regulator No. EA-399-230808 OVERVIEW RP118x is a voltage regulator featuring 0.2 µA ultra-low supply current. This device is ideal for a wearable equipment and IoT which require a long service life and a miniaturization of a battery. KEY BENEFITS • • Achieves a low supply current (0.2 µA) and contributes to a long-life and a miniaturized battery. Provides a small package to achieve the smallest possible footprint solution on boards where area is limited. KEY SPECIFICATIONS • • • • • • • • • Supply Current ················································· Typ. 0.2 µA Standby Current ··············································· Typ. 0.002 µA Output Voltage Accuracy ···································· ±0.8% Input Voltage Range (Maximum Rating) ··············· 1.7 V to 5.5 V (6.5 V) Output Voltage Range········································ 1.2 V to 3.6 V (0.1 V step) Built-in Fold Back Protection Circuit ······················ Typ. 50 mA (Current at short mode) Ceramic capacitors recommended to be used ········· 1.0 µF or more Dropout Voltage ··············································· Typ. 0.1 V (IOUT = 100 mA, VSET = 2.8 V) Operating mode ······ Automatic mode (Automatically shifts between fast response mode and low power mode) PACKAGE • TYPICAL APPLICATIONS VDD CIN CE Control VOUT RP118x CE GND VOUT COUT CIN = 1.0 µF COUT = 1.0 µF WLCSP-4-P8 (0.64 mm x 0.64 mm) DFN(PL)1010-4B SOT-23-5 SELECTION GUIDE Product Name RP118Zxx1∗-TR-F RP118Kxx1∗-TR RP118Nxx1∗-TR-FE Package ∗: Select auto-discharge function WLCSP-4-P8 Version CE pin Auto-discharge DFN(PL)1010-4B B Active-high Disable SOT-23-5 D Active-high Auto-discharge xx: Set output voltage (VSET) is selectable from 1.2 V to 3.6 V in 0.1 V step. APPLICATIONS • • • • Wearable equipment such as SmartWatch, SmartBand, and health monitoring Li-ion battery-used equipment and coin cell-used equipment Low power RF such as Bluetooth® Low Energy, Zigbee, WiSun, ANT Low power CPU, memory, sensor devices, and energy harvesting 1 RP118x No. EA-399-230808 SELECTION GUIDE The set output voltage, the auto-discharge function, and the package for the ICs are user-selectable options. Selection Guide Product Name RP118Zxx1∗-TR-F RP118Kxx1∗-TR Package Quantity per Reel Pb Free Halogen Free WLCSP-4-P8 5,000 pcs Yes Yes DFN(PL)1010-4B 10,000 pcs Yes Yes SOT-23-5 3,000 pcs Yes Yes RP118Nxx1∗-TR-FE xx: Set output voltage (VSET) is selectable from 1.2 V (12) to 3.6 V (36) in 0.1 V step. The voltage in 0.05 V step is shown as follows. 1.85 V: RP118x181∗5 ∗: Select auto-discharge function Version B D CE pin Active-high Active-high Auto-discharge Disable Auto-discharge BLOCK DIAGRAM VDD VOUT VDD Vref Vref Current Limit CE Current Limit GND RP118xxx1B Block Diagram VOUT CE GND RP118xxx1D Block Diagram 2 RP118x No. EA-399-230808 PIN DESCRIPTION Top View Bottom View Top View 4 2 2 1 1 3 Bottom View 3 4 5 4 (1) (mark side) A B B A RP118Z (WLCSP-4-P8) Pin Configuration 1 2 VDD A2 VOUT B1 CE B2 GND 1 1 RP118K (DFN(PL)1010-4B) Pin Configuration WLCSP-4-P8 Pin Description Pin No Symbol A1 2 1 2 3 RP118N (SOT-23-5) Pin Configuration Pin Description Input Pin Output Pin Chip Enable Pin (Active-high) Ground Pin DFN(PL)1010-4B Pin Description Pin No Symbol Description 1 VOUT Output Pin 2 GND Ground Pin 3 CE 4 VDD Chip Enable Pin (Active-high) Input Pin SOT-23-5 Pin Description Pin No Symbol Pin Description 1 VDD Input Pin 2 GND Ground Pin 3 CE Chip Enable Pin (Active-high) 4 NC No connection 5 VOUT Output Pin (1) The tab on the bottom of the package enhances thermal performance and is electrically connected to GND (substrate level). It is recommended that the tab be connected to the ground plane on the board, or otherwise be left floating. 3 RP118x No. EA-399-230808 ABSOLUTE MAXIMUM RATINGS Absolute Maximum Ratings Symbol Item Rating Unit VIN Input Voltage −0.3 to 6.5 V VCE CE Pin Input Voltage −0.3 to 6.5 V VOUT VOUT Pin Voltage −0.3 to VIN + 0.3 V IOUT Output Current 130 mA 470 mW 510 mW 660 mW PD Power Dissipation (1) WLCSP-4-P8, JEDEC STD. 51-9 Test Land Pattern DFN(PL)1010-4B, JEDEC STD. 51-7 Test Land Pattern SOT-23-5, JEDEC STD. 51-7 Test Land Pattern Tj Junction Temperature Range −40 to 125 °C Tstg Storage Temperature Range −55 to 125 °C ABSOLUTE MAXIMUM RATINGS Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent damages and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings is not assured. RECOMMENDED OPERATING CONDITIONS Recommended Operating Conditions Item Symbol Rating Unit VIN Input Voltage 1.7 to 5.5 V Ta Operating Temperature Range −40 to 85 °C RECOMMENDED OPERATING CONDITIONS All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) Refer to POWER DISSIPATION for detailed information. 4 RP118x No. EA-399-230808 ELECTRICAL CHARACTERISTICS VIN = VSET + 1.0 V, IOUT = 1.5 mA, CIN = COUT = 1.0 μF, unless otherwise noted. The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. RP118xxx1B/D Electrical Characteristics Symbol Parameter Test Conditions/Comments VOUT IOUT Output Voltage (Fast Response Mode) Ta = 25°C −40°C ≤ Ta ≤ 85°C VSET ≤ 2.0 V VSET ≤ 2.0 V Output Current 1 μA ≤ IOUT ≤ 1.5 mA Unit x 1.008 V 16 mV x 1.013 V 26 mV mA VSET > 2.0 V x 0.99 Dropout Voltage IOUT = 100 mA ISS Supply Current VCE = VIN, IOUT = 0 mA Standby Current VCE = 0 V Fast Response Mode switch-over current Low Power Mode switch-over current IOUT = Light load to Heavy load VIN = 5.0 V IOUT = Heavy load to Light load VIN = 5.0 V Line Regulation VSET + 0.5 V ≤ VIN ≤ 5.5 V ISC Short-circuit Current Limit VOUT = 0 V VCEH CE Pin Input Voltage, high VCEL CE Pin Input Voltage, low RLOW LOW Output NMOS On-state Resistance (RP118xxx1D only) ∆VOUT /∆VIN −26 Max. 100 VDIF IOUTL −16 VSET > 2.0 V x 0.987 Load Regulation IOUTH Typ. VSET > 2.0 V x 0.992 ∆VOUT /∆IOUT ISTANDBY (Ta = 25°C) Min. VSET ≤ 2.0 V 1.5 mA ≤ IOUT ≤ 100 mA −20 −40 2 x 1.01 V 20 mV 40 mV Refer to PRODUCT-SPECIFIC ELECTRICAL CHARACTERISTICS 0.2 0.002 0.42 µA 0.5 µA 0.055 µA 1.5 mA 0.08 mA 0.02 0.2 50 mA 1.0 V 0.4 VIN = 4.0 V, VCE = 0 V %/V 50 V Ω All test items listed under Electrical Characteristics are done under the pulse load condition (Tj ≈ Ta = 25°C). 5 RP118x No. EA-399-230808 The specifications surrounded by are guaranteed by design engineering at −40°C ≤ Ta ≤ 85°C. Product-specific Electrical Characteristics Product Name RP118x121x RP118x121x5 RP118x131x RP118x141x RP118x151x RP118x161x RP118x171x RP118x181x RP118x181x5 RP118x191x RP118x201x RP118x211x RP118x221x RP118x231x RP118x241x RP118x251x RP118x261x RP118x271x RP118x281x RP118x291x RP118x301x RP118x311x RP118x321x RP118x331x RP118x341x RP118x351x RP118x361x Min. 1.184 1.234 1.284 1.384 1.484 1.584 1.684 1.784 1.834 1.884 1.984 2.084 2.183 2.282 2.381 2.480 2.580 2.679 2.778 2.877 2.976 3.076 3.175 3.274 3.373 3.472 3.572 Ta = 25°C Typ. 1.200 1.250 1.300 1.400 1.500 1.600 1.700 1.800 1.850 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 VOUT [V] Max. 1.216 1.266 1.316 1.416 1.516 1.616 1.716 1.816 1.866 1.916 2.016 2.116 2.217 2.318 2.419 2.520 2.620 2.721 2.822 2.923 3.024 3.124 3.225 3.326 3.427 3.528 3.628 −40°C ≤ Ta ≤ 85°C Min. Typ. Max. 1.174 1.200 1.226 1.224 1.250 1.276 1.274 1.300 1.326 1.374 1.400 1.426 1.474 1.500 1.526 1.574 1.600 1.626 1.674 1.700 1.726 1.774 1.800 1.826 1.824 1.850 1.876 1.874 1.900 1.926 1.974 2.000 2.026 2.073 2.100 2.127 2.172 2.200 2.228 2.271 2.300 2.329 2.369 2.400 2.431 2.468 2.500 2.532 2.567 2.600 2.633 2.665 2.700 2.735 2.764 2.800 2.836 2.863 2.900 2.937 2.961 3.000 3.039 3.060 3.100 3.140 3.159 3.200 3.241 3.258 3.300 3.342 3.356 3.400 3.444 3.455 3.500 3.545 3.554 3.600 3.646 VDIF [V] Typ. Max. 0.640 0.975 0.560 0.490 0.410 0.340 0.280 0.890 0.770 0.660 0.560 0.435 0.230 0.380 0.200 0.320 0.150 0.285 0.130 0.230 0.110 0.180 0.100 0.160 0.090 0.145 6 RP118x No. EA-399-230808 APPLICATION INFORMATION Typical Application VDD VOUT RP118x CIN CE CE Control VOUT COUT GND RP118x Typical Application External Components Symbol Description CIN Ceramic Capacitor 1.0 µF MURATA GRM155R61A105KE15 COUT Ceramic Capacitor 1.0 µF MURATA GRM155R61A105KE15 Technical Notes on the External Components • In this device, phase compensation is provided to secure stable operation even when the load current is varied. For this purpose, use a 1.0 µF or more output capacitor (COUT). In case of using a tantalum type capacitor with a large ESR (Equivalent Series Resistance), the output might become unstable. Evaluate your circuit including consideration of frequency characteristics. • Ensure the VDD and GND lines are sufficiently robust. If their impedances are too high, noise pickup or unstable operation may result. Connect a 1.0 µF or more input capacitor (CIN) between the VDD and GND pins with shortest-distance wiring. Also, connect an output capacitor (COUT) between the VOUT and GND pins with shortest-distance wiring. TECHNICAL NOTES • When an intermediate voltage other than VIN or GND is input to the CE pin, a supply current may be increased with a through current of a logic circuit in the IC. The CE pin is neither pulled up nor pulled down, therefore an operation is not stable at open. 7 RP118x No. EA-399-230808 TYPICAL CHARACTERISTICS Typical Characteristics are intended to be used as reference data; they are not guaranteed. 1.24 1.84 1.23 1.83 1.22 1.82 Output Voltage[V] Output Voltage[V] 1) Output Voltage vs. Temperature (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) ※ RP118x121x, VIN = 2.2 V, IOUT = 1 mA RP118x181x, VIN = 2.8 V, IOUT = 1 mA 1.21 1.20 1.19 1.18 1.17 1.81 1.80 1.79 1.78 1.77 1.16 1.76 -40 -20 0 20 40 60 80 -40 -20 Tem perature Ta [℃] 20 40 60 80 Tem perature Ta [℃] RP118x281x, VIN = 3.8 V, IOUT = 1 mA RP118x361x, VIN = 4.6 V, IOUT = 1 mA 2.84 3.64 2.83 3.63 2.82 3.62 Output Voltage[V] Output Voltage[V] 0 2.81 2.80 2.79 2.78 3.61 3.60 3.59 3.58 3.57 2.77 3.56 2.76 -40 -20 0 20 40 60 -40 80 -20 0 20 40 60 80 Tem perature Ta [℃] Tem perature Ta [℃] 0.30 0.30 0.25 0.25 Supply Current[uA] Supply Current[uA] 2) Supply Current vs. Temperature (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) RP118x121x, VIN = 2.2 V RP118x181x, VIN = 2.8 V 0.20 0.15 0.10 0.05 0.20 0.15 0.10 0.05 0.00 0.00 -40 -20 0 20 40 60 80 -40 Tem perature Ta[℃] ※ -20 0 20 40 60 80 Tem perature Ta[℃] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 8 RP118x No. EA-399-230808 RP118x361x, VIN = 4.6 V ※ 0.30 0.30 0.25 0.25 Supply Current[uA] Supply Current[uA] RP118x281x, VIN = 3.8 V 0.20 0.15 0.10 0.05 0.20 0.15 0.10 0.05 0.00 0.00 -40 -20 0 20 40 60 80 -40 -20 Tem perature Ta[℃] 0 20 40 60 80 Tem perature Ta[℃] 3) Dropout Voltage vs. Temperature (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) RP118x121x RP118x181x 300 Dropout Voltage VDIF[m V] Dropout Voltage VDIF[m V] 700 600 100m A 10m A 0.1mA 500 400 30m A 1m A 300 200 100 250 200 100m A 10m A 0.1mA 150 100 50 0 0 -40 -20 0 20 40 60 -40 80 -20 20 40 60 80 RP118x361x 160 160 100m A 10m A 0.1mA 140 120 30m A 1m A Dropout Voltage VDIF[m V] Dropout Voltage VDIF[m V] 0 Tem perature Ta[℃] Tem perature Ta[℃] RP118x281x 100 80 60 40 20 0 140 100m A 30m A 120 10m A 1m A 100 0.1mA 80 60 40 20 0 -40 -20 0 20 40 60 80 -40 Tem perature Ta[℃] ※ 30m A 1m A -20 0 20 40 60 80 Tem perature Ta[℃] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 9 RP118x No. EA-399-230808 700 300 600 250 Dropout Voltage[m V] Dropout Voltage[m V] 4) Dropout Voltage vs Output Current (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF) ※ RP118x121x RP118x181x 500 400 300 -40℃ 200 25℃ 100 85℃ 0 200 150 -40℃ 100 25℃ 50 85℃ 0 0 25 50 75 100 0 25 Output Current[m A] 160 160 140 140 120 100 80 60 -40℃ 40 25℃ 20 85℃ 0 25 50 75 100 RP118x361x Dropout Voltage[m V] Dropout Voltage[m V] RP118x281x 0 50 Output Current[m A] 75 120 100 80 60 40 -40℃ 20 25℃ 85℃ 0 100 0 Output Current[m A] 25 50 75 100 Output Current[m A] 5) Dropout Voltage vs Set Output Voltage (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) ※ Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 10 RP118x No. EA-399-230808 6) Output Voltage vs. Output Current (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) ※ RP118x121x RP118x181x 1.4 2.0 Output Voltage[V] Output Voltage[V] 1.2 1.0 0.8 0.6 Vin=1.7[V] 0.4 Vin=2.2[V] 1.5 1.0 Vin=1.8[V] Vin=2.8[V] Vin=3.8[V] Vin=5.5[V] 0.5 Vin=3.8[V] 0.2 Vin=5.5[V] 0.0 0 0.0 100 200 Output Current[m A] 0 300 3.5 4.0 3.0 3.5 2.5 3.0 Vin=2.8[V] 2.0 Vin=3.8[V] 1.5 300 RP118x361x Output Voltage[V] Output Voltage[V] RP118x281x 100 200 Output Current[m A] Vin=5.5[V] 1.0 0.5 2.5 Vin=3.6[V] 2.0 Vin=4.6[V] 1.5 Vin=5.5[V] 1.0 0.5 0.0 0.0 0 100 200 Output Current[m A] 300 0 100 200 Output Current[m A] 300 7) Output Voltage vs. Input Voltage (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP118x121x RP118x181x 1.4 2.0 Output Voltage[V] Output Voltage[V] 1.2 1.0 0.8 Iout=0[mA] 0.6 Iout=1[mA] 0.4 Iout=30[mA] 0.2 Iout=50[mA] 1.5 Iout=0[mA] 1.0 Iout=1[mA] Iout=30[mA] 0.5 Iout=50[mA] 0.0 0.0 0 2 4 6 0 Input Voltage [V] ※ 2 4 6 Input Voltage [V] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 11 RP118x No. EA-399-230808 RP118x281x RP118x361x ※ 4.0 3.5 2.5 Output Voltage[V] Output Voltage[V] 3.0 2.0 Iout=0[mA] 1.5 Iout=1[mA] 1.0 Iout=30[mA] 0.5 Iout=50[mA] 3.0 2.5 Iout=0[mA] 2.0 Iout=1[mA] 1.5 1.0 Iout=30[mA] 0.5 Iout=50[mA] 0.0 0.0 0 2 4 0 6 2 4 6 Input Voltage [V] Input Voltage [V] 8) Supply Current vs. Input Voltage (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP118x121x Supply Current ISS[uA] 0.30 0.25 0.20 0.15 0.10 0.05 0.00 0 2 4 6 Input Voltage[V] RP118x181x (10 µA/div) RP118x181x (0.05 µA/div) 0.30 Supply Current ISS[uA] Supply Current ISS[uA] 40 30 20 10 0.25 0.20 0.15 0.10 0.05 0 0 2 4 Input Voltage[V] ※ 6 0.00 0 1 2 3 4 Input Voltage[V] 5 6 Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 12 RP118x No. EA-399-230808 RP118x281x (10 µA/div) RP118x281x ※ (0.05 µA/div) 0.30 Supply Current ISS[uA] Supply Current ISS[uA] 40 30 20 10 0 0.25 0.20 0.15 0.10 0.05 0.00 0 2 4 6 0 Input Voltage[V] 2 4 6 Input Voltage[V] RP118x361x (10 µA/div) RP118x361x (0.05 µA/div) 0.30 Supply Current ISS[uA] Supply Current ISS[uA] 40 30 20 10 0 0.25 0.20 0.15 0.10 0.05 0.00 0 2 4 6 0 Input Voltage[V] 2 4 6 Input Voltage[V] 9) Supply Current vs. Output Current (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP118x121x RP118x181x 100 Supply Current[uA] Supply Current[uA] 100 10 1 0.1mA => 100mA 10 1 0.1mA => 100mA 100m A => 0.1mA 100m A => 0.1mA 0.1 0.1 0.1 1 10 100 0.1 Output Current[m A] ※ 1 10 100 Output Current[m A] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 13 RP118x No. EA-399-230808 RP118x281x RP118x361x ※ 100 Supply Current[uA] Supply Current[uA] 100 10 1 0.1mA => 100mA 10 1 0.1mA => 100mA 100m A => 0.1mA 100m A => 0.1mA 0.1 0.1 0.1 1 10 100 0.1 1 Output Current[m A] 10 100 Output Current[m A] 120 100uA 1mA 30mA 50mA 100mA 100 80 60 Ripple Rejection RR [dB] Ripple Rejection RR [dB] 10) Ripple Rejection vs. Frequency (CIN = none, COUT = Ceramic 1.0 µF, Ta = 25°C) RP118x121x, VIN = 2.2 V RP118x181x, VIN = 2.8 V 40 20 0 0.1 1 10 100 120 80 60 40 20 0 1000 100uA 1mA 30mA 50mA 100mA 100 0.1 1 Frequency f [kHz] 100uA 1mA 30mA 50mA 100mA 100 80 60 40 20 0 0.1 1 10 100 1000 120 1000 100uA 1mA 30mA 50mA 100mA 100 80 60 40 20 0 0.1 Frequency f [kHz] ※ 100 RP118x361x, VIN = 4.6 V Ripple Rejection RR [dB] Ripple Rejection RR [dB] RP118x281x, VIN = 3.8 V 120 10 Frequency f [kHz] 1 10 100 1000 Frequency f [kHz] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 14 RP118x No. EA-399-230808 11) Ripple Rejection vs. Input Bias Voltage (CIN = none, COUT = Ceramic 1.0 µF, Ta = 25°C) ※ RP118x121x, IOUT = 100 µA RP118x181x, IOUT = 100 µA 70 60 0.1kHz 1kHz 10kHz 100kHz 80 Ripple Rejection RR[dB] Ripple Rejection RR[dB] 80 50 40 30 20 10 0 70 60 0.1kHz 1kHz 10kHz 100kHz 50 40 30 20 10 0 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1.5 2.0 2.5 Input Voltage VIN[V] RP118x281x, IOUT = 100 µA 80 70 0.1kHz 1kHz 60 10kHz 100kHz 50 40 30 20 10 0 2.5 3.0 3.5 4.0 4.5 5.0 70 60 5.5 0.1kHz 1kHz 10kHz 100kHz 20 10 0 5.5 3.5 3.7 3.9 4.1 4.3 4.5 4.7 4.9 5.1 5.3 5.5 Input Voltage VIN[V] RP118x181x, IOUT = 30 mA 80 70 70 60 50 40 30 0.1kHz 1kHz 10kHz 100kHz 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 Input Voltage VIN[V] Ripple Rejection RR[dB] Ripple Rejection RR[dB] ※ 5.0 30 80 0 4.5 40 RP118x121x, IOUT = 30 mA 10 4.0 50 Input Voltage VIN[V] 20 3.5 RP118x361x, IOUT = 100 µA Ripple Rejection RR[dB] Ripple Rejection RR[dB] 80 3.0 Input Voltage VIN[V] 60 50 40 30 20 10 0 1.5 2.0 2.5 0.1kHz 1kHz 10kHz 100kHz 3.0 3.5 4.0 4.5 Input Voltage VIN[V] 5.0 5.5 Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 15 RP118x No. EA-399-230808 RP118x361x, IOUT = 30 mA ※ 80 80 70 70 Ripple Rejection RR[dB] Ripple Rejection RR[dB] RP118x281x, IOUT = 30 mA 60 50 40 30 20 0.1kHz 10kHz 10 0 2.5 3.0 3.5 4.0 1kHz 100kHz 4.5 5.0 60 50 40 30 20 0 5.5 0.1kHz 10kHz 10 1kHz 100kHz 3.5 3.7 3.9 4.1 4.3 4.5 4.7 4.9 5.1 5.3 5.5 Input Voltage VIN[V] Input Voltage VIN[V] 12) Input Transient Response (CIN = Ceramic 0.1 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP118x121x, IOUT = 100 µA, tR = tF = 5 µs RP118x121x, IOUT = 30 mA, tR = tF = 5 µs 1.20 1.16 - 1.24 1.20 Output Voltage 1.16 3 2 - 1.12 -0.2 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 Time t [ms] RP118x181x, IOUT = 100 µA, tR = tF = 5 µs RP118x181x, IOUT = 30 mA, tR = tF = 5 µs 5 5 0 5 10 15 20 25 30 35 40 Time t [ms] Input Voltage 1.84 3 2 1.80 Output Voltage 1.76 1.72 Input Voltage VIN [V] 4 - -5 0 5 10 15 20 25 30 35 40 Time t [ms] - 4 1.84 Input Voltage 3 2 1.80 1.76 Input Voltage VIN [V] -5 Output Voltage VOUT [V] - Output Voltage VOUT [V] 1.12 ※ Output Voltage 2 Input Voltage Input Voltage VIN [V] 1.24 3 4 Output Voltage VOUT [V] Input Voltage Input Voltage VIN [V] Output Voltage VOUT [V] 4 Output Voltage - 1.72 -0.2 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 Time t [ms] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 16 RP118x No. EA-399-230808 5 Input Voltage 2.84 4 3 2.80 2.76 Output Voltage 2.72 - 2.84 Input Voltage 4 3 2.80 2.76 Output Voltage 2.72 Input Voltage VIN [V] 6 5 Output Voltage VOUT [V] 6 Input Voltage VIN [V] RP118x281x, IOUT = 30 mA, tR = tF = 5 µs ※ Output Voltage VOUT [V] RP118x281x, IOUT = 100 µA, tR = tF = 5 µs - RP118x361x, IOUT = 30 mA, tR = tF = 5 µs 7 7 6 6 Output Voltage VOUT [V] 0 5 10 15 20 25 30 35 40 Time t [ms] Input Voltage 3.64 5 4 3.60 Output Voltage 3.56 3.52 3.48 -5 0 5 10 15 20 25 30 35 40 Time t [ms] - 3.64 3.60 3.56 Input Voltage Input Voltage VIN [V] RP118x361x, IOUT = 100 µA, tR = tF = 5 µs -5 Output Voltage V OUT [V] 2.68 -0.2 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 Time t [ms] Input Voltage VIN [V] - 2.68 5 4 Output Voltage 3.52 3.48 -0.2 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 Time t [ms] 13) Load Transient Response (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) RP118x121x VIN = 2.2 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs VIN = 2.2 V, IOUT = 1 mA 10 mA, tR = tF = 5 µs ※ Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 17 RP118x No. EA-399-230808 VIN = 2.2 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs RP118x181x VIN = 2.8 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs ※ VIN = 2.8 V, IOUT = 1 mA 10 mA, tR = tF = 5 µs VIN = 2.8 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs RP118x281x VIN = 3.8 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs ※ VIN = 3.8 V, IOUT = 1 mA 10 mA, tR = tF = 5 µs Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 18 RP118x No. EA-399-230808 VIN = 3.8 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs RP118x361x VIN = 4.6 V, IOUT = 1 µA 10 mA, tR = tF = 5 µs ※ VIN = 4.6 V, IOUT = 1 mA 10 mA, tR = tF = 5 µs VIN = 4.6 V, IOUT = 10 mA 30 mA, tR = tF = 5 µs ※ Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 19 RP118x No. EA-399-230808 2 0 1 0 Output Voltage -20 0 20 40 60 80 100 120 140 160 180 Time t [us] CE Input Voltage 0 0 -100 0 100 200 300 400 500 600 700 800 900 Time t [us] 1 Iout = 0mA Iout = 30mA Iout = 100mA 0 -100 0 100 200 300 400 500 600 700 800 900 Time t [us] 6 CE Input Voltage Output Voltage V OUT [V] 2 0 CE Input Voltage VCE[V] Output Voltage V OUT [V] ※ 2 Output Voltage Iout = 0mA Iout = 30mA Iout = 100mA 1 RP118x361x VIN = 4.6 V, VCE = 0 V => 4.6 V 4 3 Output Voltage 2 RP118x281x VIN = 3.8 V, VCE = 0 V => 3.8 V CE Input Voltage 2 CE Input Voltage VCE[V] Iout = 0mA Iout = 30mA Iout = 100mA 2 3 2 1 Output Voltage 4 2 0 CE Input Voltage VCE[V] Output Voltage V OUT [V] CE Input Voltage 4 Output Voltage V OUT [V] 4 CE Input Voltage VCE[V] 14) Turn On Speed with CE pin (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) ※ RP118x121x RP118x181x VIN = 2.2 V, VCE = 0 V => 2.2 V VIN = 2.8 V, VCE = 0 V => 2.8 V Iout = 0mA Iout = 30mA Iout = 100mA 0 -100 0 100 200 300 400 500 600 700 800 900 Time t [us] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 20 RP118x No. EA-399-230808 2 Output Voltage 1 0 -50 0 50 100 150 200 250 300 350 400 450 Time t [us] 0 2 1 0 Output Voltage V OUT [V] ※ 2 0 2 Output 1 0 -50 0 Iout = 0mA Iout = 30mA Iout = 100mA 50 100 150 200 250 300 350 400 450 Time t [us] 50 100 150 200 250 300 350 400 450 Time t [us] 6 4 CE Input Voltage 2 Output Voltage V OUT [V] 4 3 -50 0 RP118x361D VIN = 4.6 V, VCE = 4.6 V => 0 V CE Input Voltage VCE[V] RP118x281D VIN = 3.8 V, VCE = 3.8 V => 0 V CE Input Voltage Output Voltage Iout = 0mA Iout = 30mA Iout = 100mA 4 Output Voltage 2 0 0 Iout = 0mA CE Input Voltage VCE[V] Output Voltage V OUT [V] 0 Iout = 0mA Iout = 30mA Iout = 100mA 2 CE Input Voltage CE Input Voltage VCE[V] 2 CE Input Voltage 4 Output Voltage V OUT [V] 4 CE Input Voltage VCE[V] 15) Turn OFF Speed with CE pin (CIN = Ceramic 1.0 µF, COUT = Ceramic 1.0 µF, Ta = 25°C) ※ RP118x121D RP118x181D VIN = 2.2 V, VCE = 2.2 V => 0 V VIN = 2.8 V, VCE = 2.8 V => 0 V Iout = 30mA Iout = 100mA -50 0 50 100 150 200 250 300 350 400 450 Time t [us] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 21 RP118x No. EA-399-230808 16) Inrush Current at turning on (CIN = none, Ta = 25°C) ※ RP118x121x VIN = 2.2 V, VCE = 0 V => 2.2 V 3 Output Voltage 1 Cout = 1uF Cout = 2.2uF 0 Inrush Current -50 0 200 Cout = 4.7uF Cout = 10uF 50 100 150 200 250 300 350 400 100 0 CE Input Voltage 2 Output Voltage 1 Cout = 22uF 0 Cout = 47uF Inrush Current -200 0 Time t [us] 200 100 Inrush Current Irush [mA] 2 Output Voltage V OUT [V] / CE Input Voltage VCE[V] CE Input Voltage Inrush Current Irush [mA] Output Voltage V OUT [V] / CE Input Voltage VCE[V] 3 0 200 400 600 800 1000 1200 Time t [us] RP118x181x VIN = 2.8 V, VCE = 0 V => 2.8 V Output Voltage 1 0 Inrush Current -50 0 Cout = 1uF Cout = 2.2uF Cout = 4.7uF Cout = 10uF 50 100 150 200 250 300 350 400 200 100 0 CE Input Voltage 2 Output Voltage 1 Cout = 22uF 0 Inrush Current -200 0 Time t [us] ※ Cout = 47uF Inrush Current Irush [mA] CE Input Voltage 2 Output Voltage V OUT [V] / CE Input Voltage VCE[V] 3 Inrush Current Irush [mA] Output Voltage V OUT [V] / CE Input Voltage VCE[V] 3 200 100 0 200 400 600 800 100012001400 Time t [us] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 22 RP118x No. EA-399-230808 RP118x281x VIN = 3.8 V, VCE = 0 V => 3.8 V 2 Output Voltage 1 Cout = 1uF 0 Cout = 2.2uF Cout = 4.7uF Inrush Current Cout = 10uF -100 0 100 200 300 400 500 600 700 800 200 100 0 CE Input Voltage 4 3 2 Output Voltage 1 0 Cout = 22uF Cout = 47uF Inrush Current -500 0 200 100 0 500 1000 1500 2000 2500 3000 Time t [us] Inrush Current Irush [mA] 3 Output Voltage V OUT [V] / CE Input Voltage VCE[V] 4 5 CE Input Voltage Inrush Current Irush [mA] Output Voltage V OUT [V] / CE Input Voltage VCE[V] 5 ※ Time t [us] RP118x361x VIN = 4.6 V, VCE = 0 V => 4.6 V CE Input Voltage 3 Cout = 1uF 0 Cout = 2.2uF Cout = 4.7uF Inrush Current Cout = 10uF -100 0 100 200 300 400 500 600 700 800 200 100 0 Output Voltage 2 1 0 Cout = 22uF -500 0 Time t [us] ※ 200 Cout = 47uF Inrush Current Inrush Current Irush [mA] Output Voltage 1 CE Input Voltage 4 3 2 Output Voltage V OUT [V] / CE Input Voltage VCE[V] 4 5 Inrush Current Irush [mA] Output Voltage V OUT [V] / CE Input Voltage VCE[V] 5 100 0 500 1000 1500 2000 2500 3000 Time t [us] Typical characteristics at IOUT = 1 mA are evaluated in a fast response mode. 23 RP118x No. EA-399-230808 ESR vs. Output Current It is recommended that a ceramic type capacitor be used for this device. However, other types of capacitors having lower ESR can also be used. The relation between the output current (IOUT) and the ESR of output capacitor is shown below. VDD VOUT COUT RP118x CIN CE IOUT GND ESR Measurement conditions Frequency Band : 10 Hz to 2 MHz Temperature : −40°C to 85°C : Ceramic 1.0 µF CIN, COUT RP118x121x VIN = 1.7 V to 5.5 V RP118x181x VIN = 1.8 V to 5.5 V 100 100 10 10 ESR [Ω] 1000 ESR [Ω] 1000 1 0.1 0.01 0 20 40 60 80 100 1 0.1 0.01 0 20 Output Current IOUT [mA] 100 10 10 ESR [Ω] 100 ESR [Ω] 1000 1 0.1 20 40 60 80 100 RP118x361x VIN = 3.6 V to 5.5 V 1000 0 60 Output Current IOUT [mA] RP118x281x VIN = 2.8 V to 5.5 V 0.01 40 80 Output Current IOUT [mA] 100 1 0.1 0.01 0 20 40 60 80 100 Output Current IOUT [mA] 24 POWER DISSIPATION WLCSP-4-P8 PD-WLCSP-4-P8-(85125)-JE-C The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-9. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 101.5 mm x 114.5 mm x 1.6 mm Copper Ratio Outer Layer (First Layer): 60% Inner Layers (Second and Third Layers): 100% Outer Layer (Fourth Layer): 60% Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 470 mW Thermal Resistance (θja) θja = 212°C/W θja: Junction-to-Ambient Thermal Resistance 114.5 600 470 400 300 101.5 Power Dissipation (mW) 500 200 100 0 0 25 50 75 85 100 125 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern i PACKAGE DIMENSIONS WLCSP-4-P8 DM-WLCSP-4-P8-JE-A WLCSP-4-P8 Package Dimensions (Unit: mm) i Visual Inspection Criteria WLCSP VI-160823 No. 1 Inspection Items Package chipping 2 Si surface chipping 3 No bump Marking miss 4 Inspection Criteria Figure A≥0.2mm is rejected B≥0.2mm is rejected C≥0.2mm is rejected And, Package chipping to Si surface and to bump is rejected. A≥0.2mm is rejected B≥0.2mm is rejected C≥0.2mm is rejected But, even if A≥0.2mm, B≤0.1mm is acceptable. No bump is rejected. To reject incorrect marking, such as another product name marking or 5 6 7 No marking Reverse direction of marking Defective marking 8 Scratch 9 Stain and Foreign material another lot No. marking. To reject no marking on the package. To reject reverse direction of marking character. To reject unreadable marking. (Microscope: X15/ White LED/ Viewed from vertical direction) To reject unreadable marking character by scratch. (Microscope: X15/ White LED/ Viewed from vertical direction) To reject unreadable marking character by stain and foreign material. (Microscope: X15/ White LED/ Viewed from vertical direction) i PART MARKINGS RP118Z MK-RP118Z-JE-C : Lot Number … Alphanumeric Serial Number   RP118Z (WLCSP-4-P8) Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or distributor before attempting to use AOI. i PART MARKINGS RP118Z MK-RP118Z-JE-C RP118Z Part Marking List Product Name RP118Z121B RP118Z131B RP118Z141B RP118Z151B RP118Z161B RP118Z171B RP118Z181B RP118Z191B RP118Z201B RP118Z211B RP118Z221B RP118Z231B RP118Z241B RP118Z251B RP118Z261B RP118Z271B RP118Z281B RP118Z291B RP118Z301B RP118Z311B RP118Z321B RP118Z331B RP118Z341B RP118Z351B RP118Z361B RP118Z121B5  Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Product Name RP118Z121D RP118Z131D RP118Z141D RP118Z151D RP118Z161D RP118Z171D RP118Z181D RP118Z191D RP118Z201D RP118Z211D RP118Z221D RP118Z231D RP118Z241D RP118Z251D RP118Z261D RP118Z271D RP118Z281D RP118Z291D RP118Z301D RP118Z311D RP118Z321D RP118Z331D RP118Z341D RP118Z351D RP118Z361D RP118Z181D5 RP118Z121D5  Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No Lot No ii POWER DISSIPATION DFN(PL)1010-4B PD-DFN(PL)1010-4-(85125)-D-JE-C The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes  0.2 mm × 21 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 510 mW Thermal Resistance (ja) ja = 194°C/W Thermal Characterization Parameter (ψjt) ψjt = 120°C/W ja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter 600 510 Power Dissipation (mW) 500 400 300 200 100 0 0 25 50 75 85 100 125 Ambient Temperature (°C) Power Dissipation vs. Ambient Temperature Measurement Board Pattern i PACKAGE DIMENSIONS DFN(PL)1010-4B DM-DFN(PL)1010-4B-JE-C DFN(PL)1010-4B Package Dimensions * i PART MARKINGS RP118K MK-RP118K-JE-E : Product Code … Refer to Part Marking List : Lot Number … Alphanumeric Serial Number ①② ③④ DFN(PL)1010-4B Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or distributor before attempting to use AOI. i PART MARKINGS RP118K MK-RP118K-JE-E RP118K Part Marking List RP118Kxx1B Product Name   RP118Kxx1D Product Name   RP118K121B A 0 RP118K121D D 0 RP118K131B A 1 RP118K131D D 1 RP118K141B A 2 RP118K141D D 2 RP118K151B A 3 RP118K151D D 3 RP118K161B A 4 RP118K161D D 4 RP118K171B A 5 RP118K171D D 5 RP118K181B A 6 RP118K181D D 6 RP118K191B A 7 RP118K191D D 7 RP118K201B A 8 RP118K201D D 8 RP118K211B A 9 RP118K211D D 9 RP118K221B B 0 RP118K221D E 0 RP118K231B B 1 RP118K231D E 1 RP118K241B B 2 RP118K241D E 2 RP118K251B B 3 RP118K251D E 3 RP118K261B B 4 RP118K261D E 4 RP118K271B B 5 RP118K271D E 5 RP118K281B B 6 RP118K281D E 6 RP118K291B B 7 RP118K291D E 7 RP118K301B B 8 RP118K301D E 8 RP118K311B B 9 RP118K311D E 9 RP118K321B C 0 RP118K321D F 0 RP118K331B C 1 RP118K331D F 1 RP118K341B C 2 RP118K341D F 2 RP118K351B C 3 RP118K351D F 3 RP118K361B C 4 RP118K361D F 4 RP118K181B5 C 5 RP118K181D5 F 5 RP118K121B5 C 6 RP118K121D5 F 6 ii POWER DISSIPATION SOT-23-5 PD-SOT-23-5-(85125)-JE-B The power dissipation of the package is dependent on PCB material, layout, and environmental conditions. The following measurement conditions are based on JEDEC STD. 51-7. Measurement Conditions Item Measurement Conditions Environment Mounting on Board (Wind Velocity = 0 m/s) Board Material Glass Cloth Epoxy Plastic (Four-Layer Board) Board Dimensions 76.2 mm × 114.3 mm × 0.8 mm Copper Ratio Outer Layer (First Layer): Less than 95% of 50 mm Square Inner Layers (Second and Third Layers): Approx. 100% of 50 mm Square Outer Layer (Fourth Layer): Approx. 100% of 50 mm Square Through-holes φ 0.3 mm × 7 pcs Measurement Result (Ta = 25°C, Tjmax = 125°C) Item Measurement Result Power Dissipation 660 mW Thermal Resistance (θja) θja = 150°C/W Thermal Characterization Parameter (ψjt) ψjt = 51°C/W θja: Junction-to-Ambient Thermal Resistance ψjt: Junction-to-Top Thermal Characterization Parameter Power Dissipation vs. Ambient Temperature Measurement Board Pattern i SOT-23-5 PACKAGE DIMENSIONS DM-SOT-23-5-JE-B 2.9±0.2 1.1±0.1 1.9±0.2 0.8±0.1 (0.95) 4 1 2 0~0.1 0.2min. +0.2 1.6-0.1 5 2.8±0.3 (0.95) 3 0.4±0.1 +0.1 0.15-0.05 SOT-23-5 Package Dimensions i PART MARKINGS RP118N MK-RP118N-JE-B : Product Code … Refer to Part Marking List : Lot Number … Alphanumeric Serial Number 5 4  1 2 3 RP118N (SOT-23-5) Part Markings NOTICE There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case of recognizing the marking characteristic with AOI, please contact our sales or distributor before attempting to use AOI. i PART MARKINGS RP118N MK-RP118N-JE-B RP118N Part Marking List Product Name RP118N121B RP118N131B RP118N141B RP118N151B RP118N161B RP118N171B RP118N181B RP118N181B5 RP118N191B RP118N201B RP118N211B RP118N221B RP118N231B RP118N241B RP118N251B RP118N261B RP118N271B RP118N281B RP118N291B RP118N301B RP118N311B RP118N321B RP118N331B RP118N341B RP118N351B RP118N361B RP118N121B5    E E E E E E E E E E E E E E E E E E E E E E E E E E E A A A A A A A A A A B B B B B B B B B B C C C C C C C 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 Product Name RP118N121D RP118N131D RP118N141D RP118N151D RP118N161D RP118N171D RP118N181D RP118N181D5 RP118N191D RP118N201D RP118N211D RP118N221D RP118N231D RP118N241D RP118N251D RP118N261D RP118N271D RP118N281D RP118N291D RP118N301D RP118N311D RP118N321D RP118N331D RP118N341D RP118N351D RP118N361D RP118N121D5    E E E E E E E E E E E E E E E E E E E E E E E E E E E D D D D D D D D D D F F F F F F F F F F G G G G G G G 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 ii 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. The products and the product specifications described in this document are subject to change or discontinuation of production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer to our sales representatives for the latest information thereon. The materials in this document may not be copied or otherwise reproduced in whole or in part without the prior written consent of us. This product and any technical information relating thereto are subject to complementary export controls (so-called KNOW controls) under the Foreign Exchange and Foreign Trade Law, and related politics ministerial ordinance of the law. (Note that the complementary export controls are inapplicable to any application-specific products, except rockets and pilotless aircraft, that are insusceptible to design or program changes.) Accordingly, when exporting or carrying abroad this product, follow the Foreign Exchange and Foreign Trade Control Law and its related regulations with respect to the complementary export controls. The technical information described in this document shows typical characteristics and example application circuits for the products. The release of such information is not to be construed as a warranty of or a grant of license under our or any third party's intellectual property rights or any other rights. The products listed in this document are intended and designed for use as general electronic components in standard applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products, amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and reliability, for example, in a highly specific application where the failure or misoperation of the product could result in human injury or death should first contact us. • Aerospace Equipment • Equipment Used in the Deep Sea • Power Generator Control Equipment (nuclear, steam, hydraulic, etc.) • Life Maintenance Medical Equipment • Fire Alarms / Intruder Detectors • Vehicle Control Equipment (automotive, airplane, railroad, ship, etc.) • Various Safety Devices • Traffic control system • Combustion equipment In case your company desires to use this product for any applications other than general electronic equipment mentioned above, make sure to contact our company in advance. Note that the important requirements mentioned in this section are not applicable to cases where operation requirements such as application conditions are confirmed by our company in writing after consultation with your company. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate use of the products. The products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this datasheet. Failure to employ the products in the proper applications can lead to deterioration, destruction or failure of the products. We shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of the products. Quality Warranty 8-1. Quality Warranty Period In the case of a product purchased through an authorized distributor or directly from us, the warranty period for this product shall be one (1) year after delivery to your company. For defective products that occurred during this period, we will take the quality warranty measures described in section 8-2. However, if there is an agreement on the warranty period in the basic transaction agreement, quality assurance agreement, delivery specifications, etc., it shall be followed. 8-2. Quality Warranty Remedies When it has been proved defective due to manufacturing factors as a result of defect analysis by us, we will either deliver a substitute for the defective product or refund the purchase price of the defective product. Note that such delivery or refund is sole and exclusive remedies to your company for the defective product. 8-3. Remedies after Quality Warranty Period With respect to any defect of this product found after the quality warranty period, the defect will be analyzed by us. On the basis of the defect analysis results, the scope and amounts of damage shall be determined by mutual agreement of both parties. Then we will deal with upper limit in Section 8-2. This provision is not intended to limit any legal rights of your company. Anti-radiation design is not implemented in the products described in this document. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and characteristics in the evaluation stage. WLCSP products should be used in light shielded environments. The light exposure can influence functions and characteristics of the products under operation or storage. Warning for handling Gallium and Arsenic (GaAs) products (Applying to GaAs MMIC, Photo Reflector). These products use Gallium (Ga) and Arsenic (As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed of, please follow the related regulation and do not mix this with general industrial waste or household waste. Please contact our sales representatives should you have any questions or comments concerning the products or the technical information. Official website https://www.nisshinbo-microdevices.co.jp/en/ Purchase information https://www.nisshinbo-microdevices.co.jp/en/buy/
RP118N231B-TR-FE 价格&库存
很抱歉,暂时无法提供与“RP118N231B-TR-FE”相匹配的价格&库存,您可以联系我们找货
RP118N231B-TR-FE
    • 1+1.86830
    • 200+0.72306
    • 500+0.69768
    • 1000+0.68505
    RP118N231B-TR-FE
    • 1+6.808991+0.88093
    • 10+4.8261610+0.62440
    • 25+4.3351025+0.56086
    • 100+3.79572100+0.49108
    • 250+3.53940250+0.45792
    • 500+3.38489500+0.43793
    • 1000+3.257601000+0.42146
    库存:2250
    RP118N231B-TR-FE
    • 3000+3.100393000+0.40112
    • 6000+3.023456000+0.39117
    • 9000+2.984929000+0.38618
    • 15000+2.9422015000+0.38066
    • 21000+2.9172521000+0.37743
    • 30000+2.8932730000+0.37432
    库存:2250
